cgma
CubitUtil.cpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : CubitUtil.cc
00003 //
00004 // Purpose       : This file contains utility functions that can be used
00005 //                 throughout Cubit.
00006 //
00007 // Special Notes : This is a pure virtual class, to prevent instantiation.
00008 //                 All functions are static, called like this:
00009 //                 CubitUtil::function_name();
00010 //
00011 // Creator       : Darryl Melander
00012 //
00013 // Date          : 06/08/98
00014 //
00015 // Owner         : Darryl Melander
00016 //-------------------------------------------------------------------------
00017
00018 #include "CubitUtil.hpp"
00019 #include "CubitString.hpp"
00020 #include "CubitEntity.hpp"
00021 #include "CubitMessage.hpp"
00022
00023 #include "AppUtil.hpp"
00024 #include <ctype.h>
00025 #include <time.h>
00026 #include <sstream>
00027
00028
00029 #ifdef _WIN32
00030 #include "windows.h"
00031 #else
00032 #include <unistd.h>
00033 #include <sys/utsname.h>
00034 #endif
00035
00036 FILE *CubitUtil::fp = NULL;
00037 static int displayDigits = -1;
00038
00039
00040 int CubitUtil::get_digits()
00041 {
00042   return displayDigits;
00043 }
00044
00045 void CubitUtil::set_digits(int new_digits)
00046 {
00047   displayDigits = new_digits;
00048 }
00049
00050
00051 void CubitUtil::convert_string_to_lowercase(char *string)
00052 {
00053    register char *p = string;
00054    while (*p)
00055    {
00056      if (isascii(*p) && isupper(*p))
00057          *p = tolower(*p);
00058       p++;
00059    }
00060 }
00061
00062 int CubitUtil::strcmp_case_insensitive (const char *s1, const char *s2)
00063 {
00064    char c1, c2;
00065
00066    do
00067    {
00068       c1 = *s1++;
00069       if(isupper(c1))
00070          c1 = tolower(c1);
00071
00072       c2 = *s2++;
00073       if(isupper(c2))
00074          c2 = tolower(c2);
00075
00076       if(c1 != c2)
00077          return c1 - c2;
00078
00079    } while(c1 != '\0');
00080
00081    return 0;
00082 }
00083
00084 int CubitUtil::strncmp_case_insensitive (const char *s1, const char *s2,
00085                                          int n)
00086 {
00087    char c1, c2;
00088
00089    do
00090    {
00091       c1 = *s1++;
00092       if(isupper(c1))
00093          c1 = tolower(c1);
00094
00095       c2 = *s2++;
00096       if(isupper(c2))
00097          c2 = tolower(c2);
00098
00099       if(c1 != c2)
00100          return c1 - c2;
00101
00102       n--;
00103    } while(c1 && n > 0);
00104
00105    return 0;
00106 }
00107
00108 void CubitUtil::list_ids( const char *const heading,
00109                             const DLIList<CubitEntity*> &entity_list,
00110                             int should_sort, int report_once,
00111                             int wrap )
00112 {
00113   if ( entity_list.size() == 0 )
00114   {
00115     PRINT_INFO("  No %s.\n", heading );
00116     return;
00117   }
00118   DLIList <int> id_list( entity_list.size() );
00119   for ( int j = 0; j < entity_list.size(); j++ )
00120   {
00121     id_list.append( entity_list[j]->id() );
00122   }
00123
00124   if ( id_list.size() == 1 )
00125   {
00126     PRINT_INFO("  The 1 %s id is %d.\n", heading, id_list[0]);
00127     return;
00128   }
00129   sort_and_print_ids( heading, id_list, should_sort, report_once, wrap );
00130 }
00131
00132 void CubitUtil::sort_and_print_ids( const char *const heading,
00133                                       DLIList<int> &id_list,
00134                                       int should_sort, int report_once,
00135                                       int wrap )
00136 {
00137     // sort, if desired
00138   if ( should_sort ) {
00139     id_list.sort();
00140   }
00141
00142   if ( report_once ) {
00143     DLIList <int> id_list_2( id_list );
00144     id_list_2.reset();
00145     id_list.clean_out();
00146     id_list.append( id_list_2.get_and_step() );
00147     for ( int j = id_list_2.size()-1; j--; )
00148     {
00149       if ( id_list_2.get() != id_list_2.prev() )
00150         id_list.append( id_list_2.get() );
00151       id_list_2.step();
00152     }
00153   }
00154
00155   if( wrap == -1 )
00156   {
00157     // print out ranges
00158     int begin = id_list.get_and_step();
00159     int end = begin;
00160     int current = -1;
