cgma
CubitFacet.hpp
00001 //-----------------------------------------------------------------------------
00002 //
00003 //  File: CubitFacet.hpp
00004 //
00005 //  Purpose:  Facet Class used for mesh based geometry and other tools.
00006 //
00007 //  Notes:    A facet is a triangle used for defining surfaces. The
00008 //            default construction is a linear representation, although
00009 //            b-spline control points can be defined to represent a
00010 //            higher order triangular b-spline patch. There is also
00011 //            support for quad facets by using the CubitQuadFacet
00012 //
00013 //            Note that the main private data components (ie. points, edges)
00014 //            are not contained in this class.
00015 //            This data should be defined within the child classes inherited
00016 //            from this class.  The current Cubit data class that inherits
00017 //            from CubitFacet is CubitFacetData.  This is done so that
00018 //            other applications using CubitFacets can use their own
00019 //            facet data, but take advantage of the CGM/Cubit functionality.
00020 //            Please do not add private data to this class unless it is only
00021 //            applicable to Cubit algorithms; instead add the
00022 //            data to the children and access through virtual functions.
00023 //
00024 //            Do not create a CubitFacet directly.  For example, don't do:
00025 //              CubitFacet *cf = new CubitFacet(...);
00026 //            You should instead create the appropriate child class, and
00027 //            cast it to a CubitFacet for use.  For example:
00028 //              CubitFacet *cf = (CubitFacet *) new CubitFacetData(...);
00029 //
00030 //-----------------------------------------------------------------------------
00031
00032 #ifndef CUBITFACET_HPP
00033 #define CUBITFACET_HPP
00034
00035 #include "CubitDefines.h"
00036 #include "MemoryManager.hpp"
00037 #include "DLIList.hpp"
00038 #include "CubitBox.hpp"
00039 #include "FacetEntity.hpp"
00040 #include "CubitVector.hpp"
00041 #include "CubitPlane.hpp"
00042
00043 class CubitFacetEdge;
00044 class CubitPoint;
00045
00046 class CubitFacet : public FacetEntity
00047 {
00048 public:
00049   static const int point_edge_conn[30][2];
00050   static const int point_facet_conn[16][3];
00051   static const double my_points[15][3];
00052
00053 protected:
00054
00055   CubitPlane *cachedPlane;
00056     //- cached plane for this facet
00057
00058   CubitBox bBox;
00059     //- The bounding box for the facet
00060
00061   double facetWeight;
00062     //- for interpolation
00063
00064   CubitVector *patchCtrlPts;
00065     //- control points for triangular bezier batch
00066
00067   int markedFlag;
00068     //- generic marker for list sorting.  Assume 0. Users must clean after use.
00069
00070   int isFlat;
00071     //- facet is flat
00072
00073   int isBackwards;
00074     //- facet is oriented backwards wrt. orientation of surface
00075
00076   int toolID;
00077     //- id of facet eval tool
00078
00079 public:
00080   CubitFacet();
00081
00082 //------------------------------------------------------------------------
00083 // The following functions are pure virtual and must be
00084 // implemented in the child class (ie. CubitFacetData or equivalent)
00085
00086   virtual ~CubitFacet();
00087
00088   CubitVector normal();
00089     //- Returns the normal to this facet.
00090
00091   CubitVector update_normal( void );
00092   //- update the plane and return the new normal
00093
00094
00095   const CubitBox& bounding_box() {return bBox;};
00096   void bounding_box( CubitBox &box )
00097   { bBox = box; }
00098   void reset_bounding_box();
00099     //- returns/sets the bounding box of the facet
00100
00101   void weight(double facweight) { facetWeight = facweight; }
00102   double weight() { return facetWeight; }
00103     //- get/set weight
00104
00105   void get_control_points( CubitVector points[6] );
00106   void set_control_points( CubitVector points[6] );
00107   void set_control_points( const double *pt_array );
00108   CubitVector *control_points() {return patchCtrlPts;};
00109     //- get and set the bezier patch internal control points
00110
00111   int eval_order()
00112     { return (patchCtrlPts == NULL) ? 0 : 4; }
00113     //- return the evaluation order of the facet.  Currently only
00114     //- order 0 (linear) and 4 (b-spline patch) are implemented
00115
00116   virtual CubitPoint* point( int index ) = 0;
00117     //Get the point at the specified index.
00118     //asserts that the index is in range, for a
00119     //triangle, 0 <= index <= 2.
00120
00121   void marked(int mark) {markedFlag = mark;};
00122   int marked() {return markedFlag;};
00123     //- generic marking functions.
00124
00125   int is_flat();
00126   void is_flat(int flat) {isFlat = flat;};
00127     //- get/set isFlat
00128
00129   const CubitPlane& plane();
00130   void plane(CubitPlane &this_plane);
00131   void update_plane();
00132     //- Cache and return the plane containing this triangle.
