cgma
00001 //------------------------------------------------------------------------- 00002 // COPYRIGHT 1998 CATERPILLAR INC. ALL RIGHTS RESERVED 00003 // 00004 // Filename : AnalyticGeometryTool.hpp 00005 // 00006 // Purpose : This class performs calculations on analytic geometry 00007 // (points, lines, arcs, planes, polygons). Capabilities 00008 // include vector and point math, matrix operations, 00009 // measurements, intersections and comparison/containment checks. 00010 // 00011 // Special Notes : As most of these functions were taken from Caterpillar's 00012 // Cmath library with minimal modification for this class, 00013 // the vectors, planes, etc. are represented in non-CUBIT 00014 // format. These could be converted with some effort. 00015 // 00016 // Other Notes: 00017 // ------------ 00018 // 1. Points and vectors are represented as double[3]. 00019 // 00020 // 2. Lines (unless denoted as 'segments') are defined as 00021 // a point and a vector (point-direction form). The parametric 00022 // equations of a line are: 00023 // 00024 // x = xo + t*a 00025 // y = yo + t*a 00026 // z = zo + t*a 00027 // 00028 // 3. Planes are also defined as a point and a vector 00029 // (point-normal form). The equation of a plane is: 00030 // 00031 // a*(x-xo) + b*(y-yo) + c*(z-zo) = 0 00032 // 00033 // For example, the equation of a plane passing through the 00034 // point (3,-1,7) and perpendicular to the vector n = (4,2,-5) 00035 // is: 4(x-3) + 2(y+1) -5(z-7) = 0 00036 // 00037 // This can be reduced to: 00038 // 00039 // A*x + B*y + C*z + D = 0 00040 // 00041 // For the example, the equation is: 4x + 2y -5z + 25 = 0 00042 // 00043 // 4. Most functions which can accept a 3x3 matrix have 00044 // an analogous 4x4 function. This is for convenience 00045 // only (the extra rows/columns are ignored within the function). 00046 // 00047 // 00048 // Creator : Steve Storm 00049 // 00050 // Creation Date : 10/16/98 00051 //------------------------------------------------------------------------- 00052 00053 #ifndef ANALYTIC_GEOMETRY_TOOL_HPP 00054 #define ANALYTIC_GEOMETRY_TOOL_HPP 00055 00056 #include <math.h> 00057 #include "CubitDefines.h" 00058 #include "CGMGeomConfigure.h" 00059 00060 #include <iostream> 00061 00062 class CubitBox; 00063 class CubitPlane; 00064 class CubitVector; 00065 template <class X> class DLIList; 00066 00067 // Multiplication constants 00068 const double AGT_E = 2.7182818284590452354; // e 00069 const double AGT_LOG_2E = 1.4426950408889634074; // log2(e) 00070 const double AGT_LOG_10E = 0.43429448190325182765; // log10(e) 00071 const double AGT_LN_2 = 0.69314718055994530942; // ln(2) 00072 const double AGT_LN_10 = 2.30258509299404568402; // ln(10) 00073 const double AGT_PI = 3.14159265358979323846; // PI 00074 const double AGT_PI_DIV_2 = 1.57079632679489661923; // PI/2 00075 const double AGT_PI_DIV_4 = 0.78539816339744830962; // PI/4 00076 const double AGT_1_DIV_PI = 0.31830988618379067154; // 1/PI 00077 const double AGT_2_DIV_PI = 0.63661977236758134308; // 2/PI 00078 const double AGT_2_DIV_SQRT_PI = 1.12837916709551257390; // 2/(sqrt(PI)) 00079 const double AGT_SQRT_2 = 1.41421356237309504880; // sqrt(2) 00080 const double AGT_SQRT_1_DIV_2 = 0.70710678118654752440; // sqrt(1/2) 00081 const double AGT_PI_DIV_180 = 0.017453292519943295; // PI/180 00082 const double AGT_180_DIV_PI = 57.295779513082323; // 180/PI 00083 00084 const double DEGtoRAD = AGT_PI_DIV_180; 00085 const double RADtoDEG = AGT_180_DIV_PI; 00086 00087 typedef struct { 00088 double Vec1[3]; /* First vector that defines plane of arc */ 00089 double Vec2[3]; /* Second vector that defines plane of arc */ 00090 double Origin[3]; /* Center of arc (on plane) */ 00091 double StartAngle; /* Starting angle (in radians) of arc */ 00092 double EndAngle; /* End angle (in radians) of arc */ 00093 