cgma
FacetorTool.hpp
00001 //- Class: FacetorTool
00002 //- Description: FacetorTool is a template class that accepts both CubitNode, CubitTri, CubitEdge classes
00003 //-              and CubitPoint, CubitFacet, CubitFacetEdge classes.  CubitPoint, CubitFacet, and
00004 //-              CubitFacetEdge classes have been modified to account for the difference between the mdb
00005 //=              entities and geometric entities.
00006 //-------------------------------------------------------------------------
00007 // Filename      : FacetorTool.hpp
00008 //
00009 // Purpose       : 2D Delaunay Mesher
00010 //
00011 // Creator       : Christopher Hynes
00012 //
00013 // Creation Date : 5/31/2002
00014 //
00015 // Owner         : Steve Owen
00016 //-------------------------------------------------------------------------
00017
00018 #ifndef FACETOR_TOOL_HPP
00019 #define FACETOR_TOOL_HPP
00020
00021 #include "CubitFacet.hpp"
00022 #include "CubitFacetEdge.hpp"
00023 #include "CubitPoint.hpp"
00024
00025 class CubitFacet;
00026 class CubitFacetEdge;
00027 class CubitPoint;
00028 class ParamTool;
00029
00030 //template <class X> class DLIList;
00031 #include "DLIList.hpp"
00032
00033 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC>
00034 class FacetorTool
00035 {
00036 public:
00037   FacetorTool(){};
00038
00039   FacetorTool( SURF *ref_face_ptr,
00040            DLIList<NODE *> &bounding_nodes,
00041            NODE **boundary_edge_start_nodes,
00042            NODE **boundary_edge_end_nodes,
00043            int num_boundary_edges,
00044            SIZEFUNC *sizing_function,
00045            ParamTool *ptool);
00046
00047   ~FacetorTool(void);
00048
00049    CubitStatus mesh_surf(DLIList<TRI *> &facet_list);
00050    //- mesh the surface
00051    //- returns a facet_list of the mesh entities.  If using mesh entities, these are already
00052    //- added to the surface
00053    CubitStatus mesh_surfwoIP(DLIList<TRI *> &facet_list);
00054    //- mesh the surface with out interior point refinement
00055    CubitStatus mesh_surfwoIPBC(DLIList<TRI *> &facet_list);
00056    //- mesh the surface with out interior point refinement or boundary constraints
00057
00058
00059 private:
00060   ParamTool *pTool; //paramtool needed for sizing function interpolation
00061   SURF *refFacePtr; // id for surface
00062   DLIList<TRI *> *facetList; // list of tris created
00063   DLIList<NODE *> *boundingNodes;
00064   NODE **boundaryEdgeStartNodes;
00065   NODE **boundaryEdgeEndNodes;
00066   SIZEFUNC *sizingFunction;
00067   int numBoundaryEdges;
00068    //- bounding edges on the surfaces represented by their start
00069    //- and end nodes
00070
00071   NODE *boxNodes[4];
00072    //- temporary nodes created enclosing the surface to facilitate
00073    //- Delaunay node insertion
00074
00075   int curVisitFlag;
00076    //- current visited flag for triangles
00077
00078   CubitStatus insert_hard_points(DLIList<NODE*> &hard_points);
00079    //- insert hard points into the mesh
00080
00081   CubitStatus init_box();
00082    //- create two initial bounding triangles
00083
00084   CubitStatus insert_nodes( DLIList<NODE *> *&bounding_nodes );
00085    //- insert a list of nodes into an existing triangulation
00086
00087   CubitStatus constrain_boundary(void);
00088    //- recover the boundary edges from the mesh
00089
00090   CubitStatus delete_exterior(void);
00091    //- delete the triangles on the outside of the boundary and on
00092    //- the interior of any holes
00093
00094   CubitStatus delete_tris(DLIList<TRI *> &tri_list, int marked_flag);
00095    //- delete the triangles in the list with the spacified marked_flag
00096
00097   CubitStatus mark_tris(TRI *tri_ptr, int &num_found_edges);
00098    //- recursive function to mark all the triangles up to a marked edge
00099
00100   CubitStatus refine_interior(DLIList<TRI*> &tri_list);
00101    //- generate nodes on the interior of the tiangulation to
00102    //- improve quality. This inserts nodes at the circumcenters of
00103    //- triangles roughly based on the algorithm by Jonathon Shewchuk
00104
00105   CubitStatus classify_triangles(DLIList<TRI *> &tri_list,
00106                                  DLIList<TRI*>* sorted_lists,
00107                                  const int num_lists,
00108                                  const double interval);
00109    //- order the triangles in the current mesh by their worst angle
00110
00111   TRI *next_triangle(DLIList<TRI*>* sorted_lists,
00112                      const int num_lists);
00113    //- get the next triangle to process;
00114
00115   void clean_up_data(void);
00116   //- clean up any data we've allocated
00117
00118 };
00119
00120 #include "FacetorTool.cpp"
00121 #endif // FACETOR_TOOL_HPP
00122
