cgma
00001 /* 00002 * 00003 * 00004 * Copyright (C) 2004 Sandia Corporation. Under the terms of Contract DE-AC04-94AL85000 00005 * with Sandia Corporation, the U.S. Government retains certain rights in this software. 00006 * 00007 * This file is part of facetbool--contact via cubit@sandia.gov 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 * This library is distributed in the hope that it will be useful, 00015 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 * Lesser General Public License for more details. 00018 * 00019 * You should have received a copy of the GNU Lesser General Public 00020 * License along with this library; if not, write to the Free Software 00021 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 * 00023 * 00024 * 00025 */ 00026 00027 #include "FBDataUtil.hpp" 00028 #include "GeometryDefines.h" 00029 #include "DLIList.hpp" 00030 00031 //=========================================================================== 00032 //Function Name: intersect_plane_with_boundingbox 00033 //Description: Find and return the number of intersections of a plane with 00034 // the edges of a bounding box. There will be 6 or fewer. 00035 // These will be returned in the intersection_points array. 00036 //Author: mlstate - rewritten from John Fowler's original version. 00037 //Date: 3/2005 00038 //=========================================================================== 00039 void FBDataUtil::intersect_plane_with_boundingbox(CubitBox &bbox, 00040 const CubitVector &v0, 00041 const CubitVector &v1, 00042 const CubitVector &v2, 00043 DLIList<CubitVector> &intersection_points ) 00044 { 00045 CubitVector v3 = v0 - v1; 00046 CubitVector v4 = v2 - v1; 00047 CubitVector threepointnormal = v3*v4; 00048 threepointnormal.normalize(); 00049 //CubitVector threepointcenter = (v0 + v1 + v2)/3.; 00050 // Need to get the size and location of the facetted cutting plane. Do this by 00051 // intersecting the 3-point plane with the bounding box edges. Will get a max of 00052 // six intersections. The size of the box for these intersections will determine 00053 // the cutting plane size; the centroid of the intersections will be the location 00054 // of the center of the cutting plane. 00055 00056 double a, b, c, d; // plane coefficients 00057 a = threepointnormal.x(); 00058 b = threepointnormal.y(); 00059 c = threepointnormal.z(); 00060 d = -(a*v0.x() + b*v0.y() + c*v0.z()); 00061 double xbmin, ybmin, zbmin, xbmax, ybmax, zbmax; 00062 double testpoint; 00063 00064 CubitVector boxmin = bbox.minimum(); 00065 xbmin = boxmin.x(); ybmin = boxmin.y(); zbmin = boxmin.z(); 00066 CubitVector boxmax = bbox.maximum(); 00067 xbmax = boxmax.x(); ybmax = boxmax.y(); zbmax = boxmax.z(); 00068 00069 if ( fabs(a) < GEOMETRY_RESABS && 00070 fabs(b) < GEOMETRY_RESABS ) 00071 { 00072 // Normal points in Z dir only. 00073 // a = 0; b = 0 00074 if ( ((zbmin + d/c) < -GEOMETRY_RESABS) && ((zbmax + d/c) > GEOMETRY_RESABS) ) 00075 { 00076 add_unique_point( intersection_points, CubitVector(xbmin, ybmin, -d/c) ); 00077 add_unique_point( intersection_points, CubitVector(xbmax, ybmin, -d/c) ); 00078 add_unique_point( intersection_points, CubitVector(xbmax, ybmax, -d/c) ); 00079 add_unique_point( intersection_points, CubitVector(xbmin, ybmax, -d/c) ); 