cgma
CompositeTool.hpp
00001 #ifndef COMPOSITE_TOOL_HPP
00002 #define COMPOSITE_TOOL_HPP
00003
00004 #include "CubitDefines.h"
00005 #include "BasicTopologyEntity.hpp"
00006 #include "GeometryEntity.hpp"
00007
00008 #include "CompositeSurface.hpp"
00009 #include "CompositeCurve.hpp"
00010 #include "CompositePoint.hpp"
00011
00012 class RefEdge;
00013 class RefFace;
00014 class RefEdge;
00015 class RefFace;
00016 template <class X> class DLIList;
00017 class Loop;
00018
00019 class CompositeTool
00020 {
00021   friend class PartitionTool;
00022   public:
00023
00024     static CompositeTool* instance();
00025
00026     virtual ~CompositeTool();
00027
00028     virtual RefEdge*   composite( DLIList<RefEdge*>& list,
00029                                   RefVertex* keep_vertex = NULL,
00030                                   RefEdge* survivor = NULL );
00031     virtual RefFace*   composite( DLIList<RefFace*>& list,
00032                                   RefFace* survivor = NULL );
00033     virtual RefVolume* composite( DLIList<RefVolume*>& list,
00034                                   Body** composite_body = 0 );
00035     virtual Body*      composite( DLIList<Body*>& list );
00036     //R- the composite, or NULL if error
00037     //I list
00038     //I- The list of entities to composite
00039     //I keep_vertex
00040     //I- vertex to keep if list forms a closed loop of curves
00041     //I composite_body
00042     //I- If non-null, a composite body will be created if necessary,
00043     //I- and composite_body will be set to point to the new body.
00044     //- create a composite
00045     //-
00046     //- NOTE: The 'survivor' argument is provided to meet
00047     //- special requirenments in supporting pre-version-8 save
00048     //- files.  Once support for pre-version-8 save files has
00049     //- been dropped, this argument will be removed.
00050
00051
00052
00053     virtual CubitStatus uncomposite( RefEdge* composite_edge,
00054                                      DLIList<RefEdge*>* restored_edges = NULL );
00055     virtual CubitStatus uncomposite( RefFace* composite_face,
00056                                      DLIList<RefFace*>* restored_faces = NULL,
00057                                      bool force_unmerge = false );
00058     virtual CubitStatus uncomposite( RefVolume* composite_vol,
00059                                      DLIList<RefVolume*>* restored_vols = NULL );
00060     virtual CubitStatus uncomposite( Body* composite_body,
00061                                      DLIList<Body*>* restored_bodies = NULL );
00062     //Remove a composite entity.
00063
00064     CubitBoolean isComposite( const BasicTopologyEntity* bte_ptr ) const;
00065     CubitBoolean isComposite( const GeometryEntity* ge_ptr ) const;
00066
00067     CubitStatus composite( DLIList<RefEdge*>& edges_to_composite,
00068                            DLIList<RefEdge*>& new_edge_list,
00069                            DLIList<RefVertex*>* vertices_to_keep = NULL,
00070                            double max_angle = 3.15 );
00071      //R CubitStatus
00072     //I edges_to_composite
00073     //I- The list of RefEdges to composite.
00074     //O new_edge_list
00075     //O- The list of Composite RefEdges created.
00076     //I vertices_to_keep
00077     //I- If this list is passed, no composites will be created which
00078     //I- would result in the removal of any of these vertices.  Or
00079     //I- if the curves to be composited form a closed loop, this may
00080     //I- be used to specify which vertex is kept.
00081     //I max_angle
00082     //I- The maximum angle between tangents at the point of intersection
00083     //I- for which curves can be composited.  The default value (3.15) will
00084     //I- result in all possible curves being composited.  A value of 0.0
00085     //I- will result in only C1-continous curves being composited.
00086     //- Create all possible composites from the passed list of RefEdges,
00087     //- within the constraints of topological validity, the list of
00088     //- vertices to keep, and the specified angle.
