cgma
CompSurfFacets.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : CompSurfFacets.hpp
00003 //
00004 // Purpose       : Encapsulate facet date used to speed up composite surfaces
00005 //
00006 // Special Notes :
00007 //
00008 // Creator       : Jason Kraftcheck
00009 //
00010 // Creation Date : 03/20/03
00011 //-------------------------------------------------------------------------
00012
00013 #ifndef COMP_SURF_FACETS_HPP
00014 #define COMP_SURF_FACETS_HPP
00015
00016 #include "CubitVector.hpp"
00017 #include <vector>
00018 #include <map>
00019 #include "DLIList.hpp"
00020
00021 class Surface;
00022 class GMem;
00023 class CubitFacet;
00024 class FacetEvalTool;
00025
00026
00027 template <class X> class DLIList;
00028
00029 class CompSurfFacets
00030 {
00031   typedef std::vector<CubitVector> PointList;
00032   typedef std::vector<int> IntegerList;
00033   typedef std::vector<Surface*> SurfPtrList;
00034
00035   public:
00036
00037     CompSurfFacets();
00038     ~CompSurfFacets();
00039
00040     CubitStatus setup( const SurfPtrList& surface_data );
00041
00042     int closest_index( const CubitVector& from_point,
00043                        CubitVector* point_on_facet = 0 ) const;
00044
00045     int closest_index( const CubitVector& from_point,
00046                        DLIList<int>& index_list,
00047                        CubitVector* point_on_facet = 0 );
00048
00049     void debug_draw_facets() const;
00050
00051     void graphics( double tolerance, GMem& gmem );
00052     void set_ignore_flag(DLIList<int> &indicies, int flag);
00053     int get_ignore_flag(int index);
00054
00055   protected:
00056
00057     void closest_tri_point( IntegerList::const_iterator facet,
00058                             const CubitVector& from_pt,
00059                             CubitVector& result_pt,
00060                             bool& interior ) const;
00061
00062     void consolidate_points( double tolerance );
00063     void consolidate_few_points(double tolerance);
00064     void consolidate_many_points(double tolerance);
00065
00066   private:
00067
00068     bool pointsConsolidated;
00069     IntegerList ignoreFlags;
00070     DLIList<CubitFacet*> facetsToIgnore;
00071
00072     std::map<CubitFacet*, int> facetToSurfaceMap;
00073     DLIList<CubitFacet*> allFacets;
00074     FacetEvalTool *facetEvalTool;
00075     DLIList<int> numFacetsPerSurface;
00076
00077 };
00078
00079 #endif
00080
00081
