cgma
00001 /* 00002 * 00003 * 00004 * Copyright (C) 2004 Sandia Corporation. Under the terms of Contract DE-AC04-94AL85000 00005 * with Sandia Corporation, the U.S. Government retains certain rights in this software. 00006 * 00007 * This file is part of facetbool--contact via cubit@sandia.gov 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 * This library is distributed in the hope that it will be useful, 00015 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 * Lesser General Public License for more details. 00018 * 00019 * You should have received a copy of the GNU Lesser General Public 00020 * License along with this library; if not, write to the Free Software 00021 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 * 00023 * 00024 * 00025 */ 00026 00027 #include <vector> 00028 #include "FBIntersect.hpp" 00029 #include "FBPolyhedron.hpp" 00030 #include "FBRetriangulate.hpp" 00031 #include "CubitMessage.hpp" 00032 #include "GfxDebug.hpp" 00033 #include "GeometryDefines.h" 00034 00035 FBIntersect::FBIntersect() 00036 { 00037 poly1 = poly2 = 0; 00038 do_classify = false; 00039 do_edges_only = false; 00040 do_imprint = false; 00041 classify1 = classify2 = 0; 00042 body1_is_plane = body2_is_plane = false; 00043 f_c_indices1 = f_c_indices2 = 0; 00044 nothing_intersected = false; 00045 } 00046 00047 FBIntersect::~FBIntersect() 00048 { 00049 if ( poly1 ) delete poly1; 00050 if ( poly2 ) delete poly2; 00051 if ( classify1 ) delete classify1; 00052 if ( classify2 ) delete classify2; 00053 } 00054 00055 CubitStatus FBIntersect::intersect(const std::vector<double>& Ticoords, 00056 const std::vector<int>& Ticonnections, 00057 const std::vector<double>& Tjcoords, 00058 const std::vector<int>& Tjconnections, 00059 std::vector<int>& duddedTiFacets, 00060 std::vector<int>& duddedTjFacets, 00061 std::vector<int>& newTiFacets, 00062 std::vector<int>& newTjFacets, 00063 std::vector<int>& newTiFacetsIndex, 00064 std::vector<int>& newTjFacetsIndex, 00065 std::vector<double>& newTiPoints, 00066 std::vector<double>& newTjPoints, 00067 std::vector<int>& edgesTi, 00068 std::vector<int>& edgesTj 00069 ) 00070 { 00071 CubitStatus status; 00072 bool boxes_intersect; 00073 00074 status = CUBIT_SUCCESS; 00075 00076 if ( Ticoords.size()%3 != 0 ) { 00077 PRINT_ERROR("Bad coordinates for first part fed to FBIntersect.\n"); 00078 return CUBIT_FAILURE; 00079 } 00080 if ( Tjcoords.size()%3 != 0 ) { 00081 PRINT_ERROR("Bad coordinates for second part fed to FBIntersect.\n"); 00082 return CUBIT_FAILURE; 00083 } 00084 if ( Ticonnections.size()%3 != 0 ) { 00085 PRINT_ERROR("Bad connection list for first part fed to FBIntersect.\n"); 00086 return CUBIT_FAILURE; 00087 } 00088 if ( Tjconnections.size()%3 != 0 ) { 00089 PRINT_ERROR("Bad connection list for second part fed to FBIntersect.\n"); 00090 return CUBIT_FAILURE; 00091 } 00092 00093 poly1 = new FBPolyhedron; 00094 status = poly1->makepoly(Ticoords,Ticonnections,f_c_indices1); 00095 if ( status != CUBIT_SUCCESS ) 00096 { 00097 return status; 00098 } 00099 00100 poly2 = new FBPolyhedron; 00101 status = poly2->makepoly(Tjcoords,Tjconnections,f_c_indices2); 00102 if ( status != CUBIT_SUCCESS ) 00103 { 00104 return status; 00105 } 00106 00107 boxes_intersect = poly1->boxintersection(poly2); 00108 if ( boxes_intersect == false ) { 00109 nothing_intersected = true; 00110 return status; 00111 } 00112 00113 status = pair_intersect(); 00114 if ( status != CUBIT_SUCCESS ) 00115 { 00116 return status; 00117 } 00118 00119 poly1->putnewpoints(newTiPoints); 00120 poly2->putnewpoints(newTjPoints); 00121 00122 poly1->putedges(edgesTi); 00123 poly2->putedges(edgesTj); 00124 00125 status = poly1->retriangulate(newTiFacets, newTiFacetsIndex); 00126 if ( status != CUBIT_SUCCESS ) 00127 { 00128 return status; 00129 } 00130 00131 status = poly2->retriangulate(newTjFacets, newTjFacetsIndex); 00132 if ( status != CUBIT_SUCCESS ) 00133 { 00134 return status; 00135 } 00136 00137 unsigned int i; 00138 for ( i = 0; i < poly1->tris.size(); i++ ) { 00139 if ( poly1->tris[i]->dudded == true ) duddedTiFacets.push_back(i); 00140 } 00141 00142 for ( i = 0; i < poly2->tris.size(); i++ ) { 00143 if ( poly2->tris[i]->dudded == true ) duddedTjFacets.push_back(i); 00144 } 00145 00146 // newxxFacets is updated in FBRetriangulate::make_this_tri() after 00147 // a new triangle has been made. Also newxxFacetsIndex is updated if 00148 // any new facets were made. But this update points to the start of 00149 // newxxFacets. Therefore we have to add on the last member to 00150 // newxxFacetsIndex here. 00151 newTiFacetsIndex.push_back(newTiFacets.size()); 00152 newTjFacetsIndex.push_back(newTjFacets.size()); 00153 00154 // If classification of the intersected surface parts is needed, we need to 00155 // do some things. 00156 bool other_is_planar; 00157 if ( do_classify == true ) { 00158 poly1->add_new_triangle_data(); 00159 poly2->add_new_triangle_data(); 00160 poly1->removeduddedtriangles(); 00161 poly2->removeduddedtriangles(); 00162 classify1 = new FBClassify; 00163 classify1->SetPoly(poly1, poly2); 00164 status = classify1->Group(1); 00165 if ( status != CUBIT_SUCCESS ) 00166 { 00167 return status; 00168 } 00169 other_is_planar = body2_is_plane; 00170 status = classify1->CharacterizeGroups(1,other_is_planar); 00171 if ( status != CUBIT_SUCCESS ) 00172 { 00173 return status; 00174 } 00175 classify2 = new FBClassify; 00176 classify2->SetPoly(poly1, poly2); 00177 status = classify2->Group(2); 00178 if ( status != CUBIT_SUCCESS ) 00179 { 00180 return status; 00181 } 00182 other_is_planar = body1_is_plane; 00183 status = classify2->CharacterizeGroups(2,other_is_planar); 00184 if ( status != CUBIT_SUCCESS ) 00185 { 00186 return status; 00187 } 00188 } 00189 00190 return status; 00191 00192 } 00193 00194 CubitStatus FBIntersect::intersect(const std::vector<double>& Ticoords, 00195 const std::vector<int>& Ticonnections, 00196 const std::vector<double>& Tjcoords, 00197 const std::vector<int>& Tjconnections, 00198 std::vector<int>& newTiFacets, 00199 std::vector<int>& newTjFacets, 00200 std::vector<int> *indices1, 00201 std::vector<int> *indices2 00202 ) 00203 { 00204 CubitStatus status; 00205 bool boxes_intersect; 00206 00207 status = CUBIT_SUCCESS; 00208 00209 if ( Ticoords.size()%3 != 0 ) { 00210 PRINT_ERROR("Bad coordinates for first part fed to FBIntersect.\n"); 00211 return CUBIT_FAILURE; 00212 } 00213 if ( Tjcoords.size()%3 != 0 ) { 00214 PRINT_ERROR("Bad coordinates for second part fed to FBIntersect.