00080 } 00081 } 00082 else if ( fabs(a) < GEOMETRY_RESABS && 00083 fabs(c) < GEOMETRY_RESABS ) 00084 { 00085 // Normal points in Y dir only. 00086 if ( ((ybmin + d/b) < -GEOMETRY_RESABS) && ((ybmax + d/b) > GEOMETRY_RESABS) ) 00087 { 00088 add_unique_point( intersection_points, CubitVector(xbmin, -d/b, zbmin ) ); 00089 add_unique_point( intersection_points, CubitVector(xbmax, -d/b, zbmin ) ); 00090 add_unique_point( intersection_points, CubitVector(xbmax, -d/b, zbmax ) ); 00091 add_unique_point( intersection_points, CubitVector(xbmin, -d/b, zbmax ) ); 00092 } 00093 } 00094 else if ( fabs(b) < GEOMETRY_RESABS && 00095 fabs(c) < GEOMETRY_RESABS ) 00096 { 00097 // Normal points in X dir only. 00098 if ( ((xbmin + d/a) < -GEOMETRY_RESABS) && ((xbmax + d/a) > GEOMETRY_RESABS) ) 00099 { 00100 add_unique_point( intersection_points, CubitVector(-d/a, ybmin, zbmin ) ); 00101 add_unique_point( intersection_points, CubitVector(-d/a, ybmax, zbmin ) ); 00102 add_unique_point( intersection_points, CubitVector(-d/a, ybmax, zbmax ) ); 00103 add_unique_point( intersection_points, CubitVector(-d/a, ybmin, zbmax ) ); 00104 } 00105 } 00106 else if ( fabs(a) < GEOMETRY_RESABS ) 00107 { 00108 // Normal is in YZ plane. 00109 testpoint = -(c*zbmin + d)/b; 00110 if ( (ybmin < (testpoint + GEOMETRY_RESABS)) && 00111 (ybmax > (testpoint - GEOMETRY_RESABS)) ) 00112 { 00113 add_unique_point( intersection_points, CubitVector(xbmin, testpoint, zbmin) ); 00114 add_unique_point( intersection_points, CubitVector(xbmax, testpoint, zbmin) ); 00115 } 00116 testpoint = -(c*zbmax + d)/b; 00117 if ( (ybmin < (testpoint + GEOMETRY_RESABS)) && 00118 (ybmax > (testpoint - GEOMETRY_RESABS)) ) 00119 { 00120 add_unique_point( intersection_points, CubitVector(xbmin, testpoint, zbmax) ); 00121 add_unique_point( intersection_points, CubitVector(xbmax, testpoint, zbmax) ); 00122 } 00123 testpoint = -(b*ybmin + d)/c; 00124 if ( (zbmin < (testpoint + GEOMETRY_RESABS)) && 00125 (zbmax > (testpoint - GEOMETRY_RESABS)) ) 00126 { 00127 add_unique_point( intersection_points, CubitVector(xbmin, ybmin, testpoint) ); 00128 add_unique_point( intersection_points, CubitVector(xbmax, ybmin, testpoint) ); 00129 } 00130 testpoint = -(b*ybmax + d)/c; 00131 if ( (zbmin < (testpoint + GEOMETRY_RESABS)) && 00132 (zbmax > (testpoint - GEOMETRY_RESABS)) ) 00133 { 00134 add_unique_point( intersection_points, CubitVector(xbmin, ybmax, testpoint) ); 00135 add_unique_point( intersection_points, CubitVector(xbmax, ybmax, testpoint) ); 00136 } 00137 } 00138 else if ( fabs(b) < GEOMETRY_RESABS ) 00139 { 00140 // Normal is in XZ plane 00141 testpoint = -(c*zbmin + d)/a; 00142 if ( (xbmin < (testpoint + GEOMETRY_RESABS)) && 00143 (xbmax > (testpoint - GEOMETRY_RESABS)) ) 00144 { 00145 add_unique_point( intersection_points, CubitVector(testpoint, ybmin, zbmin) ); 00146 add_unique_point( intersection_points, CubitVector(testpoint, ybmax, zbmin) ); 00147 } 00148 testpoint = -(c*zbmax + d)/a; 00149 if ( (xbmin < (testpoint + GEOMETRY_RESABS)) && 00150 (xbmax > (testpoint - GEOMETRY_RESABS)) ) 00151 { 00152 add_unique_point( intersection_points, CubitVector(testpoint, ybmin, zbmax) ); 00153 add_unique_point( intersection_points, CubitVector(testpoint, ybmax, zbmax) ); 