cgma
BoundaryConstrainTool.hpp
00001 //-Class:       BoundaryContstrainTool
00002 //-Description: recover edges from a triangle mesh.  Currently 2D meshes only
00003 //-Owner:       Steve Owen
00004 //-Altered by: Jit Ken Tan (07/08/02)
00005 //-Checked by:
00006
00007 #ifndef BOUNDARY_CONSTRAIN_TOOL_HPP
00008 #define BOUNDARY_CONSTRAIN_TOOL_HPP
00009
00010 #include "DLIList.hpp"
00011 class CubitVector;
00012
00013 typedef enum SwapStatus { SWAP_FAILURE, SWAP_SUCCESS, SWAP_INVALID } SwapStatus;
00014 typedef enum IntersectionType { AT_BEGIN, AT_EDGE, AT_MID, AT_END, NO_ISECT } IntersectionType;
00015
00016 template <class SURF, class TRI, class EDGE, class NODE, class TRICHILD> class BoundaryConstrainTool
00017 {
00018 private:
00019   DLIList <TRI *> *facetList;
00020   SURF *refFacePtr;
00021   double zeroTol;
00022   DLIList<EDGE *> edgeCrossQueue;
00023
00024   CubitStatus get_crossing_edges( CubitVector &edge_vec,
00025                                   NODE *n0_ptr,
00026                                   NODE *n1_ptr);
00027    //- generate the initial list of all edges that cross the edge_vec
00028    //- between n0 and n1
00029
00030   IntersectionType intersect_from_node(CubitVector &edge_vec,
00031                                        NODE *n0_ptr,
00032                                        TRI *&tri_ptr,
00033                                        EDGE *&edge_ptr,
00034                                        NODE *&node_ptr );
00035    //- determine next intersection assuming start from n0
00036
00037   IntersectionType intersect_from_edge( CubitVector &edge_vec,
00038                                         NODE *n0_ptr,
00039                                         NODE *n1_ptr,
00040                                         TRI *&tri_ptr,
00041                                         EDGE *&edge_ptr,
00042                                         NODE *&node_ptr );
00043    //- determine next intersection assuming start from edge_ptr
00044
00045   CubitStatus node_at_mid( CubitVector &edge_vec,
00046                            TRI *tri_ptr,
00047                            NODE *node_ptr );
00048    //- he vector hit a node on its way to the n1
00049
00050   SwapStatus swap_edge( EDGE *&edge_ptr );
00051    //- attempt to swap a single edge.  Check for valid swap
00052    //- before doing so
00053
00054   CubitStatus edge_intersected( CubitVector &edge_vec,
00055                                 EDGE *edge_ptr,
00056                                 NODE *n0_ptr,
00057                                 NODE *n1_ptr );
00058    //- check to see if the edge we just generated crosses the
00059    //- edge_vec.  If so, then add it to the queue
00060
00061 public:
00062   BoundaryConstrainTool();
00063   BoundaryConstrainTool(SURF *ref_face_ptr);
00064   ~BoundaryConstrainTool();
00065     //- constructor and desructor
00066
00067   CubitStatus recover_edge(NODE *n0_ptr,NODE *n1_ptr,
00068                            EDGE *&recovered_edge_ptr,
00069                DLIList <TRI *> *facet_list);
00070
00071     //- flip edges in the triangulation to recover the edge between
00072     //- n0_ptr and n1_ptr. Assumes 2D (x-y-0)
00073 };
00074
00075 #include "BoundaryConstrainTool.cpp"
00076
00077 #endif
00078
