cgma
AutoMidsurfaceTool.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : AutoMidsurfaceTool.cpp
00003 //
00004 // Purpose       :
00005 //   Create a midsurface of a body/volume given a thickness range. If no thickness range is given
00006 //   then make a educated guess at the thickness (using something like Volume/Surface Area).
00007 //
00008 //   Create Midsurface Volume <id_list> auto [<lower_tol> <upper_tol>]
00009 //
00010 // Creator       : Sam Showman
00011 //
00012 // Creation Date : 05/10/2008
00013 //-------------------------------------------------------------------------
00014 #ifndef AutoMidsurfaceTool_HPP
00015 #define AutoMidsurfaceTool_HPP
00016
00017 #include "CubitDefines.h"
00018 #include "CubitVector.hpp"
00019 #include "CubitPlane.hpp"
00020
00021 class GeometryModifyEngine;
00022 class Body;
00023 class RefFace;
00024 class BodySM;
00025 class Surface;
00026 class Curve;
00027 class RefEdge;
00028 template <class X> class DLIList;
00029
00030 class AutoMidsurfaceTool
00031 {
00032 public:
00033
00034     AutoMidsurfaceTool();
00035     ~AutoMidsurfaceTool(){}
00036
00037     CubitStatus midsurface(
00038     DLIList<Body*> &body_list_in,
00039     DLIList<BodySM*> &body_list_out,
00040     DLIList<Body*> &old_bodies_midsurfaced,
00041     DLIList<double> &thickness_out,
00042     double lower_tol = CUBIT_DBL_MAX,
00043     double upper_tol = CUBIT_DBL_MAX,
00044     CubitBoolean delete_midsurfaced = CUBIT_FALSE,
00045     CubitBoolean preview = CUBIT_FALSE);
00046     //- automatically midsurfaces a volume based on surface pairs and surface area
00047     //- body_list_in - list of bodies to midsurface
00048     //- body_list_out - result bodies
00049     //- lower_tol - lower tolerance
00050     //- upper_tol - upper tolerance
00051     //- delete_midsurfaced - delete the midsurfaced solid
00052     //- transp_midsurfaced - make the midsurfaced solid transparent
00053     //- preview - preview the results
00054
00055 private:
00056     CubitBoolean curve_in_surface(Curve *curve_in, Surface *surf_in);
00057
00058     CubitStatus get_planar_mid_surface(
00059         RefFace* ref_face1,
00060         RefFace* ref_face2,
00061         BodySM* body_sm_to_trim_to,
00062         BodySM*& midsurface_body_sm,
00063         GeometryModifyEngine *gme_ptr );
00064
00065     CubitStatus find_offset_pair_patches(
00066         DLIList<RefFace*> pairs_list_0,
00067         DLIList<RefFace*> pairs_list_1,
00068         DLIList<RefFace*>& red_faces,
00069         DLIList<RefFace*>& yellow_faces,
00070         DLIList<double>& offset_distances);
00071
00072     CubitStatus random_loc_on_surface( Surface* face_ptr, CubitVector &loc );
00073
00074     CubitBoolean check_surf_pairs(double min_thick, double max_thick,
00075         DLIList<RefFace*> check_list, Body* body_in );
00076 };
00077
00078 #endif
00079