\n"); 00215 return CUBIT_FAILURE; 00216 } 00217 if ( Ticonnections.size()%3 != 0 ) { 00218 PRINT_ERROR("Bad connection list for first part fed to FBIntersect.\n"); 00219 return CUBIT_FAILURE; 00220 } 00221 if ( Tjconnections.size()%3 != 0 ) { 00222 PRINT_ERROR("Bad connection list for second part fed to FBIntersect.\n"); 00223 return CUBIT_FAILURE; 00224 } 00225 00226 f_c_indices1 = indices1; 00227 f_c_indices2 = indices2; 00228 00229 poly1 = new FBPolyhedron; 00230 status = poly1->makepoly(Ticoords,Ticonnections,f_c_indices1); 00231 if ( status != CUBIT_SUCCESS ) 00232 { 00233 return status; 00234 } 00235 00236 poly2 = new FBPolyhedron; 00237 status = poly2->makepoly(Tjcoords,Tjconnections,f_c_indices2); 00238 if ( status != CUBIT_SUCCESS ) 00239 { 00240 return status; 00241 } 00242 00243 double min_angle=0.0, max_angle=0.0; 00244 int mydebug = 0; 00245 if(mydebug){ 00246 poly1->min_max_angles_in_polyhedron(min_angle, max_angle); 00247 00248 PRINT_INFO("(0) Min angle in poly1 %f, max angle %f\n", min_angle, 00249 max_angle); 00250 poly2->min_max_angles_in_polyhedron(min_angle, max_angle); 00251 PRINT_INFO("(0) Min angle in poly2 %f, max angle %f\n", min_angle, 00252 max_angle); 00253 } 00254 boxes_intersect = poly1->boxintersection(poly2); 00255 if ( boxes_intersect == false ) { 00256 nothing_intersected = true; 00257 //don't return because in the case of union we need to unite the 00258 //bodies even if they do not intersect 00259 //return status; 00260 } 00261 else{ 00262 status = pair_intersect(); 00263 if ( status != CUBIT_SUCCESS ) 00264 { 00265 return status; 00266 } 00267 } 00268 00269 if(mydebug){ 00270 poly1->min_max_angles_in_polyhedron(min_angle, max_angle); 00271 PRINT_INFO("(1) Min angle in poly1 %f, max angle %f\n", min_angle, 00272 max_angle); 00273 poly2->min_max_angles_in_polyhedron(min_angle, max_angle); 00274 PRINT_INFO("(1) Min angle in poly2 %f, max angle %f\n", min_angle, 00275 max_angle); 00276 } 00277 00278 status = poly1->retriangulate(newTiFacets); 00279 if ( status != CUBIT_SUCCESS ) 00280 { 00281 return status; 00282 } 00283 status = poly2->retriangulate(newTjFacets); 00284 if ( status != CUBIT_SUCCESS ) 00285 { 00286 return status; 00287 } 00288 00289 if(mydebug){ 00290 GfxDebug::clear(); 00291 poly1->debug_draw_boundary_edges(CUBIT_BLUE_INDEX); 00292 GfxDebug::mouse_xforms(); 00293 GfxDebug::clear(); 00294 poly2->debug_draw_boundary_edges(CUBIT_RED_INDEX); 00295 GfxDebug::mouse_xforms(); 00296 poly1->min_max_angles_in_polyhedron(min_angle, max_angle); 00297 00298 PRINT_INFO("(2) Min angle in poly1 %f, max angle %f\n", min_angle, 00299 max_angle); 00300 poly2->min_max_angles_in_polyhedron(min_angle, max_angle); 00301 PRINT_INFO("(2) Min angle in poly2 %f, max angle %f\n", min_angle, 00302 max_angle); 00303 } 00304 // If classification of the intersected surface parts is needed, we need to 00305 // do some things. 00306 bool other_is_planar; 00307 if ( do_classify == true ) { 00308 poly1->add_new_triangle_data(); 00309 poly2->add_new_triangle_data(); 00310 poly1->removeduddedtriangles(); 00311 poly2->removeduddedtriangles(); 00312 classify1 = new FBClassify; 00313 classify1->SetPoly(poly1, poly2); 00314 status = classify1->Group(1); 00315 if ( status != CUBIT_SUCCESS ) 00316 { 00317 return status; 00318 } 00319 other_is_planar = body2_is_plane; 00320 status = classify1->CharacterizeGroups(1,other_is_planar); 00321 if ( status != CUBIT_SUCCESS ) 00322 { 00323 return status; 00324 } 00325 classify2 = new FBClassify; 00326 classify2->SetPoly(poly1, poly2); 00327 status = classify2->Group(2); 00328 if ( status != CUBIT_SUCCESS ) 00329 { 00330 return status; 00331 } 00332 other_is_planar = body1_is_plane; 00333 status = classify2->CharacterizeGroups(2,other_is_planar); 00334 if ( status != CUBIT_SUCCESS ) 00335 { 00336 return status; 00337 } 00338 } 00339 00340 return status; 00341 00342 } 00343 00344 CubitStatus FBIntersect::pair_intersect() 00345 { 00346 CubitStatus status; 00347 unsigned int i, j, k; 00348 int numboxesfound, *boxlist; 00349 double dtemp; 00350 00351 boxlist = new int[poly2->tris.size()]; 00352 00353 status = CUBIT_SUCCESS; 00354 for ( i = 0; i < poly1->tris.size(); i++ ) { 00355 FB_Triangle *tri1 = poly1->tris[i]; 00356 if ( (tri1->boundingbox.xmax < poly2->polyxmin) || 00357 (tri1->boundingbox.xmin > poly2->polyxmax) || 00358 (tri1->boundingbox.ymax < poly2->polyymin) || 00359 (tri1->boundingbox.ymin > poly2->polyymax) || 00360 (tri1->boundingbox.zmax < poly2->polyzmin) || 00361 (tri1->boundingbox.zmin > poly2->polyzmax) ) continue; 00362 poly2->kdtree->box_kdtree_intersect(tri1->boundingbox,&numboxesfound,boxlist); 00363 00364 for ( j = 0; j < (unsigned int)numboxesfound; j++ ) { 00365 FB_Triangle *tri2 = poly2->tris[boxlist[j]]; 00366 if ( (tri1->boundingbox.xmax < tri2->boundingbox.xmin) || 00367 (tri1->boundingbox.xmin > tri2->boundingbox.xmax) || 00368 (tri1->boundingbox.ymax < tri2->boundingbox.ymin) || 00369 (tri1->boundingbox.ymin > tri2->boundingbox.ymax) || 00370 (tri1->boundingbox.zmax < tri2->boundingbox.zmin ) || 00371 (tri1->boundingbox.zmin > tri2->boundingbox.zmax) ) continue; 00372 00373 int mydebug = 0; 00374 if ( mydebug ) 00375 { 00376 // Draw the 2 facets which are intersecting. 00377 GfxDebug::clear(); 00378 poly1->debug_draw_boundary_edges(CUBIT_YELLOW_INDEX); 00379 poly2->debug_draw_boundary_edges(CUBIT_PINK_INDEX); 00380 poly1->debug_draw_fb_triangle(tri1); 00381 poly2->debug_draw_fb_triangle(tri2); 00382 GfxDebug::mouse_xforms(); 00383 } 00384 00385 // Find the line of intersection of the two triangle planes. 00386 linecoeff[0] = tri1->c*tri2->b - tri1->b*tri2->c; 00387 linecoeff[1] = tri1->a*tri2->c - tri1->c*tri2->a; 00388 linecoeff[2] = tri1->b*tri2->a - tri1->a*tri2->b; 00389 00390 if ( (fabs(linecoeff[0]) < EPSILON) && 00391 (fabs(linecoeff[1]) < EPSILON) && 00392 (fabs(linecoeff[2]) < EPSILON) ) { 00393 if ( do_imprint == true ) continue; 00394 // Don't intersect nearly-coplanar triangles. 00395 00396 // calculate the distance between the triangles. Just because they are coplanar 00397 // does not mean we have to intersect. If the distance between them is larger than 00398 // GEOMETRY_RESABS, then just continue on. 00399 double dist = poly1->verts[tri1->v2]->coord[0]*tri2->a + 00400 poly1->verts[tri1->v2]->coord[1]*tri2->b + 00401 poly1->verts[tri1->v2]->coord[2]*tri2->c + tri2->d; 00402 if ( dist > GEOMETRY_RESABS ) 00403 { 00404 continue; 00405 } 00406 00407 // coplanar triangles; tilt each vertex of the triangle up successively 00408 // and then do the usual tri-tri intersection. 