00154 } 00155 testpoint = -(a*xbmin + d)/c; 00156 if ( (zbmin < (testpoint + GEOMETRY_RESABS)) && 00157 (zbmax > (testpoint - GEOMETRY_RESABS)) ) 00158 { 00159 add_unique_point( intersection_points, CubitVector(xbmin, ybmin, testpoint) ); 00160 add_unique_point( intersection_points, CubitVector(xbmin, ybmax, testpoint) ); 00161 } 00162 testpoint = -(a*xbmax + d)/c; 00163 if ( (zbmin < (testpoint + GEOMETRY_RESABS)) && 00164 (zbmax > (testpoint - GEOMETRY_RESABS)) ) 00165 { 00166 add_unique_point( intersection_points, CubitVector(xbmax, ybmin, testpoint) ); 00167 add_unique_point( intersection_points, CubitVector(xbmax, ybmax, testpoint) ); 00168 } 00169 } 00170 else if ( fabs(c) < GEOMETRY_RESABS ) 00171 { 00172 // Normal is in XY plane 00173 testpoint = -(a*xbmin + d)/b; 00174 if ( (ybmin < (testpoint + GEOMETRY_RESABS)) && 00175 (ybmax > (testpoint - GEOMETRY_RESABS)) ) 00176 { 00177 add_unique_point( intersection_points, CubitVector(xbmin, testpoint, zbmin) ); 00178 add_unique_point( intersection_points, CubitVector(xbmin, testpoint, zbmax) ); 00179 } 00180 testpoint = -(a*xbmax + d)/b; 00181 if ( (ybmin < (testpoint + GEOMETRY_RESABS)) && 00182 (ybmax > (testpoint - GEOMETRY_RESABS)) ) 00183 { 00184 add_unique_point( intersection_points, CubitVector(xbmax, testpoint, zbmin) ); 00185 add_unique_point( intersection_points, CubitVector(xbmax, testpoint, zbmax) ); 00186 } 00187 testpoint = -(b*ybmin + d)/a; 00188 if ( (xbmin < (testpoint + GEOMETRY_RESABS)) && 00189 (xbmax > (testpoint - GEOMETRY_RESABS)) ) 00190 { 00191 add_unique_point( intersection_points, CubitVector(testpoint, ybmin, zbmin) ); 00192 add_unique_point( intersection_points, CubitVector(testpoint, ybmin, zbmax) ); 00193 } 00194 testpoint = -(b*ybmax + d)/a; 00195 if ( (xbmin < (testpoint + GEOMETRY_RESABS)) && 00196 (xbmax > (testpoint - GEOMETRY_RESABS)) ) 00197 { 00198 add_unique_point( intersection_points, CubitVector(testpoint, ybmax, zbmin) ); 00199 add_unique_point( intersection_points, CubitVector(testpoint, ybmax, zbmax) ); 00200 } 00201 } 00202 else 00203 { 00204 // The general case 00205 // a != 0; b != 0; c != 0 00206 testpoint = -(b*ybmin + c*zbmin + d)/a; 00207 if ( (testpoint > (xbmin-GEOMETRY_RESABS)) && (testpoint < (xbmax+GEOMETRY_RESABS)) ) 00208 { 00209 add_unique_point( intersection_points, CubitVector(testpoint, ybmin, zbmin) ); 00210 } 00211 if ( intersection_points.size() == 6 ) return; 00212 testpoint = -(b*ybmax + c*zbmin + d)/a; 00213 if ( (testpoint > (xbmin-GEOMETRY_RESABS)) && (testpoint < (xbmax+GEOMETRY_RESABS)) ) 00214 { 00215 add_unique_point( intersection_points, CubitVector(testpoint, ybmax, zbmin) ); 00216 } 00217 if ( intersection_points.size() == 6 ) return; 00218 testpoint = -(b*ybmax + c*zbmax + d)/a; 00219 if ( (testpoint > (xbmin-GEOMETRY_RESABS)) && (testpoint < (xbmax+GEOMETRY_RESABS)) ) 00220 { 00221 add_unique_point( intersection_points, CubitVector(testpoint, ybmax, zbmax) ); 00222 } 00223 if ( intersection_points.size() == 6 ) return; 00224 testpoint = -(b*ybmin + c*zbmax + d)/a; 00225 if ( (testpoint > (xbmin-GEOMETRY_RESABS)) && (testpoint < (xbmax+GEOMETRY_RESABS)) ) 00226 { 00227 add_unique_point( intersection_points, CubitVector(testpoint, ybmin, zbmax) ); 