MOAB: Mesh Oriented datABase  (version 5.1.1)
iBase.h File Reference
+ This graph shows which files directly or indirectly include this file:
Defines
#define IBASE_VERSION_MAJOR   1
 Compile time version number digits.
#define IBASE_VERSION_MINOR   4
#define IBASE_VERSION_PATCH   1
#define IBASE_VERSION_GE(Maj, Min, Pat)
 Version Comparison.
#define IBASE_VERSION_STRING___(I, X, Y, Z)   #I "_Version_" #X "." #Y "." #Z
 Compose compile-time string represention of the version number.
#define IBASE_VERSION_STRING__(I, X, Y, Z)   IBASE_VERSION_STRING___(I,X,Y,Z)
#define IBASE_VERSION_STRING_(I)   IBASE_VERSION_STRING__(I,IBASE_VERSION_MAJOR,IBASE_VERSION_MINOR,IBASE_VERSION_PATCH)
#define IBASE_VERSION_STRING   IBASE_VERSION_STRING_(iBase)
#define IBASE_VERSION_TAG__(I, X, Y, Z)   I##_Version_##X##_##Y##_##Z
 Compose compile-time symbol name derived from the version number.
#define IBASE_VERSION_TAG_(I, X, Y, Z)   IBASE_VERSION_TAG__(I,X,Y,Z)
#define IBASE_VERSION_TAG(I)   IBASE_VERSION_TAG_(I,IBASE_VERSION_MAJOR,IBASE_VERSION_MINOR,IBASE_VERSION_PATCH)
#define ITAPS_VERSION_MAJOR   IBASE_VERSION_MAJOR
 ITAPS-wide (across all ITAPS APIs) version handling.
#define ITAPS_VERSION_MINOR   IBASE_VERSION_MINOR
#define ITAPS_VERSION_PATCH   IBASE_VERSION_PATCH
#define ITAPS_VERSION_GE(Maj, Min, Pat)   IBASE_VERSION_GE(Maj,Min,Pat)
#define ITAPS_VERSION_STRING_(I)   IBASE_VERSION_STRING_(I)
#define ITAPS_VERSION_STRING   ITAPS_VERSION_STRING_(ITAPS)
#define ITAPS_VERSION_TAG_(I)   IBASE_VERSION_TAG(I)
#define ITAPS_VERSION_TAG   ITAPS_VERSION_TAG_(I)
#define IBASE_MINENUM(enumName)   enumName ## _MIN
#define IBASE_MAXENUM(enumName)   enumName ## _MAX
#define IBASE_NUMENUM(enumName)   ((int)IBASE_MAXENUM(enumName) - (int)IBASE_MINENUM(enumName) + 1)
#define IBASE_INCENUM(enumName, I)   (I = (enum enumName)((int)I+1))
Typedefs
typedef void * iBase_Instance
typedef struct
iBase_EntityHandle_Private *
iBase_EntityHandle
typedef struct
iBase_EntitySetHandle_Private *
typedef struct
iBase_TagHandle_Private *
iBase_TagHandle
typedef struct
iBase_EntityIterator_Private *
typedef struct
iBase_EntityArrIterator_Private
Enumerations
enum  iBase_EntityType {
  iBase_EntityType_MIN = 0, iBase_VERTEX = iBase_EntityType_MIN, iBase_EDGE, iBase_FACE,
  iBase_REGION, iBase_ALL_TYPES, iBase_EntityType_MAX = iBase_ALL_TYPES
enum  iBase_AdjacencyCost {
  iBase_AdjacencyCost_MIN = 0, iBase_UNAVAILABLE = iBase_AdjacencyCost_MIN, iBase_ALL_ORDER_1, iBase_ALL_ORDER_LOGN,
  iBase_ALL_ORDER_N, iBase_SOME_ORDER_1, iBase_SOME_ORDER_LOGN, iBase_SOME_ORDER_N,
  iBase_AVAILABLE, iBase_AdjacencyCost_MAX = iBase_AVAILABLE
enum  iBase_CreationStatus {
  iBase_CreationStatus_MIN = 0, iBase_NEW = iBase_CreationStatus_MIN, iBase_ALREADY_EXISTED, iBase_CREATED_DUPLICATE,
  iBase_CREATION_FAILED, iBase_CreationStatus_MAX = iBase_CREATION_FAILED
enum  iBase_ErrorType {
