compareMaps.cpp File Reference
#include "moab/MOABConfig.h"
#include "moab/ProgOptions.hpp"
#include "netcdf.h"
#include <cmath>
#include <iomanip>
#include <Eigen/Sparse>
+ Include dependency graph for compareMaps.cpp:
Defines
#define ERR_NC(e)
#define INS_ID(stringvar, prefix, id)   sprintf( stringvar, prefix, id )
#define GET_DIM1(ncdim, name, val)
#define GET_DIMB1(ncdim, name, varname, id, val)
#define GET_VAR1(name, id, dims)
#define GET_1D_INT_VAR1(name, id, vals)
#define GET_1D_DBL_VAR1(name, id, vals)
#define GET_DIM2(ncdim, name, val)
#define GET_DIMB2(ncdim, name, varname, id, val)
#define GET_VAR2(name, id, dims)
#define GET_1D_INT_VAR2(name, id, vals)
#define GET_1D_DBL_VAR2(name, id, vals)
#define GET_2D_DBL_VAR1(name, id, vals)
#define GET_2D_DBL_VAR2(name, id, vals)
Typedefs
typedef Eigen::Map
< Eigen::VectorXd >
EigenV
Functions
void diff_vect (const char *var_name, int n)
void diff_2d_vect (const char *var_name, int n)
int main (int argc, char *argv[])
Variables
int ncFile1
int ncFile2
Define Documentation
#define ERR_NC (   e)
Value:
        printf( "Error: %s\n", nc_strerror( e ) ); \
        exit( 2 );                                 \
Definition at line 27 of file compareMaps.cpp.
Referenced by main().
#define GET_1D_DBL_VAR1 (   name,
  id,
  vals
Value:
        std::vector< int > dum_dims;                                                       \
        GET_VAR1( name, id, dum_dims );                                                    \
        if( -1 != ( id ) )        \
            size_t ntmp;        \
            int dvfail = nc_inq_dimlen( ncFile1, dum_dims[0], &ntmp );                     \
            if( NC_NOERR != dvfail )                                                       \
                ERR_NC( dvfail )                                                           \
            ( vals ).resize( ntmp );                                                       \
            size_t ntmp1 = 0;                                                              \
            dvfail       = nc_get_vara_double( ncFile1, id, &ntmp1, &ntmp, &( vals )[0] ); \
                ERR_NC( dvfail )                                                           \
Definition at line 103 of file compareMaps.cpp.
Referenced by diff_vect(), and main().
#define GET_1D_DBL_VAR2 (   name,
  id,
  vals
Value:
        GET_VAR2( name, id, dum_dims );                                                    \
            size_t ntmp;        \
            int dvfail = nc_inq_dimlen( ncFile2, dum_dims[0], &ntmp );                     \
                ERR_NC( dvfail )                                                           \
            size_t ntmp1 = 0;                                                              \
            dvfail       = nc_get_vara_double( ncFile2, id, &ntmp1, &ntmp, &( vals )[0] ); \
                ERR_NC( dvfail )                                                           \
Definition at line 190 of file compareMaps.cpp.
#define GET_1D_INT_VAR1 (   name,
  id,
  vals
Value:
        GET_VAR1( name, id, vals );                                                     \
            size_t ntmp;        \
            int ivfail = nc_inq_dimlen( ncFile1, ( vals )[0], &ntmp );                  \
            if( NC_NOERR != ivfail )                                                    \
                ERR_NC( ivfail )                                                        \
            size_t ntmp1 = 0;                                                           \
            ivfail       = nc_get_vara_int( ncFile1, id, &ntmp1, &ntmp, &( vals )[0] ); \
                ERR_NC( ivfail )                                                        \
Definition at line 82 of file compareMaps.cpp.
#define GET_1D_INT_VAR2 (   name,
  id,
  vals
Value:
        GET_VAR2( name, id, vals );                                                     \
            size_t ntmp;        \
            int ivfail = nc_inq_dimlen( ncFile2, ( vals )[0], &ntmp );                  \
                ERR_NC( ivfail )                                                        \
            size_t ntmp1 = 0;                                                           \
            ivfail       = nc_get_vara_int( ncFile2, id, &ntmp1, &ntmp, &( vals )[0] ); \
                ERR_NC( ivfail )                                                        \
Definition at line 169 of file compareMaps.cpp.
