cgma
CubitFacetData.hpp
00001 #ifndef CUBITFACETDATA_HPP
00002 #define CUBITFACETDATA_HPP
00003
00004 // Include for CubitBoolean
00005 #include "CubitDefines.h"
00006 #include "MemoryManager.hpp"
00007 #include "CubitPoint.hpp"
00008 #include "DLIList.hpp"
00009 #include "CubitBox.hpp"
00010 #include "CubitFacet.hpp"
00011 class CubitVector;
00012 class CubitBox;
00013 class CubitPlane;
00014 class CubitFacetEdge;
00015
00016 class CubitFacetData : public CubitFacet
00017 {
00018 private:
00019   CubitPoint *pointArray[3];
00020   CubitFacetEdge *edgeArray[3];
00021   int edgeUse[3];
00022   static MemoryManager memoryManager;
00023     //- memory management object
00024   int entityId;
00025     //- for debug tracking...
00026   void allocate_edge(CubitPoint *p1, CubitPoint *p2, int edge_index);
00027   void define_point(CubitFacetEdge *e1, CubitFacetEdge *e2,
00028                     int point_index);
00029   void define_bounding_box();
00030
00031 public:
00032   CubitFacetData( CubitPoint *p1, CubitPoint *p2,
00033                   CubitPoint *p3);
00034   CubitFacetData( CubitPoint *p1, CubitPoint *p2,
00035                   CubitPoint *p3, int *tool_data);
00036   CubitFacetData( CubitFacetEdge *e1, CubitFacetEdge *e2,
00037                   CubitFacetEdge *e3);
00038   ~CubitFacetData();
00039
00040   void destruct_facet_internals();
00041
00042   virtual int id(){return entityId;}
00043   virtual void set_id( int ii ) { entityId = ii; }
00044
00045   SetDynamicMemoryAllocation(memoryManager)
00046     //- class specific new and delete operators
00047   CubitStatus closest_point( const CubitVector &point,
00048                                      CubitVector &closest_point);
00049     //- Sets the closest point on the plane defined by
00050     //- this facet to the point in space.
00051     //- If the normal length to the facet is 0, it will return CUBIT_FAILURE.
00052
00053   CubitPoint* point( int index );
00054     //Get the point at the specified index.
00055     //asserts that the index is in range, for a
00056     //triangle, 0 <= index <= 2.
00057
00058
00059   void set_point( CubitPoint *the_point, int index );
00060     //- sets the point into the facet.
00061
00062   CubitFacetEdge *edge( int index );
00063   void edge( CubitFacetEdge *the_edge, int index );
00064     //- get and set edge pointers
00065
00066   void edge_use( int direction, int index );
00067   int edge_use( int index );
00068     //- get and set the edge uses
00069   int sense(int index);
00070
00071   CubitPoint* split_edge( int edge_index, const CubitVector& position );
00072   CubitPoint* split_edge( CubitPoint* edge_pt1, CubitPoint* edge_pt2,
00073                           const CubitVector& position );
00074     //R CubitPoint
00075     //R- The new CubitPoint created.
00076     //I edge_pt1, edge_pt2
00077     //I- The end points of an edge of this triangle.
00078     //I position
00079     //I- The position at which to split the edge.
00080     //O new_facet1
00081     //O- The new facet resulting from splitting the edge on
00082     //O- this triangle.
00083     //O new_facet2
00084     //O- The new facet resulting from splitting the same edge
00085     //O- on the ajacent triangle.  If there is no other
00086     //O- triangle sharing the edge, NULL will be passed back.
00087     //- Split an edge on this triangle and the other triangle
00088     //- sharing the edge, if it exists.
00089     //-
00090     //- Note:  No check is done on the location of the split
00091     //-        position.
00092
00093   CubitPoint* insert_point( const CubitVector& position,
00094                             CubitFacet*& new_tri1,
00095                             CubitFacet*& new_tri2 );
00096     //R CubitPoint
00097     //R- The new CubitPoint created.
00098     //I position
00099     //I- The position at which to insert a point in the triangle.
00100     //O new_facet1, new_facet2
00101     //O- The two new facets created.
00102     //- Insert a point in the interior of this triangle.