00161     PRINT_INFO("  The %d %s ids are %d", id_list.size(), heading, begin);
00162     for (int i=id_list.size()-1; i > 0; i--) {
00163       current = id_list.get_and_step();
00164       if (current == end+1) {
00165         end++;
00166       }
00167       else {
00168         if (end == begin) {
00169           PRINT_INFO(", %d", current);
00170         }
00171         else if (end == begin+1) {
00172           PRINT_INFO(", %d, %d", end, current);
00173         }
00174         else {
00175           PRINT_INFO(" to %d, %d", end, current);
00176         }
00177         begin = current;
00178         end = begin;
00179       }
00180     }
00181     if (current == begin + 1)   {
00182       PRINT_INFO(", %d", current);
00183     }
00184     else if (current != begin) {
00185       PRINT_INFO(" to %d", current);
00186     }
00187     PRINT_INFO(".\n");
00188   }
00189   else
00190   {
00191     char pre_string[67];
00192     sprintf( pre_string, "  The %d %s ids are: ", id_list.size(),heading );
00193     CubitUtil::list_entity_ids( pre_string, id_list, wrap, ".\n", CUBIT_FALSE,
00194                                 CUBIT_FALSE );
00195   }
00196 }
00197
00198 void CubitUtil::list_entity_ids( const char *pre_string,
00199                                  const DLIList<CubitEntity*> &entity_list,
00200                                  int width, const char *post_string,
00201                                  int sort, int unique,
00202                                  int tab, const char *sep_string,
00203                                  const char *post_string_none )
00204 {
00205   DLIList <int> id_list( entity_list.size() );
00206   for ( int i=0; i<entity_list.size(); i++ )
00207     id_list.append( entity_list.next(i)->id() );
00208
00209   list_entity_ids( pre_string, id_list, width, post_string, sort,
00210                    unique, tab, sep_string, post_string_none );
00211 }
00212
00213 void CubitUtil::list_entity_ids( const char *pre_string,
00214                                  DLIList<int> &id_list,
00215                                  int width,
00216                                  const char *post_string,
00217                                  int sort, int unique,
00218                                  int tab_len, const char *sep_string,
00219                                  const char *post_string_none )
00220 {
00221   CubitString ret_str;
00222   process_entity_ids( 1, ret_str, pre_string, id_list, width, post_string,
00223                       sort, unique, tab_len, sep_string, post_string_none );
00224 }
00225
00226 CubitString CubitUtil::get_entity_ids_str( const char *pre_string,
00227                                            DLIList<int> &id_list,
00228                                            int width, const char *post_string,
00229                                            int sort, int unique, int tab_len,
00230                                            const char *sep_string,
00231                                            const char *post_string_none )
00232 {
00233   CubitString ret_str;
00234
00235   process_entity_ids( 0, ret_str, pre_string, id_list, width, post_string,
00236                       sort, unique, tab_len, sep_string, post_string_none );
00237   return ret_str;
00238 }
00239
00240 void CubitUtil::process_entity_ids( int method,
00241                                     CubitString &ret_str,
00242                                     const char *pre_string,
00243                                     DLIList<int> &id_list,
00244                                     int max_len,
00245                                     const char *post_string,
00246                                     int sort, int unique,
00247                                     int tab_len, const char *sep_string,
00248                                     const char* post_string_none )
00249 {
00250   // Method: 0 - to a string
00251   //         1 - to PRINT_INFO
00252   char temp[200];
00253
00254   if ( id_list.size() == 0 ) {
00255     if( method )
00256       PRINT_INFO("%s%s", pre_string, post_string_none );
00257     else
00258     {
00259       sprintf( temp, "%s%s", pre_string, post_string_none );
00260       ret_str = temp;
00261     }
00262     if( fp )
00263       fprintf( fp, "%s%s", pre_string, post_string_none );
