smoab::detail::LoadGeometry Class Reference
#include <LoadGeometry.h>
+ Collaboration diagram for smoab::detail::LoadGeometry:
Public Member Functions
 LoadGeometry (const smoab::Range &cells, int topologyDim, const smoab::Interface &interface)
const smoab::RangemoabPoints () const
template<typename vtkDataSetType >
void fill (vtkDataSetType *dataSet)
Private Member Functions
void addCoordinates (vtkPointSet *grid)
void addGridsTopology (vtkDataSetType *grid, vtkIdType numCells, vtkIdType numConnectivity) const
Private Attributes
moab::InterfaceInterface
int TopologyDim
smoab::detail::MixedCellConnectivity MixConn
smoab::Range Points
Detailed Description
Definition at line 73 of file LoadGeometry.h.
smoab::detail::LoadGeometry::LoadGeometry ( const smoab::Range cells,
int  topologyDim,
const smoab::Interface interface
) [inline]
Definition at line 83 of file LoadGeometry.h.
            : Interface( interface.Moab ), TopologyDim( topologyDim ), MixConn( cells, interface.Moab ), Points()
Member Function Documentation
void smoab::detail::LoadGeometry::addCoordinates ( vtkPointSet *  grid) [inline, private]
Definition at line 109 of file LoadGeometry.h.
References MixConn, smoab::detail::MixedCellConnectivity::moabPoints(), Points, and moab::Range::size().
Referenced by fill().
            //this is sorta of hackish as moabPoints is only valid
            //after compactIds has been called
            this->MixConn.moabPoints( this->Points );
            //since the smoab::range are always unique and sorted
            //we can use the more efficient coords_iterate
            //call in moab, which returns moab internal allocated memory
            vtkNew< vtkPoints > newPoints;
            newPoints->SetDataTypeToDouble();
            newPoints->SetNumberOfPoints( this->Points.size() );
            //need a pointer to the allocated vtkPoints memory so that we
            //don't need to use an extra copy and we can bypass all vtk's check
            //on out of bounds
            double* rawPoints = static_cast< double* >( newPoints->GetVoidPointer( 0 ) );
            this->Interface->get_coords( this->Points, rawPoints );
            grid->SetPoints( newPoints.GetPointer() );
void smoab::detail::LoadGeometry::addGridsTopology ( vtkDataSetType *  grid,
vtkIdType  numCells,
) const [inline, private]
Definition at line 133 of file LoadGeometry.h.
References smoab::detail::MixedCellConnectivity::copyToVtkCellInfo(), MixConn, and TopologyDim.
            //correct the connectivity size to account for the vtk padding
            const vtkIdType vtkConnectivity = numCells + numConnectivity;
            vtkNew< vtkIdTypeArray > cellArray;
            vtkNew< vtkIdTypeArray > cellLocations;
            vtkNew< vtkUnsignedCharArray > cellTypes;
            cellArray->SetNumberOfValues( vtkConnectivity );
            cellLocations->SetNumberOfValues( numCells );
            cellTypes->SetNumberOfValues( numCells );
            vtkIdType* rawArray     = static_cast< vtkIdType* >( cellArray->GetVoidPointer( 0 ) );
            vtkIdType* rawLocations = static_cast< vtkIdType* >( cellLocations->GetVoidPointer( 0 ) );
            unsigned char* rawTypes = static_cast< unsigned char* >( cellTypes->GetVoidPointer( 0 ) );
            this->MixConn.copyToVtkCellInfo( rawArray, rawLocations, rawTypes );
            vtkNew< vtkCellArray > cells;
            cells->SetCells( numCells, cellArray.GetPointer() );
            setCells< vtkDataSetType >()( grid, this->TopologyDim, cellTypes.GetPointer(), cellLocations.GetPointer(),
                                          cells.GetPointer() );
void smoab::detail::LoadGeometry::fill ( vtkDataSetType *  dataSet) [inline]
Definition at line 96 of file LoadGeometry.h.
References addCoordinates(), addGridsTopology(), smoab::detail::MixedCellConnectivity::compactIds(), and MixConn.
Referenced by smoab::DataSetConverter::fill().
            //now that mixConn has all the cells properly stored, lets fixup
            //the ids so that they start at zero and keep the same logical ordering
            //as before.
            vtkIdType numCells, connLen;
            this->MixConn.compactIds( numCells, connLen );
            this->addGridsTopology( dataSet, numCells, connLen );
            this->addCoordinates( dataSet );
Definition at line 88 of file LoadGeometry.h.
References Points.
            return this->Points;
Member Data Documentation
Definition at line 78 of file LoadGeometry.h.
Referenced by addCoordinates(), and moabPoints().
Definition at line 76 of file LoadGeometry.h.
Referenced by addGridsTopology().
List of all members.