00133
00134   int is_backwards() {return isBackwards;};
00135   void is_backwards( int flipped ) { isBackwards = flipped; }
00136     //- return whether the facet was reoriented
00137
00138   virtual int id() = 0;
00139   virtual void set_id( int ii ) = 0;
00140   int tool_id(){return toolID;}
00141   void set_tool_id(int tool_id){toolID = tool_id;}
00142
00143   virtual CubitFacetEdge *edge( int index ) = 0;
00144   virtual void edge( CubitFacetEdge *the_edge, int index ) = 0;
00145     //- get and set edge pointers
00146
00147   virtual void edge_use( int direction, int index ) = 0;
00148   virtual int edge_use( int index ) = 0;
00149     //- get and set the edge uses.  Direction is 1 or -1 based
00150     //- upon the orientation of the edge with respect to a CCW orientation
00151     //- of the facet
00152
00153   virtual void flip() = 0;
00154     //- reorient the facet
00155
00156 //---------------------------------------------------------------------
00157 //  The following virtual functions are optional.  Implement them
00158 //  based upon the application's need.  If they are called without
00159 //  being implemented, an assertion will occur.
00160
00161   virtual int sense(int /*index*/){ assert(0); return -1;}
00162   //- Gives the direction of the edge given the edge index
00163
00164   virtual CubitPoint* split_edge( CubitPoint* edge_pt1,
00165                                   CubitPoint* edge_pt2,
00166                                   const CubitVector& position );
00167     //R CubitPoint
00168     //R- The new CubitPoint created.
00169     //I edge_pt1, edge_pt2
00170     //I- The end points of an edge of this triangle.
00171     //I position
00172     //I- The position at which to split the edge.
00173     //- Split an edge on this triangle and the other triangle
00174     //- sharing the edge, if it exists.
00175     //-
00176     //- Note:  No check is done on the location of the split
00177     //-        position.
00178
00179   virtual CubitPoint* insert_point( const CubitVector& position,
00180                                     CubitFacet*& new_tri1,
00181                                     CubitFacet*& new_tri2 );
00182     //R CubitPoint
00183     //R- The new CubitPoint created.
00184     //I position
00185     //I- The position at which to insert a point in the triangle.
00186     //O new_facet1, new_facet2
00187     //O- The two new facets created.
00188     //- Insert a point in the interior of this triangle.
00189     //-
00190     //- Note:  No check is done on the location of the split
00191     //-        position.
00192
00193   virtual CubitStatus closest_point( const CubitVector &point,
00194                                      CubitVector &closest_point);
00195     //- Sets the closest point on the plane defined by
00196     //- this facet to the point in space.
00197     //- If the normal length to the facet is 0, it will return CUBIT_FAILURE.
00198
00199 //----------------------------------------------------------------------
00200 // The following functions access the data in a child class
00201
00202   CubitVector center();
00203     //- Returns the center of the facet.
00204
00205   void debug_draw(int color=-1, int flush_it = 1, int draw_uv=0);
00206     //- draws the current facet.
00207
00208   CubitStatus closest_point_trimmed( const CubitVector &point,
00209                                      CubitVector &closest_point,
00210                                      CubitPoint *&next_edge_p1,
00211                                      CubitPoint *&next_edge_p2 );
00212     //- returns the closest point on this facet to the point in space.
00213     //- If the point is not in the facet, then the edge to which it was closest
00214     //- will be set and returned.  Other wise they will be "NULLED".
00215
00216   void get_edge_1( CubitPoint *&p1, CubitPoint *&p2 )
00217     { p1 = point(0); p2 = point(1);}
00218   void get_edge_2( CubitPoint *&p1, CubitPoint *&p2 )
00219     { p1 = point(1); p2 = point(2);}
00220   void get_edge_3( CubitPoint *&p1, CubitPoint *&p2 )
00221     { p1 = point(2); p2 = point(0);}
00222     //- Get the points that define the three edges of the facet.
00223   void get_edge_pts( int index, CubitPoint *&p1, CubitPoint *&p2 );
00224     //- get the points that define an edge
00225     //- The index of the edge corresponds to the point index on
00226     //- the facet opposite the edge
00227
00228   CubitFacetEdge *edge_from_pts( CubitPoint *p1, CubitPoint *p2, int &index );
00229     //- return the edge pointer based on its end points
00230   int edge_index( CubitPoint *p1, CubitPoint *p2, int &sense );
00231   int edge_index( CubitFacetEdge *edge );
00232     //- return the index of the edge on the facet
00233   int point_index( CubitPoint *pt );
00234     //- return the index of the point on the facet
00235
00236   void opposite_edge( CubitPoint* point,
00237                       CubitPoint*& p1, CubitPoint*& p2 );
00238     //- Get the edge on the triangle opposite of the passed point.
00239     //- p1 and p2 will be passed back as NULL if point is not a
00240     //- point on this triangle.
