cgma
CylinderEvaluator.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : CylinderEvaluator.hpp
00003 //
00004 // Purpose       : Provide evaluators for a cylindrical surface.  Since a cylinder
00005 //                 is an analytic primitive, its evaluators can be overwritten
00006 //                 rather than using the engine, or Facet based evaluators.
00007 //
00008 // Special Notes :
00009 //
00010 // Creator       : Matthew Staten
00011 //
00012 // Creation Date : 09/14/04
00013 //
00014 // Owner         : Matthew Staten
00015 //-------------------------------------------------------------------------
00016
00017 #ifndef CYLINDER_EVALUATOR_HPP
00018 #define CYLINDER_EVALUATOR_HPP
00019
00020 #include "CubitEvaluator.hpp"
00021 #include "CubitDefines.h"
00022 #include "CubitVector.hpp"
00023 #include "GeometryDefines.h"
00024
00025 class CUBIT_GEOM_EXPORT CylinderEvaluatorData : public CubitEvaluatorData
00026 {
00027 public:
00028     double height;
00029     double base_radius_x;
00030     double base_radius_y;
00031     double top_radius;
00032
00033     virtual GeometryType ask_type() const { return CONE_SURFACE_TYPE; }
00034 };
00035
00036 class CUBIT_GEOM_EXPORT CylinderEvaluator: public CubitEvaluator
00037 {
00038
00039 private:
00040
00041     CylinderEvaluatorData mEvalData;
00042
00043 protected:
00044
00045     CubitVector base() const;
00046
00047 public :
00048
00049     CylinderEvaluator( const CylinderEvaluatorData *data );
00050
00051   virtual ~CylinderEvaluator()
00052     {}
00053
00054     virtual GeometryType ask_type() { return CONE_SURFACE_TYPE; }
00055     virtual CubitBoolean is_parametric() const { return CUBIT_TRUE; }
00056     virtual CubitBoolean is_periodic() const { return CUBIT_TRUE; }
00057     virtual CubitBoolean is_periodic_in_U( double &period ) const { period = 2*CUBIT_PI;
00058        return CUBIT_TRUE; }
00059     virtual CubitBoolean is_periodic_in_V( double &period ) const { period = mEvalData.height;
00060        return CUBIT_FALSE; }
00061     virtual CubitBoolean is_singular_in_U() const { return CUBIT_FALSE; }
00062     virtual CubitBoolean is_singular_in_V() const { return CUBIT_FALSE; }
00063     virtual CubitBoolean is_closed_in_U() const { return CUBIT_TRUE; }
00064     virtual CubitBoolean is_closed_in_V() const { return CUBIT_FALSE; }
00065     virtual CubitBoolean get_param_range_U( double& lower_bound,
00066                                             double& upper_bound ) const;
00067     virtual CubitBoolean get_param_range_V( double& lower_bound,
00068                                             double& upper_bound ) const;
00069     virtual CubitVector position_from_u_v( double u, double v ) const;
00070     virtual CubitStatus u_v_from_position( CubitVector const& location,
00071                                            double& u,
00072                                            double& v,
00073                                            CubitVector* closest_location ) const;
00074
00075     virtual const CubitEvaluatorData* evaluator_data() const;
00076
00077     virtual CubitBox bounding_box() const;
00078     //- Return the bounding box of this cylinder.
00079
00080     virtual CubitStatus principal_curvatures( CubitVector const& location,
00081                                               double& curvature_1,
00082                                               double& curvature_2,
00083                                               CubitVector* closest_location = NULL );
00084     //R CubitStatus
00085     //R- CUBIT_SUCCESS/FAILURE
00086     //I location
00087     //I- The point at which the curvatures are being requested -- it is also
00088     //I- the point to which the closest point on the surface is returned.
00089     //I- curvatures.
00090     //O closest_location
00091     //O- The point on the surface, closest to the input location (this
00092     //O- might not be on the surface).  This is input as a reference
00093     //O- so that the function can modify its contents.
00094     //O curvature_1/2
00095     //O- Returned principal curvature magnitudes.
00096     //- This functions computes the point on the surface that is closest
00097     //- to the input location and then calculates the magnitudes of the
00098     //- principal curvatures at this (possibly, new) point on the surface.
00099
00100     virtual CubitStatus closest_point( CubitVector const& location,
00101                                        CubitVector* closest_location = NULL,
00102                                        CubitVector* unit_normal_ptr = NULL,
00103                                        CubitVector* curvature1_ptr = NULL,
00104                                        CubitVector* curvature2_ptr = NULL ) const;
00105     //R CubitStatus
00106     //R- CUBIT_SUCCESS/FAILURE
00107     //I location
00108     //I- The point to which the closest point on the surface is desired.
00109     //O closest_location
00110     //O- The point on the Surface, closest to the
00111     //O- input location (which might not be on the Surface).  This is
00112     //O- input as a reference so that the function can modify its
00113     //O- contents.
00114     //O unit_normal_ptr
00115     //O- The normal (represented as a unit vector) at the closest_location.
00116     //O- If this pointer is NULL, the normal is not returned.
00117     //O curvature1_ptr
00118     //O- The first principal curvature of the surface at closest_location.
00119     //O- If this pointer is NULL, this curvature is not returned.
00120     //O curvature2_ptr
00121     //O- The second principal curvature of the surface at closest_location.
00122     //O- If this pointer is NULL, this curvature is not returned.
00123     //- This function computes the point on the surface closest to the input
00124     //- location -- i.e., closest_location.
00125     //- The first Facet FACE in the list
00126     //- is queried.
00127     //-
00128     //- If the input pointer values of unit_normal, curvature1 and
00129     //- curvature2
00130     //- are non-NULL, the normal and principal curvatures, too, are
00131     //- returned.  These are computed at closest_location, not at the
00132     //- input location.
00133     //-
00134     //- NOTE:
00135     //- It is assumed that if the calling code needs the normal or the
00136     //- principal curvatures, it will *allocate* space for the CubitVectors
00137     //- before sending in the pointers.
00138
00139 };
00140
00141
00142 // ********** BEGIN INLINE FUNCTIONS       **********
00143 // ********** END INLINE FUNCTIONS         **********
00144
00145 // ********** BEGIN FRIEND FUNCTIONS       **********
00146 // ********** END FRIEND FUNCTIONS         **********
00147
00148 // ********** BEGIN EXTERN FUNCTIONS       **********
00149 // ********** END EXTERN FUNCTIONS         **********
00150
00151 #endif
00152
