DirectAccessNoHoles.cpp
Use direct access to MOAB data to avoid calling through API
This example creates a 1d row of quad elements, such that all quad and vertex handles are contiguous in the handle space and in the database. Then it shows how to get access to pointers to MOAB-native data for vertex coordinates, quad connectivity, tag storage, and vertex to quad adjacency lists. This allows applications to access this data directly without going through MOAB's API. In cases where the mesh is not changing (or only mesh vertices are moving), this can save significant execution time in applications.
  1. Initialize MOAB
  2. Create a quad mesh, as depicted above
  3. Create 2 dense tags (tag1, tag2) for avg position to assign to quads, and # verts per quad (tag3)
  4. Get connectivity, coordinate, tag1 iterators
  5. Iterate through quads, computing midpoint based on vertex positions, set on quad-based tag1
  6. Iterate through vertices, summing positions into tag2 on connected quads and incrementing vertex count
  7. Iterate through quads, normalizing tag2 by vertex count and comparing values of tag1 and tag2
To compile:
make DirectAccessNoHoles MOAB_DIR=<installdir>
To run: ./DirectAccessNoHoles [-nquads <# quads>]
/** @example DirectAccessNoHoles.cpp \n
 * \brief Use direct access to MOAB data to avoid calling through API \n
 * This example creates a 1d row of quad elements, such that all quad and vertex handles
 * are contiguous in the handle space and in the database.  Then it shows how to get access
 * to pointers to MOAB-native data for vertex coordinates, quad connectivity, tag storage,
 * and vertex to quad adjacency lists.  This allows applications to access this data directly
 * without going through MOAB's API.  In cases where the mesh is not changing (or only mesh
 * vertices are moving), this can save significant execution time in applications.
 * \verbatim
 * \endverbatim
 *    -#  Initialize MOAB \n
 *    -#  Create a quad mesh, as depicted above
 *    -#  Create 2 dense tags (tag1, tag2) for avg position to assign to quads, and # verts per quad
 * (tag3)
 *    -#  Get connectivity, coordinate, tag1 iterators
 *    -#  Iterate through quads, computing midpoint based on vertex positions, set on quad-based
 * tag1
 *    -#  Iterate through vertices, summing positions into tag2 on connected quads and incrementing
 * vertex count
 *    -#  Iterate through quads, normalizing tag2 by vertex count and comparing values of tag1 and
 * tag2
 * <b>To compile</b>: \n
 *    make DirectAccessNoHoles MOAB_DIR=<installdir> \n
 * <b>To run</b>: ./DirectAccessNoHoles [-nquads <# quads>]\n
#include "moab/Core.hpp"
#include "moab/ProgOptions.hpp"
#include "moab/ReadUtilIface.hpp"
#include <map>
#include <iostream>
#include <cassert>
using namespace moab;
using namespace std;
ErrorCode create_mesh_no_holes( Interface* mbImpl, int nquads );
int main( int argc, char** argv )
    // Get MOAB instance
    Interface* mbImpl = new( std::nothrow ) Core;
    if( NULL == mbImpl ) return 1;
    int nquads = 1000;
    // Parse options
    ProgOptions opts;
    opts.addOpt< int >( string( "nquads,n" ), string( "Number of quads in the mesh (default = 1000" ), &nquads );
    opts.parseCommandLine( argc, argv );
    // Create simple structured mesh with hole, but using unstructured representation
    ErrorCode rval = create_mesh_no_holes( mbImpl, nquads );MB_CHK_SET_ERR( rval, "Trouble creating mesh" );