00241
00242
00243   CubitPoint *opposite_point( CubitFacetEdge *edge );
00244   //- returns the opposite point of input edge.  Input edge should be incident on facet.
00245   //- If input edge is not incident on facet then any of the one point can be returned
00246
00247
00248   void points( CubitPoint *&p0, CubitPoint *&p1, CubitPoint *&p2 )
00249     { p0 = point(0); p1 = point(1); p2 = point(2); }
00250   void points( CubitPoint *pts[3] )
00251     { pts[0] = point(0); pts[1] = point(1); pts[2] = point(2); }
00252   void tri_nodes( CubitPoint *&p0, CubitPoint *&p1, CubitPoint *&p2 )
00253     { points( p0, p1, p2); }
00254   void points(DLIList<CubitPoint*> &point_list )
00255     { for ( int i = 0; i < 3; i++ )
00256       point_list.append(point(i));
00257     }
00258   void facets(DLIList<CubitFacet*> &facet_list )
00259     { facet_list.append( this ); }
00260   void edges(DLIList<CubitFacetEdge*> &edge_list )
00261     { for ( int i = 0; i < 3; i++ )
00262       edge_list.append(edge(i));
00263     }
00264
00265   CubitBoolean contains(CubitPoint *p1);
00266     //- Returns TRUE/FALSE if the point defines this facet.
00267
00268   CubitFacetEdge* shared_edge( CubitFacet *cubit_facet );
00269
00270   CubitFacet* shared_facet( CubitPoint *p1, CubitPoint *p2 );
00271     //- Returns the "other" facet attached to this edge. (if
00272     //- there is one., other wise returns NULL).
00273   void shared_facets( CubitPoint *p1, CubitPoint *p2,
00274                       DLIList <CubitFacet *> &adj_facet_list);
00275     //- Returns all adjacent facets to this edge (not including
00276     //- this facet)
00277
00278   CubitFacet *adjacent( int &index, int *tool_data )
00279     //- Returns all adjacent facets to this edge index(not including
00280     //- this facet)
00281   {
00282         //convert MESHING TRI edge index to GEOMETRY FACET edge index
00283         index = (index+2)%3;
00284         CubitPoint *p1, *p2;
00285
00286         get_edge_pts( index, p1, p2 );
00287         return shared_facet_on_surf( p1, p2, *tool_data );
00288   }
00289
00290   CubitPoint* next_node(CubitPoint *current_point)
00291   {
00292     int index = point_index(current_point);
00293     return point((index+1)%3);
00294   }
00295     //- return the adjacent triangle at the edge index
00296   CubitFacet* shared_facet_on_surf( CubitPoint *p1, CubitPoint *p2, int tool_id );
00297     //- same as above except also matches tool_id with toolID
00298
00299   double min_diagonal();
00300     //- Returns the length of the minimum diagonal of the triangle.
00301
00302   double angle( CubitPoint *pt );
00303     //- return the angle (radians) at one of the points on the facet
00304
00305   void update_bezier_bounding_box( );
00306     //- Update the facet bounding box based on its control polygon
00307
00308   CubitFacetEdge *prev_edge( CubitFacetEdge *edge );
00309   CubitFacetEdge *next_edge( CubitFacetEdge *edge );
00310     //- return the prvious or next edge on the facet
00311
00312   int other_index( CubitPoint* pt1, CubitPoint* pt2 );
00313
00314   CubitStatus evaluate_position( const CubitVector &start_position,
00315                                  CubitVector *eval_point,
00316                                  CubitVector *eval_normal = NULL );
00317
00318   CubitStatus evaluate( CubitVector &areacoord,
00319                         CubitVector *eval_point,
00320                         CubitVector *eval_normal = NULL );
00321
00322   void get_parents(DLIList<FacetEntity *> &){};
00323     // dummy for this class
00324
00325   CubitFacetEdge *next_edge_at_point( CubitFacetEdge *edge_ptr,
00326                                       CubitPoint *point_ptr );
00327     // return the next edge on the triangle at the point
00328
00329   CubitStatus get_edge_control_points( CubitVector P[3][5] );
00330     // get the control points on the facet edges
00331
00332   double area();
00333     // return the area of the facet
00334
00335   double aspect_ratio();
00336
00337
00338   CubitStatus init_patch(  );
00339     // computes the interior control points for the facet and
00340     // stores them with the facet.  Assumes edge control points
00341     // have already been computed
00342
00343   void add_edge(CubitFacetEdge *edge);
00344    //- add an existing edge to a facet
00345
00346   void unlink_from_children( void );
00347
00348 };
00349
00350 inline void CubitFacet::plane(CubitPlane &this_plane)
00351 {
00352   this_plane = plane();
00353 }
00354
00355 template <> struct DLIListSorter<CubitFacet*>
00356 {
00357   bool operator()(CubitFacet* a, CubitFacet* b) { return a->id() < b->id(); }
00358 };
00359
00360 #endif
00361
00362