00103     //-
00104     //- Note:  No check is done on the location of the split
00105     //-        position.
00106
00107   CubitStatus flip_edge( int edge_index );
00108   CubitStatus flip_edge( CubitFacetEdge *edge );
00109     //- Given an edge shared by exactly two facets,
00110     //- flip the edge such that it connects the
00111     //- "other" two facet points instead.
00112     //-
00113     //-  *----*        *----*
00114     //-  |\   |        |   /|
00115     //-  | \  |  ==>   |  / |
00116     //-  |  \ |        | /  |
00117     //-  |   \|        |/   |
00118     //-  *----*        *----*
00119     //-
00120     //- NOTE:  If you are trying to reverse the sense of
00121     //-        an edge, this is NOT the function you want!
00122
00123   void flip();
00124     //- reorient the facet
00125
00126 };
00127
00128
00129 inline CubitPoint* CubitFacetData::point( int index )
00130 {
00131   assert( (index >= 0) && (index < 3) );
00132   if (!is_backwards())
00133     return pointArray[index];
00134   else
00135   {
00136     switch(index)
00137     {
00138     case 0: return pointArray[0];
00139     case 1: return pointArray[2];
00140     case 2: return pointArray[1];
00141     }
00142   }
00143   return NULL;
00144 }
00145
00146 inline void CubitFacetData::set_point( CubitPoint* the_point, int index )
00147 {
00148   assert( (index >= 0) && (index < 3) );
00149   if (!is_backwards())
00150     pointArray[index] = the_point;
00151   else
00152   {
00153     switch(index)
00154     {
00155     case 0: pointArray[0] = the_point; break;
00156     case 1: pointArray[2] = the_point; break;
00157     case 2: pointArray[1] = the_point; break;
00158     }
00159   }
00160 }
00161
00162 inline CubitFacetEdge* CubitFacetData::edge( int index )
00163 {
00164   assert( (index >= 0) && (index < 3) );
00165   if (!is_backwards()) {
00166     return edgeArray[index];
00167   }
00168   else
00169   {
00170     switch(index)
00171     {
00172     case 0:return edgeArray[0];
00173     case 1:return edgeArray[2];
00174     case 2:return edgeArray[1];
00175     }
00176   }
00177   return NULL;
00178 }
00179
00180
00181 inline void CubitFacetData::edge( CubitFacetEdge *the_edge, int index )
00182 {
00183   assert( (index >= 0) && (index < 3) );
00184   if (!is_backwards())
00185     edgeArray[index] = the_edge;
00186   else
00187   {
00188     switch(index)
00189     {
00190     case 0: edgeArray[0] = the_edge; break;
00191     case 1: edgeArray[2] = the_edge; break;
00192     case 2: edgeArray[1] = the_edge; break;
00193     }
00194   }
00195 }
00196
00197 inline int CubitFacetData::edge_use( int index )
00198 {
00199   assert( (index >= 0) && (index < 3) );
00200   if (!is_backwards())
00201     return edgeUse[index];
00202   else
00203   {
00204     switch(index)
00205     {
00206     case 0: return -edgeUse[0];
00207     case 1: return -edgeUse[2];
00208     case 2: return -edgeUse[1];
00209     }
00210   }
00211   return 0;
00212 }
00213
00214 //- This function is defined so that Meshing and Geometry Entities
00215 //- return the same values as needed in the FacetorTool
00216 inline int CubitFacetData::sense( int index ) {
00217   if(edge_use(index) == 1)
00218     return CUBIT_FORWARD;
00219   else if(edge_use(index) == -1)
00220     return CUBIT_REVERSED;
00221   else
00222     return CUBIT_UNKNOWN;
00223 }
00224
00225 inline void CubitFacetData::edge_use( int direction, int index )
00226 {
00227   assert( (index >= 0) && (index < 3) );
00228   if (!is_backwards())
00229     edgeUse[index] = direction;
00230   else
00231   {
00232     switch(index)
00233     {
00234     case 0: edgeUse[0] = -direction; break;
00235     case 1: edgeUse[2] = -direction; break;
00236     case 2: edgeUse[1] = -direction; break;
00237     }
00238   }
00239 }
00240
00241 #endif
00242
00243