    // Get all vertices and non-vertex entities
    Range verts, quads;
    rval = mbImpl->get_entities_by_handle( 0, quads );MB_CHK_SET_ERR( rval, "Trouble getting all entities" );
    verts = quads.subset_by_dimension( 0 );
    quads -= verts;
    // Create tag1 (element-based avg), tag2 (vertex-based avg), tag3 (# connected verts)
    Tag tag1, tag2, tag3;
    rval = mbImpl->tag_get_handle( "tag1", 3, MB_TYPE_DOUBLE, tag1, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating tag1" );
    double def_val[3] = { 0.0, 0.0, 0.0 };  // need a default value for tag2 because we sum into it
    rval              = mbImpl->tag_get_handle( "tag2", 3, MB_TYPE_DOUBLE, tag2, MB_TAG_DENSE | MB_TAG_CREAT, def_val );MB_CHK_SET_ERR( rval, "Trouble creating tag2" );
    int def_val_int = 0;  // need a default value for tag3 because we increment it
    rval = mbImpl->tag_get_handle( "tag3", 1, MB_TYPE_INTEGER, tag3, MB_TAG_DENSE | MB_TAG_CREAT, &def_val_int );MB_CHK_SET_ERR( rval, "Trouble creating tag3" );
    // Get pointers to connectivity, coordinate, tag, and adjacency arrays; each of these returns a
    // count, which should be compared to the # entities you expect to verify there's only one chunk
    // (no holes)
    int count, vpere;
    EntityHandle* conn_ptr;
    rval = mbImpl->connect_iterate( quads.begin(), quads.end(), conn_ptr, vpere, count );MB_CHK_SET_ERR( rval, "Error in connect_iterate" );
    assert( count == (int)quads.size() );  // Should end up with just one contiguous chunk of quads
    double *x_ptr, *y_ptr, *z_ptr;
    rval = mbImpl->coords_iterate( verts.begin(), verts.end(), x_ptr, y_ptr, z_ptr, count );MB_CHK_SET_ERR( rval, "Error in coords_iterate" );
    assert( count == (int)verts.size() );  // Should end up with just one contiguous chunk of vertices
    double *tag1_ptr, *tag2_ptr;
    int* tag3_ptr;
    rval = mbImpl->tag_iterate( tag1, quads.begin(), quads.end(), count, (void*&)tag1_ptr );MB_CHK_SET_ERR( rval, "Error in tag1_iterate" );
    rval = mbImpl->tag_iterate( tag2, quads.begin(), quads.end(), count, (void*&)tag2_ptr );MB_CHK_SET_ERR( rval, "Error in tag2_iterate" );
    rval = mbImpl->tag_iterate( tag3, quads.begin(), quads.end(), count, (void*&)tag3_ptr );MB_CHK_SET_ERR( rval, "Error in tag3_iterate" );
    const vector< EntityHandle >** adjs_ptr;
    rval = mbImpl->adjacencies_iterate( verts.begin(), verts.end(), adjs_ptr, count );MB_CHK_SET_ERR( rval, "Error in adjacencies_iterate" );
    // Start_ handles used to compute indices into vertex/quad arrays; can use direct subtraction
    // because we know there aren't any holes in the handle spaces for verts or quads
    EntityHandle start_vert = *verts.begin(), start_quad = *quads.begin();
    // Iterate over elements, computing tag1 from coords positions
    for( int i = 0; i < nquads; i++ )
        tag1_ptr[3 * i + 0] = tag1_ptr[3 * i + 1] = tag1_ptr[3 * i + 2] = 0.0;  // Initialize position for this element
        for( int j = 0; j < vpere; j++ )
        {                                                        // Loop over vertices in this element
            int v_index = conn_ptr[vpere * i + j] - start_vert;  // vert index is just the offset from start vertex
            tag1_ptr[3 * i + 0] += x_ptr[v_index];
            tag1_ptr[3 * i + 1] += y_ptr[v_index];  // Sum vertex positions into tag1...