double Radius; /* Radius of arc */ 00094 } AGT_3D_Arc; 00095 00096 // Return values */ 00097 enum AgtEquality { 00098 AGT_EQUAL = 0, // define for comparisons 00099 AGT_LESSTHAN = 1, // define for comparisons 00100 AGT_GREATERTHAN = 2 // define for comparisons 00101 }; 00102 00103 enum AgtSide { 00104 AGT_ON_PLANE = 0, // define for which side of plane 00105 AGT_POS_SIDE = 1, // define for which side of plane 00106 AGT_NEG_SIDE = 2, // define for which side of plane 00107 AGT_INT_PLANE = 3, // define for intersects plane 00108 AGT_CROSS = 4 // define for line crossing plane 00109 }; 00110 00111 enum AgtOrientation { 00112 AGT_OPP_DIR = 0, // define for vector direction comparision 00113 AGT_SAME_DIR = 1 // define for vector direction comparision 00114 }; 00115 00116 enum AgtDistanceMethod { 00117 AGT_FRACTION = 0, // define for distance along a curve 00118 AGT_ABSOLUTE = 1 // define for distance along a curve 00119 }; 00120 00121 // Macros 00122 #define number_sign(number) (number<0 ? -1 : 1) 00123 #define copy_vec(vec1,vec2) copy_pnt(vec1,vec2) 00124 #define set_vec(pnt,x,y,z) set_pnt(pnt,x,y,z) 00125 00127 // MAGIC SOFTWARE // 00128 // See note later in file regarding MAGIC softare. // 00130 // Minimal 2D bounding box - parameters 00131 const int maxPartition = 32; 00132 const int invInterp = 32; 00133 const double angleMin = -0.25*AGT_PI; 00134 const double angleMax = +0.25*AGT_PI; 00135 const double angleRange = 0.5*AGT_PI; 00136 00137 typedef struct 00138 { 00139 double x, y; 00140 } 00141 Point2; 00142 00143 typedef struct 00144 { 00145 double x, y, z; 00146 } 00147 Point3; 00148 00149 typedef struct 00150 { 00151 Point2 center; 00152 Point2 axis[2]; 00153 double extent[2]; 00154 } 00155 OBBox2; 00156 00157 typedef struct 00158 { 00159 Point3 center; 00160 Point3 axis[3]; 00161 double extent[3]; 00162 } 00163 OBBox3; 00164 00165 // threshold on determinant to conclude lines/rays/segments are parallel 00166 const double par_tolerance = 1e-06; 00167 #define DIST(x) (Sqrt(Abs(x))) 00168 00169 // Line in 2D 00170 typedef struct 00171 { 00172 // line is Dot(N,X) = c, N not necessarily unit length 00173 Point2 N; 00174 double c; 00175 } 00176 AgtLine; 00177 00178 // Triangle in 2D 00179 typedef struct 00180 { 00181 Point2 v[3]; 00182 } 00183 Triangle; 00184 00185 // Linked list of triangle 00186 typedef struct AgtTriList 00187 { 00188 Triangle* tri; 00189 AgtTriList* next; 00190 } 00191 AgtTriList; 00192 00193 //--------------------------------------------------------------------------- 00194 // Lines in 3D 00195 //--------------------------------------------------------------------------- 00196 typedef struct 00197 { 00198 // Line is L(t) = b+t*m for any real-valued t 00199 // Ray has constraint t >= 0, b is the origin of the ray 00200 // Line segment has constraint 0 <= t <= 1, b and b+m are end points 00201 00202 Point3 b, m; 00203 } 00204 Line3; 00205 //--------------------------------------------------------------------------- 00206 00207 //--------------------------------------------------------------------------- 00208 // Circles in 3D 00209 //--------------------------------------------------------------------------- 00210 typedef struct 00211 { 00212 // Plane containing circle is Dot(N,X-C) = 0 where X is any point in the 00213 // plane. Vectors U, V, and N form an orthonormal right-handed set 00214 // (matrix [U V N] is orthonormal and has determinant 1). Circle within 00215 // the plane is parameterized by X = C + R*(cos(A)*U + sin(A)*V) where 00216 // A is an angle in [0,2*pi). 