moab::ReadNCDF Member List
This is the complete list of members for moab::ReadNCDF, including all inherited members.
blocksLoadingmoab::ReadNCDF [private]
CPU_WORD_SIZEmoab::ReadNCDF [private]
create_sideset_element(const std::vector< EntityHandle > &, EntityType, EntityHandle &, int &)moab::ReadNCDF [private]
create_ss_elements(int *element_ids, int *side_list, int num_sides, int num_dist_factors, std::vector< EntityHandle > &entities_to_add, std::vector< EntityHandle > &reverse_entities, std::vector< double > &dist_factor_vector, int ss_seq_id)moab::ReadNCDF [private]
dimension_exists(const char *attrib_name)moab::ReadNCDF [private]
exodus_file()moab::ReadNCDF [private]
exodusFilemoab::ReadNCDF [private]
faceBlocksLoadingmoab::ReadNCDF [private]
factory(Interface *)moab::ReadNCDF [static]
find_side_element_type(const int element_id, ExoIIElementType &type, ReadBlockData &block_data, int &df_index, int side_id)moab::ReadNCDF [private]
get_number_nodes(EntityHandle handle)moab::ReadNCDF [private]
get_type(char *exo_element_type, EntityType &elem_type)moab::ReadNCDF [private]
get_type(EntityType &elem_type, std::string &exo_element_type)moab::ReadNCDF [private]
initRangemoab::ReadNCDF [private]
IO_WORD_SIZEmoab::ReadNCDF [private]
load_file(const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0)moab::ReadNCDF [virtual]
max_line_lengthmoab::ReadNCDF [private]
max_str_lengthmoab::ReadNCDF [private]
mCurrentMeshHandlemoab::ReadNCDF [private]
mdbImplmoab::ReadNCDF [private]
mDirichletSetTagmoab::ReadNCDF [private]
mDistFactorTagmoab::ReadNCDF [private]
mGlobalIdTagmoab::ReadNCDF [private]
mHasMidNodesTagmoab::ReadNCDF [private]
mMaterialSetTagmoab::ReadNCDF [private]
mNeumannSetTagmoab::ReadNCDF [private]
mQaRecordTagmoab::ReadNCDF [private]
ncFilemoab::ReadNCDF [private]
nodesInLoadedBlocksmoab::ReadNCDF [private]
number_dimensions()moab::ReadNCDF [inline, private]
numberDimensions_loadingmoab::ReadNCDF [private]
numberElementBlocks_loadingmoab::ReadNCDF [private]
numberElements_loadingmoab::ReadNCDF [private]
numberFaceBlocks_loadingmoab::ReadNCDF [private]
numberNodes_loadingmoab::ReadNCDF [private]
numberNodeSets_loadingmoab::ReadNCDF [private]
numberSideSets_loadingmoab::ReadNCDF [private]
polyfacesmoab::ReadNCDF [private]
read_block_headers(const int *blocks_to_load, const int num_blocks)moab::ReadNCDF [private]
read_elements(const Tag *file_id_tag)moab::ReadNCDF [private]
read_exodus_header()moab::ReadNCDF [private]
read_face_blocks_headers()moab::ReadNCDF [private]
read_global_ids()moab::ReadNCDF [private]
read_nodes(const Tag *file_id_tag)moab::ReadNCDF [private]
read_nodesets()moab::ReadNCDF [private]
read_polyhedra_faces()moab::ReadNCDF [private]
read_qa_information(std::vector< std::string > &qa_record_list)moab::ReadNCDF [private]
read_qa_records(EntityHandle file_set)moab::ReadNCDF [private]
read_qa_string(char *string, int record_number, int record_position)moab::ReadNCDF [private]
read_sidesets()moab::ReadNCDF [private]
read_tag_values(const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0)moab::ReadNCDF [virtual]
readMeshIfacemoab::ReadNCDF [private]
ReadNCDF(Interface *impl=NULL)moab::ReadNCDF
reset()moab::ReadNCDF [private]
tokenize(const std::string &str, std::vector< std::string > &tokens, const char *delimiters)moab::ReadNCDF
update(const char *exodus_file_name, const FileOptions &opts, const int num_blocks, const int *blocks_to_load, const EntityHandle file_set)moab::ReadNCDF
vertexOffsetmoab::ReadNCDF [private]
~ReaderIface()moab::ReaderIface [inline, virtual]
~ReadNCDF()moab::ReadNCDF [virtual]