00264     return;
00265   }
00266
00267   // sort
00268   if( sort )
00269   {
00270     id_list.sort();
00271
00272     // make unique
00273     if( unique )
00274     {
00275       int i;
00276       DLIList <int> id_list_2( id_list );
00277       id_list_2.reset();
00278       id_list.clean_out();
00279       id_list.append( id_list_2.get_and_step() );
00280       for ( i=id_list_2.size()-1; i--; )
00281       {
00282         if ( id_list_2.get() != id_list_2.prev() )
00283           id_list.append( id_list_2.get() );
00284         id_list_2.step();
00285       }
00286     }
00287   }
00288
00289   if( max_len < 0 )
00290     max_len = CUBIT_INT_MAX/2;
00291
00292   // TODO: wrap prestring, if necessary
00293   if( method )
00294     PRINT_INFO( "%s", pre_string );
00295   else
00296     ret_str = pre_string;
00297   if( fp )
00298     fprintf( fp, "%s", pre_string );
00299
00300   // Keep track of length printed
00301   int curr_len = strlen(pre_string);
00302
00303   int num = 0;
00304   int begin = id_list.get();
00305   int previous = begin;
00306   int current;
00307   int comma = 0; // Is comma needed
00308   int beg_len, prev_len;
00309   int sep_len = strlen( sep_string );
00310
00311   // Setup the tab
00312   char* tab = new char[tab_len+1];
00313   for( int i=0; i<tab_len; i++ )
00314      tab[i] = ' ';
00315   tab[tab_len] = '\0';
00316
00317   // Loop until all the ids are printed.  Use ranges if possible.
00318   while( num < id_list.size()+1 )
00319   {
00320     current = id_list.get_and_step();
00321     num++;
00322
00323     // Handle last entity
00324     if( num <= id_list.size() )
00325     {
00326       if( num==1 ) // Handle 1st time in loop
00327         continue;
00328
00329       if( current==previous+1 )
00330       {
00331         previous = current;
00332         continue;
00333       }
00334     }
00335
00336     // If we are here, we are no longer tracking a range and
00337     // need to print the range or a number.
00338     if( comma )
00339     {
00340       if( method )
00341         PRINT_INFO("%s", sep_string );
00342       else
00343         ret_str += sep_string;
00344       if( fp )
00345         fprintf( fp, "%s", sep_string );
00346       curr_len += sep_len;
00347     }
00348
00349     if( begin==previous )
00350     {
00351       // a single number
00352       prev_len = int_len(previous);
00353
00354       if( curr_len+1+prev_len+sep_len > max_len )
00355       {
00356         if( method )
00357         {
00358           PRINT_INFO( "\n" );
00359           PRINT_INFO( "%s%d", tab, previous );
00360         }
00361         else
00362         {
00363           sprintf( temp, "\n%s%d", tab, previous );
00364           ret_str += temp;
00365         }
00366         if( fp )
00367           fprintf( fp, "\n%s%d", tab, previous );
00368         curr_len = tab_len + prev_len;
00369       }
00370       else
00371       {
00372         if( comma ) // Don't print space before first item
00373         {
00374           if( method )
00375             PRINT_INFO( " " );
00376           else
00377             ret_str += " ";
00378           if( fp )
00379             fprintf( fp, " " );
00380           curr_len++;
00381         }
00382
00383         if( method )
00384           PRINT_INFO( "%d", previous );
00385         else
00386         {
00387           sprintf( temp, "%d", previous );
00388           ret_str += temp;
00389         }
00390         if( fp )
00391           fprintf( fp, "%d", previous );
00392         curr_len = curr_len + prev_len;
00393       }
00394     }
00395     else if( previous==begin+1 )
00396     {
00397       // a range, but only 2 consecutive numbers
00398       prev_len = int_len(previous);
00399       beg_len = int_len(begin);
00400
00401       // Print 1st
00402       if( curr_len+1+beg_len+sep_len > max_len )
00403       {
00404         if( method )
00405         {
00406           PRINT_INFO( "\n" );
00407           PRINT_INFO( "%s%d%s", tab, begin, sep_string );
00408         }
00409         else
00410         {
00411           sprintf( temp, "\n%s%d%s", tab, begin, sep_string );
00412           ret_str += temp;
00413         }
00414         if( fp )
00415           fprintf( fp, "\n%s%d%s", tab, begin, sep_string );
00416         curr_len = tab_len + beg_len + sep_len;
