moab::StructuredElementSeq Member List
This is the complete list of members for moab::StructuredElementSeq, including all inherited members.
append_entities(EntityID count)moab::EntitySequence [protected]
boundary_complete() const moab::StructuredElementSeq [inline]
contains(const int i, const int j, const int k) const moab::StructuredElementSeq [inline]
contains(const HomCoord &coords) const moab::StructuredElementSeq [inline]
create_data_subset(EntityHandle start_handle, EntityHandle end_handle) const moab::StructuredElementSeq [virtual]
moab::ElementSequence::create_data_subset(EntityHandle start_handle, EntityHandle end_handle, int num_sequence_arrays, unsigned const *bytes_per_element) const moab::EntitySequence [protected]
data() const moab::EntitySequence [inline]
data(SequenceData *ptr)moab::EntitySequence [inline]
ElementSequence(EntityHandle start, EntityID count, unsigned int nodes_per_elem, SequenceData *dat)moab::ElementSequence [inline]
ElementSequence(ElementSequence &split_from, EntityHandle here)moab::ElementSequence [inline, protected]
end_handle() const moab::EntitySequence [inline]
EntitySequence(EntityHandle h)moab::EntitySequence [inline, protected]
EntitySequence(EntitySequence &split_from, EntityHandle here)moab::EntitySequence [inline, protected]
EntitySequence(EntityHandle start, EntityID count, SequenceData *dat)moab::EntitySequence [inline]
get_connectivity(EntityHandle handle, std::vector< EntityHandle > &connect, bool topological=false) const moab::StructuredElementSeq [virtual]
get_connectivity(EntityHandle handle, EntityHandle const *&connect, int &connect_length, bool topological=false, std::vector< EntityHandle > *storage=0) const moab::StructuredElementSeq [virtual]
get_connectivity_array()moab::StructuredElementSeq [virtual]
moab::ElementSequence::get_connectivity_array() const moab::ElementSequence [inline]
get_const_memory_use(unsigned long &bytes_per_entity, unsigned long &size_of_sequence) const moab::StructuredElementSeq [virtual]
get_element(const int i, const int j, const int k) const moab::StructuredElementSeq [inline]
get_element(const HomCoord &coords) const moab::StructuredElementSeq [inline]
get_params(const EntityHandle ehandle, int &i, int &j, int &k) const moab::StructuredElementSeq [inline]
get_params_connectivity(const int i, const int j, const int k, std::vector< EntityHandle > &connectivity) const moab::StructuredElementSeq [inline]
get_per_entity_memory_use(EntityHandle first, EntityHandle last) const moab::EntitySequence [virtual]
get_vertex(const int i, const int j, const int k) const moab::StructuredElementSeq [inline]
get_vertex(const HomCoord &coords) const moab::StructuredElementSeq [inline]
has_mid_edge_nodes() const moab::ElementSequence [inline]
has_mid_face_nodes() const moab::ElementSequence [inline]
has_mid_volume_nodes() const moab::ElementSequence [inline]
i_max() const moab::StructuredElementSeq [inline]
i_min() const moab::StructuredElementSeq [inline]
is_periodic(int is_periodic_ij[2]) const moab::StructuredElementSeq [inline]
is_periodic_i() const moab::StructuredElementSeq [inline]
is_periodic_j() const moab::StructuredElementSeq [inline]
j_max() const moab::StructuredElementSeq [inline]
j_min() const moab::StructuredElementSeq [inline]
k_max() const moab::StructuredElementSeq [inline]
k_min() const moab::StructuredElementSeq [inline]
max_params() const moab::StructuredElementSeq [inline]
max_params(HomCoord &coords) const moab::StructuredElementSeq [inline]
max_params(int &i, int &j, int &k) const moab::StructuredElementSeq [inline]
merge(EntitySequence &other)moab::EntitySequence [virtual]
min_params() const moab::StructuredElementSeq [inline]
min_params(HomCoord &coords) const moab::StructuredElementSeq [inline]
min_params(int &i, int &j, int &k) const moab::StructuredElementSeq [inline]
nodes_per_element() const moab::ElementSequence [inline]
param_extents(int &di, int &dj, int &dk) const moab::StructuredElementSeq [inline]
pop_back(EntityID count)moab::EntitySequence [virtual]
pop_front(EntityID count)moab::EntitySequence [virtual]
prepend_entities(EntityID count)moab::EntitySequence [protected]
sdata()moab::StructuredElementSeq [inline]
sdata() const moab::StructuredElementSeq [inline]
set_connectivity(EntityHandle handle, EntityHandle const *connect, int connect_length)moab::StructuredElementSeq [virtual]
size() const moab::EntitySequence [inline]
split(EntityHandle here)moab::StructuredElementSeq [virtual]
start_handle() const moab::EntitySequence [inline]
StructuredElementSeq(EntityHandle start_handle, const int imin, const int jmin, const int kmin, const int imax, const int jmax, const int kmax, int *is_periodic=NULL)moab::StructuredElementSeq
StructuredElementSeq(StructuredElementSeq &split_from, EntityHandle here)moab::StructuredElementSeq [inline, protected]
type() const moab::EntitySequence [inline]
using_entire_data() const moab::EntitySequence
values_per_entity() const moab::StructuredElementSeq [virtual]
~ElementSequence()moab::ElementSequence [inline, virtual]
~EntitySequence()moab::EntitySequence [inline, virtual]
~StructuredElementSeq()moab::StructuredElementSeq [virtual]