00228 } 00229 if ( intersection_points.size() == 6 ) return; 00230 testpoint = -(a*xbmin + c*zbmin + d)/b; 00231 if ( (testpoint > (ybmin-GEOMETRY_RESABS)) && (testpoint < (ybmax+GEOMETRY_RESABS)) ) 00232 { 00233 add_unique_point( intersection_points, CubitVector(xbmin, testpoint, zbmin) ); 00234 } 00235 if ( intersection_points.size() == 6 ) return; 00236 testpoint = -(a*xbmax + c*zbmin + d)/b; 00237 if ( (testpoint > (ybmin-GEOMETRY_RESABS)) && (testpoint < (ybmax+GEOMETRY_RESABS)) ) 00238 { 00239 add_unique_point( intersection_points, CubitVector(xbmax, testpoint, zbmin) ); 00240 } 00241 if ( intersection_points.size() == 6 ) return; 00242 testpoint = -(a*xbmax + c*zbmax + d)/b; 00243 if ( (testpoint > (ybmin-GEOMETRY_RESABS)) && (testpoint < (ybmax+GEOMETRY_RESABS)) ) 00244 { 00245 add_unique_point( intersection_points, CubitVector(xbmax, testpoint, zbmax) ); 00246 } 00247 if ( intersection_points.size() == 6 ) return; 00248 testpoint = -(a*xbmin + c*zbmax + d)/b; 00249 if ( (testpoint > (ybmin-GEOMETRY_RESABS)) && (testpoint < (ybmax+GEOMETRY_RESABS)) ) 00250 { 00251 add_unique_point( intersection_points, CubitVector(xbmin, testpoint, zbmax) ); 00252 } 00253 if ( intersection_points.size() == 6 ) return; 00254 testpoint = -(a*xbmin + b*ybmin + d)/c; 00255 if ( (testpoint > (zbmin-GEOMETRY_RESABS)) && (testpoint < (zbmax+GEOMETRY_RESABS)) ) 00256 { 00257 add_unique_point( intersection_points, CubitVector(xbmin, ybmin, testpoint) ); 00258 } 00259 if ( intersection_points.size() == 6 ) return; 00260 testpoint = -(a*xbmax + b*ybmin + d)/c; 00261 if ( (testpoint > (zbmin-GEOMETRY_RESABS)) && (testpoint < (zbmax+GEOMETRY_RESABS)) ) 00262 { 00263 add_unique_point( intersection_points, CubitVector(xbmax, ybmin, testpoint) ); 00264 } 00265 if ( intersection_points.size() == 6 ) return; 00266 testpoint = -(a*xbmax + b*ybmax + d)/c; 00267 if ( (testpoint > (zbmin-GEOMETRY_RESABS)) && (testpoint < (zbmax+GEOMETRY_RESABS)) ) 00268 { 00269 add_unique_point( intersection_points, CubitVector(xbmax, ybmax, testpoint) ); 00270 } 00271 if ( intersection_points.size() == 6 ) return; 00272 testpoint = -(a*xbmin + b*ybmax + d)/c; 00273 if ( (testpoint > (zbmin-GEOMETRY_RESABS)) && (testpoint < (zbmax+GEOMETRY_RESABS)) ) 00274 { 00275 add_unique_point( intersection_points, CubitVector(xbmin, ybmax, testpoint) ); 00276 } 00277 } 00278 } 00279 00280 //=========================================================================== 00281 //Function Name: add_unique_point 00282 //Description: Given a point and a list of points, add the point to the list 00283 // unless it is already in the list within GEOMETRY_RESABS. 00284 //Author: 00285 //Date: 3/2005 00286 //=========================================================================== 00287 void FBDataUtil::add_unique_point 00288 ( 00289 DLIList<CubitVector > &points, 00290 const CubitVector &pt 00291 ) 00292 { 00293 int ipt; 00294 for ( ipt = 0; ipt < points.size(); ipt++ ) 00295 { 00296 double dist = pt.distance_between( points[ipt] ); 00297 if ( dist <= GEOMETRY_RESABS ) 00298 { 00299 return; 00300 } 00301 } 00302 points.append( pt ); 00303 } 00304 00305 //=========================================================================== 00306 //Function Name: FBmake_xy_plane 00307 //Description: Makes a triangle plane centered on the origin in the x-y 00308 // direction. 