moab::ExoIIInterface Class Reference
#include <ExoIIInterface.hpp>
+ Inheritance diagram for moab::ExoIIInterface:
Public Types
enum  { MAX_STR_LENGTH = 33, MAX_LINE_LENGTH = 80 }
Public Member Functions
 ExoIIInterface ()
virtual ~ExoIIInterface ()
virtual ExoIIElementType element_name_to_type (const char *name)=0
 given the element name, return the type
virtual ExoIIElementType get_element_type (EntityHandle entity, Tag mid_nodes_tag, Tag geom_dimension_tag, EntityType indiv_entity_type=MBMAXTYPE)=0
virtual int has_mid_nodes (ExoIIElementType elem_type, int dimension)=0
virtual void has_mid_nodes (ExoIIElementType elem_type, int *array)=0
virtual const char * element_type_name (ExoIIElementType type)=0
virtual int geometric_dimension (const ExoIIElementType elem_type)=0
 return the geometric dimension of the specified element type
Detailed Description
Definition at line 77 of file ExoIIInterface.hpp.
Member Enumeration Documentation
anonymous enum
Enumerator:
MAX_STR_LENGTH
MAX_LINE_LENGTH
Definition at line 80 of file ExoIIInterface.hpp.
Definition at line 86 of file ExoIIInterface.hpp.
virtual moab::ExoIIInterface::~ExoIIInterface ( ) [inline, virtual]
Definition at line 87 of file ExoIIInterface.hpp.
Member Function Documentation
virtual ExoIIElementType moab::ExoIIInterface::element_name_to_type ( const char *  name) [pure virtual]
Implemented in moab::ExoIIUtil.
virtual const char* moab::ExoIIInterface::element_type_name ( ExoIIElementType  type) [pure virtual]
virtual int moab::ExoIIInterface::geometric_dimension ( const ExoIIElementType  elem_type) [pure virtual]
virtual ExoIIElementType moab::ExoIIInterface::get_element_type ( EntityHandle  entity,
Tag  mid_nodes_tag,
EntityType  indiv_entity_type = MBMAXTYPE
) [pure virtual]
get the element type of the entity; this entity can either be a meshset, in which case it will be assumed to be a material set meshset, or an individual entity.
virtual int moab::ExoIIInterface::has_mid_nodes ( ExoIIElementType  elem_type,
int  dimension
) [pure virtual]
virtual void moab::ExoIIInterface::has_mid_nodes ( ExoIIElementType  elem_type,
int *  array
) [pure virtual]
List of all members.
