verdict_defines.hpp File Reference
#include <cmath>
#include "v_vector.h"
#include "VerdictVector.hpp"
+ Include dependency graph for verdict_defines.hpp:
+ This graph shows which files directly or indirectly include this file:
Defines
#define VERDICT_MIN(a, b)   ( ( a ) < ( b ) ? ( a ) : ( b ) )
#define VERDICT_MAX(a, b)   ( ( a ) > ( b ) ? ( a ) : ( b ) )
#define jacobian_matrix(a, b, c, d, e, f, g)
#define form_t(m11, m21, m12, m22, mw11, mw21, mw12, mw22, detmw, xm11, xm21, xm12, xm22)
#define metric_matrix(m11, m21, m12, m22, gm11, gm12, gm22)
Enumerations
enum  VerdictBoolean { VERDICT_FALSE = 0, VERDICT_TRUE = 1 }
Functions
double determinant (double a, double b, double c, double d)
double determinant (const VerdictVector &v1, const VerdictVector &v2, const VerdictVector &v3)
double normalize_jacobian (double jacobi, VerdictVector &v1, VerdictVector &v2, VerdictVector &v3, int tet_flag=0)
double norm_squared (double m11, double m21, double m12, double m22)
int skew_matrix (double gm11, double gm12, double gm22, double det, double &qm11, double &qm21, double &qm12, double &qm22)
void inverse (const VerdictVector &x1, const VerdictVector &x2, const VerdictVector &x3, VerdictVector &u1, VerdictVector &u2, VerdictVector &u3)
void form_Q (const VerdictVector &v1, const VerdictVector &v2, const VerdictVector &v3, VerdictVector &q1, VerdictVector &q2, VerdictVector &q3)
void product (VerdictVector &a1, VerdictVector &a2, VerdictVector &a3, VerdictVector &b1, VerdictVector &b2, VerdictVector &b3, VerdictVector &c1, VerdictVector &c2, VerdictVector &c3)
double norm_squared (VerdictVector &x1, VerdictVector &x2, VerdictVector &x3)
double skew_x (VerdictVector &q1, VerdictVector &q2, VerdictVector &q3, VerdictVector &qw1, VerdictVector &qw2, VerdictVector &qw3)
Variables
double verdictSqrt2
Define Documentation
#define form_t (   m11,
  m21,
  m12,
  m22,
  mw11,
  mw21,
  mw12,
  mw22,
  detmw,
  xm11,
  xm21,
  xm12,
  xm22
Value:
xm11     = ( ( m11 ) * ( mw22 ) - ( m12 ) * ( mw21 ) ) / ( detmw );                     \
    ( xm21 ) = ( ( m21 ) * ( mw22 ) - ( m22 ) * ( mw21 ) ) / ( detmw );                     \
    ( xm12 ) = ( ( m12 ) * ( mw11 ) - ( m11 ) * ( mw12 ) ) / ( detmw );                     \
    ( xm22 ) = ( ( m22 ) * ( mw11 ) - ( m21 ) * ( mw12 ) ) / ( detmw );
Definition at line 67 of file verdict_defines.hpp.
#define jacobian_matrix (   a,
  b,
  c,
  d,
  e,
  f,
Value:
double jac_mat_tmp;                        \
    jac_mat_tmp = sqrt( a );                   \
    if( jac_mat_tmp == 0 )                     \
        ( d ) = 0;                             \
        ( e ) = 0;                             \
        ( f ) = 0;                             \
        ( g ) = 0;                             \
    else                                       \
        ( d ) = jac_mat_tmp;                   \
        ( e ) = 0;                             \
        ( f ) = ( b ) / jac_mat_tmp;           \
        ( g ) = ( c ) / jac_mat_tmp;           \
Definition at line 48 of file verdict_defines.hpp.
#define metric_matrix (   m11,
  m21,
  m12,
  m22,
  gm11,
  gm12,
  gm22
Value:
gm11     = ( m11 ) * ( m11 ) + ( m21 ) * ( m21 );         \
    ( gm12 ) = ( m11 ) * ( m12 ) + ( m21 ) * ( m22 );         \
    ( gm22 ) = ( m12 ) * ( m12 ) + ( m22 ) * ( m22 );
Definition at line 116 of file verdict_defines.hpp.
#define VERDICT_MIN (   a,
Enumeration Type Documentation
Enumerator:
VERDICT_FALSE
VERDICT_TRUE
Definition at line 29 of file verdict_defines.hpp.
Function Documentation
double determinant ( double  a,
double  b,
double  c,
double  d
) [inline]
Definition at line 38 of file verdict_defines.hpp.
Referenced by get_weight(), inverse(), v_quad_quality(), v_quad_relative_size_squared(), v_tri_quality(), and v_tri_relative_size_squared().
    return ( ( a ) * ( d ) - ( b ) * ( c ) );
double determinant ( const VerdictVector v1,
const VerdictVector v2,
const VerdictVector v3
) [inline]
Definition at line 43 of file verdict_defines.hpp.
    return v1 % ( v2 * v3 );
void form_Q ( const VerdictVector v1,
const VerdictVector v3,
VerdictVector q1,
VerdictVector q2,
VerdictVector q3
) [inline]
Definition at line 210 of file verdict_defines.hpp.