#define GET_2D_DBL_VAR1 (   name,
  id,
  vals
Value:
            size_t ntmp[2];        \
            int dvfail = nc_inq_dimlen( ncFile1, dum_dims[0], &ntmp[0] );                   \
                ERR_NC( dvfail )                                                            \
            dvfail = nc_inq_dimlen( ncFile1, dum_dims[1], &ntmp[1] );                       \
                ERR_NC( dvfail )                                                            \
            ( vals ).resize( ntmp[0] * ntmp[1] );                                           \
            size_t ntmp1[2] = { 0, 0 };                                                     \
            dvfail          = nc_get_vara_double( ncFile1, id, ntmp1, ntmp, &( vals )[0] ); \
                ERR_NC( dvfail )                                                            \
Definition at line 212 of file compareMaps.cpp.
Referenced by diff_2d_vect().
#define GET_2D_DBL_VAR2 (   name,
  id,
  vals
Value:
            size_t ntmp[2];        \
            int dvfail = nc_inq_dimlen( ncFile2, dum_dims[0], &ntmp[0] );                   \
                ERR_NC( dvfail )                                                            \
            dvfail = nc_inq_dimlen( ncFile2, dum_dims[1], &ntmp[1] );                       \
                ERR_NC( dvfail )                                                            \
            dvfail          = nc_get_vara_double( ncFile2, id, ntmp1, ntmp, &( vals )[0] ); \
                ERR_NC( dvfail )                                                            \
Definition at line 239 of file compareMaps.cpp.
#define GET_DIM1 (   ncdim,
  name,
  val
Value:
        int gdfail = nc_inq_dimid( ncFile1, name, &( ncdim ) ); \
        if( NC_NOERR == gdfail )                                \
            size_t tmp_val;                                     \
            gdfail = nc_inq_dimlen( ncFile1, ncdim, &tmp_val ); \
            if( NC_NOERR != gdfail )                            \
                ERR_NC( gdfail )                                \
            else                                                \
                ( val ) = tmp_val;                              \
        else                                                    \
            ( val ) = 0;                                        \
Definition at line 40 of file compareMaps.cpp.
#define GET_DIM2 (   ncdim,
  name,
  val
Value:
        int gdfail = nc_inq_dimid( ncFile2, name, &( ncdim ) ); \
            size_t tmp_val;                                     \
            gdfail = nc_inq_dimlen( ncFile2, ncdim, &tmp_val ); \
                ERR_NC( gdfail )                                \
            else                                                \
        else                                                    \
            ( val ) = 0;                                        \
Definition at line 127 of file compareMaps.cpp.
#define GET_DIMB1 (   ncdim,
  name,
  varname,
  id,
  val
Value:
INS_ID( name, varname, id );                   \
    GET_DIM1( ncdim, name, val );
Definition at line 58 of file compareMaps.cpp.
#define GET_DIMB2 (   ncdim,
  name,
  varname,
  id,
  val
Value:
    GET_DIM2( ncdim, name, val );
Definition at line 145 of file compareMaps.cpp.
#define GET_VAR1 (   name,
  id,
  dims
Value:
        ( id )     = -1;                                               \
        int gvfail = nc_inq_varid( ncFile1, name, &( id ) );           \
        if( NC_NOERR == gvfail )                                       \
            int ndims;                                                 \
            gvfail = nc_inq_varndims( ncFile1, id, &ndims );           \
                ( dims ).resize( ndims );                              \
                gvfail = nc_inq_vardimid( ncFile1, id, &( dims )[0] ); \
                if( NC_NOERR != gvfail )                               \
                    ERR_NC( gvfail )                                   \
Definition at line 62 of file compareMaps.cpp.
#define GET_VAR2 (   name,
  id,
  dims
Value:
        ( id )     = -1;                                               \
        int gvfail = nc_inq_varid( ncFile2, name, &( id ) );           \
            int ndims;                                                 \
            gvfail = nc_inq_varndims( ncFile2, id, &ndims );           \
                gvfail = nc_inq_vardimid( ncFile2, id, &( dims )[0] ); \
                    ERR_NC( gvfail )                                   \
Definition at line 149 of file compareMaps.cpp.