            tag1_ptr[3 * i + 2] += z_ptr[v_index];
        tag1_ptr[3 * i + 0] /= vpere;
        tag1_ptr[3 * i + 1] /= vpere;  // Then normalize
        tag1_ptr[3 * i + 2] /= vpere;
    }  // Loop over elements in chunk
    // Iterate through vertices, summing positions into tag2 on connected elements and incrementing
    // vertex count
    for( int v = 0; v < count; v++ )
        const vector< EntityHandle >* avec = *( adjs_ptr + v );
        for( vector< EntityHandle >::const_iterator ait = avec->begin(); ait != avec->end(); ++ait )
            // *ait is the quad handle, its index is computed by subtracting the start quad handle
            int a_ind = *ait - start_quad;
            tag2_ptr[3 * a_ind + 0] += x_ptr[v];  // Tag on each element is 3 doubles, x/y/z
            tag2_ptr[3 * a_ind + 1] += y_ptr[v];
            tag2_ptr[3 * a_ind + 2] += z_ptr[v];
            tag3_ptr[a_ind]++;  // Increment the vertex count
    // Normalize tag2 by vertex count (tag3); loop over elements using same approach as before
    // At the same time, compare values of tag1 and tag2
    int n_dis = 0;
    for( Range::iterator q_it = quads.begin(); q_it != quads.end(); ++q_it )
        int i = *q_it - start_quad;
        for( int j = 0; j < 3; j++ )
            tag2_ptr[3 * i + j] /= (double)tag3_ptr[i];  // Normalize by # verts
        if( tag1_ptr[3 * i] != tag2_ptr[3 * i] || tag1_ptr[3 * i + 1] != tag2_ptr[3 * i + 1] ||
            tag1_ptr[3 * i + 2] != tag2_ptr[3 * i + 2] )
            cout << "Tag1, tag2 disagree for element " << *q_it + i << endl;
            n_dis++;
    if( !n_dis ) cout << "All tags agree, success!" << endl;
    // Ok, we're done, shut down MOAB
    delete mbImpl;
    return 0;
    // First make the mesh, a 1d array of quads with left hand side x = elem_num; vertices are
    // numbered in layers
    ReadUtilIface* read_iface;
    ErrorCode rval = mbImpl->query_interface( read_iface );MB_CHK_SET_ERR( rval, "Error in query_interface" );
    vector< double* > coords;
    EntityHandle start_vert, start_elem, *connect;
    // Create verts, num is 2(nquads+1) because they're in a 1d row; will initialize coords in loop
    // over quads later
    rval = read_iface->get_node_coords( 3, 2 * ( nquads + 1 ), 0, start_vert, coords );MB_CHK_SET_ERR( rval, "Error in get_node_arrays" );
    // Create quads
    rval = read_iface->get_element_connect( nquads, 4, MBQUAD, 0, start_elem, connect );MB_CHK_SET_ERR( rval, "Error in get_element_connect" );
        coords[0][2 * i] = coords[0][2 * i + 1] = (double)i;  // x values are all i
        coords[1][2 * i]                        = 0.0;
        coords[1][2 * i + 1]                    = 1.0;          // y coords
        coords[2][2 * i] = coords[2][2 * i + 1] = (double)0.0;  // z values, all zero (2d mesh)
        EntityHandle quad_v                     = start_vert + 2 * i;
        connect[4 * i + 0]                      = quad_v;
        connect[4 * i + 1]                      = quad_v + 2;
        connect[4 * i + 2]                      = quad_v + 3;
        connect[4 * i + 3]                      = quad_v + 1;
    // Last two vertices
    // Cppcheck warning (false positive): variable coords is assigned a value that is never used
    coords[0][2 * nquads] = coords[0][2 * nquads + 1] = (double)nquads;
    coords[1][2 * nquads]                             = 0.0;
    coords[1][2 * nquads + 1]                         = 1.0;          // y coords
    coords[2][2 * nquads] = coords[2][2 * nquads + 1] = (double)0.0;  // z values, all zero (2d mesh)
    // Call a vertex-quad adjacencies function to generate vertex-element adjacencies in MOAB
    Range dum_range;
    rval = mbImpl->get_adjacencies( &start_vert, 1, 2, false, dum_range );MB_CHK_SET_ERR( rval, "Error in get_adjacencies" );
    assert( !dum_range.empty() );
    return MB_SUCCESS;
