moab::ReadCGM Member List
This is the complete list of members for moab::ReadCGM, including all inherited members.
category_tagmoab::ReadCGM [private]
create_curve_facets(std::map< RefEntity *, EntityHandle > &curve_map, std::map< RefEntity *, EntityHandle > &vertex_map, int norm_tol, double faceting_tol, bool verbose_warn=false, bool fatal_on_curves=false)moab::ReadCGM [private]
create_entity_sets(std::map< RefEntity *, EntityHandle >(&entmap)[5])moab::ReadCGM [private]
create_group_entsets(std::map< RefEntity *, EntityHandle > &group_map)moab::ReadCGM [private]
create_surface_facets(std::map< RefEntity *, EntityHandle > &surface_map, std::map< RefEntity *, EntityHandle > &vertex_map, int norm_tol, double facet_tol, double length_tol)moab::ReadCGM [private]
create_topology(std::map< RefEntity *, EntityHandle >(&entitymap)[5])moab::ReadCGM [private]
create_vertices(std::map< RefEntity *, EntityHandle > &vertex_map)moab::ReadCGM [private]
dump_fail_counts()moab::ReadCGM [private]
faceting_tol_tagmoab::ReadCGM [private]
factory(Interface *)moab::ReadCGM [static]
failed_curve_countmoab::ReadCGM [private]
failed_curvesmoab::ReadCGM [private]
failed_surface_countmoab::ReadCGM [private]
failed_surfacesmoab::ReadCGM [private]
geom_tagmoab::ReadCGM [private]
geometry_resabs_tagmoab::ReadCGM [private]
get_failed_curve_count()moab::ReadCGM
get_failed_surface_count()moab::ReadCGM
get_geom_file_type(const char *filename)moab::ReadCGM [private]
get_geom_fptr_type(FILE *file)moab::ReadCGM [private]
id_tagmoab::ReadCGM [private]
is_cubit_file(FILE *file)moab::ReadCGM [private]
is_facet_file(FILE *file)moab::ReadCGM [private]
is_iges_file(FILE *file)moab::ReadCGM [private]
is_occ_brep_file(FILE *file)moab::ReadCGM [private]
is_step_file(FILE *file)moab::ReadCGM [private]
load_file(const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0)moab::ReadCGM [virtual]
mdbImplmoab::ReadCGM [private]
myGeomToolmoab::ReadCGM [private]
name_tagmoab::ReadCGM [private]
read_tag_values(const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0)moab::ReadCGM [virtual]
ReadCGM(Interface *impl=NULL)moab::ReadCGM
readUtilIfacemoab::ReadCGM [private]
set_cgm_attributes(bool const act_attributes, bool const verbose)moab::ReadCGM [private]
set_options(const FileOptions &opts, int &norm_tol, double &faceting_tol, double &len_tol, bool &act_att, bool &verbose_warnings, bool &fatal_on_curves)moab::ReadCGM [private]
store_curve_senses(std::map< RefEntity *, EntityHandle > &curve_map, std::map< RefEntity *, EntityHandle > &surface_map)moab::ReadCGM [private]
store_group_content(std::map< RefEntity *, EntityHandle >(&entitymap)[5])moab::ReadCGM [private]
store_groups(std::map< RefEntity *, EntityHandle >(&entitymap)[5])moab::ReadCGM [private]
store_surface_senses(std::map< RefEntity *, EntityHandle > &surface_map, std::map< RefEntity *, EntityHandle > &volume_map)moab::ReadCGM [private]
tokenize(const std::string &str, std::vector< std::string > &tokens, const char *delimiters)moab::ReadCGM
~ReadCGM()moab::ReadCGM [virtual]
~ReaderIface()moab::ReaderIface [inline, virtual]