00409 double ta, tb, tc, td; 00410 double tx1[3],ty1[3],tz1[3]; 00411 00412 // triangle 1 00413 ta = tri1->a; tb = tri1->b; tc = tri1->c; td = tri1->d; 00414 for ( k = 0; k < 3; k++ ) { 00415 tx1[k] = poly1->verts[tri1->v0]->coord[k]; 00416 ty1[k] = poly1->verts[tri1->v1]->coord[k]; 00417 tz1[k] = poly1->verts[tri1->v2]->coord[k]; 00418 } 00419 00420 poly1->verts[tri1->v2]->coord[0] += ta; 00421 poly1->verts[tri1->v2]->coord[1] += tb; 00422 poly1->verts[tri1->v2]->coord[2] += tc; 00423 // Compute new normal and linecoeff 00424 newplanecoefficients(poly1, tri1); 00425 linecoeff[0] = tri1->c*tri2->b - tri1->b*tri2->c; 00426 linecoeff[1] = tri1->a*tri2->c - tri1->c*tri2->a; 00427 linecoeff[2] = tri1->b*tri2->a - tri1->a*tri2->b; 00428 dtemp = sqrt(linecoeff[0]*linecoeff[0] + 00429 linecoeff[1]*linecoeff[1] + 00430 linecoeff[2]*linecoeff[2]); 00431 linecoeff[0] /= dtemp; 00432 linecoeff[1] /= dtemp; 00433 linecoeff[2] /= dtemp; 00434 00435 status = tri_tri_intersect(tri1,tri2); 00436 if ( status != CUBIT_SUCCESS ) 00437 { 00438 return status; 00439 } 00440 00441 // Restore values. 00442 poly1->verts[tri1->v2]->coord[0] = tz1[0]; 00443 poly1->verts[tri1->v2]->coord[1] = tz1[1]; 00444 poly1->verts[tri1->v2]->coord[2] = tz1[2]; 00445 tri1->a = ta; tri1->b = tb; tri1->c = tc; tri1->d = td; 00446 00447 poly1->verts[tri1->v1]->coord[0] += ta; 00448 poly1->verts[tri1->v1]->coord[1] += tb; 00449 poly1->verts[tri1->v1]->coord[2] += tc; 00450 // Compute new normal and linecoeff 00451 newplanecoefficients(poly1, tri1); 00452 linecoeff[0] = tri1->c*tri2->b - tri1->b*tri2->c; 00453 linecoeff[1] = tri1->a*tri2->c - tri1->c*tri2->a; 00454 linecoeff[2] = tri1->b*tri2->a - tri1->a*tri2->b; 00455 dtemp = sqrt(linecoeff[0]*linecoeff[0] + 00456 linecoeff[1]*linecoeff[1] + 00457 linecoeff[2]*linecoeff[2]); 00458 linecoeff[0] /= dtemp; 00459 linecoeff[1] /= dtemp; 00460 linecoeff[2] /= dtemp; 00461 00462 status = tri_tri_intersect(tri1,tri2); 00463 if ( status != CUBIT_SUCCESS ) 00464 { 00465 return status; 00466 } 00467 00468 // Restore values. 00469 poly1->verts[tri1->v1]->coord[0] = ty1[0]; 00470 poly1->verts[tri1->v1]->coord[1] = ty1[1]; 00471 poly1->verts[tri1->v1]->coord[2] = ty1[2]; 00472 tri1->a = ta; tri1->b = tb; tri1->c = tc; tri1->d = td; 00473 00474 poly1->verts[tri1->v0]->coord[0] += ta; 00475 poly1->verts[tri1->v0]->coord[1] += tb; 00476 poly1->verts[tri1->v0]->coord[2] += tc; 00477 // Compute new normal and linecoeff 00478 newplanecoefficients(poly1, tri1); 00479 linecoeff[0] = tri1->c*tri2->b - tri1->b*tri2->c; 00480 linecoeff[1] = tri1->a*tri2->c - tri1->c*tri2->a; 00481 linecoeff[2] = tri1->b*tri2->a - tri1->a*tri2->b; 00482 dtemp = sqrt(linecoeff[0]*linecoeff[0] + 00483 linecoeff[1]*linecoeff[1] + 00484 linecoeff[2]*linecoeff[2]); 00485 linecoeff[0] /= dtemp; 00486 linecoeff[1] /= dtemp; 00487 linecoeff[2] /= dtemp; 00488 00489 status = tri_tri_intersect(tri1,tri2); 00490 if ( status != CUBIT_SUCCESS ) 00491 { 00492 return status; 00493 } 00494 00495 // Restore values. 00496 poly1->verts[tri1->v0]->coord[0] = tx1[0]; 00497 poly1->verts[tri1->v0]->coord[1] = tx1[1]; 00498 poly1->verts[tri1->v0]->coord[2] = tx1[2]; 00499 tri1->a = ta; tri1->b = tb; tri1->c = tc; tri1->d = td; 00500 00501 // triangle 2 00502 ta = tri2->a; tb = tri2->b; tc = tri2->c; td = tri2->d; 00503 for ( k = 0; k < 3; k++ ) { 00504 tx1[k] = poly2->verts[tri2->v0]->coord[k]; 00505 ty1[k] = poly2->verts[tri2->v1]->coord[k]; 00506 tz1[k] = poly2->verts[tri2->v2]->coord[k]; 00507 } 00508 00509 poly2->verts[tri2->v2]->coord[0] += ta; 00510 poly2->verts[tri2->v2]->coord[1] += tb; 00511 poly2->verts[tri2->v2]->coord[2] += tc; 00512 // Compute new normal and linecoeff 00513 newplanecoefficients(poly2, tri2); 00514 linecoeff[0] = tri1->c*tri2->b - tri1->b*tri2->c; 00515 linecoeff[1] = tri1->a*tri2->c - tri1->c*tri2->a; 00516 linecoeff[2] = tri1->b*tri2->a - tri1->a*tri2->b; 00517 dtemp = sqrt(linecoeff[0]*linecoeff[0] + 00518 linecoeff[1]*linecoeff[1] + 00519 linecoeff[2]*linecoeff[2]); 00520 linecoeff[0] /= dtemp; 00521 linecoeff[1] /= dtemp; 00522 linecoeff[2] /= dtemp; 00523 00524 status = tri_tri_intersect(tri1,tri2); 00525 if ( status != CUBIT_SUCCESS ) 00526 { 00527 return status; 00528 } 00529 00530 // Restore values. 00531 poly2->verts[tri2->v2]->coord[0] = tz1[0]; 00532 poly2->verts[tri2->v2]->coord[1] = tz1[1]; 00533 poly2->verts[tri2->v2]->coord[2] = tz1[2]; 00534 tri2->a = ta; tri2->b = tb; tri2->c = tc; tri2->d = td; 00535 00536 poly2->verts[tri2->v1]->coord[0] += ta; 00537 poly2->verts[tri2->v1]->coord[1] += tb; 00538 poly2->verts[tri2->v1]->coord[2] += tc; 00539 // Compute new normal and linecoeff 00540 newplanecoefficients(poly2, tri2); 00541 linecoeff[0] = tri1->c*tri2->b - tri1->b*tri2->c; 00542 linecoeff[1] = tri1->a*tri2->c - tri1->c*tri2->a; 00543 linecoeff[2] = tri1->b*tri2->a - tri1->a*tri2->b; 00544 dtemp = sqrt(linecoeff[0]*linecoeff[0] + 00545 linecoeff[1]*linecoeff[1] + 00546 linecoeff[2]*linecoeff[2]); 00547 linecoeff[0] /= dtemp; 00548 linecoeff[1] /= dtemp; 00549 linecoeff[2] /= dtemp; 00550 00551 status = tri_tri_intersect(tri1,tri2); 00552 if ( status != CUBIT_SUCCESS ) 00553 { 00554 return status; 00555 } 00556 00557 // Restore values. 00558 poly2->verts[tri2->v1]->coord[0] = ty1[0]; 00559 poly2->verts[tri2->v1]->coord[1] = ty1[1]; 00560 poly2->verts[tri2->v1]->coord[2] = ty1[2]; 00561 tri2->a = ta; tri2->b = tb; tri2->c = tc; tri2->d = td; 00562 00563 poly2->verts[tri2->v0]->coord[0] += ta; 00564 poly2->verts[tri2->v0]->coord[1] += tb; 00565 poly2->verts[tri2->v0]->coord[2] += tc; 00566 // Compute new normal and linecoeff 00567 newplanecoefficients(poly2, tri2); 00568 linecoeff[0] = tri1->c*tri2->b - tri1->b*tri2->c; 00569 linecoeff[1] = tri1->a*tri2->c - tri1->c*tri2->a; 00570 linecoeff[2] = tri1->b*tri2->a - tri1->a*tri2->b; 00571 dtemp = sqrt(linecoeff[0]*linecoeff[0] + 00572 linecoeff[1]*linecoeff[1] + 00573 linecoeff[2]*linecoeff[2]); 00574 linecoeff[0] /= dtemp; 00575 linecoeff[1] /= dtemp; 00576 linecoeff[2] /= dtemp; 00577 00578 status = tri_tri_intersect(tri1,tri2); 00579 if ( status != CUBIT_SUCCESS ) 00580 { 00581 return status; 00582 } 00583 00584 // Restore values. 00585 poly2->verts[tri2->v0]->coord[0] = tx1[0]; 00586 poly2->verts[tri2->v0]->coord[1] = tx1[1]; 00587 poly2->verts[tri2->v0]->coord[2] = tx1[2]; 00588 tri2->a = ta; tri2->b = tb; tri2->c = tc; tri2->d = td; 00589 00590 continue; 00591 } 00592 00593 if ( do_imprint == true ) { 00594 // Don't intersect nearly-coplanar triangles. 