00417       }
00418       else
00419       {
00420         if( comma ) // Don't print space before first item
00421         {
00422           if( method )
00423             PRINT_INFO( " " );
00424           else
00425             ret_str += " ";
00426           if( fp )
00427             fprintf( fp, " " );
00428           curr_len++;
00429         }
00430
00431         if( method )
00432           PRINT_INFO( "%d%s", begin, sep_string );
00433         else
00434         {
00435           sprintf( temp, "%d%s", begin, sep_string );
00436           ret_str += temp;
00437         }
00438         if( fp )
00439           fprintf( fp, "%d%s", begin, sep_string );
00440         curr_len = curr_len + beg_len + sep_len;
00441       }
00442
00443       // Print 2nd
00444       if( curr_len+1+prev_len+sep_len > max_len )
00445       {
00446         if( method )
00447         {
00448           PRINT_INFO( "\n" );
00449           PRINT_INFO( "%s%d", tab, previous );
00450         }
00451         else
00452         {
00453           sprintf( temp, "\n%s%d", tab, previous );
00454           ret_str += temp;
00455         }
00456         if( fp )
00457           fprintf( fp, "\n%s%d", tab, previous );
00458         curr_len = tab_len + prev_len;
00459       }
00460       else
00461       {
00462         if( method )
00463           PRINT_INFO( " %d", previous );
00464         else
00465         {
00466           sprintf( temp, " %d", previous );
00467           ret_str += temp;
00468         }
00469         if( fp )
00470           fprintf( fp, " %d", previous );
00471         curr_len = curr_len + 1+prev_len;
00472       }
00473     }
00474     else
00475     {
00476       // a range of 3 or more consecutive numbers
00477       prev_len = int_len(previous);
00478       beg_len = int_len(begin);
00479
00480       if( curr_len+beg_len+prev_len+5+sep_len > max_len )
00481       {
00482         if( method )
00483         {
00484           PRINT_INFO( "\n" );
00485           PRINT_INFO( "%s%d to %d", tab, begin, previous );
00486         }
00487         else
00488         {
00489           sprintf( temp, "\n%s%d to %d", tab, begin, previous );
00490           ret_str += temp;
00491         }
00492         if( fp )
00493           fprintf( fp, "\n%s%d to %d", tab, begin, previous );
00494         curr_len = tab_len + beg_len+prev_len+4;
00495       }
00496       else
00497       {
00498         if( comma ) // Don't print space before first item
00499         {
00500           if( method )
00501             PRINT_INFO( " " );
00502           else
00503             ret_str += " ";
00504           if( fp )
00505             fprintf( fp, " " );
00506           curr_len++;
00507         }
00508
00509         if( method )
00510           PRINT_INFO( "%d to %d", begin, previous );
00511         else
00512         {
00513           sprintf( temp, "%d to %d", begin, previous );
00514           ret_str += temp;
00515         }
00516         if( fp )
00517           fprintf( fp, "%d to %d", begin, previous );
00518         curr_len = curr_len + beg_len+4+prev_len;
00519       }
00520     }
00521
00522     begin = current;
00523     previous = current;
00524     comma = 1;
00525
00526   }
00527
00528   //TODO: wrap poststring, if required
00529   if (post_string) {
00530
00531     if( method )
00532       PRINT_INFO( "%s", post_string );
00533     else
00534       ret_str += post_string;
00535     if( fp )
00536       fprintf( fp, "%s", post_string );
00537   }
00538
00539   delete [] tab;
00540 }
00541
00542 #define INTABS(n) ((n) >= 0 ? (n) : (-(n)))
00543 int CubitUtil::int_len( int num )
00544 {
00545   int len = 0; // length of the string to hold the integer number
00546   unsigned long n; // absolute value of the integer value
00547
00548   // If the number is negative, add 1 for the negative sign
00549   if (num < 0) len++;
00550
00551   // Loop until the absolute value of the number reaches 0
00552   n = INTABS(num);
00553   do {
00554     // Increment the length and divide the number by 10
00555     len++;
00556     n /= 10;
00557   } while (n);
00558
00559   return len;
00560 }
00561
00562 namespace
00563 {
00564   // Unix: Returns the TEMPDIR, TMP, or TEMP directory, whichever is set to a
00565   // writeable directory.  If neither is set, return /tmp.