00089
00090     CubitStatus composite( DLIList<RefFace*>& faces_to_composite,
00091                            DLIList<RefFace*>& result_faces,
00092                            double max_angle = 4.0 /*radians*/);
00093     //R CubitStatus
00094     //R- CUBIT_SUCCESS/CUBIT_FAILURE
00095     //I facets_to_composite
00096     //I- A list of RefFaces to create composites from.
00097     //O result_facets
00098     //O- The resulting composite surfaces.
00099     //I max_angle
00100     //I- The largest angle between surfaces to composite over.
00101     //- Create all possible composites from the passed list of RefFaces,
00102     //- within the constraints of toopologal validity, and the
00103     //- specified angle.
00104
00105
00106     RefFace* composite( DLIList<RefFace*>& faces_to_composite,
00107                         DLIList<RefEdge*>& result_edges,
00108                         DLIList<RefVertex*>* vertices_to_keep = NULL,
00109                         double max_vertex_angle = 0.26 /*radians*/ );
00110     //R RefFace*
00111     //R- The resulting composite, or NULL if an error was encountered.
00112     //I faces_to_composite
00113     //I- The list of connected surfaces to composite.
00114     //O result_edges
00115     //O- The list of curves composited with the surface.
00116     //I vertices_to_keep
00117     //I- The list of vertices that should not be composited over when
00118     //I- creating composite curves.
00119     //I max_vertex_angle
00120     //I- The maximum angle between curves at their common vertex, for
00121     //I- which the vertex can be composited over.
00122     //- Create a single composite surface, and as many composite curves
00123     //- as possible on the boundary of that surface.
00124
00125     CubitStatus composite( DLIList<RefFace*>& faces_to_composite,
00126                            DLIList<RefFace*>& result_faces,
00127                             DLIList<RefEdge*>& result_edges,
00128                            double max_curve_angle = 2.0 /*radians*/,
00129                            DLIList<RefVertex*>* vertices_to_keep = NULL,
00130                            double max_vtx_angle = 0.26 /*radians*/ );
00131     //R CubitStatus
00132     //R- CUBIT_SUCCESS/CUBIT_FAILURE
00133     //I facets_to_composite
00134     //I- The list of surfaces to create composites from.
00135     //O result_faces
00136     //O- The composite surfaces created.
00137     //O result_edges
00138     //O- The composite curves created.
00139     //I max_curve_angle
00140     //I- The largest angle between surfaces (at a curve) that can
00141     //I- be composited over.
00142     //I vertices_to_keep
00143     //I- The list of vertices that should not be composited over
00144     //I- when creating composite curves.
00145     //I max_vtx_angle
00146     //I- The largest angle between curves (at a vertex) that can
00147     //I- be composited over.
00148     //- Create composite surfaces and curves.
00149
00150
00151     CubitBoolean okayToComposite( DLIList<BasicTopologyEntity*>& bte_list,
00152                                   DLIList<BasicTopologyEntity*>* boundary = NULL,
00153                                   DLIList<BasicTopologyEntity*>* internal = NULL,
00154                                   bool print_errors = true,
00155                                   bool force_same_parent = false ) const;
00156     //This function is public because it is also used in PartitionTool,
00157     //and because it is only a series of queries anyway.
00158
00159     static CubitStatus classify_children( DLIList<BasicTopologyEntity*>& bte_list,
00160                                   DLIList<BasicTopologyEntity*>& boundary_children,
00161                                   DLIList<BasicTopologyEntity*>& internal_children,
00162                                   DLIList<BasicTopologyEntity*>& unknown_children );
00163
00164     RefEdge* remove_vertex( RefVertex* vertex,
00165                             bool remove_partitions = false,
00166                             bool update_dag = true,
00167                             RefEdge* survivor = NULL );
00168     RefFace* remove_edge( RefEdge* edge,
00169                           bool remove_partitions = false,
00170                           bool update_dag = true,
00171                           RefFace* survivor = NULL );
00172
00173     RefVolume* remove_face( RefFace* face,
00174                             bool remove_partitions = false,
00175                             bool update_dag = true );
00176
00177   protected:
00178
00179     // These functions do nothing as implemented in CompositeTool.
