ProgOptions.cpp File Reference
#include <iostream>
#include <sstream>
#include <iomanip>
#include <cstdlib>
#include <list>
#include <limits>
#include <set>
#include <algorithm>
#include <cassert>
#include <cstring>
#include "moab/MOABConfig.h"
#include "moab/ProgOptions.hpp"
+ Include dependency graph for ProgOptions.cpp:
Classes
class  ProgOpt
Defines
#define DECLARE_OPTION_TYPE(T)
#define DECLARE_VALUED_OPTION_TYPE(T)
Enumerations
enum  OptType {
  FLAG = 0, INT, REAL, STRING,
  INT_VECT
Functions
template<typename T >
static OptType get_opt_type ()
template<>
OptType get_opt_type< void > ()
template<>
OptType get_opt_type< int > ()
template<>
OptType get_opt_type< double > ()
template<>
OptType get_opt_type< std::string > ()
template<>
OptType get_opt_type< std::vector< int > > ()
static bool parse_int_list (const char *string, std::vector< int > &results)
static std::string do_rank_subst (const std::string &s)
Define Documentation
#define DECLARE_OPTION_TYPE (   T)
Value:
template void ProgOptions::addOpt< T >( const std::string&, const std::string&, T*, int ); \
    template bool ProgOptions::getOpt< T >( const std::string&, T* );
Definition at line 1029 of file ProgOptions.cpp.
Value:
DECLARE_OPTION_TYPE( T )        \
    template void ProgOptions::getOptAllArgs< T >( const std::string&, std::vector< T >& );                   \
    template void ProgOptions::addRequiredArg< T >( const std::string&, const std::string&, T*, int );        \
    template void ProgOptions::addOptionalArgs< T >( unsigned, const std::string&, const std::string&, int ); \
    template T ProgOptions::getReqArg< T >( const std::string& );                                             \
    template void ProgOptions::getArgs< T >( const std::string&, std::vector< T >& );
Definition at line 1033 of file ProgOptions.cpp.
Enumeration Type Documentation
enum OptType
Enumerator:
FLAG
INT
REAL
STRING
INT_VECT
Definition at line 19 of file ProgOptions.cpp.
    FLAG = 0,
    INT,
    REAL,
    STRING,
    INT_VECT
Function Documentation
static std::string do_rank_subst ( const std::string &  s) [static]
Definition at line 459 of file ProgOptions.cpp.
References MPI_COMM_WORLD, rank, and size.
Referenced by ProgOptions::evaluate().
#ifndef MOAB_HAVE_MPI
    return s;
#else
    int rank, size;
    if( MPI_SUCCESS != MPI_Comm_rank( MPI_COMM_WORLD, &rank ) || MPI_SUCCESS != MPI_Comm_size( MPI_COMM_WORLD, &size ) )
        return s;
    int width = 1;
    while( size > 10 )
        size /= 10;
        width++;
    size_t j = s.find( '%' );
    if( j == std::string::npos ) return s;
    std::ostringstream st;
    st << std::setfill( '0' );
    st << s.substr( 0, j );
    st << rank;
    size_t i;
    while( ( i = s.find( '%', j + 1 ) ) != std::string::npos )
        st << s.substr( j, i - j );
        st << std::setw( width ) << rank;
        j = i;
    st << s.substr( j + 1 );
    return st.str();
#endif
static OptType get_opt_type ( ) [inline, static]
template<>
OptType get_opt_type< double > ( )
Definition at line 42 of file ProgOptions.cpp.
References REAL.
    return REAL;
template<>
OptType get_opt_type< int > ( )
Definition at line 37 of file ProgOptions.cpp.
References INT.
    return INT;
template<>
OptType get_opt_type< std::string > ( )
Definition at line 47 of file ProgOptions.cpp.
References get_opt_type< std::string >(), and STRING.
Referenced by get_opt_type< std::string >().
    return STRING;
template<>
OptType get_opt_type< std::vector< int > > ( )
Definition at line 52 of file ProgOptions.cpp.
References INT_VECT.
    return INT_VECT;
template<>
OptType get_opt_type< void > ( )
Definition at line 32 of file ProgOptions.cpp.
References FLAG.
    return FLAG;
static bool parse_int_list ( const char *  string,
std::vector< int > &  results
) [static]
Definition at line 409 of file ProgOptions.cpp.
    bool okay   = true;
    char* mystr = strdup( string );
    for( const char* ptr = strtok( mystr, ", \t" ); ptr; ptr = strtok( 0, ", \t" ) )
        char* endptr;
        long val = strtol( ptr, &endptr, 0 );
        if( endptr == ptr )
            std::cerr << "Not an integer: \"" << ptr << '"' << std::endl;
            okay = false;
            break;
        long val2 = val;
        if( *endptr == '-' )
            const char* sptr = endptr + 1;
            val2             = strtol( sptr, &endptr, 0 );
            if( endptr == sptr )
                std::cerr << "Not an integer: \"" << sptr << '"' << std::endl;
                okay = false;
                break;
            if( val2 < val )
                std::cerr << "Invalid id range: \"" << ptr << '"' << std::endl;
                okay = false;
                break;
        if( *endptr )
            okay = false;
            break;
        for( ; val <= val2; ++val )
            results.push_back( (int)val );
    free( mystr );
    return okay;