00595 if ( fabs(tri1->a*tri2->a + tri1->b*tri2->b +tri1->c*tri2->c) > 0.8 ) continue; 00596 } 00597 double dtemp; 00598 dtemp = sqrt(linecoeff[0]*linecoeff[0] + 00599 linecoeff[1]*linecoeff[1] + 00600 linecoeff[2]*linecoeff[2]); 00601 linecoeff[0] /= dtemp; 00602 linecoeff[1] /= dtemp; 00603 linecoeff[2] /= dtemp; 00604 00605 status = tri_tri_intersect(tri1,tri2); 00606 if ( status != CUBIT_SUCCESS ) 00607 { 00608 return status; 00609 } 00610 00611 } // end of loop over poly2 00612 00613 } // end of loop over poly1 00614 00615 //delete entire array. 00616 delete [] boxlist; 00617 00618 return status; 00619 } 00620 00621 CubitStatus FBIntersect::tri_tri_intersect(FB_Triangle *tri1, 00622 FB_Triangle *tri2) 00623 { 00624 int ret1, ret2, i; 00625 double xc10[3], xc11[3],xc12[3]; // coords for poly1 triangle 00626 double xc20[3], xc21[3],xc22[3]; // coords for poly2 triangle 00627 double d10, d11, d12, d20, d21, d22; // distance of vertex from plane of other triangle 00628 double tt[4]; 00629 int edge_vert_type[4]; 00630 CubitStatus status; 00631 00632 int mydebug = 0; 00633 status = CUBIT_SUCCESS; 00634 00635 tt[0] = tt[1] = tt[2] = tt[3] = CUBIT_DBL_MAX; 00636 // Is tri1 entirely on one side of tri2? 00637 for ( i = 0; i < 3; i++ ) { 00638 xc10[i] = poly1->verts[tri1->v0]->coord[i]; 00639 xc11[i] = poly1->verts[tri1->v1]->coord[i]; 00640 xc12[i] = poly1->verts[tri1->v2]->coord[i]; 00641 } 00642 00643 // distance of each tri1 vert to plane of tri2 00644 d10 = xc10[0]*tri2->a + xc10[1]*tri2->b + xc10[2]*tri2->c + tri2->d; 00645 d11 = xc11[0]*tri2->a + xc11[1]*tri2->b + xc11[2]*tri2->c + tri2->d; 00646 d12 = xc12[0]*tri2->a + xc12[1]*tri2->b + xc12[2]*tri2->c + tri2->d; 00647 if ( ( (d10 < -EPSILON2) && (d11 < -EPSILON2) && (d12 < -EPSILON2) ) || 00648 ( (d10 > EPSILON2) && (d11 > EPSILON2) && (d12 > EPSILON2) ) ) 00649 return CUBIT_SUCCESS; 00650 // Is tri2 entirely on one side of tri1? 00651 for ( i = 0; i < 3; i++ ) { 00652 xc20[i] = poly2->verts[tri2->v0]->coord[i]; 00653 xc21[i] = poly2->verts[tri2->v1]->coord[i]; 00654 xc22[i] = poly2->verts[tri2->v2]->coord[i]; 00655 } 00656 00657 // distance of each tri2 vert to plane of tri1 00658 d20 = xc20[0]*tri1->a + xc20[1]*tri1->b + xc20[2]*tri1->c + tri1->d; 00659 d21 = xc21[0]*tri1->a + xc21[1]*tri1->b + xc21[2]*tri1->c + tri1->d; 00660 d22 = xc22[0]*tri1->a + xc22[1]*tri1->b + xc22[2]*tri1->c + tri1->d; 00661 if ( ( (d20 < -EPSILON2) && (d21 < -EPSILON2) && (d22 < -EPSILON2) ) || 00662 ( (d20 > EPSILON2) && (d21 > EPSILON2) && (d22 > EPSILON2) ) ) 00663 return CUBIT_SUCCESS; 00664 // Get a point on the line of intersection to serve as a reference point. 00665 double ta, tb, ts1, ts2, tdot11; 00666 ts1 = -tri1->d; ts2 = -tri2->d; 00667 00668 tdot11 = tri1->a*tri2->a + tri1->b*tri2->b + tri1->c*tri2->c; 00669 ta = (ts2*tdot11 - ts1)/(tdot11*tdot11 - 1); 00670 tb = (ts1*tdot11 - ts2)/(tdot11*tdot11 - 1); 00671 linept[0] = ta*tri1->a + tb*tri2->a; 00672 linept[1] = ta*tri1->b + tb*tri2->b; 00673 linept[2] = ta*tri1->c + tb*tri2->c; 00674 00675 // There are several cases for the distances. 00676 // ret1 holds the number of intersections of the triangle with the 00677 // intersection line. 00678 // Do tri1. 00679 ret1 = get_intersectionline_parameter_values(d10,d11,d12, 00680 xc10,xc11,xc12, 00681 tt[0],tt[1], 00682 edge_vert_type[0],edge_vert_type[1]); 00683 // Do tri2. 00684 ret2 = get_intersectionline_parameter_values(d20,d21,d22, 00685 xc20,xc21,xc22, 00686 tt[2],tt[3], 00687 edge_vert_type[2],edge_vert_type[3]); 00688 // If not two intersections for each triangle, no intersection edge exists. 00689 if ( (ret1 == 2) && (ret2 == 2) ) 00690 { 00691 status = add_intersection_edges(tri1,tri2,tt,edge_vert_type); 00692 if ( status != CUBIT_SUCCESS ) 00693 { 00694 return status; 00695 } 00696 } 00697 if(mydebug){ 00698 double min_angle_1, max_angle_1; 00699 double min_angle_2, max_angle_2; 00700 poly1->min_max_angles_in_fb_triangle(tri1, min_angle_1, max_angle_1); 00701 poly2->min_max_angles_in_fb_triangle(tri2, min_angle_2, max_angle_2); 00702 00703 00704 if(min_angle_1 < 10 || min_angle_2 < 10){ 00705 PRINT_INFO(" Tri 1 min angle = %f\n",min_angle_1); 00706 PRINT_INFO(" Tri 2 min angle = %f\n",min_angle_2); 00707 } 00708 } 00709 00710 return status; 00711 } 00712 00713 CubitStatus FBIntersect::add_intersection_edges(FB_Triangle *tri1, 00714 FB_Triangle *tri2, 00715 double *tt, 00716 int *edge_vert_type 00717 ) 00718 { 00719 int v10, v11, v20, v21; 00720 bool ifoundit, exists; 00721 FB_Edge *edge; 00722 double x1pt, y1pt, z1pt, x2pt, y2pt, z2pt; 00723 int edge1_vert0_type, edge1_vert1_type, edge2_vert0_type, edge2_vert1_type; 00724 00725 ifoundit = false; 00726 edge1_vert0_type = edge1_vert1_type = edge2_vert0_type = edge2_vert1_type = UNKNOWN; 00727 00728 // Try to handle the epsilon cases by forcing tt[] values that are almost 00729 // equal to be equal. 00730 00731 if ( fabs(tt[0]-tt[2]) < EPSILON ) tt[2] = tt[0]; 00732 if ( fabs(tt[0]-tt[3]) < EPSILON ) tt[3] = tt[0]; 00733 if ( fabs(tt[1]-tt[2]) < EPSILON ) tt[2] = tt[1]; 00734 if ( fabs(tt[1]-tt[3]) < EPSILON ) tt[3] = tt[1]; 00735 00736 // cases 0 and 9, no overlap 00737 // if ( (tt[1] < tt[2]) || (tt[3] < tt[0]) ) return CUBIT_SUCCESS; 00738 if ( tt[1] < tt[2] ) { return CUBIT_SUCCESS; } 00739 00740 if ( tt[3] < tt[0] ) { return CUBIT_SUCCESS; } 00741 00742 // These next four cases are by far the most common forms of overlap, 00743 // so check for them first. 00744 00745 // The 1's (e.g.: 11111111) refer to the portion of the line of intersection 00746 // that is in tri1; the 2's for tri2. The case numbers were arbirtarily assigned. 00747 00748 // case 4 00749 // 11111111 00750 // 2222 00751 if ( (tt[2] > tt[0]) && (tt[3] < tt[1]) ) { 00752 ifoundit = true; 00753 get_point_from_parameter(tt[2],&x1pt,&y1pt,&z1pt); 00754 get_point_from_parameter(tt[3],&x2pt,&y2pt,&z2pt); 00755 edge1_vert0_type = INTERIOR_VERT; 00756 edge1_vert1_type = INTERIOR_VERT; 00757 edge2_vert0_type = edge_vert_type[2]; 00758 edge2_vert1_type = edge_vert_type[3]; 00759 00760 // case 2 00761 // 11111111 00762 // 22222222 00763 } else if ( (tt[2] < tt[1]) && (tt[2] > tt[0]) && (tt[3] > tt[1]) ) { 00764 ifoundit = true; 00765 get_point_from_parameter(tt[2],&x1pt,&y1pt,&z1pt); 00766 get_point_from_parameter(tt[1],&x2pt,&y2pt,&z2pt); 00767 edge1_vert0_type = INTERIOR_VERT; 00768 edge1_vert1_type = edge_vert_type[1]; 00769 edge2_vert0_type = edge_vert_type[2]; 00770 edge2_vert1_type = INTERIOR_VERT; 00771 00772 // case 7 00773 // 11111111 00774 // 22222222 00775 } else if ( (tt[0] < tt[3]) && (tt[0] > tt[2]) && (tt[1] > tt[3]) ) { 00776 ifoundit = true; 