MBMesquite::MsqMatrix< 1, 1 > Class Template Reference
#include <MsqMatrix.hpp>
Public Types
enum  { ROWS = 1, COLS = 1 }
typedef MsqMatrix< 1, 1 > my_type
Public Member Functions
 MsqMatrix ()
 MsqMatrix (double v)
 MsqMatrix (const double *v)
 MsqMatrix (const char *s)
 MsqMatrix (const std::string &s)
 MsqMatrix (const MsqMatrix< 2, 2 > &M, unsigned r, unsigned c)
MsqMatrix< 1, 1 > & operator= (double v)
MsqMatrix< 1, 1 > & operator= (const double *v)
MsqMatrix< 1, 1 > & operator= (const char *s)
MsqMatrix< 1, 1 > & operator= (const std::string &s)
double & operator() (unsigned, unsigned)
double operator() (unsigned, unsigned) const
double * data ()
const double * data () const
void zero ()
void identity ()
void set (double v)
void set (const double *v)
void set (const char *s)
void set (const std::string &s)
void diag (double v)
void diag (const double *v)
void make_minor (const MsqMatrix< 2, 2 > &M, unsigned r, unsigned c)
MsqMatrix< 1, 1 > & assign_add_transpose (const MsqMatrix< 1, 1 > &other)
MsqMatrix< 1, 1 > & assign_product (double s, const MsqMatrix< 1, 1 > &other)
MsqMatrix< 1, 1 > & assign_add_product (double s, const MsqMatrix< 1, 1 > &other)
MsqMatrix< 1, 1 > & assign_multiply_elements (const MsqMatrix< 1, 1 > &other)
 operator double () const
Protected Attributes
double m
Detailed Description
template<>
class MBMesquite::MsqMatrix< 1, 1 >
Definition at line 220 of file MsqMatrix.hpp.
Member Typedef Documentation
typedef MsqMatrix< 1, 1 > MBMesquite::MsqMatrix< 1, 1 >::my_type
Definition at line 226 of file MsqMatrix.hpp.
Member Enumeration Documentation
anonymous enum
Enumerator:
ROWS
COLS
Definition at line 228 of file MsqMatrix.hpp.
        ROWS = 1,
        COLS = 1
MBMesquite::MsqMatrix< 1, 1 >::MsqMatrix ( ) [inline]
Constructor for uninitialized matrix
Definition at line 235 of file MsqMatrix.hpp.
MBMesquite::MsqMatrix< 1, 1 >::MsqMatrix ( double  v) [inline]
Initialize diagonal values, zero others
Definition at line 237 of file MsqMatrix.hpp.
: m( v ) {}
MBMesquite::MsqMatrix< 1, 1 >::MsqMatrix ( const double *  v) [inline]
Initialize to an array of values
Definition at line 239 of file MsqMatrix.hpp.
: m( *v ) {}
MBMesquite::MsqMatrix< 1, 1 >::MsqMatrix ( const char *  s) [inline]
Parse initial values from string
Definition at line 241 of file MsqMatrix.hpp.
        set( s );
MBMesquite::MsqMatrix< 1, 1 >::MsqMatrix ( const std::string &  s) [inline]
Definition at line 246 of file MsqMatrix.hpp.
        set( s );
MBMesquite::MsqMatrix< 1, 1 >::MsqMatrix ( const MsqMatrix< 2, 2 > &  M,
unsigned  r,
unsigned  c
) [inline]
Initialize to the minor of a larger matrix This matrix is the passed matrix with the specified row and column removed.
Definition at line 254 of file MsqMatrix.hpp.
: m( M( r, c ) ) {}
Member Function Documentation
MsqMatrix< 1, 1 >& MBMesquite::MsqMatrix< 1, 1 >::assign_add_product ( double  s,
const MsqMatrix< 1, 1 > &  other
) [inline]
*this += s*m
Definition at line 348 of file MsqMatrix.hpp.