#define INS_ID (   stringvar,
  prefix,
  id
Definition at line 38 of file compareMaps.cpp.
Typedef Documentation
typedef Eigen::Map< Eigen::VectorXd > EigenV
Definition at line 266 of file compareMaps.cpp.
Function Documentation
void diff_2d_vect ( const char *  var_name,
int  n
Definition at line 289 of file compareMaps.cpp.
References GET_2D_DBL_VAR1, and GET_2D_DBL_VAR2.
    // compare frac_a between maps
    std::vector< double > fraca1( n ), fraca2( n );
    int idfa1, idfa2;
    GET_2D_DBL_VAR1( var_name, idfa1, fraca1 );
    EigenV fa1( fraca1.data(), n );
    GET_2D_DBL_VAR2( var_name, idfa2, fraca2 );
    EigenV fa2( fraca2.data(), n );
    std::cout << var_name << " diff norm: " << ( fa1 - fa2 ).norm() << "\n";
    return;
void diff_vect ( const char *  var_name,
int  n
Definition at line 268 of file compareMaps.cpp.
References GET_1D_DBL_VAR1, and GET_1D_DBL_VAR2.
    int idfa1, idfa2;
    GET_1D_DBL_VAR1( var_name, idfa1, fraca1 );
    GET_1D_DBL_VAR2( var_name, idfa2, fraca2 );
    EigenV diff( fraca2.data(), n );
    diff = fa1 - fa2;
    int imin, imax;
    double minV = diff.minCoeff( &imin );
    double maxV = diff.maxCoeff( &imax );
    std::cout << var_name << " diff norm: " << diff.norm() << " min at " << imin << " : " << minV << " max at " << imax
              << " : " << maxV << "\n";
    return;
int main ( int  argc,
char *  argv[]
Definition at line 301 of file compareMaps.cpp.
References ProgOptions::addOpt(), diff_2d_vect(), diff_vect(), ERR_NC, fail(), GET_1D_DBL_VAR1, GET_1D_DBL_VAR2, GET_1D_INT_VAR1, GET_1D_INT_VAR2, GET_DIM1, GET_DIM2, ncFile1, ncFile2, and ProgOptions::parseCommandLine().
    ProgOptions opts;
    std::string inputfile1, inputfile2;
    opts.addOpt< std::string >( "firstMap,i", "input filename 1", &inputfile1 );
    opts.addOpt< std::string >( "secondMap,j", "input second map", &inputfile2 );
    int print_diff = 20;
    opts.addOpt< int >( "print_differences,p", "print differences ", &print_diff );
    double fraction = 0.9;
    opts.addOpt< double >( "fraction_diff,f", "fraction threshold", &fraction );
    opts.parseCommandLine( argc, argv );
    // Open netcdf/exodus file
    int fail = nc_open( inputfile1.c_str(), 0, &ncFile1 );
    if( NC_NOWRITE != fail )
        ERR_NC( fail )
    std::cout << " opened " << inputfile1 << " for map 1 \n";
    fail = nc_open( inputfile2.c_str(), 0, &ncFile2 );
        ERR_NC( fail )
    std::cout << " opened " << inputfile2 << " for map 2 \n";
    int temp_dim;
    int na1, nb1, ns1, na2, nb2, ns2, nv_a, nv_b, nv_a2, nv_b2;
    GET_DIM1( temp_dim, "n_a", na1 );
    GET_DIM2( temp_dim, "n_a", na2 );
    GET_DIM1( temp_dim, "n_b", nb1 );
    GET_DIM2( temp_dim, "n_b", nb2 );
    GET_DIM1( temp_dim, "n_s", ns1 );
    GET_DIM2( temp_dim, "n_s", ns2 );
    GET_DIM1( temp_dim, "nv_a", nv_a );
    GET_DIM2( temp_dim, "nv_a", nv_a2 );
    GET_DIM1( temp_dim, "nv_b", nv_b );
    GET_DIM2( temp_dim, "nv_b", nv_b2 );
    if( nv_a != nv_a2 || nv_b != nv_b2 )
        std::cout << " different nv dimensions:" << nv_a << " == " << nv_a2 << "  or " << nv_b << " == " << nv_b2
                  << "  bail out \n";
        return 1;
    std::cout << " n_a, n_b, n_s : " << na1 << ", " << nb1 << ", " << ns1 << " for map 1 \n";
    std::cout << " n_a, n_b, n_s : " << na2 << ", " << nb2 << ", " << ns2 << " for map 2 \n";