00309 //Author: jdfowle 00310 //Date: 1/2004 00311 //=========================================================================== 00312 CubitStatus FBDataUtil::FBmake_xy_plane(std::vector<double>& verts, 00313 std::vector<int>& conns, 00314 double xsize, 00315 double ysize, 00316 int numx, 00317 int numy) 00318 { 00319 int i, j; 00320 double xc, yc, zc, xinc, yinc; 00321 00322 zc = 0.; 00323 xinc = xsize/(double)(numx-1); 00324 yinc = ysize/(double)(numy-1); 00325 xc = -0.5*xsize; 00326 // Make the coordinates 00327 for ( i = 0; i < numx; i++ ) { 00328 yc = -0.5*ysize; 00329 for ( j = 0; j < numy; j++ ) { 00330 verts.push_back(xc); 00331 verts.push_back(yc); 00332 verts.push_back(zc); 00333 yc += yinc; 00334 } 00335 xc += xinc; 00336 } 00337 // Make the connections 00338 int i1, i2, i3, i4; 00339 00340 for ( i = 0; i < numx-1; i++ ) { 00341 00342 for ( j = 0; j < numy-1; j++ ) { 00343 i1 = numy*i + j; 00344 i2 = numy*(i+1) + j; 00345 i3 = numy*i + j + 1; 00346 i4 = numy*(i+1) + j + 1; 00347 conns.push_back(i1); 00348 conns.push_back(i2); 00349 conns.push_back(i4); 00350 conns.push_back(i1); 00351 conns.push_back(i4); 00352 conns.push_back(i3); 00353 } 00354 } 00355 00356 return CUBIT_SUCCESS; 00357 } 00358 00359 //=========================================================================== 00360 //Function Name: rotate_FB_object 00361 //Description: Rotates a facetedboolean object so that the z-direction 00362 // points in the direction of NormalDir 00363 //Author: jdfowle 00364 //Date: 1/2004 00365 //=========================================================================== 00366 CubitStatus FBDataUtil::rotate_FB_object(std::vector<double>& verts, 00367 CubitVector &NormalDir, CubitVector &CenterPt) 00368 { 00369 unsigned int i; 00370 double l1, l2, l3, m1, m2, m3, n1, n2, n3; 00371 double tnx, tny, tnz, temp; 00372 double tx, ty, tz; 00373 double xpcen, ypcen, zpcen; 00374 00375 tnx = NormalDir.x(); 00376 tny = NormalDir.y(); 00377 tnz = NormalDir.z(); 00378 xpcen = CenterPt.x(); 00379 ypcen = CenterPt.y(); 00380 zpcen = CenterPt.z(); 00381 00382 n1 = tnx; n2 = tny; n3 = tnz; 00383 l1 = n3; l2 = 0.; l3 = -n1; 00384 m1 = -n1*n2; m2 = n1*n1 + n3*n3; m3 = -n2*n3; 00385 temp = sqrt(l1*l1 + l3*l3); 00386 if ( fabs(temp) > 1.e-6 ) { 00387 l1 /= temp; l3 /= temp; 00388 temp = sqrt(m1*m1 + m2*m2 + m3*m3); 00389 m1 /= temp; m2 /= temp; m3 /= temp; 00390 } else { 00391 l1 = 1.; l2 = l3 = 0.; 00392 m1 = m2 = 0.; m3 = 1.; 00393 n1 = n3 = 0.; n2 = -1.; 00394 } 00395 // Rotate the plane, whiuch is normal to the Z axis and through the origin, 00396 // so that it will be normal to threepointnormal. Also translate it so 00397 // that the center point, (0,0,0), moves to threepointcenter. 