cgma
AppUtil.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : AppUtil.hpp
00003 //
00004 // Purpose       : This file represents the Cubit application itself.
00005 //
00006 // Special Notes :
00007 //
00008 // Creator       : Darryl Melander
00009 //
00010 // Date          : 06/08/98
00011 //
00012 // Owner         : Darryl Melander
00013 //-------------------------------------------------------------------------
00014
00015 #ifndef APP_UTIL_HPP
00016 #define APP_UTIL_HPP
00017
00018 #include "CubitDefines.h"
00019 #include "CubitString.hpp"
00020 #include "CGMUtilConfigure.h"
00021 #include "CubitEventDispatcher.hpp"
00022 #ifdef BUILD_WITH_CONCURRENT_SUPPORT
00023 #include "CubitConcurrentApi.h"
00024 #endif
00025 #include <time.h>
00026
00027 #ifndef _WIN32
00028 #include <sys/resource.h>
00029 #endif
00030
00031 class ProgressTool;
00032 class CubitString;
00033 class CubitThreadPool;
00034
00035 class CUBIT_UTIL_EXPORT AppUtil
00036 {
00037 public:
00038    static AppUtil* instance_no_create();
00039
00040    static AppUtil* instance();
00041      //- Access to the application object
00042
00043    static void delete_instance();
00044
00045    void report_resource_usage() const;
00046      //- Prints out information about the session
00047
00048    bool get_terminal_size( int& rows, int& cols );
00049    //- Get the size of the terminal, if known.
00050
00051 #ifdef CAT
00052    int days_to_expire(int year, int month, int day) const;
00053      //- Returns number of days until the app expires
00054 #endif
00055    ~AppUtil();
00056
00057
00058   // Signal handing code.  The signal handler provided by
00059   // AppUtil sets the flag cubit_intr to CUBIT_TRUE when
00060   // an interrupt (SIGINT) is detected.  See the comments
00061   // with the declaration of cubit_intr in AppUtil.cpp
00062   // for more information.
00063
00064   // returns whether the interupt flag has been set
00065   CubitBoolean interrupt();
00066   void set_interrupt(CubitBoolean);
00067
00068   // clears the interrupt flag
00069   void clear_interrupt();
00070
00071   static CubitBoolean catch_interrupt() { return catching_sigint_; }
00072   //- Check if the signal handler provided in AppUtil
00073   //- is being used.
00074
00075   static void catch_interrupt( CubitBoolean yesno );
00076   //- yesno:
00077   //-  CUBIT_TRUE:  Set signal handler for SIGINT to the
00078   //-               handler provided by AppUtil.
00079   //-  CUBIT_FALSE: Set the signal hander for SIGINT to
00080   //-               the system default.
00081
00082   void startup();
00083    //-  Contains startup code for cubit
00084
00085   int shutdown();
00086    //- Contains shutdown code for cubit
00087
00088   void apputil_getrusage(struct rusage &r_usage) const;
00089     //- fill the r_usage with data from getrusage; implements special code to
00090     //- find memory usage when you don't get that from the system call getrusage
00091
00092    void set_terminal_size( int rows, int cols );
00093    //- This function sets the values returned from
00094    //- get_terminal_size().  It has no effect on
00095    //- the actual terminal size.
00096
00097   ProgressTool *progress_tool();
00098   void progress_tool(ProgressTool* pTool);
00099    // pass in a pointer to a progress tool  - the lifetime of the tool will be
00100    // controlled by AppUtil
00101
00106   CubitString get_app_dir();
00107     // get the cubit dir variable
00108
00109   static void initialize_settings();
00110     // initialize settings
00111
00112   CubitEventDispatcher& event_dispatcher() { return mEventDispatcher; }
00113
00115   template <class T>
00116   void send_event(const T& event)
00117   {
00118     CubitObservable* obs = dynamic_cast<CubitObservable*>(event.get_entity());
00119     this->send_event(obs, event);
00120   }
00121
00122   bool concurrent_enabled()
00123   {
00124     return concurrentSupport;
00125   }
00126
00127   CubitThreadPool* thread_pool();
00128
00129 private:
00130
00131   void send_event(CubitObservable* obs, const CubitEvent& event);
00132
00133   static CubitBoolean catching_sigint_;
00134    //- Signal handler registered for SIGINT?
00135
00136    int term_width, term_height;
00137
00138    static AppUtil* instance_;
00139    CubitBoolean mAppStarted;
00140
00141   CubitString cubitDir;
00142     //- directory of the cubit executable
00143
00144    ProgressTool *mProgressTool;
00145
00146    CubitEventDispatcher mEventDispatcher;
00147
00148    clock_t mInterruptThrottle;
00149
00150    CubitBoolean concurrentSupport;
00151 #ifdef BUILD_WITH_CONCURRENT_SUPPORT
00152    CubitConcurrent *mConcurrentInstance;
00153 #endif
00154
00155    CubitThreadPool* mThreadPool;
00156
00157    AppUtil();
00158 };
00159
00160 // returns the directory where cubit binaries reside,
00161 // or more correctly, the path of the library/executable that contains this AppUtil code.
00162 inline CubitString AppUtil::get_app_dir()
00163 {
00164   return cubitDir;
00165 }
00166
00167 #endif
00168