References MBMesquite::MsqMatrix< R, C >::m, and m.
        m += s * other.m;
        return *this;
MsqMatrix< 1, 1 >& MBMesquite::MsqMatrix< 1, 1 >::assign_add_transpose ( const MsqMatrix< 1, 1 > &  other) [inline]
*this += transpose(other)
Definition at line 336 of file MsqMatrix.hpp.
        m += other.m;
        return *this;
MsqMatrix< 1, 1 >& MBMesquite::MsqMatrix< 1, 1 >::assign_multiply_elements ( const MsqMatrix< 1, 1 > &  other) [inline]
multiply each element by the cooresponding element in m
Definition at line 354 of file MsqMatrix.hpp.
        m *= other.m;
        return *this;
MsqMatrix< 1, 1 >& MBMesquite::MsqMatrix< 1, 1 >::assign_product ( double  s,
) [inline]
*this = s*m
Definition at line 342 of file MsqMatrix.hpp.
        m = s * other.m;
        return *this;
double* MBMesquite::MsqMatrix< 1, 1 >::data ( ) [inline]
Definition at line 285 of file MsqMatrix.hpp.
References MBMesquite::MsqMatrix< R, C >::m.
        return &m;
const double* MBMesquite::MsqMatrix< 1, 1 >::data ( ) const [inline]
Definition at line 289 of file MsqMatrix.hpp.
        return &m;
void MBMesquite::MsqMatrix< 1, 1 >::diag ( double  v) [inline]
Set diagonal value to passed values, others to zero.
Definition at line 320 of file MsqMatrix.hpp.
        m = v;
void MBMesquite::MsqMatrix< 1, 1 >::diag ( const double *  v) [inline]
Set diagonal values to passed values, others to zero.
Definition at line 325 of file MsqMatrix.hpp.
        m = *v;
void MBMesquite::MsqMatrix< 1, 1 >::identity ( ) [inline]
Definition at line 298 of file MsqMatrix.hpp.
        m = 1.0;
void MBMesquite::MsqMatrix< 1, 1 >::make_minor ( const MsqMatrix< 2, 2 > &  M,
unsigned  r,
unsigned  c
) [inline]
Set this matrix to the minor of a larger matrix
Definition at line 330 of file MsqMatrix.hpp.
        m = M( r, c );
MBMesquite::MsqMatrix< 1, 1 >::operator double ( ) const [inline]
Definition at line 360 of file MsqMatrix.hpp.
        return m;
double& MBMesquite::MsqMatrix< 1, 1 >::operator() ( unsigned  ,
unsigned
) [inline]
Definition at line 277 of file MsqMatrix.hpp.
        return m;
double MBMesquite::MsqMatrix< 1, 1 >::operator() ( unsigned  ,
unsigned
) const [inline]
Definition at line 281 of file MsqMatrix.hpp.
        return m;
MsqMatrix< 1, 1 >& MBMesquite::MsqMatrix< 1, 1 >::operator= ( double  v) [inline]
Definition at line 256 of file MsqMatrix.hpp.
        m = v;
        return *this;
MsqMatrix< 1, 1 >& MBMesquite::MsqMatrix< 1, 1 >::operator= ( const double *  v) [inline]
Definition at line 261 of file MsqMatrix.hpp.
        m = *v;
        return *this;
MsqMatrix< 1, 1 >& MBMesquite::MsqMatrix< 1, 1 >::operator= ( const char *  s) [inline]
Definition at line 266 of file MsqMatrix.hpp.
        set( s );
        return *this;
MsqMatrix< 1, 1 >& MBMesquite::MsqMatrix< 1, 1 >::operator= ( const std::string &  s) [inline]
Definition at line 271 of file MsqMatrix.hpp.
        set( s );
        return *this;
void MBMesquite::MsqMatrix< 1, 1 >::set ( double  v) [inline]
Definition at line 302 of file MsqMatrix.hpp.
        m = v;
void MBMesquite::MsqMatrix< 1, 1 >::set ( const double *  v) [inline]
Definition at line 306 of file MsqMatrix.hpp.
        m = *v;
void MBMesquite::MsqMatrix< 1, 1 >::set ( const char *  s) [inline]
Definition at line 310 of file MsqMatrix.hpp.
        std::istringstream i( s );
        i >> m;
void MBMesquite::MsqMatrix< 1, 1 >::set ( const std::string &  s) [inline]
Definition at line 315 of file MsqMatrix.hpp.
        set( s.c_str() );
void MBMesquite::MsqMatrix< 1, 1 >::zero ( ) [inline]
Definition at line 294 of file MsqMatrix.hpp.
        m = 0.0;
Member Data Documentation
double MBMesquite::MsqMatrix< 1, 1 >::m [protected]
List of all members.