00180     // They are provided for CompositeToolMesh to overload with
00181     // mesh-handling code.
00182     virtual CubitStatus update_combined_vols( RefVolume* keep, RefVolume* dead );
00183     virtual CubitStatus update_combined_faces( RefFace* keep, RefEdge* dead, RefFace* delete_face );
00184     virtual CubitStatus update_combined_edges( RefEdge* keep, RefEdge* dead,int keep_interval,double keep_size,FirmnessType keep_interval_type,SizeIntervalType keep_size_type);
00185     virtual CubitStatus determine_combined_edges_interval_or_size( RefEdge* edge_1, RefEdge* edge_2,int& result_interval,double& result_size,FirmnessType& interval_keep_type,SizeIntervalType& size_keep_type);
00186
00187     CompositeTool();
00188
00189     //CubitStatus make_mergeable( GeometryEntity* bridge1, GeometryEntity* bridge2 );
00190
00191     CubitStatus removeOldTopology( BasicTopologyEntity* composite );
00192
00193     CubitVector tangent( RefEdge* edge_ptr, RefVertex* vtx_ptr ) const;
00194     //R CubitVector
00195     //R- The tangent vector
00196     //I edge_ptr
00197     //I- The RefEdge to get the tangent of.
00198     //I vtx_ptr
00199     //I- The RefVertex to get the tangent at.
00200     //- Return the tangent of the passed RefEdge at the location of
00201     //- the passed RefVertex.  The tanget is reversed if the passed
00202     //- RefVertex is the end vertex of the RefEdge, such that the
00203     //- resulting tangent vector points along the edge away from the
00204     //- vertex.
00205
00206
00207     CubitStatus fast_edge_sort( DLIList<RefEdge*>& edge_list,
00208                                 bool valence2_vertices ) const;
00209     //R CubitStatus
00210     //R- CUBIT_SUCCESS if all edges form a single chain.
00211     //R- CUBIT_FAILURE otherwise
00212     //I edge_list
00213     //I- The list of edges to sort
00214     //O edge_list
00215     //O- The sorted list of edges
00216     //- This function sorts edges by common vertices.  The result
00217     //- will be several consecutive sorted sets of edges, if all
00218     //- edges do not form a single chain.
00219
00220
00221     CubitStatus restore_merged_point( TBPoint* point,
00222                                       DLIList<RefFace*>& update,
00223                                       bool force = false );
00224
00225     CubitStatus stitch_points( TBPoint* pt1, TBPoint* pt2 );
00226     CubitStatus stitch_curves( Curve* cv1, Curve* cv2 );
00227
00228     static CompositeTool* instance_;
00229
00230   private:
00231
00232 };
00233
00234 inline CompositeTool* CompositeTool::instance()
00235 {
00236   return (instance_ != NULL ) ? instance_ : instance_ = new CompositeTool();
00237 }
00238
00239 inline CubitBoolean CompositeTool::
00240   isComposite( const GeometryEntity* ge_ptr ) const
00241 {
00242   if( dynamic_cast<const CompositeSurface*>(ge_ptr) ||
00243       dynamic_cast<const CompositeCurve*>(ge_ptr) ||
00244       dynamic_cast<const CompositePoint*>(ge_ptr) )
00245     return CUBIT_TRUE;
00246   return CUBIT_FALSE;
00247 }
00248
00249 inline CubitBoolean CompositeTool::
00250   isComposite( const BasicTopologyEntity* bte_ptr ) const
00251 {
00252   return bte_ptr ? isComposite(bte_ptr->get_geometry_entity_ptr()) : CUBIT_FALSE;
00253 }
00254
00255
00256 #endif
