cgma
CubitDefines.h File Reference
#include <stdio.h>
#include <stdlib.h>
#include <limits.h>
#include <math.h>
#include <sys/types.h>
#include <assert.h>
#include "CGMUtilConfigure.h"
#include <float.h>
Defines
#define CUBIT_TRUE   1;
#define CUBIT_FALSE   0;
#define CUBIT_PI   3.1415926535897932384626
#define DEGREES_TO_RADIANS(angle)   ( (angle) / 180.0 * CUBIT_PI )
#define RADIANS_TO_DEGREES(angle)   ( 180.0 * (angle) / CUBIT_PI )
#define CUBIT_INT_MAX   INT_MAX
#define CUBIT_INT_MIN   INT_MIN
#define CUBIT_DBL_MIN   1.0E-30
#define CUBIT_DBL_MAX   1.0E30
#define CUBIT_MIN(a, b)   ( (a) < (b) ? (a) : (b) )
#define CUBIT_MAX(a, b)   ( (a) > (b) ? (a) : (b) )
#define CUBIT_MIN_4(a, b, c, d)
#define CUBIT_MAX_4(a, b, c, d)
Typedefs
typedef unsigned int Bit
typedef unsigned short IttyBit
typedef unsigned char cBit
typedef char CubitBoolean
Enumerations
enum  CubitStatus { CUBIT_FAILURE = 0, CUBIT_SUCCESS = 1 }
enum  CubitSense { CUBIT_UNKNOWN = -1, CUBIT_FORWARD = 0, CUBIT_REVERSED = 1 }
enum  CubitPointContainment {
  CUBIT_PNT_UNKNOWN = -1, CUBIT_PNT_OUTSIDE = 0, CUBIT_PNT_OFF = 0, CUBIT_PNT_INSIDE = 1,
  CUBIT_PNT_ON = 1, CUBIT_PNT_BOUNDARY = 2
enum  FirmnessType { LIMP, SOFT, FIRM, HARD }
enum  SizeIntervalType { NOT_SET = LIMP, CALCULATED = SOFT, USER_SET = HARD }
enum  CubitEntityRelation { CUBIT_RELATION_NONE = -1, CUBIT_RELATION_PARENT = 0, CUBIT_RELATION_CHILD = 1 }
enum  CubitAssocDataType {
  CUBIT_ASSOC_NULL = 0, CUBIT_ASSOC_GEOM_REFENTITY = 1, CUBIT_ASSOC_BC_BLOCK = 2, CUBIT_ASSOC_BC_NSET = 3,
  CUBIT_ASSOC_BC_SSET = 4
enum  ObserverType { MODEL_OBSERVER, DRAWING_OBSERVER, GUI_OBSERVER }
enum  CubitFacetboolOp { CUBIT_FB_UNION, CUBIT_FB_INTERSECTION, CUBIT_FB_SUBTRACTION }
Variables
static int const INVALID_ENTITY_ID = -1
Define Documentation
Definition at line 211 of file CubitDefines.h.
Definition at line 197 of file CubitDefines.h.
Definition at line 73 of file CubitDefines.h.
Definition at line 164 of file CubitDefines.h.
Definition at line 180 of file CubitDefines.h.
#define CUBIT_MAX (   a,
Definition at line 216 of file CubitDefines.h.
#define CUBIT_MAX_4 (   a,
  b,
  c,
Value:
(( (a) > (b) ? (a) : (b) ) > \
                                          ( (c) > (d) ? (c) : (d) ) ? \
                                          ( (a) > (b) ? (a) : (b) ) : \
                                          ( (c) > (d) ? (c) : (d) ))
Definition at line 223 of file CubitDefines.h.
#define CUBIT_MIN (   a,
Definition at line 215 of file CubitDefines.h.
#define CUBIT_MIN_4 (   a,
  b,
  c,
Value:
(( (a) < (b) ? (a) : (b) ) < \
                                          ( (c) < (d) ? (c) : (d) ) ? \
                                          ( (a) < (b) ? (a) : (b) ) : \
                                          ( (c) < (d) ? (c) : (d) ))
Definition at line 218 of file CubitDefines.h.
Definition at line 150 of file CubitDefines.h.
Definition at line 72 of file CubitDefines.h.
#define DEGREES_TO_RADIANS (   angle)    ( (angle) / 180.0 * CUBIT_PI )
Definition at line 153 of file CubitDefines.h.
#define RADIANS_TO_DEGREES (   angle)    ( 180.0 * (angle) / CUBIT_PI )
Definition at line 154 of file CubitDefines.h.
Typedef Documentation
Definition at line 59 of file CubitDefines.h.
Definition at line 61 of file CubitDefines.h.
Definition at line 71 of file CubitDefines.h.
Definition at line 60 of file CubitDefines.h.
Enumeration Type Documentation
Enumerator:
CUBIT_ASSOC_NULL
CUBIT_ASSOC_BC_NSET
CUBIT_ASSOC_BC_SSET
Definition at line 110 of file CubitDefines.h.
Enumerator:
CUBIT_RELATION_NONE
Definition at line 101 of file CubitDefines.h.
Enumerator:
CUBIT_FB_UNION
Definition at line 131 of file CubitDefines.h.
Enumerator:
CUBIT_PNT_UNKNOWN
CUBIT_PNT_OUTSIDE
CUBIT_PNT_OFF
CUBIT_PNT_INSIDE
CUBIT_PNT_ON
CUBIT_PNT_BOUNDARY
Definition at line 86 of file CubitDefines.h.
enum CubitSense
Enumerator:
CUBIT_UNKNOWN
CUBIT_FORWARD
CUBIT_REVERSED
Definition at line 80 of file CubitDefines.h.
Enumerator:
CUBIT_FAILURE
CUBIT_SUCCESS
Definition at line 77 of file CubitDefines.h.
Enumerator:
LIMP
SOFT
FIRM
HARD
Definition at line 90 of file CubitDefines.h.
Enumerator:
MODEL_OBSERVER
DRAWING_OBSERVER
GUI_OBSERVER
Definition at line 119 of file CubitDefines.h.
    MODEL_OBSERVER,
      /* big brother observer */
    DRAWING_OBSERVER,
      /* any observer concerned with drawing */
    GUI_OBSERVER
      /* a gui-type observer */
Enumerator:
NOT_SET
CALCULATED
USER_SET
Definition at line 97 of file CubitDefines.h.
Variable Documentation
int const INVALID_ENTITY_ID = -1 [static]
Definition at line 63 of file CubitDefines.h.