00777 get_point_from_parameter(tt[0],&x1pt,&y1pt,&z1pt); 00778 get_point_from_parameter(tt[3],&x2pt,&y2pt,&z2pt); 00779 edge1_vert0_type = edge_vert_type[0]; 00780 edge1_vert1_type = INTERIOR_VERT; 00781 edge2_vert0_type = INTERIOR_VERT; 00782 edge2_vert1_type = edge_vert_type[3]; 00783 00784 // case 12 00785 // 1111 00786 // 22222222 00787 } else if ( (tt[0] > tt[2]) && (tt[1] < tt[3]) ) { 00788 ifoundit = true; 00789 get_point_from_parameter(tt[0],&x1pt,&y1pt,&z1pt); 00790 get_point_from_parameter(tt[1],&x2pt,&y2pt,&z2pt); 00791 edge1_vert0_type = edge_vert_type[0]; 00792 edge1_vert1_type = edge_vert_type[1]; 00793 edge2_vert0_type = INTERIOR_VERT; 00794 edge2_vert1_type = INTERIOR_VERT; 00795 00796 // case 1 00797 // 11111111 00798 // 22222222 00799 } else if ( fabs(tt[1]-tt[2]) < EPSILON ) { 00800 ifoundit = true; 00801 // return CUBIT_SUCCESS; 00802 get_point_from_parameter(tt[1],&x1pt,&y1pt,&z1pt); 00803 get_point_from_parameter(tt[1],&x2pt,&y2pt,&z2pt); 00804 edge1_vert0_type = edge_vert_type[1]; 00805 edge1_vert1_type = edge_vert_type[1]; 00806 edge2_vert0_type = edge_vert_type[2]; 00807 edge2_vert1_type = edge_vert_type[2]; 00808 00809 // case 3 00810 } else if ( tt[0] < tt[2] ) { 00811 // case 3 00812 // 11111111 00813 // 22222 00814 if ( tt[1] == tt[3] ) { 00815 ifoundit = true; 00816 get_point_from_parameter(tt[2],&x1pt,&y1pt,&z1pt); 00817 get_point_from_parameter(tt[3],&x2pt,&y2pt,&z2pt); 00818 edge1_vert0_type = INTERIOR_VERT; 00819 edge1_vert1_type = edge_vert_type[1]; 00820 edge2_vert0_type = edge_vert_type[2]; 00821 edge2_vert1_type = edge_vert_type[3]; 00822 } 00823 00824 // case 5, 6, or 11 00825 } else if ( fabs(tt[0]-tt[2]) < EPSILON ) { 00826 00827 // case 5 00828 // 11111111 00829 // 22222222 00830 if ( tt[1] == tt[3] ) { 00831 ifoundit = true; 00832 get_point_from_parameter(tt[0],&x1pt,&y1pt,&z1pt); 00833 get_point_from_parameter(tt[1],&x2pt,&y2pt,&z2pt); 00834 edge1_vert0_type = edge_vert_type[0]; 00835 edge1_vert1_type = edge_vert_type[1]; 00836 edge2_vert0_type = edge_vert_type[2]; 00837 edge2_vert1_type = edge_vert_type[3]; 00838 00839 // case 6 00840 // 11111111 00841 // 2222 00842 } else if ( tt[1] > tt[3] ) { 00843 ifoundit = true; 00844 get_point_from_parameter(tt[2],&x1pt,&y1pt,&z1pt); 00845 get_point_from_parameter(tt[3],&x2pt,&y2pt,&z2pt); 00846 edge1_vert0_type = edge_vert_type[0]; 00847 edge1_vert1_type = INTERIOR_VERT; 00848 edge2_vert0_type = edge_vert_type[2]; 00849 edge2_vert1_type = edge_vert_type[3]; 00850 00851 // case 11 00852 // 1111 00853 // 22222222 00854 } else { 00855 ifoundit = true; 00856 get_point_from_parameter(tt[0],&x1pt,&y1pt,&z1pt); 00857 get_point_from_parameter(tt[1],&x2pt,&y2pt,&z2pt); 00858 edge1_vert0_type = edge_vert_type[0]; 00859 edge1_vert1_type = edge_vert_type[1]; 00860 edge2_vert0_type = edge_vert_type[2]; 00861 edge2_vert1_type = INTERIOR_VERT; 00862 } 00863 00864 // case 8 or 10 00865 } else { 00866 00867 // case 8 00868 // 11111111 00869 // 22222222 00870 if ( fabs(tt[0]-tt[3]) < EPSILON ) { 00871 ifoundit = true; 00872 // return CUBIT_SUCCESS; 00873 get_point_from_parameter(tt[0],&x1pt,&y1pt,&z1pt); 00874 get_point_from_parameter(tt[0],&x2pt,&y2pt,&z2pt); 00875 edge1_vert0_type = edge_vert_type[0]; 00876 edge1_vert1_type = edge_vert_type[0]; 00877 edge2_vert0_type = edge_vert_type[3]; 00878 edge2_vert1_type = edge_vert_type[3]; 00879 00880 // case 10 00881 // 1111 00882 // 22222222 00883 } else if ( fabs(tt[1]-tt[3]) < EPSILON ) { 00884 ifoundit = true; 00885 get_point_from_parameter(tt[0],&x1pt,&y1pt,&z1pt); 00886 get_point_from_parameter(tt[1],&x2pt,&y2pt,&z2pt); 00887 edge1_vert0_type = edge_vert_type[0]; 00888 edge1_vert1_type = edge_vert_type[1]; 00889 edge2_vert0_type = INTERIOR_VERT; 00890 edge2_vert1_type = edge_vert_type[3]; 00891 } 00892 00893 } 00894 00895 if ( ifoundit == false ) { 00896 PRINT_ERROR("unaccounted for case in add_intersection_edges: tt[] = %e %e %e %e\n", 00897 tt[0],tt[1],tt[2],tt[3]); 00898 return CUBIT_FAILURE; 00899 } else { 00900 tri1->dudded = true; 00901 v10 = poly1->addavertex(x1pt,y1pt,z1pt); 00902 v11 = poly1->addavertex(x2pt,y2pt,z2pt); 00903 if ( v10 != v11 ) { 00904 exists = poly1->edge_exists_in_tri(*tri1,v10,v11); 00905 if ( exists == false ) { 00906 if ( edge1_vert0_type == INTERIOR_VERT ) 00907 edge1_vert0_type = determine_edge_vert_type(edge_vert_type[0], 00908 edge_vert_type[1]); 00909 if ( edge1_vert1_type == INTERIOR_VERT ) 00910 edge1_vert1_type = determine_edge_vert_type(edge_vert_type[0], 00911 edge_vert_type[1]); 00912 edge = new FB_Edge(v10,v11,edge1_vert0_type,edge1_vert1_type,true); 00913 tri1->edge_list.push_back(edge); 00914 if ( poly1->edge_exists(v10,v11) == false ) 00915 poly1->intersection_edges.push_back(edge); 00916 } 00917 } else { 00918 int edge_type = UNKNOWN; 00919 int vtype1 = UNKNOWN_VERT, vtype2 = UNKNOWN_VERT; 00920 int v_other1 = UNKNOWN_VERT, v_other2 = UNKNOWN_VERT; 00921 // edge_type = UNKNOWN; 00922 if ( edge1_vert0_type == EDGE_2 ) { 00923 v_other1 = tri1->v0; 00924 v_other2 = tri1->v2; 00925 edge_type = EDGE_2; 00926 vtype1 = VERTEX_0; 00927 vtype2 = VERTEX_2; 00928 } else if ( edge1_vert0_type == EDGE_1 ) { 00929 v_other1 = tri1->v1; 00930 v_other2 = tri1->v2; 00931 edge_type = EDGE_1; 00932 vtype1 = VERTEX_1; 00933 vtype2 = VERTEX_2; 00934 00935 } else if ( edge1_vert0_type == EDGE_0 ) { 00936 v_other1 = tri1->v0; 00937 v_other2 = tri1->v1; 00938 edge_type = EDGE_0; 00939 vtype1 = VERTEX_0; 00940 vtype2 = VERTEX_1; 00941 00942 } 00943 if ( edge_type != UNKNOWN ) { 00944 exists = poly1->edge_exists_in_tri(*tri1,v_other1,v10); 00945 if ( exists == false ) { 00946 edge = new FB_Edge(v_other1,v10,vtype1,edge_type,false); 00947 tri1->edge_list.push_back(edge); 00948 if ( poly1->edge_exists(v_other1,v10) == false ) 00949 poly1->intersection_edges.push_back(edge); 00950 } 00951 exists = poly1->edge_exists_in_tri(*tri1,v10,v_other2); 00952 if ( exists == false ) { 00953 edge = new FB_Edge(v10,v_other2,edge_type,vtype2,false); 00954 tri1->edge_list.push_back(edge); 00955 if ( poly1->edge_exists(v10,v_other2) == false ) 00956 poly1->intersection_edges.push_back(edge); 00957 } 00958 } 00959 } 00960 00961 tri2->dudded = true; 00962 v20 = poly2->addavertex(x1pt,y1pt,z1pt); 00963 v21 = poly2->addavertex(x2pt,y2pt,z2pt); 00964 if ( v20 != v21) { 00965 exists = poly2->edge_exists_in_tri(*tri2,v20,v21); 00966 if ( exists == false ) { 00967 if ( edge2_vert0_type == INTERIOR_VERT ) 00968 edge2_vert0_type = determine_edge_vert_type(edge_vert_type[2], 00969 edge_vert_type[3]); 00970 if ( edge2_vert1_type == INTERIOR_VERT ) 00971 edge2_vert1_type = determine_edge_vert_type(edge_vert_type[2], 00972 edge_vert_type[3]); 00973 edge = new FB_Edge(v20,v21,edge2_vert0_type,edge2_vert1_type,true); 00974 tri2->edge_list.push_back(edge); 00975 if ( poly2->edge_exists(v20,v21) == false ) 00976 poly2->intersection_edges.push_back(edge); 00977 } 00978 } else { 00979 int edge_type = UNKNOWN; 00980 int vtype1 = UNKNOWN_VERT, vtype2 = UNKNOWN_VERT; 00981 int v_other1 = UNKNOWN_VERT, v_other2 = UNKNOWN_VERT; 00982 // edge_type = UNKNOWN; 00983 if ( edge2_vert0_type == EDGE_2 ) { 00984 v_other1 = tri2->v0; 00985 v_other2 = tri2->v2; 00986 edge_type = EDGE_2; 00987 vtype1 = VERTEX_0; 00988 vtype2 = VERTEX_2; 00989 } else if ( edge2_vert0_type == EDGE_1 ) { 00990 v_other1 = tri2->v1; 00991 v_other2 = tri2->v2; 00992 edge_type = EDGE_1; 00993 vtype1 = VERTEX_1; 00994 vtype2 = VERTEX_2; 00995 00996 } else if ( edge2_vert0_type == EDGE_0 ) { 00997 v_other1 = tri2->v0; 00998 v_other2 = tri2->v1; 00999 edge_type = EDGE_0; 01000 vtype1 = VERTEX_0; 01001 vtype2 = VERTEX_1; 01002 01003 } 01004 if ( edge_type != UNKNOWN ) { 01005 exists = poly2->edge_exists_in_tri(*tri2,v_other1,v20); 01006 if ( exists == false ) { 01007 edge = new FB_Edge(v_other1,v20,vtype1,edge_type,false); 01008 tri2->edge_list.push_back(edge); 01009 if ( poly2->edge_exists(v_other1,v20) == false ) 01010 poly2->intersection_edges.push_back(edge); 01011 } 01012 exists = poly2->edge_exists_in_tri(*tri2,v20,v_other2); 01013 if ( exists == false ) { 01014 edge = new FB_Edge(v20,v_other2,edge_type,vtype2,false); 01015 tri2->edge_list.push_back(edge); 01016 if ( poly2->edge_exists(v20,v_other2) == false ) 01017 poly2->intersection_edges.push_back(edge); 01018 } 01019 } 01020 } 01021 } 01022 01023 return CUBIT_SUCCESS; 01024 01025 } 01026 01027 void FBIntersect::get_point_from_parameter(double parameter, 01028 double *x, double *y, double *z) 01029 { 01030 *x = linept[0] + linecoeff[0]*parameter; 01031 *y = linept[1] + linecoeff[1]*parameter; 01032 *z = linept[2] + linecoeff[2]*parameter; 01033 01034 } 01035 01036 double FBIntersect::get_distance_parameter(double *xc0, 01037 double *xc1, 01038 double d0, double d1) 01039 { 01040 double v1dot, v2dot; 01041 01042 // dot the coordinates onto the line. 01043 // Assume that it has been checked already that d0 != d1. 01044 01045 v1dot = linecoeff[0]*(xc0[0] - linept[0]) + 01046 linecoeff[1]*(xc0[1] - linept[1]) + 01047 linecoeff[2]*(xc0[2] - linept[2]); 01048 v2dot = linecoeff[0]*(xc1[0] - linept[0]) + 01049 linecoeff[1]*(xc1[1] - linept[1]) + 01050 linecoeff[2]*(xc1[2] - linept[2]); 01051 01052 return v1dot + (v2dot - v1dot)*d0/(d0-d1); 01053 } 01054 01055 01056 double FBIntersect::get_distance_parameter_single(double *xc) 01057 { 01058 double coeff; 01059 int coord; 01060 01061 if ( (fabs(linecoeff[0]) >= fabs(linecoeff[1])) && 01062 (fabs(linecoeff[0]) >= fabs(linecoeff[2])) ){ 01063 coord = 0; 01064 } else if ( fabs(linecoeff[1]) >= fabs(linecoeff[2]) ) { 01065 coord = 1; 01066 } else { 01067 coord = 2; 01068 } 01069 coeff = linecoeff[coord]; 01070 return (xc[coord] - linept[coord])/coeff; 01071 } 01072 01073 int FBIntersect::get_intersectionline_parameter_values( 01074 double d0, 01075 double d1, 01076 double d2, 01077 double *pt0, 01078 double *pt1, 01079 double *pt2, 01080 double& t0, 01081 double& t1, 01082 int& vert_type_0, 01083 int& vert_type_1) 01084 { 01085 int ret = 0; 01086 // ret holds the nnumber of intersections of the line with the triangle. 01087 01088 if ( fabs(d0) < EPSILON ) { 01089 if ( fabs(d1) < EPSILON ) { 01090 if ( fabs(d2) < EPSILON ) { 01091 // coplanar 01092 ret = 0; 01093 } else { 01094 // d0 = d1 = 0 01095 t0 = get_distance_parameter_single(pt0); 01096 t1 = get_distance_parameter_single(pt1); 01097 vert_type_0 = VERTEX_0; 01098 vert_type_1 = VERTEX_1; 01099 ret = 2; 01100 } 01101 } else if ( fabs(d2) < EPSILON ) { 01102 // d0 = d2 = 0 01103 t0 = get_distance_parameter_single(pt0); 01104 t1 = get_distance_parameter_single(pt2); 01105 vert_type_0 = VERTEX_0; 01106 vert_type_1 = VERTEX_2; 01107 ret = 2; 01108 } else if ( d1*d2 < 0.0 ) { 01109 // d0 = 0 and edge 12 crosses 01110 t0 = get_distance_parameter_single(pt0); 01111 t1 = get_distance_parameter(pt1,pt2,d1,d2); 01112 vert_type_0 = VERTEX_0; 01113 vert_type_1 = EDGE_1; 01114 ret = 2; 01115 } else { 01116 // d0 = 0 and no edges cross 01117 ret = 0; 01118 } 01119 } else if ( fabs(d1) < EPSILON ) { 01120 if ( fabs(d2) < EPSILON ) { 01121 // d1 = d2 = 0 01122 t0 = get_distance_parameter_single(pt1); 01123 t1 = get_distance_parameter_single(pt2); 01124 vert_type_0 = VERTEX_1; 01125 vert_type_1 = VERTEX_2; 01126 ret = 2; 01127 } else if ( d0*d2 < 0.0 ) { 01128 // d1 = 0 and edge 20 crosses 01129 t0 = get_distance_parameter_single(pt1); 01130 t1 = get_distance_parameter(pt0,pt2,d0,d2); 01131 vert_type_0 = VERTEX_1; 01132 vert_type_1 = EDGE_2; 01133 ret = 2; 01134 } else { 01135 // d1 = 0 and no edges cross 01136 ret = 0; 01137 } 01138 } else if ( fabs(d2) < EPSILON ) { 01139 if ( d0*d1 < 0.0 ) { 01140 // d2 = 0 and edge 01 crosses 01141 t0 = get_distance_parameter_single(pt2); 01142 t1 = get_distance_parameter(pt0,pt1,d0,d1); 01143 vert_type_0 = VERTEX_2; 01144 vert_type_1 = EDGE_0; 01145 ret = 2; 01146 } else { 01147 // d2 = 0 and no edges cross 01148 ret = 0; 01149 } 01150 } else if ( d0*d1 < 0.0 ) { 01151 if ( d0*d2 < 0.0 ) { 01152 // edges 01 and 02 cross 01153 t0 = get_distance_parameter(pt0,pt1,d0,d1); 01154 t1 = get_distance_parameter(pt0,pt2,d0,d2); 01155 vert_type_0 = EDGE_0; 01156 vert_type_1 = EDGE_2; 01157 ret = 2; 01158 } else { 01159 // edges 01 and 12 cross 01160 t0 = get_distance_parameter(pt0,pt1,d0,d1); 01161 t1 = get_distance_parameter(pt1,pt2,d1,d2); 01162 vert_type_0 = EDGE_0; 01163 vert_type_1 = EDGE_1; 01164 ret = 2; 01165 } 01166 } else { 01167 // edges 02 and 12 cross 01168 t0 = get_distance_parameter(pt0,pt2,d0,d2); 01169 t1 = get_distance_parameter(pt1,pt2,d1,d2); 01170 vert_type_0 = EDGE_2; 01171 vert_type_1 = EDGE_1; 01172 ret = 2; 01173 } 01174 01175 if ( ret == 2 ) { // Sort them if necessary. 