00217 00218 Point3 U, V, N; // coordinate system of plane containing circle 00219 Point3 C; // center 00220 double R; // radius > 0 00221 } 00222 Circle3; 00223 //--------------------------------------------------------------------------- 00224 00225 //--------------------------------------------------------------------------- 00226 // Triangles in 3D 00227 //--------------------------------------------------------------------------- 00228 typedef struct 00229 { 00230 // Triangle points are tri(s,t) = b+s*e0+t*e1 where 0 <= s <= 1, 00231 // 0 <= t <= 1, and 0 <= s+t <= 1. 00232 00233 // If the vertices of the triangle are v0, v1, and v2, then b = v0, 00234 // e0 = v1 - v0, and e1 = v2 - v0. 00235 00236 Point3 b, e0, e1; 00237 } 00238 Triangle3; 00239 //--------------------------------------------------------------------------- 00240 00241 //--------------------------------------------------------------------------- 00242 // Parallelograms in 3D 00243 //--------------------------------------------------------------------------- 00244 typedef struct 00245 { 00246 // Rectoid points are rect(s,t) = b+s*e0+t*e1 where 0 <= s <= 1 00247 // and 0 <= t <= 1. Could have called this a parallelogram, but 00248 // I do not like typing long words... 00249 00250 Point3 b, e0, e1; 00251 } 00252 Rectoid3; 00253 //--------------------------------------------------------------------------- 00254 00255 //--------------------------------------------------------------------------- 00256 // Planes in 3D 00257 //--------------------------------------------------------------------------- 00258 typedef struct 00259 { 00260 // plane is Dot(N,X) = d 00261 Point3 N; 00262 double d; 00263 } 00264 Plane3; 00265 //--------------------------------------------------------------------------- 00266 00267 // END OF MAGIC SOFTWARE 00269 00271 class CUBIT_GEOM_EXPORT AnalyticGeometryTool 00272 { 00273 public: 00274 00275 ~AnalyticGeometryTool(); 00276 static AnalyticGeometryTool* instance(); 00277 00278 static void delete_instance() 00279 { 00280 if( instance_ ) 00281 delete instance_; 00282 instance_ = NULL; 00283 }; 00284 00285 //********************************************************* 00286 // Double numbers 00287 //********************************************************* 00288 00292 CubitBoolean dbl_eq( double val_1, double val_2 ); 00293 00296 double get_epsilon(); 00299 double set_epsilon( double new_epsilon ); 00300 00304 void round_near_val( double& val ); 00305 00306 //************************************************************************** 00307 // Matrices & Transforms 00308 //************************************************************************** 00309 // Note: For these functions the matrix format is defined as follows: 00310 // 00311 // Consider the transformation from [x,y,z] to [x',y',z']: 00312 // _ _ 00313 // | x1 y1 z1 0 | 00314 // [x',y',z',1] = [x,y,z,1]| x2 y2 z2 0 | 00315 // | x3 y3 z3 0 | 00316 // | ox oy oz 1 | 00317 // - - 00321 void transform_pnt( double m[4][4], double pin[3], double pout[3] ); 00322 00326 void transform_vec( double m3[3][3], double vin[3], double vout[3] ); 00327 00331 void transform_vec( double m4[4][4], double vin[3], double vout[3] ); 00332 00335 void transform_line( double rot_mtx[4][4], double origin[3], double axis[3] ); 00338 void transform_line( double rot_mtx[4][4], CubitVector &origin, CubitVector &axis ); 00339 00340 00342 00346 void copy_mtx( double from[3][3],double to[3][3] ); 00347 void copy_mtx( double from[4][4], double to[4][4] ); 00348 void copy_mtx( double from[4][4], double to[3][3] ); 00349 void copy_mtx(double from[3][3], double to[4][4], double *origin = NULL ); 00351 00353 00354 00355 void create_rotation_mtx( double theta, double v[3], double mtx3x3[3][3] ); 00356 void create_rotation_mtx( double theta, double v[3], double mtx4x4[4][4] ); 00358 00362 void add_origin_to_rotation_mtx( double rot_mtx[4][4], double origin[3] ); 00363 00365 00366 void identity_mtx( double mtx3x3[3][3] ); 00367 void identity_mtx( double mtx4x4[4][4] ); 00369 00371 00372 00373 00374 00375 00376 00377 00378 00379 void mtx_to_angs( double mtx3x3[3][3], double &ax, double &ay, double &az ); 00380 void mtx_to_angs( double mtx4x4[4][4], double &ax, double &ay, double &az ); 00382 00383 00385 // This routine rotates a 3x3 system given a transformation matrix. The 00386 // matrix can be rotated in place by sending same variable in & out, or a 00387 // new matrix can be created. In the 4x4 case, the translation portion 00388 // of the matrix is unchanged. 