cgma
ArrayBasedContainer.hpp
00001 //- Class: ArrayBasedContainer
00002 //- Description: Base class for container classed implemented as arrays.
00003 //-              Contains 'void*' entities. This class allows copying
00004 //-              between container types.
00005 //- Assumptions: Containers derived from this are implemented as arrays.
00006 //-
00007 //- Owner: Paul Kinney
00008 //- Checked by:
00009 //- Version: $Id:
00010
00011 #ifndef ARRAYBASEDCONTAINER_HPP
00012 #define ARRAYBASEDCONTAINER_HPP
00013
00014 #include "CubitDefines.h"
00015 #include "MemoryManager.hpp"
00016 #include "CGMUtilConfigure.h"
00017 #include <cstring>
00018
00019 const int INCREMENT = 8; //- Default list size increment
00020
00021 class CUBIT_UTIL_EXPORT ArrayBasedContainer
00022 {
00023
00024 public:
00025
00026     ArrayBasedContainer (int size);
00027     //- Constructor: Create a list with initial size {size}. The list
00028     //- will be grown by {size} each time it is filled. Memory for the
00029     //- list is not allocated until the first element is inserted using
00030     //- {insertLink}.
00031     //- If {size} is zero, the default increment ({INCREMENT}) will be used
00032     //- From an efficiency standpoint, it is very important that the
00033     //- increment be set large enough to reduce the number of list
00034     //- growths, but small enough to not waste memory.
00035     //- It is more efficient to sligthly overestimate the size than
00036     //- to underestimate the size.
00037
00038     ArrayBasedContainer(const ArrayBasedContainer& copy_from);
00039     //- Copy Constructor
00040
00041     virtual ~ArrayBasedContainer();
00042     //- Destructor: Free all resources used by this list.
00043
00044     int  size() const;      //- Return the number of items stored in the list.
00045
00046     void clean_out();
00047     //- Delete all elements in the list, reset the pointer to zero.
00048     //- Does not release memory already allocated for the list. This
00049     //- call is more efficient creating a new list repeatadly within
00050     //- a loop.
00051
00052     void shrink(int k);
00053     //- itemCount -= k;  Doesn't change array elements.
00054
00055     ArrayBasedContainer& operator=(const ArrayBasedContainer&);
00056     //- Create a copy of a list.
00057
00058     ArrayBasedContainer& operator+=(const ArrayBasedContainer&);
00059     //- Append one list to the end of the other list.
00060
00061     ArrayBasedContainer& operator-=(const ArrayBasedContainer&);
00062     //- Subtract one container from the other. Preserves order of first container.
00063
00064     virtual void compress();
00065     //- remove all the NULLs, preserve order
00066
00067     static unsigned int current_allocated_memory();
00068     static unsigned int maximum_allocated_memory();
00069
00070 protected:
00071
00072   void **listArray;            //- array of items in the list
00073   int  itemCount;              //- number of items in list
00074   int  listLength;             //- size of {listArray}
00075   Bit  poolAllocated : 1;
00076   //- TRUE if allocated from special memory pool, FALSE if normal allocation
00077   Bit  listIsSorted : 1;       //- Used in SDLList
00078   Bit  listIncrement : 30;     //- amount by which to grow list
00079   //- This is limited to 1.07e9
00080
00081   void lengthen_list();
00082
00083 private:
00084   static unsigned int currentAllocatedMemory;
00085   static unsigned int maxAllocatedMemory;
00086 };
00087
00088 inline void ArrayBasedContainer::shrink(int k)
00089 {
00090   if (k > 0)
00091   {
00092     if (itemCount >= k)
00093       itemCount -= k;
00094     else
00095       itemCount = 0;
00096   }
00097 }
00098
00099 inline int ArrayBasedContainer::size() const { return itemCount; }
00100
00101 inline void ArrayBasedContainer::clean_out ()
00102 {
00103     itemCount = 0;
00104 }
00105
00106
00107 // This class is used internally by ArrayBasedContainer to maintain
00108 // a large pool of memory of size {INCREMENT} (The default size for
00109 // ArrayBasedContainers). If a list of size {INCREMENT} is constructed,
00110 // the memory is allocated from this pool rather than allocating the memory
00111 // from the system global new routine.
00112 class ArrayMemory
00113 {
00114   public:
00115     ArrayMemory() { memset(mem, 0, sizeof(mem)); }
00116
00117     SetDynamicMemoryAllocation(memoryManager)
00118     //- overloaded new and delete operators
00119
00120   private:
00121
00122     static MemoryManager  memoryManager;
00123
00124     void*  mem[INCREMENT];
00125 };
00126
00127 #endif //- ARRAYBASEDCONTAINER_HPP
00128