01176 if ( t0 > t1 ) { 01177 int itemp; 01178 double dtemp; 01179 dtemp = t0; 01180 t0 = t1; 01181 t1 = dtemp; 01182 itemp = vert_type_0; 01183 vert_type_0 = vert_type_1; 01184 vert_type_1 = itemp; 01185 } 01186 01187 } 01188 01189 return ret; 01190 } 01191 01192 void FBIntersect::set_classify_flag(bool value) 01193 { 01194 do_classify = value; 01195 } 01196 01197 CubitStatus FBIntersect::get_persistent_entity_info(bool *surfs_in, 01198 bool *curves_in, 01199 bool *surfs_out, 01200 bool *curves_out, 01201 const CubitFacetboolOp op, 01202 const int whichparent 01203 ) 01204 { 01205 std::vector<int> *group, *groupcharacterization; 01206 std::vector<int>::iterator it, ig; 01207 int booltest1, booltest2, booltest1a, booltest2a, booltest_in, booltest_out; 01208 FBPolyhedron *poly; 01209 01210 if ( nothing_intersected == true ) return CUBIT_SUCCESS; 01211 if ( !poly1 || !poly2 ) { 01212 PRINT_ERROR("Error: Objects for Booleans must first be created.\n"); 01213 return CUBIT_FAILURE; 01214 } 01215 if ( !classify1 || !classify2 ) { 01216 PRINT_ERROR("Error: Objects for Booleans must first be classified.\n"); 01217 return CUBIT_FAILURE; 01218 } 01219 if ( (whichparent < 1) || (whichparent > 2) ) { 01220 PRINT_ERROR("Error: Requested nonexistent object.\n"); 01221 return CUBIT_FAILURE; 01222 } 01223 if ( op == CUBIT_FB_UNION ) { 01224 booltest1 = FB_ORIENTATION_INSIDE + FB_ORIENTATION_SAME; 01225 booltest2 = FB_ORIENTATION_INSIDE; 01226 booltest1a = FB_ORIENTATION_OUTSIDE + FB_ORIENTATION_SAME; 01227 booltest2a = FB_ORIENTATION_OUTSIDE; 01228 } else if ( op == CUBIT_FB_INTERSECTION ) { 01229 booltest1 = FB_ORIENTATION_INSIDE + FB_ORIENTATION_SAME; 01230 booltest2 = FB_ORIENTATION_INSIDE; 01231 booltest1a = FB_ORIENTATION_OUTSIDE+ FB_ORIENTATION_OPPOSITE; 01232 booltest2a = FB_ORIENTATION_INSIDE; 01233 } else if ( op == CUBIT_FB_SUBTRACTION ) { 01234 booltest1 = FB_ORIENTATION_OUTSIDE+ FB_ORIENTATION_OPPOSITE; 01235 booltest2 = FB_ORIENTATION_INSIDE; 01236 booltest1a = FB_ORIENTATION_INSIDE + FB_ORIENTATION_SAME; 01237 booltest2a = FB_ORIENTATION_INSIDE; 01238 } else { 01239 PRINT_ERROR("Error: Unrecognized Boolean operation.\n"); 01240 return CUBIT_FAILURE; 01241 } 01242 01243 if ( whichparent == 1 ) { 01244 booltest_in = booltest1; 01245 booltest_out = booltest1a; 01246 classify1->get_group(&group, &groupcharacterization); 01247 poly = poly1; 01248 } else { 01249 booltest_in = booltest2; 01250 booltest_out = booltest2a; 01251 classify2->get_group(&group, &groupcharacterization); 01252 poly = poly2; 01253 } 01254 unsigned int i; 01255 int isurf, icurve0, icurve1, icurve2; 01256 01257 it = group->begin(); 01258 ig = groupcharacterization->begin(); 01259 01260 i = 0; 01261 while ( it != group->end() ) { 01262 if ( ( *(ig + *it) & booltest_in ) != 0 ) { 01263 // vtx = poly1->tris[i]->v0; 01264 isurf = poly->tris[i]->cubitsurfaceindex; 01265 if ( isurf > 0 ) 01266 surfs_in[isurf] = true; 01267 icurve0 = poly->tris[i]->cubitedge0index; 01268 if ( icurve0 > 0 ) 01269 curves_in[icurve0] = true; 01270 icurve1 = poly->tris[i]->cubitedge1index; 01271 if ( icurve1 > 0 ) 01272 curves_in[icurve1] = true; 01273 icurve2 = poly->tris[i]->cubitedge2index; 01274 if ( icurve2 > 0 ) 01275 curves_in[icurve2] = true; 01276 } 01277 it++; 01278 i++; 01279 } 01280 01281 it = group->begin(); 01282 ig = groupcharacterization->begin(); 01283 01284 i = 0; 01285 while ( it != group->end() ) { 01286 if ( ( *(ig + *it) & booltest_out ) != 0 ) { 01287 isurf = poly->tris[i]->cubitsurfaceindex; 01288 if ( isurf > 0 ) 01289 surfs_out[isurf] = true; 01290 icurve0 = poly->tris[i]->cubitedge0index; 01291 if ( icurve0 > 0 ) 01292 curves_out[icurve0] = true; 01293 icurve1 = poly->tris[i]->cubitedge1index; 01294 if ( icurve1 > 0 ) 01295 curves_out[icurve1] = true; 01296 icurve2 = poly->tris[i]->cubitedge2index; 01297 if ( icurve2 > 0 ) 01298 curves_out[icurve2] = true; 01299 } 01300 it++; 01301 i++; 01302 } 01303 01304 return CUBIT_SUCCESS; 01305 01306 } 01307 01308 CubitStatus FBIntersect::update_surfs_and_curves(std::vector<double>& out_coords, 01309 std::vector<int>& out_connections, 01310 std::vector<int> *out_surf_index, 01311 std::vector<int> *out_curve_index, 01312 const int whichone) 01313 { 01314 unsigned int i; 01315 FBPolyhedron *poly; 01316 01317 if ( whichone == 1 ) poly = poly1; 01318 else poly = poly2; 01319 for ( i = 0; i < poly->verts.size(); i++ ) { 01320 out_coords.push_back(poly->verts[i]->coord[0]); 01321 out_coords.push_back(poly->verts[i]->coord[1]); 01322 out_coords.push_back(poly->verts[i]->coord[2]); 01323 } 01324 for ( i = 0; i < poly->tris.size(); i++ ) { 01325 if ( poly->tris[i]->dudded == true ) continue; 01326 out_connections.push_back(poly->tris[i]->v0); 01327 out_connections.push_back(poly->tris[i]->v1); 01328 out_connections.push_back(poly->tris[i]->v2); 01329 out_surf_index->push_back(poly->tris[i]->cubitsurfaceindex); 01330 out_curve_index->push_back(poly->tris[i]->cubitedge0index); 01331 out_curve_index->push_back(poly->tris[i]->cubitedge1index); 01332 out_curve_index->push_back(poly->tris[i]->cubitedge2index); 01333 } 01334 return CUBIT_SUCCESS; 01335 } 01336 01337 CubitStatus FBIntersect::gather_by_boolean(std::vector<double>& out_coords, 01338 std::vector<int>& out_connections, 01339 std::vector<int> *out_surf_index, 01340 std::vector<int> *out_curve_index, 01341 std::vector<bool> *is_body_1, 01342 const CubitFacetboolOp op) 01343 { 01344 CubitStatus status; 01345 std::vector<int> *group1, 01346 *group2, 01347 *groupcharacterization1, 01348 *groupcharacterization2; 01349 std::vector<int>::iterator it, ig; 01350 int booltest1, booltest2; 01351 01352 if ( nothing_intersected == true && op !=CUBIT_FB_UNION) 01353 { 01354 return CUBIT_SUCCESS; 01355 } 01356 if ( !poly1 || !poly2 ) 01357 { 01358 PRINT_ERROR("Error: Objects for Booleans must first be created.\n"); 01359 return CUBIT_FAILURE; 01360 } 01361 if ( !classify1 || !classify2 ) 01362 { 01363 PRINT_ERROR("Error: Objects for Booleans must first be classified.\n"); 01364 return CUBIT_FAILURE; 01365 } 01366 01367 if ( op == CUBIT_FB_UNION ) 01368 { 01369 booltest1 = FB_ORIENTATION_OUTSIDE + FB_ORIENTATION_SAME; 01370 booltest2 = FB_ORIENTATION_OUTSIDE; 01371 } 01372 else if ( op == CUBIT_FB_INTERSECTION ) 01373 { 01374 booltest1 = FB_ORIENTATION_INSIDE + FB_ORIENTATION_SAME; 01375 booltest2 = FB_ORIENTATION_INSIDE; 01376 } 01377 else if ( op == CUBIT_FB_SUBTRACTION ) 01378 { 01379 booltest1 = FB_ORIENTATION_OUTSIDE+ FB_ORIENTATION_OPPOSITE; 01380 booltest2 = FB_ORIENTATION_INSIDE; 01381 } 01382 else 01383 { 01384 PRINT_ERROR("Error: Unrecognized Boolean operation.