00389 void rotate_system( double mtx[3][3], double sys_in[3][3], 00390 double sys_out[3][3] ); 00391 void rotate_system( double mtx[4][4], double sys_in[4][4], 00392 double sys_out[4][4] ); 00394 00396 double det_mtx( double m[3][3] ); 00397 00399 // Multiply matrices together. If any input is NULL, the identity 00400 // matrix is used in its place. 00401 void mult_mtx( double a[3][3],double b[3][3], double d[3][3] ); 00402 void mult_mtx( double a[4][4], double b[4][4], double d[4][4] ); 00404 00410 CubitStatus inv_mtx_adj( double mtx[3][3], double inv_mtx[3][3] ); 00411 00416 CubitStatus inv_trans_mtx( double transf[4][4], double inv_transf[4][4] ); 00417 00419 00420 00421 void vecs_to_mtx( double xvec[3], double yvec[3], double zvec[3], 00422 double matrix[3][3] ); 00423 void vecs_to_mtx( double xvec[3], double yvec[3], double zvec[3], 00424 double origin[3], double matrix[4][4] ); 00426 00428 00429 void print_mtx( double mtx[3][3] ); 00430 void print_mtx( double mtx[4][4] ); 00432 00433 //************************************************************************** 00434 // 3D Points 00435 //************************************************************************** 00438 void copy_pnt( double pnt_in[3], double pnt_out[3] ); 00439 00441 00442 void copy_pnt( double pnt_in[3], CubitVector &cubit_vec ); 00443 void copy_pnt( CubitVector &cubit_vec, double pnt_out[3] ); 00445 00447 void set_pnt( double pnt[3], double x, double y, double z ); 00448 00453 CubitBoolean pnt_eq( double pnt1[3],double pnt2[3] ); 00454 00460 CubitStatus mirror_pnt( double pnt[3], double pln_orig[3], 00461 double pln_norm[3], double m_pnt[3]); 00462 00467 CubitStatus next_pnt( double str_pnt[3], double vec_dir[3], double len, 00468 double new_pnt[3]); 00469 00470 //*************************************************************************** 00471 // 3D Vectors 00472 //*************************************************************************** 00474 CubitStatus unit_vec( double vin[3], double vout[3] ); 00475 00480 double dot_vec( double uval[3], double vval[3] ); 00481 00486 void cross_vec( double uval[3], double vval[3], double cross[3] ); 00487 00489 void cross_vec_unit( double uval[3], double vval[3], double cross[3] ); 00490 00492 void orth_vecs( double uvect[3], double vvect[3], double wvect[3] ); 00493 00496 double mag_vec( double vec[3] ); 00497 00500 CubitStatus get_vec ( double str_pnt[3], double stp_pnt[3], 00501 double vector_out[3] ); 00502 00505 CubitStatus get_vec_unit( double str_pnt[3], double stp_pnt[3], 00506 double uv_out[3] ); 00507 00509 void mult_vecxconst( double constant, double vec[3], double vec_out[3] ); 00510 00512 void reverse_vec( double vin[3],double vout[3] ); 00513 00517 double angle_vec_vec( double v1[3],double v2[3] ); 00518 00519 //*************************************************************************** 00520 // Distances 00521 //*************************************************************************** 00523 double dist_pnt_pnt( double pnt1[3], double pnt2[3] ); 00524 00530 double dist_pln_pln( double pln_1_orig[3], double pln_1_norm[3], 00531 double pln_2_orig[3], double pln_2_norm[3], 00532 AgtSide *side = NULL, AgtOrientation *orien = NULL, 00533 unsigned short *status = NULL ); 00534 00535 //*************************************************************************** 00536 // Intersections 00537 //*************************************************************************** 00541 CubitStatus int_ln_pln( double ln_orig[3], double ln_vec[3], double pln_orig[3], 00542 double pln_norm[3], double int_pnt[3] ); 00552 int int_ln_ln( double p1[3], double v1[3], double p2[3], double v2[3], 00553 double int_pnt1[3], double int_pnt2[3] ); 00554 00558 int int_pnt_ln( double pnt[3], double ln_orig[3], double ln_vec[3], 00559 double int_pnt[3] ); 00560 00564 int int_pnt_pln( double pnt[3], double pln_orig[3], double pln_norm[3], 00565 double pln_int[3] ); 00566 00569 CubitStatus int_pln_pln( double pln_1_orig[3], double pln_1_norm[3], 00570 double pln_2_orig[3], double pln_2_norm[3], 00571 double ln_orig[3], double ln_vec[3] ); 00572 00573 //************************************************************************** 00574 // Comparison/Containment Tests 00575 //************************************************************************** 00579 CubitBoolean is_vec_par( double vec_1[3], double vec_2[3] ); 00580 00583 CubitBoolean is_vec_perp( double vec_1[3],double vec_2[3]); 00584 00587 CubitBoolean is_vecs_same_dir( double vec_1[3], double vec_2[3] ); 00588 00591 CubitBoolean is_pnt_on_ln( double pnt[3], double ln_orig[3], double ln_vec[3] ); 00592 00596 CubitBoolean is_pnt_on_ln_seg( double pnt1[3], double end1[3], double end2[3] ); 00597 00600 CubitBoolean is_pnt_on_pln( double pnt[3], double pln_orig[3], double pln_norm[3] ); 00601 00605 CubitBoolean is_ln_on_pln( double ln_orig[3], double ln_vec[3], 00606 double pln_orig[3], double pln_norm[3] ); 00607 00608 00610 CubitBoolean is_pln_on_pln( double pln_orig1[3], double pln_norm1[3], 00611 double pln_orig2[3], double pln_norm2[3] ); 00612 00613 //************************************************************************** 00614 // Arcs/Circles 00615 //************************************************************************** 00616 00618 00619 00620 00621 00622 00623 void setup_arc( double vec_1[3], double vec_2[3], double origin[3], 00624 double start_angle, double end_angle, // Angles in radians 00625 double radius, AGT_3D_Arc &arc ); 00626 void setup_arc( CubitVector& vec_1, CubitVector& vec_2, 00627 CubitVector origin, double start_angle, // Angles in radians 00628 double end_angle, double radius, 00629 AGT_3D_Arc &arc ); 00631 00633 00634 00635 void get_arc_xyz( AGT_3D_Arc &arc, double param, double pnt[3] ); 00636 void get_arc_xyz( AGT_3D_Arc &arc, double param, CubitVector& pnt ); 00638 00645 int get_num_circle_tess_pnts( double radius, double len_tolerance = 1e-4 ); 00646 00647 //************************************************************************** 00648 // Miscellaneous 00649 //************************************************************************** 00650 00653 void get_pln_orig_norm( double A, double B, double C, double D, 00654 double pln_orig[3], double pln_norm[3] = NULL ); 00658 void get_box_corners( double box_min[3],double box_max[3],double c[8][3] ); 00659 00661 00662 00663 00664 00665 00666 00667 00668 00669 00670 00671 CubitStatus min_pln_box_int_corners( const CubitPlane& plane, 00672 const CubitBox& box, 00673 int extension_type, double extension, 00674 CubitVector& p1, CubitVector& p2, 00675 CubitVector& p3, CubitVector& p4, 00676 CubitBoolean silent = CUBIT_FALSE ); 00677 CubitStatus min_pln_box_int_corners( CubitVector& vec1, 00678 CubitVector& vec2, 00679 CubitVector& vec3, 00680 CubitVector& box_min, CubitVector& box_max, 00681 int extension_type, double extension, 00682 CubitVector& p1, CubitVector& p2, 00683 CubitVector& p3, CubitVector& p4, 00684 CubitBoolean silent = CUBIT_FALSE ); 00685 CubitStatus min_pln_box_int_corners( double plane_norm[3], double plane_coeff, 00686 double box_min[3], double box_max[3], 00687 int extension_type, double extension, 00688 double p1[3], double p2[3], // OUT 00689 double p3[3], double p4[3], // OUT 