MOAB: Mesh Oriented datABase
(version 5.4.1)
LinearPyramid implementation. More...
Namespaces | |
namespace | MBMesquite |
Implements the NonSmoothDescent class member functions. | |
Functions | |
static void | MBMesquite::set_equal_derivatives (double value, size_t *indices, MsqVector< 3 > *derivs, size_t &num_vtx) |
static void | MBMesquite::set_edge_derivatives (unsigned base_corner, double value, size_t *indices, MsqVector< 3 > *derivs, size_t &num_vtx) |
static void | MBMesquite::set_corner_derivatives (unsigned corner, double value, size_t *indices, MsqVector< 3 > *derivs, size_t &num_vtx) |
static void | MBMesquite::coefficients_at_corner (unsigned corner, double *coeff_out, size_t *indices_out, size_t &num_coeff) |
static void | MBMesquite::coefficients_at_mid_edge (unsigned edge, double *coeff_out, size_t *indices_out, size_t &num_coeff) |
static void | MBMesquite::coefficients_at_mid_face (unsigned face, double *coeff_out, size_t *indices_out, size_t &num_coeff) |
static void | MBMesquite::coefficients_at_mid_elem (double *coeff_out, size_t *indices_out, size_t &num_coeff) |
Definition in file LinearPyramid.cpp.