    if( na1 != na2 || nb1 != nb2 )
        std::cout << " different dimensions bail out \n";
        return 1;
    std::vector< int > col1( ns1 ), row1( ns1 );
    std::vector< int > col2( ns2 ), row2( ns2 );
    std::vector< double > val1( ns1 ), val2( ns2 );
    int idrow1, idcol1, idrow2, idcol2, ids1, ids2;
    GET_1D_INT_VAR1( "row", idrow1, row1 );
    GET_1D_INT_VAR1( "col", idcol1, col1 );
    GET_1D_DBL_VAR1( "S", ids1, val1 );
    GET_1D_INT_VAR2( "row", idrow2, row2 );
    GET_1D_INT_VAR2( "col", idcol2, col2 );
    GET_1D_DBL_VAR2( "S", ids2, val2 );
    // first matrix
    typedef Eigen::Triplet< double > Triplet;
    std::vector< Triplet > tripletList;
    tripletList.reserve( ns1 );
    for( int iv = 0; iv < ns1; iv++ )
        tripletList.push_back( Triplet( row1[iv] - 1, col1[iv] - 1, val1[iv] ) );
    Eigen::SparseMatrix< double > weight1( nb1, na1 );
    weight1.setFromTriplets( tripletList.begin(), tripletList.end() );
    weight1.makeCompressed();
    if( ns1 != ns2 ) tripletList.resize( ns2 );
    for( int iv = 0; iv < ns2; iv++ )
        tripletList[iv] = Triplet( row2[iv] - 1, col2[iv] - 1, val2[iv] );
    Eigen::SparseMatrix< double > weight2( nb2, na2 );
    weight2.setFromTriplets( tripletList.begin(), tripletList.end() );
    weight2.makeCompressed();
    // default storage type is column major
    Eigen::SparseMatrix< double > diff = weight1 - weight2;
    diff.makeCompressed();  // is it needed or not ?
    auto coeffs = diff.coeffs();
    double maxv = coeffs.maxCoeff();
    double minv = coeffs.minCoeff();
    std::cout << " euclidian norm for difference: " << diff.norm()
              << " \n squared norm for difference: " << diff.squaredNorm() << "\n"
              << " minv: " << minv << " maxv: " << maxv << "\n";
    // print out the first 10 positions for which the value is outside 90% of min/max values
    double min_threshold = fraction * minv;
    double max_threshold = fraction * maxv;
    int counter          = 0;
    std::cout << std::setprecision( 9 );
    for( int k = 0; ( k < diff.outerSize() ); ++k )  // this is by column
        for( Eigen::SparseMatrix< double >::InnerIterator it( diff, k ); ( it ) && ( counter < print_diff ); ++it )
            double val = it.value();
            if( val <= min_threshold || val >= max_threshold )
                int row = it.row();
                int col = it.col();
                std::cout << " counter:" << counter << "\t col: " << col + 1 << "\t row: " << row + 1
                          << "\t diff: " << val;
                std::cout << "\t map1: " << weight1.coeffRef( row, col ) << "\t map2: " << weight2.coeffRef( row, col )
                          << "\n";  // row index
                counter++;
    diff_vect( "frac_a", na1 );
    diff_vect( "frac_b", nb1 );
    diff_vect( "area_a", na1 );
    diff_vect( "area_b", nb1 );
    diff_vect( "yc_a", na1 );
    diff_vect( "yc_b", nb1 );
    diff_vect( "xc_a", na1 );
    diff_vect( "xc_b", nb1 );
    diff_2d_vect( "xv_a", na1 * nv_a );
    diff_2d_vect( "yv_a", na1 * nv_a );
    diff_2d_vect( "xv_b", nb1 * nv_b );
    diff_2d_vect( "yv_b", nb1 * nv_b );
    return 0;
Variable Documentation
int ncFile1
Definition at line 36 of file compareMaps.cpp.
int ncFile2
Definition at line 125 of file compareMaps.cpp.