00690 CubitBoolean silent = CUBIT_FALSE); 00692 00694 00695 00696 CubitStatus get_tight_bounding_box( DLIList<CubitVector*> &point_list, 00697 CubitVector& p1, CubitVector& p2, 00698 CubitVector& p3, CubitVector& p4, 00699 CubitVector& p5, CubitVector& p6, 00700 CubitVector& p7, CubitVector& p8); 00701 CubitStatus get_tight_bounding_box( DLIList<CubitVector*> &point_list, 00702 CubitVector ¢er, 00703 CubitVector axes[3], 00704 CubitVector &extension ); 00706 00707 00709 00710 00711 00712 00713 00714 00715 00716 00717 00718 00719 CubitStatus min_cyl_box_int( double radius, CubitVector& axis, CubitVector& center, 00720 CubitBox& box, 00721 int extension_type, double extension, 00722 CubitVector &start, CubitVector &end, 00723 int num_tess_pnts = 2048 ); 00724 CubitStatus min_cyl_box_int( double radius, double axis[3], double center[3], 00725 double box_min[3], double box_max[3], 00726 int extension_type, double extension, 00727 double start[3], double end[3], 00728 int num_tess_pnts = 2048 ); 00730 00732 double MinTriangleTriangle (Triangle3& tri0, 00733 Triangle3& tri1, 00734 double& s, double& t, double& u, double& v); 00735 00737 double AreaIntersection (Triangle &tri1, Triangle &tri2 ); 00738 00740 double Angle( Triangle3& tri1, Triangle3& tri2 ); 00741 00743 double MinPointTriangle (const Point3& p, const Triangle3& tri, double& s, double& t); 00744 00746 void Normal( Triangle3& tri, double normal[3] ); 00747 00749 double ProjectedOverlap( Triangle3& tri1, Triangle3& tri2, bool draw_overlap = false ); 00750 00751 protected: 00752 AnalyticGeometryTool(); 00753 //- Class Constructor. (Not callable by user code. Class is constructed 00754 //- by the {instance()} member function. 00755 00756 private: 00757 00758 static AnalyticGeometryTool* instance_; 00759 00760 double agtEpsilon; // default = 1e-6 00761 00762 00764 // MAGIC SOFTWARE 00765 //This code was obtained from Dave Eberly, at www.magic-software.com. It 00766 //has been modified only to be placed into AnalyticGeometryTool. This was 00767 //done for convenience only. An alternate solution would be to create a 00768 //separate library for these functions. 00769 // 00770 //Steve Storm, storm@CAT.com, 3-27-99 00772 //MAGIC is an acronym for My Alternate Graphics and Image Code. The 00773 //initial code base originated in 1991 as an attempt to answer questions that 00774 //arise in my favorite news group, comp.graphics.algorithms, and has been 00775 //growing ever since. Magic is intended to provide free source code for solving 00776 //problems that commonly arise in computer graphics and image analysis. While 00777 //the code at this web site is free, additional conditions are: 00778 // 00779 // * You may distribute the original source code to others at no charge. You 00780 // got it for free, so do not charge others for it. 00781 // * You may modify the original source code and distribute it to others at no 00782 // charge. The modified code must be documented to indicate that it is not 00783 // part of the original package. I do not want folks to blame me for bugs 00784 // introduced by modifications. I do accept blame for bugs that are my 00785 // doing and will do my best to fix them. 00786 // * You may use this code for non-commercial purposes. You may also 00787 // incorporate this code into commercial packages. However, you may not 00788 // sell any of your source code which contains my original and/or modified 00789 // source code (see items 1 and 2 in this list of conditions). In such a case, 00790 // you would need to factor out my code and freely distribute it. Send me 00791 // email if you use it. I am always interested in knowing where and how 00792 // my code is being used. 00793 // * The original code comes with absolutely no warranty and no guarantee is 00794 // made that the code is bug-free. Caveat emptor. 