\n"); 01385 return CUBIT_FAILURE; 01386 } 01387 01388 classify1->get_group(&group1, &groupcharacterization1); 01389 classify2->get_group(&group2, &groupcharacterization2); 01390 01391 IntegerHash *hashobj = new IntegerHash(NUMHASHBINS,20); 01392 01393 it = group1->begin(); 01394 ig = groupcharacterization1->begin(); 01395 unsigned int i; 01396 int vtx, vertnum1, vertnum2, vertnum3, verts_sofar; 01397 01398 i = 0; 01399 verts_sofar = 0; 01400 while ( it != group1->end() ) 01401 { 01402 if ( ( *(ig + *it) & booltest1 ) != 0 ) 01403 { 01404 vtx = poly1->tris[i]->v0; 01405 vertnum1 = get_vertex(poly1, vtx, hashobj, out_coords, verts_sofar); 01406 01407 vtx = poly1->tris[i]->v1; 01408 vertnum2 = get_vertex(poly1, vtx, hashobj, out_coords, verts_sofar); 01409 01410 vtx = poly1->tris[i]->v2; 01411 vertnum3 = get_vertex(poly1, vtx, hashobj, out_coords, verts_sofar); 01412 01413 if ( store_connectivity( out_connections, 01414 vertnum1, 01415 vertnum2, 01416 vertnum3 ) != CUBIT_SUCCESS ) 01417 { 01418 return CUBIT_FAILURE; 01419 } 01420 if ( out_surf_index ) 01421 { 01422 out_surf_index->push_back(poly1->tris[i]->cubitsurfaceindex); 01423 } 01424 if ( out_curve_index ) 01425 { 01426 out_curve_index->push_back(poly1->tris[i]->cubitedge0index); 01427 out_curve_index->push_back(poly1->tris[i]->cubitedge1index); 01428 out_curve_index->push_back(poly1->tris[i]->cubitedge2index); 01429 } 01430 if ( is_body_1 ) is_body_1->push_back(true); 01431 } 01432 it++; 01433 i++; 01434 } 01435 it = group2->begin(); 01436 ig = groupcharacterization2->begin(); 01437 i = 0; 01438 while ( it != group2->end() ) 01439 { 01440 if ( ( *(ig + *it) & booltest2 ) != 0 ) 01441 { 01442 vtx = poly2->tris[i]->v0; 01443 vertnum1 = get_vertex(poly2, vtx, hashobj, out_coords, verts_sofar); 01444 01445 vtx = poly2->tris[i]->v1; 01446 vertnum2 = get_vertex(poly2, vtx, hashobj, out_coords, verts_sofar); 01447 01448 vtx = poly2->tris[i]->v2; 01449 vertnum3 = get_vertex(poly2, vtx, hashobj, out_coords, verts_sofar); 01450 01451 if ( op == CUBIT_FB_SUBTRACTION ) // reverse the winding 01452 { 01453 if ( store_connectivity( out_connections, 01454 vertnum1, 01455 vertnum3, 01456 vertnum2 ) != CUBIT_SUCCESS ) 01457 { 01458 return CUBIT_FAILURE; 01459 } 01460 if ( out_curve_index ) 01461 { 01462 out_curve_index->push_back(poly2->tris[i]->cubitedge2index); 01463 out_curve_index->push_back(poly2->tris[i]->cubitedge1index); 01464 out_curve_index->push_back(poly2->tris[i]->cubitedge0index); 01465 } 01466 } 01467 else 01468 { 01469 if ( store_connectivity( out_connections, 01470 vertnum1, 01471 vertnum2, 01472 vertnum3 ) != CUBIT_SUCCESS ) 01473 { 01474 return CUBIT_FAILURE; 01475 } 01476 if ( out_curve_index ) 01477 { 01478 out_curve_index->push_back(poly2->tris[i]->cubitedge0index); 01479 out_curve_index->push_back(poly2->tris[i]->cubitedge1index); 01480 out_curve_index->push_back(poly2->tris[i]->cubitedge2index); 01481 } 01482 } 01483 if ( out_surf_index ) out_surf_index->push_back(poly2->tris[i]->cubitsurfaceindex); 01484 if ( is_body_1 ) is_body_1->push_back(false); 01485 } 01486 it++; 01487 i++; 01488 } 01489 // GfxDebug::clear(); 01490 // poly1->debug_draw_boundary_edges(CUBIT_MAGENTA_INDEX); 01491 // GfxDebug::mouse_xforms(); 01492 // GfxDebug::clear(); 01493 // poly2->debug_draw_boundary_edges(CUBIT_GREEN_INDEX); 01494 delete hashobj; 01495 01496 status = CUBIT_SUCCESS; 01497 return status; 01498 } 01499 01500 CubitStatus FBIntersect::store_connectivity 01501 ( 01502 std::vector<int>& out_connections, 01503 int vertnum1, 01504 int vertnum2, 01505 int vertnum3 01506 ) 01507 { 01508 if ( vertnum1 == vertnum2 || 01509 vertnum2 == vertnum3 || 01510 vertnum1 == vertnum3 ) 01511 { 01512 PRINT_ERROR( "Cannot continue without generating a degenerate facet.\n" ); 01513 return CUBIT_FAILURE; 01514 } 01515 out_connections.push_back(vertnum1); 01516 out_connections.push_back(vertnum2); 01517 out_connections.push_back(vertnum3); 01518 return CUBIT_SUCCESS; 01519 } 01520 01521 int FBIntersect::get_vertex(FBPolyhedron *poly, int vtx, 01522 IntegerHash *hashobj, 01523 std::vector<double>& out_coords, 01524 int &num_sofar) 01525 { 01526 double xx, yy, zz, xval, yval, zval; 01527 int i, hashvalue, *hasharrayptr, hasharraysize, hptr, ifoundit; 01528 01529 xx = poly->verts[vtx]->coord[0]; 01530 yy = poly->verts[vtx]->coord[1]; 01531 zz = poly->verts[vtx]->coord[2]; 01532 hashvalue = makeahashvaluefrom_coord(xx,yy,zz); 01533 hasharrayptr = hashobj->getHashBin(hashvalue,&hasharraysize); 01534 ifoundit = -1; 01535 for ( i = 0; i < hasharraysize; i++ ) { 01536 hptr = hasharrayptr[i]; 01537 xval = out_coords[3*hptr]; 01538 yval = out_coords[3*hptr+1]; 01539 zval = out_coords[3*hptr+2]; 01540 if ( ( fabs(xval-xx) < EPSILON ) && 01541 ( fabs(yval-yy) < EPSILON ) && 01542 ( fabs(zval-zz) < EPSILON ) ) { 01543 ifoundit = hasharrayptr[i]; 01544 break; 01545 } 01546 } 01547 if ( ifoundit == -1 ) { 01548 ifoundit = num_sofar; 01549 hashobj->addtoHashList(hashvalue,num_sofar); 01550 out_coords.push_back(xx); 01551 out_coords.push_back(yy); 01552 out_coords.push_back(zz); 01553 num_sofar++; 01554 } 01555 01556 return ifoundit; 01557 } 01558 01559 int FBIntersect::makeahashvaluefrom_coord(double x, double y, double z) 01560 { 01561 double mantissasum; 01562 01563 if ( fabs(x) < 1.e-3 ) x = 0.0; 01564 if ( fabs(y) < 1.e-3 ) y = 0.0; 01565 if ( fabs(z) < 1.e-3 ) z = 0.0; 01566 mantissasum = (int)(10000.0*fabs(x) + 0.5) + 01567 (int)(10000.0*fabs(y) + 0.5) + 01568 (int)(10000.0*fabs(z) + 0.5); 01569 01570 return (int)(mantissasum) % NUMHASHBINS; 01571 } 01572 01573 01574 void FBIntersect::set_body1_planar() 01575 { 01576 body1_is_plane = true; 01577 } 01578 01579 void FBIntersect::set_body2_planar() 01580 { 01581 body2_is_plane = true; 01582 } 01583 01584 void FBIntersect::set_imprint() 01585 { 01586 do_imprint = true; 01587 } 01588 01589 void FBIntersect::newplanecoefficients(FBPolyhedron *poly, FB_Triangle *tri) 01590 { 01591 FB_Coord *mycoord; 01592 double x1, x2, x3, y1, y2, y3, z1, z2, z3, e1x, e1y, e1z, e2x, e2y, e2z; 01593 double a, b, c, d, dtemp; 01594 01595 mycoord = poly->verts[tri->v0]; 01596 x1 = mycoord->coord[0]; 01597 y1 = mycoord->coord[1]; 01598 z1 = mycoord->coord[2]; 01599 mycoord = poly->verts[tri->v1]; 01600 x2 = mycoord->coord[0]; 01601 y2 = mycoord->coord[1]; 01602 z2 = mycoord->coord[2]; 01603 mycoord = poly->verts[tri->v2]; 01604 x3 = mycoord->coord[0]; 01605 y3 = mycoord->coord[1]; 01606 z3 = mycoord->coord[2]; 01607 e1x = x1 - x2; e1y = y1 - y2; e1z = z1 - z2; 01608 e2x = x3 - x2; e2y = y3 - y2; e2z = z3 - z2; 01609 a = e1z*e2y - e2z*e1y; 01610 b = e1x*e2z - e2x*e1z; 01611 c = e1y*e2x - e2y*e1x; 01612 dtemp = sqrt(a*a + b*b + c*c); 01613 if ( dtemp > EPSILON2 ) { 01614 a /= dtemp; 01615 b /= dtemp; 01616 c /= dtemp; 01617 } else { 01618 PRINT_WARNING("small-area triangle\n"); 01619 } 01620 d = -(a*x1 + b*y1 + c*z1); 01621 tri->a = a; tri->b = b; tri->c = c; tri->d = d; 01622 01623 }