References moab::cross(), and VerdictVector::set().
    double g11, g12, g13, g22, g23, g33;
    g11 = v1 % v1;
    g12 = v1 % v2;
    g13 = v1 % v3;
    g22 = v2 % v2;
    g23 = v2 % v3;
    g33 = v3 % v3;
    double rtg11 = sqrt( g11 );
    double rtg22 = sqrt( g22 );
    double rtg33 = sqrt( g33 );
    VerdictVector temp1;
    temp1 = v1 * v2;
    double cross = sqrt( temp1 % temp1 );
    double q11, q21, q31;
    double q12, q22, q32;
    double q13, q23, q33;
    q11 = 1;
    q21 = 0;
    q31 = 0;
    q12 = g12 / rtg11 / rtg22;
    q22 = cross / rtg11 / rtg22;
    q32 = 0;
    q13   = g13 / rtg11 / rtg33;
    q23   = ( g11 * g23 - g12 * g13 ) / rtg11 / rtg33 / cross;
    temp1 = v2 * v3;
    q33   = ( v1 % temp1 ) / rtg33 / cross;
    q1.set( q11, q21, q31 );
    q2.set( q12, q22, q32 );
    q3.set( q13, q23, q33 );
void inverse ( const VerdictVector x1,
const VerdictVector x2,
const VerdictVector x3,
VerdictVector u1,
VerdictVector u2,
VerdictVector u3
) [inline]
Definition at line 143 of file verdict_defines.hpp.
References determinant(), VerdictVector::set(), VerdictVector::x(), VerdictVector::y(), and VerdictVector::z().
Referenced by moab::element_utility::Linear_tet_map< Entity_handle, moab::Matrix3 >::set_tet(), skew_x(), moab::element_utility::Linear_hex_map< moab::Matrix3 >::solve_inverse(), and test_spectral_hex().
    double detx = determinant( x1, x2, x3 );
    VerdictVector rx1, rx2, rx3;
    rx1.set( x1.x(), x2.x(), x3.x() );
    rx2.set( x1.y(), x2.y(), x3.y() );
    rx3.set( x1.z(), x2.z(), x3.z() );
    u1 = rx2 * rx3;
    u2 = rx3 * rx1;
    u3 = rx1 * rx2;
    u1 /= detx;
    u2 /= detx;
    u3 /= detx;
double norm_squared ( double  m11,
double  m21,
double  m12,
double  m22
) [inline]
Definition at line 111 of file verdict_defines.hpp.
Referenced by skew_x().
    return m11 * m11 + m21 * m21 + m12 * m12 + m22 * m22;
double norm_squared ( VerdictVector x1,
VerdictVector x2,
VerdictVector x3
) [inline]
Definition at line 280 of file verdict_defines.hpp.
    return ( x1 % x1 ) + ( x2 % x2 ) + ( x3 % x3 );
double normalize_jacobian ( double  jacobi,
VerdictVector v1,
VerdictVector v2,
VerdictVector v3,
int  tet_flag = 0
) [inline]
Definition at line 75 of file verdict_defines.hpp.
References VerdictVector::length_squared(), and verdictSqrt2.
    double return_value = 0.0;
    if( jacobi != 0.0 )
        double l1, l2, l3, length_product;
        // Note: there may be numerical problems if one is a lot shorter
        // than the others this way. But scaling each vector before the
        // triple product would involve 3 square roots instead of just
        // one.
        l1             = v1.length_squared();
        l2             = v2.length_squared();
        l3             = v3.length_squared();
        length_product = sqrt( l1 * l2 * l3 );
        // if some numerical scaling problem, or just plain roundoff,
        // then push back into range [-1,1].
        if( length_product < fabs( jacobi ) )
            length_product = fabs( jacobi );
        if( tet_flag == 1 )
            return_value = verdictSqrt2 * jacobi / length_product;
        else
            return_value = jacobi / length_product;
    return return_value;
void product ( VerdictVector a1,
VerdictVector a2,
VerdictVector a3,
VerdictVector b1,
VerdictVector b2,
VerdictVector b3,
VerdictVector c1,
VerdictVector c2,
VerdictVector c3
) [inline]
Definition at line 258 of file verdict_defines.hpp.
References VerdictVector::set(), VerdictVector::x(), VerdictVector::y(), and VerdictVector::z().
    VerdictVector x1, x2, x3;
    x1.set( a1.x(), a2.x(), a3.x() );
    x2.set( a1.y(), a2.y(), a3.y() );
    x3.set( a1.z(), a2.z(), a3.z() );
    c1.set( x1 % b1, x2 % b1, x3 % b1 );
    c2.set( x1 % b2, x2 % b2, x3 % b2 );
    c3.set( x1 % b3, x2 % b3, x3 % b3 );
int skew_matrix ( double  gm11,
double  gm12,
double  gm22,
double  det,
double &  qm11,
double &  qm21,
double &  qm12,
double &  qm22
) [inline]
Definition at line 121 of file verdict_defines.hpp.
    double tmp = sqrt( gm11 * gm22 );
    if( tmp == 0 )
        return false;
    qm11 = 1;
    qm21 = 0;
    qm12 = gm12 / tmp;
    qm22 = det / tmp;
    return true;
double skew_x ( VerdictVector q1,
VerdictVector q2,
VerdictVector q3,
VerdictVector qw1,
VerdictVector qw2,
VerdictVector qw3
) [inline]
Definition at line 286 of file verdict_defines.hpp.
References inverse(), norm_squared(), product(), and VERDICT_DBL_MIN.
    double normsq1, normsq2, kappa;
    VerdictVector u1, u2, u3;
    inverse( qw1, qw2, qw3, u1, u2, u3 );
    product( q1, q2, q3, u1, u2, u3, x1, x2, x3 );
    inverse( x1, x2, x3, u1, u2, u3 );
    normsq1 = norm_squared( x1, x2, x3 );
    normsq2 = norm_squared( u1, u2, u3 );
    kappa   = sqrt( normsq1 * normsq2 );
    double skew = 0;
    if( kappa > VERDICT_DBL_MIN ) skew = 3 / kappa;
    return skew;
Variable Documentation
double verdictSqrt2
Definition at line 30 of file V_GaussIntegration.cpp.
Referenced by normalize_jacobian().