00795 // 00796 // Dave Eberly, eberly@magic-software.com, www.magic-software.com 00798 //FILE: minbox2.h 00799 double Area (int N, Point2* pt, double angle); 00800 void MinimalBoxForAngle (int N, Point2* pt, double angle, OBBox2& box); 00801 OBBox2 MinimalBox2 (int N, Point2* pt); 00802 // Functions to find minimal area rectangle that surrounds a set of points. 00803 00804 #if 1 00805 //FILE: minbox3.h 00806 void MatrixToAngleAxis( double** R, double& angle, double axis[3] ); 00807 void AngleAxisToMatrix( double angle, double axis[3], double R[3][3] ); 00808 double Volume( int N, Point3* pt, double angle[3] ); 00809 void MinimalBoxForAngles( int N, Point3* pt, double angle[3], OBBox3& box ); 00810 void GetInterval( double A[3], double D[3], double& tmin, double& tmax ); 00811 void Combine( double result[3], double A[3], double t, double D[3] ); 00812 double MinimizeOnInterval( int N, Point3* pt, double A[3], double D[3] ); 00813 double MinimizeOnLattice( int N, Point3* pt, double A[3], int layers, 00814 double thickness ); 00815 void InitialGuess( int N, Point3* pt, double angle[3] ); 00816 OBBox3 MinimalBox3( int N, Point3* pt ); 00817 // Functions to find minimal volume box that surrounds a set of points. 00818 #endif 00819 00820 double Abs (double x); 00821 double ACos (double x); 00822 double ATan2 (double y, double x); 00823 double Cos (double x); 00824 double Sign (double x); 00825 double Sin (double x); 00826 double Sqrt (double x); 00827 double UnitRandom (); 00828 double Dot (const Point2& p, const Point2& q); 00829 double Length (const Point2& p); 00830 CubitBoolean Unitize (Point2& p ); 00831 double Dot (const Point3& p, const Point3& q); 00832 Point3 Cross (const Point3& p, const Point3& q); 00833 double Length (const Point3& p); 00834 CubitBoolean Unitize (Point3& p ); 00835 // Supporting code for triangle calculations 00836 00837 double MinLineSegmentLineSegment (const Line3& seg0, const Line3& seg1, double& s, double& t); 00838 00839 //get intersection between bounding box and plane 00840 int get_plane_bbox_intersections( double box_min[3], 00841 double box_max[3], 00842 double pln_orig[3], 00843 double pln_norm[3], 00844 double int_array[6][3] ); 00845 // FILE: pt3tri3.cpp 00846 00847 00848 // FILE: lin3tri3.cpp 00849 double MinLineSegmentTriangle (const Line3& seg, const Triangle3& tri, double& r, double& s, double& t); 00850 // Code to support distance between triangles 00851 00852 //FILE: triasect.cpp 00853 AgtLine EdgeToLine (Point2* v0, Point2* v1); 00854 void TriangleLines (Triangle* T, AgtLine line[3]); 00855 AgtTriList* SplitAndDecompose (Triangle* T, AgtLine* line); 00856 AgtTriList* Intersection (Triangle* T0, Triangle* T1); 00857 double AreaTriangle (Triangle* T); 00858 double Area (AgtTriList* list); 00859 double Area (Triangle &tri1, Triangle &tri2 ); 00860 // Code to support area of overlap of two triangles 00861 }; 00862 00863 #if 1 00864 // FILE: eigen.h 00865 class mgcEigen 00866 { 00867 public: 00868 mgcEigen (int _size); 00869 ~mgcEigen (); 00870 00871 mgcEigen& Matrix (float** inmat); 00872 00873 private: 00874 int size; 00875 float** mat; 00876 float* diag; 00877 float* subd; 00878 00879 // Householder reduction to tridiagonal form 00880 void Tridiagonal2 (float** pmat, float* pdiag, float* psubd); 00881 void Tridiagonal3 (float** pmat, float* pdiag, float* psubd); 00882 void Tridiagonal4 (float** pmat, float* pdiag, float* psubd); 00883 void TridiagonalN (int n, float** mat, float* diag, float* subd); 00884 00885 // QL algorithm with implicit shifting, applies to tridiagonal matrices 00886 void QLAlgorithm (int n, float* pdiag, float* psubd, float** pmat); 00887 00888 // sort eigenvalues from largest to smallest 00889 void DecreasingSort (int n, float* eigval, float** eigvec); 00890 00891 // sort eigenvalues from