moab::Tqdcfr Member List
This is the complete list of members for moab::Tqdcfr, including all inherited members.
aBODY enum valuemoab::Tqdcfr
acisb enum valuemoab::Tqdcfr
acisDumpFilemoab::Tqdcfr [private]
acist enum valuemoab::Tqdcfr
aEDGE enum valuemoab::Tqdcfr
ATTRIB enum valuemoab::Tqdcfr
attribVectorTagmoab::Tqdcfr
aVERTEX enum valuemoab::Tqdcfr
BAR enum valuemoab::Tqdcfr [private]
BAR2 enum valuemoab::Tqdcfr [private]
BAR3 enum valuemoab::Tqdcfr [private]
BEAM enum valuemoab::Tqdcfr [private]
BEAM2 enum valuemoab::Tqdcfr [private]
BEAM3 enum valuemoab::Tqdcfr [private]
beforeEntsmoab::Tqdcfr
block_type_to_mb_typemoab::Tqdcfr [private, static]
blockTagmoab::Tqdcfr
BODY enum valuemoab::Tqdcfr [private]
categoryTagmoab::Tqdcfr
char_bufmoab::Tqdcfr
check_contiguous(const unsigned int num_ents, int &contig, unsigned int &min_id, unsigned int &max_id)moab::Tqdcfr
COEDGE enum valuemoab::Tqdcfr
convert_nodesets_sidesets()moab::Tqdcfr [private]
CONVERT_TO_INTS(unsigned int num_ents)moab::Tqdcfr
create_set(EntityHandle &h, unsigned int flags=MESHSET_SET)moab::Tqdcfr
cub_elem_num_vertsmoab::Tqdcfr [private, static]
cub_elem_num_verts_lenmoab::Tqdcfr [private, static]
cubFilemoab::Tqdcfr
cubIdTagmoab::Tqdcfr
cubMOABVertexMapmoab::Tqdcfr [private]
currElementIdOffsetmoab::Tqdcfr
currVHandleOffsetmoab::Tqdcfr
CURVE enum valuemoab::Tqdcfr [private]
dbl_bufmoab::Tqdcfr
EDGE enum valuemoab::Tqdcfr [private]
entityNameTagmoab::Tqdcfr
exodusmesh enum valuemoab::Tqdcfr
FACE enum valuemoab::Tqdcfr
facet enum valuemoab::Tqdcfr
factory(Interface *)moab::Tqdcfr [static]
fileTOCmoab::Tqdcfr
find_model(const unsigned int model_type)moab::Tqdcfr
FREADC(unsigned num_ents)moab::Tqdcfr
FREADCA(unsigned num_ents, char *arrat)moab::Tqdcfr
FREADD(unsigned num_ents)moab::Tqdcfr
FREADDA(unsigned num_ents, double *array)moab::Tqdcfr
FREADI(unsigned num_ents)moab::Tqdcfr
FREADIA(unsigned num_ents, unsigned int *array)moab::Tqdcfr
FSEEK(unsigned offset)moab::Tqdcfr
geom_categoriesmoab::Tqdcfr [private, static]
geomTagmoab::Tqdcfr
get_entities(const unsigned int *mem_types, int *id_buf, const unsigned int id_buf_size, const bool is_group, std::vector< EntityHandle > &entities)moab::Tqdcfr [private]
get_entities(const unsigned int this_type, int *id_buf, const unsigned int id_buf_size, std::vector< EntityHandle > &entities, std::vector< EntityHandle > &excl_entities)moab::Tqdcfr [private]
get_mesh_entities(const unsigned int this_type, int *id_buf, const unsigned id_buf_size, std::vector< EntityHandle > &entities, std::vector< EntityHandle > &excl_entities)moab::Tqdcfr [private]
get_names(MetaDataContainer &md, unsigned int set_index, EntityHandle seth)moab::Tqdcfr [private]
get_ref_entities(const unsigned int this_type, int *id_buf, const unsigned id_buf_size, std::vector< EntityHandle > &entities)moab::Tqdcfr [private]
gidSetMapmoab::Tqdcfr
globalIdTagmoab::Tqdcfr
GROUP enum valuemoab::Tqdcfr [private]
group_type_to_mb_typemoab::Tqdcfr [private, static]
hasMidNodesTagmoab::Tqdcfr
HEX enum valuemoab::Tqdcfr [private]
HEX20 enum valuemoab::Tqdcfr [private]
HEX27 enum valuemoab::Tqdcfr [private]
HEX8 enum valuemoab::Tqdcfr [private]
HEX9 enum valuemoab::Tqdcfr [private]
HEXeight enum valuemoab::Tqdcfr [private]
HEXSHELL enum valuemoab::Tqdcfr [private]
int_bufmoab::Tqdcfr
interpret_acis_records(std::vector< AcisRecord > &records)moab::Tqdcfr [private]
INVALID_ELEMENT_TYPE enum valuemoab::Tqdcfr [private]
load_file(const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0)moab::Tqdcfr [virtual]
LOOP enum valuemoab::Tqdcfr
LUMP enum valuemoab::Tqdcfr
mdbImplmoab::Tqdcfr
mFileSetmoab::Tqdcfr [private]
modelEntriesmoab::Tqdcfr
modelMetaDatamoab::Tqdcfr
mp_type_to_mb_typemoab::Tqdcfr [private, static]