00566   // Windows: Return path returned by GetTempPath() windows function.
00567   // If it doesn't return a writeable directory, use current directory.
00568   CubitString get_temp_directory()
00569   {
00570 #ifdef _WIN32
00571
00572     //get a place to put the temporary file
00573     const DWORD buf_size = MAX_PATH;
00574     wchar_t temp_path[buf_size];
00575     GetTempPathW(buf_size, temp_path);
00576
00577     // If the path is not writeable, use the current directory instead
00578     DWORD atts = GetFileAttributesW(temp_path);
00579 #if _MSC_VER > 1200 // after VC6.0
00580     if (atts == INVALID_FILE_ATTRIBUTES ||      // File doesn't exist
00581         (atts & FILE_ATTRIBUTE_DIRECTORY) == 0 || // File isn't a directory
00582         atts & FILE_ATTRIBUTE_READONLY)         // File is read only
00583 #else
00584     if ((atts & FILE_ATTRIBUTE_DIRECTORY) == 0 || // File isn't a directory
00585         atts & FILE_ATTRIBUTE_READONLY)         // File is read only
00586 #endif
00587     {
00588       if (DEBUG_FLAG(141))
00589       {
00590         PRINT_DEBUG_141("\nUsing cwd because ");
00591 #if _MSC_VER > 1200
00592         if (atts == INVALID_FILE_ATTRIBUTES)
00593         {
00594           PRINT_DEBUG_141("directory doesn't exist: %s\n", CubitString::toUtf8(temp_path).c_str());
00595         }
00596         else if ((atts & FILE_ATTRIBUTE_DIRECTORY) == 0)
00597         {
00598           PRINT_DEBUG_141("file isn't a directory: %s\n", CubitString::toUtf8(temp_path).c_str());
00599         }
00600         else if (atts & FILE_ATTRIBUTE_READONLY)
00601         {
00602           PRINT_DEBUG_141("directory is read only: %s\n", CubitString::toUtf8(temp_path).c_str());
00603         }
00604 #else
00605         if ((atts & FILE_ATTRIBUTE_DIRECTORY) == 0)
00606         {
00607           PRINT_DEBUG_141("file isn't a directory: %s\n", CubitString::toUtf8(temp_path).c_str());
00608         }
00609         else if (atts & FILE_ATTRIBUTE_READONLY)
00610         {
00611           PRINT_DEBUG_141("directory is read only: %s\n", CubitString::toUtf8(temp_path).c_str());
00612         }
00613 #endif
00614       }
00615       temp_path[0] = '.';
00616       temp_path[1] = '\0';
00617     }
00618     else
00619     {
00620       PRINT_DEBUG_141("\nUsing GetTempPath: %s\n", CubitString::toUtf8(temp_path).c_str());
00621     }
00622     return CubitString::toUtf8(temp_path);
00623
00624 #else
00625
00626     const char* tmpdir = "/tmp";
00627     const char* env_tmpdir = getenv("TMPDIR");
00628     if (!env_tmpdir)
00629       env_tmpdir = getenv("TMP");
00630     if (!env_tmpdir)
00631       env_tmpdir = getenv("TEMP");
00632     if(env_tmpdir)
00633       tmpdir = env_tmpdir;
00634
00635     return tmpdir;
00636
00637 #endif
00638   }
00639 }
00640
00641 CubitString CubitUtil::get_temporary_filename()
00642 {
00643
00644   CubitString ret_str;
00645
00646 #ifdef _WIN32
00647
00648   //get a place to put the temporary file
00649   CubitString temp_path = get_temp_directory();
00650
00651   // make an empty temporary and return the name for it
00652   wchar_t temp_file_name[MAX_PATH];
00653   if( GetTempFileNameW(CubitString::toUtf16(temp_path.c_str()).c_str(), L"CBT", 0, temp_file_name) != 0 )
00654     ret_str = CubitString::toUtf8(temp_file_name);
00655
00656 #else
00657
00658   CubitString tmpdir = get_temp_directory();
00659   const char* filepattern = "CBT.XXXXXX";
00660     //needs to be two longer because of the "/"?