  iBase_ErrorType_MIN = 0, iBase_SUCCESS = iBase_ErrorType_MIN, iBase_MESH_ALREADY_LOADED, iBase_FILE_NOT_FOUND,
  iBase_FILE_WRITE_ERROR, iBase_NIL_ARRAY, iBase_BAD_ARRAY_SIZE, iBase_BAD_ARRAY_DIMENSION,
  iBase_INVALID_ENTITY_HANDLE, iBase_INVALID_ENTITY_COUNT, iBase_INVALID_ENTITY_TYPE, iBase_INVALID_ENTITY_TOPOLOGY,
  iBase_BAD_TYPE_AND_TOPO, iBase_ENTITY_CREATION_ERROR, iBase_INVALID_TAG_HANDLE, iBase_TAG_NOT_FOUND,
  iBase_TAG_ALREADY_EXISTS, iBase_TAG_IN_USE, iBase_INVALID_ENTITYSET_HANDLE, iBase_INVALID_ITERATOR_HANDLE,
  iBase_INVALID_ARGUMENT, iBase_MEMORY_ALLOCATION_FAILED, iBase_NOT_SUPPORTED, iBase_FAILURE,
  iBase_ErrorType_MAX = iBase_FAILURE
enum  iBase_StorageOrder { iBase_StorageOrder_MIN = 0, iBase_BLOCKED = iBase_StorageOrder_MIN, iBase_INTERLEAVED, iBase_StorageOrder_MAX = iBase_INTERLEAVED }
enum  iBase_TagValueType {
  iBase_TagValueType_MIN = 0, iBase_BYTES = iBase_TagValueType_MIN, iBase_INTEGER, iBase_DOUBLE,
  iBase_ENTITY_HANDLE, iBase_ENTITY_SET_HANDLE, iBase_TagValueType_MAX = iBase_ENTITY_SET_HANDLE
Define Documentation
Definition at line 20 of file iBase.h.
Definition at line 21 of file iBase.h.
Definition at line 42 of file iBase.h.
#define IBASE_VERSION_STRING__ (   I,
  X,
  Y,
  Z
Definition at line 40 of file iBase.h.
#define IBASE_VERSION_TAG_ (   I,
  X,
  Y,
  Z
Definition at line 49 of file iBase.h.
#define ITAPS_VERSION_GE (   Maj,
  Min,
  Pat
Definition at line 59 of file iBase.h.
Definition at line 57 of file iBase.h.
Definition at line 58 of file iBase.h.
Definition at line 61 of file iBase.h.
#define ITAPS_VERSION_STRING_ (   I)    IBASE_VERSION_STRING_(I)
Definition at line 60 of file iBase.h.
Definition at line 63 of file iBase.h.
#define ITAPS_VERSION_TAG_ (   I)    IBASE_VERSION_TAG(I)
Definition at line 62 of file iBase.h.
Typedef Documentation
Definition at line 103 of file iBase.h.
typedef struct iBase_EntityHandle_Private* iBase_EntityHandle
Definition at line 99 of file iBase.h.
typedef struct iBase_EntityIterator_Private* iBase_EntityIterator
Definition at line 102 of file iBase.h.
typedef struct iBase_EntitySetHandle_Private* iBase_EntitySetHandle
Definition at line 100 of file iBase.h.
typedef void* iBase_Instance
Definition at line 98 of file iBase.h.
typedef struct iBase_TagHandle_Private* iBase_TagHandle
Definition at line 101 of file iBase.h.
Enumeration Type Documentation
Enumerator:
facilitates iteration over all values
iBase_UNAVAILABLE
Adjacency information not supported
iBase_ALL_ORDER_1
No more than local mesh traversal required (i!=j)
Global tree search (i!=j)
iBase_ALL_ORDER_N
Global exhaustive search (i!=j)
iBase_SOME_ORDER_1
Only some adjacency info, local (i!=j)
Only some adjacency info, tree (i!=j)
iBase_SOME_ORDER_N
Only some adjacency info, exhaustive (i!=j)
iBase_AVAILABLE
ALL (intermediate) entities available. (i==j)
Definition at line 122 of file iBase.h.