NODE enum valuemoab::Tqdcfr [private]
nsTagmoab::Tqdcfr
parse_acis_attribs(const unsigned int entity_rec_num, std::vector< AcisRecord > &records)moab::Tqdcfr [private]
printedElemWarningmoab::Tqdcfr [private]
printedSeqWarningmoab::Tqdcfr [private]
process_record(AcisRecord &this_record)moab::Tqdcfr [private]
process_sideset_10(const int this_type, const int num_ents, const int sense_size, std::vector< EntityHandle > &ss_entities, Tqdcfr::SidesetHeader *sideseth)moab::Tqdcfr [private]
process_sideset_11(std::vector< EntityHandle > &ss_entities, int num_wrts, Tqdcfr::SidesetHeader *sideseth)moab::Tqdcfr [private]
put_into_set(EntityHandle set_handle, std::vector< EntityHandle > &entities, std::vector< EntityHandle > &excl_entities)moab::Tqdcfr [private]
PYRAMID enum valuemoab::Tqdcfr [private]
PYRAMID13 enum valuemoab::Tqdcfr [private]
PYRAMID18 enum valuemoab::Tqdcfr [private]
PYRAMID5 enum valuemoab::Tqdcfr [private]
PYRAMID8 enum valuemoab::Tqdcfr [private]
PYRAMIDfive enum valuemoab::Tqdcfr [private]
QUAD enum valuemoab::Tqdcfr [private]
QUAD4 enum valuemoab::Tqdcfr [private]
QUAD5 enum valuemoab::Tqdcfr [private]
QUAD8 enum valuemoab::Tqdcfr [private]
QUAD9 enum valuemoab::Tqdcfr [private]
QUADfour enum valuemoab::Tqdcfr [private]
read_acis_records(const char *sat_file_name=0)moab::Tqdcfr [private]
read_block(const unsigned int blindex, const double data_version, ModelEntry *model, BlockHeader *blockh)moab::Tqdcfr
read_elements(ModelEntry *model, GeomHeader *entity)moab::Tqdcfr
read_file_header()moab::Tqdcfr
read_group(const unsigned int gr_index, ModelEntry *model, GroupHeader *grouph)moab::Tqdcfr
read_md_string(std::string &name)moab::Tqdcfr
read_meta_data(const unsigned int metadata_offset, MetaDataContainer &mc)moab::Tqdcfr
read_model_entries()moab::Tqdcfr
read_nodes(const unsigned int gindex, ModelEntry *model, GeomHeader *entity)moab::Tqdcfr
read_nodeset(const unsigned int nsindex, ModelEntry *model, NodesetHeader *nodeseth)moab::Tqdcfr
read_sideset(const unsigned int ssindex, const double data_version, ModelEntry *model, SidesetHeader *sideseth)moab::Tqdcfr
read_tag_values(const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0)moab::Tqdcfr [virtual]
readUtilIfacemoab::Tqdcfr
reset_record(AcisRecord &this_record)moab::Tqdcfr [private]
SHEL enum valuemoab::Tqdcfr [private]
SHELL4 enum valuemoab::Tqdcfr [private]
SHELL8 enum valuemoab::Tqdcfr [private]
SHELL9 enum valuemoab::Tqdcfr [private]
SPHERE_EXO enum valuemoab::Tqdcfr [private]
SPRING enum valuemoab::Tqdcfr [private]
ssTagmoab::Tqdcfr
SURFACE enum valuemoab::Tqdcfr [private]
swapForEndiannessmoab::Tqdcfr
TET enum valuemoab::Tqdcfr [private]
TETRA10 enum valuemoab::Tqdcfr [private]
TETRA14 enum valuemoab::Tqdcfr [private]
TETRA4 enum valuemoab::Tqdcfr [private]
TETRA8 enum valuemoab::Tqdcfr [private]
TETRAfour enum valuemoab::Tqdcfr [private]
Tqdcfr(Interface *impl)moab::Tqdcfr
TRI enum valuemoab::Tqdcfr [private]
TRI3 enum valuemoab::Tqdcfr [private]
TRI6 enum valuemoab::Tqdcfr [private]
TRI7 enum valuemoab::Tqdcfr [private]
TRISHELL enum valuemoab::Tqdcfr [private]
TRISHELL3 enum valuemoab::Tqdcfr [private]
TRISHELL6 enum valuemoab::Tqdcfr [private]
TRISHELL7 enum valuemoab::Tqdcfr [private]
TRIthree enum valuemoab::Tqdcfr [private]
TRUSS enum valuemoab::Tqdcfr [private]
TRUSS2 enum valuemoab::Tqdcfr [private]
TRUSS3 enum valuemoab::Tqdcfr [private]
type_from_cub_type(const unsigned int cub_type, const unsigned int nodes_per_elem)moab::Tqdcfr
uidSetMapmoab::Tqdcfr
uint_bufmoab::Tqdcfr
uniqueIdTagmoab::Tqdcfr
UNKNOWN enum valuemoab::Tqdcfr
VERTEX enum valuemoab::Tqdcfr [private]
VOLUME enum valuemoab::Tqdcfr [private]
~ReaderIface()moab::ReaderIface [inline, virtual]
~Tqdcfr()moab::Tqdcfr
