moab::TypeSequenceManager::DummySequence Class Reference
Dummy EntitySequence for use in querying set container. More...
#include <TypeSequenceManager.hpp>
+ Inheritance diagram for moab::TypeSequenceManager::DummySequence:
+ Collaboration diagram for moab::TypeSequenceManager::DummySequence:
Public Member Functions
 DummySequence (EntityHandle start)
EntitySequencesplit (EntityHandle)
 Split this sequence into two consecutive sequences.
SequenceDatacreate_data_subset (EntityHandle, EntityHandle) const
 Create a new SequenceData that is a copy of a subset of the one referenced by this sequence.
void get_const_memory_use (unsigned long &a, unsigned long &b) const
 Get memory characteristcs that are the same for all entities.
unsigned long get_per_entity_memory_use (EntityHandle, EntityHandle) const
 Get portion of memory use that varies per entity.
Detailed Description
Definition at line 40 of file TypeSequenceManager.hpp.
Member Function Documentation
SequenceData* moab::TypeSequenceManager::DummySequence::create_data_subset ( EntityHandle  start_handle,
EntityHandle  end_handle
) const [inline, virtual]
Create a new SequenceData that is a copy of a subset of the SequenceData referenced by this EntitySequence. Do not make any changes to this EntitySequence or the current SequenceData.
Implements moab::EntitySequence.
Definition at line 49 of file TypeSequenceManager.hpp.
            return 0;
void moab::TypeSequenceManager::DummySequence::get_const_memory_use ( unsigned long &  bytes_per_entity,
unsigned long &  size_of_sequence
Get charactersitic constant memory use for all entities in sequence.
Parameters:
bytes_per_entityThe total bytes consumed for each entity in the underlying SequenceData. It is assumed that the same amount of memory is consumed for unused portions of the SequenceData.
size_of_sequenceThe size of the leaf subclass of this class
Definition at line 54 of file TypeSequenceManager.hpp.
            a = b = 0;
unsigned long moab::TypeSequenceManager::DummySequence::get_per_entity_memory_use ( EntityHandle  first,
EntityHandle  last
Returns:
Any per-entity memory use not accounted for in the results of get_const_memory_use.
Reimplemented from moab::EntitySequence.
Definition at line 58 of file TypeSequenceManager.hpp.
            return 0;
Split this sequence into two sequences.
Parameters:
hereNew sequences should be [start_handle(),here) & [here,end_handle()]
Returns:
New sequence containing [here,end_handle()]
Definition at line 45 of file TypeSequenceManager.hpp.
            return 0;
List of all members.
