cgma
CoEdge.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : CoEdge.hpp
00003 //
00004 // Purpose       :
00005 //
00006 // Special Notes :
00007 //
00008 // Creator       : Xuechen Liu
00009 //
00010 // Creation Date : 08/02/96
00011 //
00012 // Owner         : Malcolm J. Panthaki
00013 //-------------------------------------------------------------------------
00014
00015 #ifndef COEDGE_HPP
00016 #define COEDGE_HPP
00017
00018 // ********** BEGIN STANDARD INCLUDES      **********
00019 // ********** END STANDARD INCLUDES        **********
00020
00021 // ********** BEGIN CUBIT INCLUDES         **********
00022 #include "CubitDefines.h"
00023 #include "SenseEntity.hpp"
00024 #include "ToolDataUser.hpp"
00025 // ********** END CUBIT INCLUDES           **********
00026
00027 // ********** BEGIN FORWARD DECLARATIONS   **********
00028 class RefEdge;
00029 class RefFace;
00030 class Loop;
00031 class CoEdgeSM;
00032 // ********** END FORWARD DECLARATIONS     **********
00033
00034 class CUBIT_GEOM_EXPORT  CoEdge : public SenseEntity,
00035                public ToolDataUser
00036 {
00037    public :
00038
00039       CoEdge() ;
00040       //- The default constructor
00041
00042       virtual ~CoEdge() ;
00043       //- The destructor
00044
00045       CoEdge(RefEdge* edgePtr, CubitSense sense) ;
00046       //I edgePtr
00047       //I- The pointer to a edge.
00048       //I sense
00049       //I- The sense of this CoEdge.
00050       //- The constructor with a pointer to a edge and the sense of this
00051       //- CoEdge.
00052
00053       CoEdge(CoEdgeSM* OSMEPtr);
00054
00055       DagType dag_type() const { return DagType::co_edge_type(); }
00056
00057       RefEdge* get_ref_edge_ptr() ;
00058       //R RefEdge*
00059       //R- A pointer to the RefEdge which the current sense
00060       //R- entity is associated with.
00061       //- This function returns a pointer to the RefEdge which
00062       //- the current CoEdge is associated with.
00063
00064       RefFace* get_ref_face();
00065       //R RefFace*
00066       //R- A pointer to the RefFace on which this co-edge is a part of.
00067
00068       Loop* get_loop_ptr();
00069             //R Loop*
00070             //R- A pointer to the parent Loop of this CoEdge.
00071
00072       virtual void switch_child_notify(TopologyEntity const* newChild,
00073                                        TopologyEntity const* oldChild) ;
00074       //R void
00075       //I newChild
00076       //I- A pointer to the new child
00077       //I oldChild
00078       //I- A pointer to the old child
00079       //- This function is called after a child of a TopologyEntity is
00080       //- switched. The sense of a CoEdge may change if one of its
00081       //- RefEdges changes. This function takes care of that. If the sense
00082       //- of the RefEdges that were switched is same, nothing is done. If
00083       //- the RefEdges are of opposite sense, the sense of this object is
00084       //- switched, i.e. if it was FORWARD, it is made REVERSED, and vice
00085       //- versa.
00086
00087       CoEdgeSM* get_co_edge_sm_ptr() const;
00088
00089       CubitStatus set_co_edge_sm_ptr(CoEdgeSM*);
00090
00091       CubitBoolean about_spatially_equal( CoEdge* other_coedge,
00092                                           CubitSense relative_sense,
00093                                           double tolerance_factor = 1.0,
00094                                           CubitBoolean notify_refEntity =
00095                                             CUBIT_FALSE );
00096
00097       RefVertex* start_vertex();
00098
00099       RefVertex* end_vertex();
00100
00101    protected:
00102
00103    private:
00104     CoEdge( const CoEdge& );
00105     void operator=( const CoEdge&);
00106 } ;
00107
00108
00109 // ********** BEGIN INLINE FUNCTIONS       **********
00110 // ********** END INLINE FUNCTIONS         **********
00111
00112 // ********** BEGIN FRIEND FUNCTIONS       **********
00113 // ********** END FRIEND FUNCTIONS         **********
00114
00115 // ********** BEGIN EXTERN FUNCTIONS       **********
00116 // ********** END EXTERN FUNCTIONS         **********
00117
00118 #endif
00119