smallest to largest 00892 void IncreasingSort (int n, float* eigval, float** eigvec); 00893 00894 // error handling 00895 public: 00896 static int verbose1; 00897 static unsigned error; 00898 static void Report (std::ostream& ostr); 00899 private: 00900 static const unsigned invalid_size; 00901 static const unsigned allocation_failed; 00902 static const unsigned ql_exceeded; 00903 static const char* message[3]; 00904 static int Number (unsigned single_error); 00905 static void Report (unsigned single_error); 00906 }; 00907 00908 // FILE: eigen.h 00909 class mgcEigenD 00910 { 00911 public: 00912 mgcEigenD (int _size); 00913 ~mgcEigenD (); 00914 00915 // set the matrix for eigensolving 00916 double& Matrix (int row, int col) { return mat[row][col]; } 00917 mgcEigenD& Matrix (double** inmat); 00918 00919 // get the results of eigensolving 00920 double Eigenvector (int row, int col) { return mat[row][col]; } 00921 const double** Eigenvector () { return (const double**) mat; } 00922 00923 void EigenStuff3 (); // uses TriDiagonal3 00924 00925 private: 00926 int size; 00927 double** mat; 00928 double* diag; 00929 double* subd; 00930 00931 // Householder reduction to tridiagonal form 00932 void Tridiagonal2 (double** mat, double* diag, double* subd); 00933 void Tridiagonal3 (double** mat, double* diag, double* subd); 00934 void Tridiagonal4 (double** mat, double* diag, double* subd); 00935 void TridiagonalN (int n, double** mat, double* diag, double* subd); 00936 00937 // QL algorithm with implicit shifting, applies to tridiagonal matrices 00938 void QLAlgorithm (int n, double* diag, double* subd, double** mat); 00939 00940 // sort eigenvalues from largest to smallest 00941 void DecreasingSort (int n, double* eigval, double** eigvec); 00942 00943 // sort eigenvalues from smallest to largest 00944 void IncreasingSort (int n, double* eigval, double** eigvec); 00945 00946 // error handling 00947 public: 00948 static int verbose1; 00949 static unsigned error; 00950 static void Report (std::ostream& ostr); 00951 private: 00952 static const unsigned invalid_size; 00953 static const unsigned allocation_failed; 00954 static const unsigned ql_exceeded; 00955 static const char* message[3]; 00956 static int Number (unsigned single_error); 00957 static void Report (unsigned single_error); 00958 }; 00959 #endif 00960 00962 //--------------------------------------------------------------------------- 00963 // Wrapped math functions 00964 //--------------------------------------------------------------------------- 00965 inline double AnalyticGeometryTool::Abs (double x) 00966 { 00967 return double(fabs(x)); 00968 } 00969 00970 inline double AnalyticGeometryTool::ATan2 (double y, double x) 00971 { 00972 return double(atan2(y,x)); 00973 } 00974 00975 inline double AnalyticGeometryTool::Sqrt (double x) 00976 { 00977 return double(sqrt(x)); 00978 } 00979 00980 inline double AnalyticGeometryTool::UnitRandom () 00981 { 00982 return double(rand())/double(RAND_MAX); 00983 } 00984 00985 //--------------------------------------------------------------------------- 00986 // Points in 2D 00987 //--------------------------------------------------------------------------- 00988 00989 inline double AnalyticGeometryTool::Dot (const Point3& p, const Point3& q) 00990 { 00991 return double(p.x*q.x + p.y*q.y + p.z*q.z); 00992 } 00993 00994 00995 inline double AnalyticGeometryTool::set_epsilon( double new_epsilon ) 00996 { 00997 double old_epsilon = agtEpsilon; 00998 agtEpsilon = new_epsilon; 00999 return old_epsilon; 01000 } 01001 01002 inline CubitBoolean AnalyticGeometryTool::dbl_eq(double val_1,double val_2) 01003 { 01004 CubitBoolean result; 01005 if (fabs(val_1 - val_2) < agtEpsilon) 01006 result = CUBIT_TRUE; 01007 else 01008 result = CUBIT_FALSE; 01009 return result; 01010 } 01011 01012 #endif 01013