00661   char *temp_file_name = new char[tmpdir.length() + strlen(filepattern) + 2];
00662   sprintf(temp_file_name, "%s/%s", tmpdir.c_str(), filepattern);
00663
00664   // make an empty file and return the name for it
00665   int fd = mkstemp(temp_file_name);
00666   if( fd != -1 )
00667   {
00668     ret_str = temp_file_name;
00669     // release the open done by mkstemp,
00670     // temporary file still exists
00671     close(fd);
00672   }
00673   delete [] temp_file_name;
00674
00675 #endif
00676
00677   return ret_str;
00678 }
00679
00680 void CubitUtil::print_columns( const std::vector<CubitString>& array,
00681                                const CubitString& indent)
00682 {
00683   int term_height, term_width;
00684
00685   if( ! AppUtil::instance()->get_terminal_size( term_height, term_width ) )
00686   {
00687     for( size_t i = 0; i < array.size(); i++ )
00688     {
00689       PRINT_INFO("%s%s\n", indent.c_str(), array[i].c_str() );
00690     }
00691     return;
00692   }
00693
00694     // find lenth of longest string
00695   int maxlen = 0;
00696   for( size_t i = 0; i < array.size(); i++ )
00697   {
00698     int len = CubitUtil::string_length(array[i].c_str());
00699     if( len > maxlen )
00700       maxlen = len;
00701   }
00702
00703   char* const line = new char[CUBIT_MAX(maxlen,term_width)+2];
00704
00705     // calculate number of columns of output
00706   term_width -= string_length(indent.c_str());
00707   int width = maxlen + 1;
00708   int columns = term_width > width ? term_width / width : 1;
00709
00710     // calculate number of rows of output
00711   int rows = array.size() / columns;
00712   if( array.size() % columns )
00713     rows++;
00714
00715     // calculate the width of one column
00716   if (columns > 1)
00717     width = maxlen + (term_width - columns * maxlen) / (columns - 1);
00718   else
00719     width = term_width;
00720
00721     // now write output
00722   for( int i = 0; i < rows; i++ )
00723   {
00724     size_t idx;
00725     const char* str;
00726     char* ptr = line + sprintf( line, "%s", indent.c_str() );
00727     for(int j = 0; j < columns - 1; j++ )
00728     {
00729       idx = j * rows + i;
00730       if (idx < array.size() )
00731         str = array[idx].c_str();
00732       else
00733         str = "";
00734
00735       ptr += sprintf( ptr, "%-*s", width, str);
00736     }
00737
00738     idx = (columns - 1) * rows + i;
00739     if (idx < array.size() )
00740       sprintf(ptr, "%s\n", array[idx].c_str());
00741     else
00742       sprintf(ptr, "\n");
00743
00744     PRINT_INFO( "%s", line );
00745   }
00746
00747   delete [] line;
00748 }
00749
00750 int CubitUtil::string_length( const char* string, int tabsize )
00751 {
00752   int result = 0;
00753   for( ; *string ; string++ )
00754   {
00755     if( *string == '\t' )
00756       result += tabsize;
00757     else if( *string >= ' ' )
00758       result ++;
00759   }
00760   return result;
00761 }
00762
