moab::ReadMCNP5 Member List
This is the complete list of members for moab::ReadMCNP5, including all inherited members.
average_tally_values(const unsigned long int nps0, const unsigned long int nps1, double *values0, const double *values1, double *errors0, const double *errors1, const unsigned long int n_values)moab::ReadMCNP5 [private]
average_with_existing_tally(bool debug, unsigned long int &new_nps, unsigned long int nps, unsigned int tally_number, Tag tally_number_tag, Tag nps_tag, Tag tally_tag, Tag error_tag, double values[], double errors[], unsigned int n_elements)moab::ReadMCNP5 [private]
C2PImoab::ReadMCNP5 [private, static]
CARTESIAN enum valuemoab::ReadMCNP5 [private]
coordinate_system enum namemoab::ReadMCNP5 [private]
CPImoab::ReadMCNP5 [private, static]
create_elements(bool debug, std::vector< double > planes[3], unsigned int n_chopped_x0_planes, unsigned int n_chopped_x2_planes, EntityHandle start_vert, double values[], double errors[], Tag tally_tag, Tag error_tag, EntityHandle tally_meshset, coordinate_system tally_coord_sys)moab::ReadMCNP5 [private]
create_tags(Tag &date_and_time_tag, Tag &title_tag, Tag &nps_tag, Tag &tally_number_tag, Tag &tally_comment_tag, Tag &tally_particle_tag, Tag &tally_coord_sys_tag, Tag &tally_tag, Tag &error_tag)moab::ReadMCNP5 [private]
create_vertices(std::vector< double > planes[3], bool debug, EntityHandle &start_vert, coordinate_system coord_sys, EntityHandle tally_meshset)moab::ReadMCNP5 [private]
CYLINDRICAL enum valuemoab::ReadMCNP5 [private]
ELECTRON enum valuemoab::ReadMCNP5 [private]
elemIdmoab::ReadMCNP5 [private]
factory(Interface *)moab::ReadMCNP5 [static]
fileIDTagmoab::ReadMCNP5 [private]
get_mesh_plane(std::istringstream &ss, bool debug, std::vector< double > &plane)moab::ReadMCNP5 [private]
get_tally_particle(std::string a, bool debug, particle &tally_particle)moab::ReadMCNP5 [private]
load_file(const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0)moab::ReadMCNP5 [virtual]
load_one_file(const char *fname, const EntityHandle *input_meshset, const FileOptions &options, const bool average)moab::ReadMCNP5 [private]
MBImoab::ReadMCNP5 [private]
NEUTRON enum valuemoab::ReadMCNP5 [private]
NO_SYSTEM enum valuemoab::ReadMCNP5 [private]
nodeIdmoab::ReadMCNP5 [private]
particle enum namemoab::ReadMCNP5 [private]
PHOTON enum valuemoab::ReadMCNP5 [private]
read_element_values_and_errors(std::fstream &file, bool debug, std::vector< double > planes[3], unsigned int n_chopped_x0_planes, unsigned int n_chopped_x2_planes, particle tally_particle, double values[], double errors[])moab::ReadMCNP5 [private]
read_file_header(std::fstream &file, bool debug, char date_and_time[100], char title[100], unsigned long int &nps)moab::ReadMCNP5 [private]
read_mesh_planes(std::fstream &file, bool debug, std::vector< double > planes[3], coordinate_system &coord_sys)moab::ReadMCNP5 [private]
read_tag_values(const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0)moab::ReadMCNP5 [virtual]
read_tally_header(std::fstream &file, bool debug, unsigned int &tally_number, char tally_comment[100], particle &tally_particle)moab::ReadMCNP5 [private]
ReadMCNP5(Interface *impl=NULL)moab::ReadMCNP5
readMeshIfacemoab::ReadMCNP5 [private]
set_header_tags(EntityHandle output_meshset, char date_and_time[100], char title[100], unsigned long int nps, Tag data_and_time_tag, Tag title_tag, Tag nps_tag)moab::ReadMCNP5 [private]
set_tally_tags(EntityHandle tally_meshset, unsigned int tally_number, char tally_comment[100], particle tally_particle, coordinate_system tally_coord_sys, Tag tally_number_tag, Tag tally_comment_tag, Tag tally_particle_tag, Tag tally_coord_sys_tag)moab::ReadMCNP5 [private]
SPHERICAL enum valuemoab::ReadMCNP5 [private]
transform_point_to_cartesian(double *in, double *out, coordinate_system coord_sys)moab::ReadMCNP5 [private]
~ReaderIface()moab::ReaderIface [inline, virtual]
~ReadMCNP5()moab::ReadMCNP5 [virtual]