00398 for ( i = 0; i < verts.size(); i += 3 ) { 00399 tx = verts[i]; 00400 ty = verts[i+1]; 00401 tz = verts[i+2]; 00402 verts[i] = tx*l1 + ty*m1 + tz*n1 + xpcen; 00403 verts[i+1] = tx*l2 + ty*m2 + tz*n2 + ypcen; 00404 verts[i+2] = tx*l3 + ty*m3 + tz*n3 + zpcen; 00405 } 00406 00407 return CUBIT_SUCCESS; 00408 } 00409 00410 int FBDataUtil::makeahashvaluefrom_coord(double x, double y, double z, int numhashbins) 00411 { 00412 double sum; 00413 00414 if ( fabs(x) < 1.e-3 ) x = 0.0; 00415 if ( fabs(y) < 1.e-3 ) y = 0.0; 00416 if ( fabs(z) < 1.e-3 ) z = 0.0; 00417 sum = (int)(10000.0*fabs(x) + 0.5) + 00418 (int)(10000.0*fabs(y) + 0.5) + 00419 (int)(10000.0*fabs(z) + 0.5); 00420 00421 return (int)(sum) % numhashbins; 00422 } 00423 00424 CubitStatus FBDataUtil::FBmake_cylinder(std::vector<double>& verts, 00425 std::vector<int>& coords, 00426 double radius, 00427 double length, 00428 int nr, 00429 int nz) 00430 { 00431 int i, j; 00432 CubitStatus status; 00433 double cfac, rinc, linc; 00434 double x, y, z; 00435 int istart, iend, V3, pend; 00436 double zoffset, lpos, rpos, xrad, yrad; 00437 00438 status = CUBIT_SUCCESS; 00439 00440 rinc = 360.0/(double)nr; 00441 linc = length/(double)nz; 00442 cfac = CUBIT_PI/180.; 00443 00444 istart = 0; iend = nz+1; 00445 V3 = (nz+1)*nr; 00446 pend = nz; 00447 00448 00449 // Make the points. 00450 00451 zoffset = 0.0; 00452 lpos = -0.5*length; 00453 xrad = radius; 00454 yrad = radius; 00455 for ( i = istart; i < iend; i++ ) { 00456 rpos = 10.0; 00457 for ( j = 0; j < nr; j++ ) { 00458 x = xrad*cos(cfac*rpos); 00459 y = yrad*sin(cfac*rpos); 00460 z = lpos; 00461 verts.push_back(x); 00462 verts.push_back(y); 00463 verts.push_back(z); 00464 rpos += rinc; 00465 } 00466 lpos += linc; 00467 zoffset += linc; 00468 } 00469 // Add the two points on the axis at the ends. 00470 verts.push_back(0.); 00471 verts.push_back(0.); 00472 verts.push_back(-0.5*length); 00473 verts.push_back(0.); 00474 verts.push_back(0.); 00475 verts.push_back(0.5*length); 00476 00477 // Make the triangles. 00478 int vertnum; 00479 vertnum = 0; 00480 for ( i = 0; i < pend; i++ ) { 00481 for ( j = 0; j < nr-1; j++ ) { 00482 // facet_ptr = new CubitFacetData( points[vertnum+j],points[vertnum+j+1], points[vertnum+j+nr] ); 00483 coords.push_back(vertnum+j); 00484 coords.push_back(vertnum+j+1); 00485 coords.push_back(vertnum+j+nr); 00486 00487 // facet_ptr = new CubitFacetData( points[vertnum+j+1],points[vertnum+j+1+nr], points[vertnum+j+nr] ); 00488 coords.push_back(vertnum+j+1); 00489 coords.push_back(vertnum+j+1+nr); 00490 coords.push_back(vertnum+j+nr); 00491 00492 } 00493 // facet_ptr = new CubitFacetData( points[vertnum],points[vertnum+nr], points[vertnum+2*nr-1] ); 00494 coords.push_back(vertnum); 00495 coords.push_back(vertnum+nr); 00496 coords.push_back(vertnum+2*nr-1); 00497 00498 // facet_ptr = new CubitFacetData( points[vertnum+nr-1],points[vertnum], points[vertnum+2*nr-1] ); 00499 coords.push_back(vertnum+nr-1); 00500 coords.push_back(vertnum); 00501 coords.push_back(vertnum+2*nr-1); 00502 00503 vertnum += nr; 00504 } 00505 00506 // Endcap(s) 00507 for ( i = 0; i < nr-1; i++ ) { // top cap 00508 // facet_ptr = new CubitFacetData( points[vertnum+i],points[vertnum+i+1], points[V3+1] ); 00509 coords.push_back(vertnum+i); 00510 coords.push_back(vertnum+i+1); 00511 coords.push_back(V3+1); 00512 00513 } 00514 // facet_ptr = new CubitFacetData( points[nr-1+vertnum],points[vertnum], points[V3+1] ); 00515 coords.push_back(vertnum+nr-1); 00516 coords.push_back(vertnum); 00517 coords.push_back(V3+1); 00518 00519 00520 for ( i = 0; i < nr-1; i++ ) { // bottom cap 00521 // facet_ptr = new CubitFacetData( points[i+1],points[i], points[V3] ); 00522 coords.push_back(i+1); 00523 coords.push_back(i); 00524 coords.push_back(V3); 00525 00526 } 00527 // facet_ptr = new CubitFacetData( points[0],points[nr-1], points[V3] ); 00528 coords.push_back(0); 00529 coords.push_back(nr-1); 00530 coords.push_back(V3); 00531 00532 return status; 00533 00534 } 00535 00536 double FBDataUtil::project_point_to_plane(double *point, double a, double b, 00537 double c, double d, 00538 double *projected_pt) 00539 { 00540 double signed_distance; 00541 00542 signed_distance = point[0]*a + point[1]*b + point[2]*c + d; 00543 projected_pt[0] = point[0] - signed_distance*a; 00544 projected_pt[1] = point[1] - signed_distance*b; 00545 projected_pt[2] = point[2] - signed_distance*c; 00546 00547 00548 return signed_distance; 00549 00550 } 00551 00552 00553 #define EPS_SEG_SEG 1.e-6 00554 // From Schneider and Eberly,"Geometric Tools for Computer Graphics", 00555 // Chap. 10.8, segment to segment 00556 // Note: if the segments are parallel, *s and *t are undefined; *parallel 00557 // is true; *sunclipped = 0.0, and *tunclipped is the corresponding value 00558 // for t. 00559 double FBDataUtil::closest_seg_seg_dist(double *p0, double *d0, double *p1, 00560 double *d1, double *s, double *t, 00561 double *sunclipped, double *tunclipped, 00562 bool *parallel) 00563 { 00564 double ux, uy, uz; 00565 double a, b, c, d, e, det; 00566 double snum, sdenom, tnum, tdenom; 00567 00568 *parallel = false; 00569 00570 ux = p0[0] - p1[0]; 00571 uy = p0[1] - p1[1]; 00572 uz = p0[2] - p1[2]; 00573 00574 a = d0[0]*d0[0] + d0[1]*d0[1] + d0[2]*d0[2]; 00575 b = d0[0]*d1[0] + d0[1]*d1[1] + d0[2]*d1[2]; 00576 c = d1[0]*d1[0] + d1[1]*d1[1] + d1[2]*d1[2]; 00577 d = d0[0]*ux + d0[1]*uy + d0[2]*uz; 00578 e = d1[0]*ux + d1[1]*uy + d1[2]*uz; 00579 det = a*c - b*b; 00580 00581 if ( det < EPS_SEG_SEG ) { 00582 snum = 0.; 00583 tnum = e; 00584 tdenom = c; 00585 sdenom = 1.; 00586 *sunclipped = snum/sdenom; 00587 *tunclipped = tnum/tdenom; 00588 double f = ux*ux + uy*uy + uz*uz; 00589 *parallel = true; 00590 return sqrt(f - e*e/c); 00591 } else { 00592 snum = b*e - c*d; 00593 tnum = a*e - b*d; 00594 sdenom = det; 00595 *sunclipped = snum/det; 00596 *tunclipped = tnum/det; 00597 } 00598 00599 00600 if ( snum < 0.0 ) { 00601 snum = 0.0; 00602 tnum = e; 00603 tdenom = c; 00604 } else if ( snum > det ) { 00605 snum = det; 00606 tnum = e + b; 00607 tdenom = c; 00608 } else { 00609 tdenom = det; 00610 } 00611 00612 if ( tnum < 0.0 ) { 00613 tnum = 0.0; 00614 if ( -d < 0.0 ) { 00615 snum = 0.0; 00616 } else if ( -d > a ) { 00617 snum = sdenom; 00618 } else { 00619 snum = -d; 00620 sdenom = a; 00621 } 00622 } else if ( tnum > tdenom ) { 00623 tnum = tdenom; 00624 if ( (-d + b) < 0.0 ) { 00625 snum = 0.0; 00626 } else if ( (-d + b) > a ) { 00627 snum = sdenom; 00628 } else { 00629 snum = -d + b; 00630 sdenom = a; 00631 } 00632 } 00633 00634 *s = snum/sdenom; 00635 *t = tnum/tdenom; 00636 00637 double vx, vy, vz; 00638 vx = p0[0] + (*s*d0[0]) - (p1[0] + (*t*d1[0])); 00639 vy = p0[1] + (*s*d0[1]) - (p1[1] + (*t*d1[1])); 00640 vz = p0[2] + (*s*d0[2]) - (p1[2] + (*t*d1[2])); 00641 00642 return sqrt(vx*vx + vy*vy + vz*vz); 00643 00644 }