00763 //does the same thing as strdup... strdup is not supported by some
00764 // compilers
00765 char* CubitUtil::util_strdup(const char *s1)
00766 {
00767 #ifdef CUBIT_NO_STRDUP
00768   int len = strlen(s1)+1;
00769   char* ret_char = (char*) malloc ( (unsigned long) len * sizeof(char));
00770   strcpy(ret_char, s1);
00771   return ret_char;
00772 #else
00773 #ifdef _WIN32
00774   return _strdup(s1);
00775 #else
00776   return strdup(s1);
00777 #endif
00778 #endif
00779 }
00780
00781 void CubitUtil::cubit_sleep(int duration_in_seconds)
00782 {
00783 #ifdef _WIN32
00784   ::Sleep(duration_in_seconds*1000);
00785 #else
00786   sleep(duration_in_seconds);
00787 #endif
00788 }
00789
00790 CubitString CubitUtil::getenv(const CubitString& var)
00791 {
00792 #ifdef _WIN32
00793   return CubitString::toUtf8(_wgetenv(CubitString::toUtf16(var).c_str()));
00794 #else
00795   return CubitString(::getenv(var.c_str()));
00796 #endif
00797 }
00798
00799 void CubitUtil::setenv(const CubitString& var, const CubitString& value)
00800 {
00801 #ifdef _WIN32
00802   CubitString tmp = var + "=" + value;
00803   _wputenv(CubitString::toUtf16(tmp).c_str());
00804 #else
00805   ::setenv(var.c_str(), value.c_str(), 1);
00806 #endif
00807 }
00808
00809
00810 CubitString CubitUtil::get_computer_name()
00811 {
00812   CubitString name = "unknown";
00813 #ifdef _WIN32
00814   wchar_t machine_buf[MAX_COMPUTERNAME_LENGTH + 1];
00815   DWORD machine_buf_length = MAX_COMPUTERNAME_LENGTH + 1;
00816   if (::GetComputerNameW(machine_buf, &machine_buf_length))
00817     name = CubitString::toUtf8(machine_buf);
00818 #else
00819   struct utsname uname_data;
00820   if( uname( &uname_data ) >= 0 )
00821   {
00822     name = uname_data.nodename;
00823   }
00824 #endif
00825   return name;
00826 }
00827
00828 CubitString CubitUtil::get_os()
00829 {
00830 #ifdef _WIN32
00831   CubitString os = "Microsoft Windows";
00832   OSVERSIONINFO osvi;
00833
00834   ZeroMemory(&osvi, sizeof(OSVERSIONINFO));
00835   osvi.dwOSVersionInfoSize = sizeof(OSVERSIONINFO);
00836
00837   if(GetVersionEx(&osvi))
00838   {
00839     std::stringstream str;
00840     str << " ";
00841     str << osvi.dwMajorVersion << "." << osvi.dwMinorVersion;
00842     str << " ";
00843     str << osvi.szCSDVersion;
00844     DWORD build = osvi.dwBuildNumber & 0xFFFF;
00845     str << " (Build " << build << ")";
00846     os += str.str().c_str();
00847   }
00848 #else
00849   CubitString os = "unknown";
00850   struct utsname uname_data;
00851   if( uname( &uname_data ) >= 0 )
00852   {
00853     os = uname_data.sysname;
00854     os += " ";
00855     os += uname_data.release;
00856   }
00857 #endif
00858   return os;
00859 }
00860
00861 int CubitUtil::num_cpu()
00862 {
00863   int num_cpu = 0;
00864
00865   #ifdef _WIN32
00866     SYSTEM_INFO sysinfo;
00867     GetSystemInfo( &sysinfo );
00868     num_cpu = sysinfo.dwNumberOfProcessors;
00869   #else
00870     num_cpu = sysconf( _SC_NPROCESSORS_ONLN );
00871   #endif
00872
00873   return num_cpu;
00874 }