        /**< facilitates iteration over all values */
        /**< Adjacency information not supported */
    iBase_ALL_ORDER_1,
        /**< No more than local mesh traversal required (i!=j) */
        /**< Global tree search (i!=j) */
    iBase_ALL_ORDER_N,
        /**< Global exhaustive search (i!=j) */
    iBase_SOME_ORDER_1,
        /**< Only some adjacency info, local (i!=j) */
        /**< Only some adjacency info, tree (i!=j) */
    iBase_SOME_ORDER_N,
        /**< Only some adjacency info, exhaustive (i!=j) */
    iBase_AVAILABLE,
        /**< ALL (intermediate) entities available. (i==j) */
Enumerator:
iBase_NEW
The entity was newly created
The entity already existed and the handle for that already existing handle was returned
The entity already existed but a new, duplicate entity was nevertheless created
Creation of the entity did not succeed
Definition at line 145 of file iBase.h.
        /**< The entity was newly created */
        /**< The entity already existed and the handle for that
             already existing handle was returned */
        /**< The entity already existed but a new, duplicate entity was
             nevertheless created */
        /**< Creation of the entity did not succeed */
Enumerator:
iBase_VERTEX
A topological dimension 0 entity
iBase_EDGE
A topological dimension 1 entity
iBase_FACE
A topological dimension 2 entity
iBase_REGION
A topological dimension 3 entity
iBase_ALL_TYPES
used only in queries to request information about all types
Definition at line 105 of file iBase.h.
        /**< A topological dimension 0 entity */
    iBase_EDGE,
        /**< A topological dimension 1 entity */
    iBase_FACE,
        /**< A topological dimension 2 entity */
    iBase_REGION,
        /**< A topological dimension 3 entity */
    iBase_ALL_TYPES,
        /**< used only in queries to request information about all types */
Enumerator:
iBase_ErrorType_MIN
iBase_SUCCESS
iBase_NIL_ARRAY
iBase_TAG_NOT_FOUND
iBase_TAG_IN_USE
iBase_NOT_SUPPORTED
iBase_FAILURE
iBase_ErrorType_MAX
Definition at line 162 of file iBase.h.
Many of the functions in iMesh can return arrays of tuples; that is, arrays of multi-valued type. For example, the function iMesh_getVtxArrCoords, returns an array of xyz coordinate 3-tuples (or, perhaps for geometrically 2D meshes, xy 2-tuples). In these situations, there are multiple ways the data can be organized in memory. For example, it could be stored xyz,xyz,xyz or xxx...,yyy...,zzz.... These two different storage orders are referred to as INTERLEAVED and BLOCKED, respectively. For some functions in iMesh, the storage order is explicitly specified as an argument to the function. For other functions, the storage order is not explicitly specified. And, in these cases, it shall always be implicitly assumed to be INTERLEAVED. This fact will be mentioned in the documentation for each specific function where it applies. For example, in case of iMesh_getEntArrAdj, the returned array of adjacent entities is multi-valued in that it stores for each entity queried, all its adjacent entities. Such an array will be stored INTERLEAVED with all adjacent entities for the first entity in the query followed by all adjacent entities for the second entity in the query and so forth.
Enumerator:
iBase_BLOCKED
xxx...yyy...zzz...
iBase_INTERLEAVED
xyzxyzxyz...
Definition at line 212 of file iBase.h.
        /**< xxx...yyy...zzz... */
    iBase_INTERLEAVED,
        /**< xyzxyzxyz... */
Enumerator:
iBase_BYTES
An opaque sequence of bytes, size always measured in bytes
iBase_INTEGER
A value of type int
iBase_DOUBLE
A value of type double
iBase_ENTITY_HANDLE
A value of type iBase_EntityHandle
A value of type iBase_EntitySetHandle
Definition at line 223 of file iBase.h.
        /**< An opaque sequence of bytes, size always measured in bytes */
    iBase_INTEGER,
        /**< A value of type \c int */
    iBase_DOUBLE,
        /**< A value of type \c double */
        /**< A value of type \c iBase_EntityHandle */
        /**< A value of type \c iBase_EntitySetHandle */
