cgma
GeometryHealerEngine.hpp
00001 //-----------------------------------------------------------------------------
00002 // Filename      : GeometryHealerEngine.hpp
00003 //
00004 // Purpose       : Define the healer interface for all solid modeling engines.
00005 //
00006 // Special Notes : This is an abstract base class for the healer functions.
00007 //
00008 // Creator       : Tyronne Lim (CAT)
00009 //
00010 // Creation Date : 7/21/03
00011 //
00012 // Owner         :
00013 //-----------------------------------------------------------------------------
00014
00015 #ifndef _GEOMETRYHEALERENGINE_HPP
00016 #define _GEOMETRYHEALERENGINE_HPP
00017
00018 // *** BEGIN INCLUDES *** //
00019
00020 #include "CubitDefines.h"
00021 #include "DLIList.hpp"
00022 #include "CGMGeomConfigure.h"
00023
00024 // *** END INCLUDES *** //
00025
00026 // *** BEGIN FORWARD DECLARATIONS *** //
00027
00028 class Body;
00029
00030 class RefEntity;
00031 class RefFace;
00032 class RefEdge;
00033
00034 class TopologyBridge;
00035 class TopologyEntity;
00036
00037 // *** END FORWARD DECLARATIONS *** //
00038
00039 class CUBIT_GEOM_EXPORT GeometryHealerEngine
00040 {
00041    public:
00042
00043       // virtual destructor
00044       virtual ~GeometryHealerEngine() {}
00045
00046       // returns CUBIT_TRUE if the entity belongs to this healer engine
00047       virtual CubitBoolean is_healer_engine( const TopologyBridge* ) = 0;
00048       virtual CubitBoolean is_healer_engine( const TopologyEntity* ) = 0;
00049
00050       virtual CubitStatus auto_heal_bodies( DLIList<Body*> &body_list, DLIList<Body*> &new_body_list,
00051                                             DLIList<TopologyEntity*> &bad_geometry,
00052                                             CubitBoolean rebuild = CUBIT_FALSE,
00053                                             CubitBoolean keep_old = CUBIT_FALSE,
00054                                             CubitBoolean make_tolerant = CUBIT_FALSE,
00055                                             FILE* logfile_ptr = NULL ) = 0;
00056       // Uses the autohealer to heal the given body list.  The rebuild option
00057       // can be used for more rigorous healing, where each surface is pulled off,
00058       // healed, and then stitched back into a body.
00059
00060       virtual CubitStatus heal_bodies( DLIList<Body*> &body_list, DLIList<Body*> &new_body_list,
00061                                        DLIList<TopologyEntity*> &bad_geometry,
00062                                        CubitBoolean rebuild = CUBIT_FALSE,
00063                                        CubitBoolean keep_old = CUBIT_FALSE,
00064                                        CubitBoolean make_tolerant = CUBIT_FALSE,
00065                                        FILE* logfile_ptr = NULL ) = 0;
00066       // Heals the input bodies, using either autoheal or incremental,
00067       // depending on the switches that are setup.  Writes to the logfile
00068       // if it's been opened.
00069
00070       virtual CubitStatus analyze_badgeom( DLIList<Body*> &body_list,
00071                                            DLIList<TopologyEntity*> &bad_geometry,
00072                                            FILE* logfile = NULL ) = 0;
00073       // Uses the healing husk to find bad geometry and give feedback to
00074       // the user.  A lot more could be done here - this is just a quick
00075       // overview for the user (the user will have no idea why the identified
00076       // geometry is bad).  A logfile can give a little more information.
00077
00078       virtual CubitStatus get_badgeom( DLIList<Body*> &body_list,
00079                                        DLIList<TopologyEntity*> &bad_geometry ) = 0;
00080       // Shows the bad geometry.  The geometry must have been analyzed first.
00081       // If body_list is empty, shows only for those bodies that have been
00082       // analyzed.
00083
00084       virtual CubitStatus get_tcurves( DLIList<Body*> &body_list,
00085                                        DLIList<RefEdge*> &t_curves ) = 0;
00086       // Gets tolerant curves.  If the body list is empty, all tolerant
00087       // curves are retrieved.
00088
00089       virtual CubitStatus heal_incremental( DLIList<Body*> &body_list,
00090                                             DLIList<Body*> &new_bodies,
00091                                             DLIList<TopologyEntity*> &bad_geometry,
00092                                             double simplify_tol = CUBIT_DBL_MAX,
00093                                             double stitch_min_tol = CUBIT_DBL_MAX,
00094                                             double stitch_max_tol = CUBIT_DBL_MAX,
00095                                             double geombuild_tol = CUBIT_DBL_MAX,
00096                                             double analytic_tol = CUBIT_DBL_MAX,
00097                                             double isospline_tol = CUBIT_DBL_MAX,
00098                                             double reblend_classify_tol = CUBIT_DBL_MAX,
00099                                             double reblend_tol = CUBIT_DBL_MAX,
00100                                             CubitBoolean keep_old = CUBIT_FALSE,
00101                                             CubitBoolean make_tolerant = CUBIT_FALSE,
00102                                             FILE* logfile_ptr = NULL) = 0;
00103       // Uses the healing husk to perform one or more healing operations.
00104       // Which operations are performed is determined by switches in the
00105       // healer.  The user can set default tolerances (separate from this
00106       // function, override the defaults with this function, or just use the
00107       // tolerances calculated by the healer (preferred).
00108       //
00109       // The possible healing steps are:
00110       //    1) preprocess - removes zero-length edges, sliver faces, duplicate
00111       //                    vertices. This is the first step which is always
00112       //                    done (user shouldn't suppress this).  Tolerance is resabs.
00113       //    2) simplify - simplify NURBS into analytic.
00114       //                     Default simplify_tol = .0001
00115       //    3) stitch - stitch geometry together.  Iterative from min to max
00116       //                tolerance.
00117       //                   Default min tol = 10e-5
00118       //                   Default max tol = 1
00119       //    4) geombuild - geometry-related healing.
00120       //                      Default geombuild_tol = .01
00121       //                      Default analytic_tangency_tol = .01
00122       //                      Default isolspline_solver_tol = .01
00123       //          Individual geombuild steps can be (instead of doing all):
00124       //             analytic - performs all of the stages of the analytic solver
00125       //                        subphase of the geometry building phase. The analytic
00126       //                        solver subphase attempts to heal all edges and
00127       //                        vertices shared by analytic surfaces.
00128       //             isospline - performs all of the stages of the isospline solver
00129       //                         subphase of the geometry building phase. The
00130       //                         isospline solver attempts to heal all edges shared
00131       //                         by tangential isoparametric surfaces (e.g., the
00132       //                         intersection curve is an isoparametric curve of
00133       //                         both splines in the intersection).
00134       //             reblend - future option
00135       //             sharpedge - performs all of the stages of the sharp edge solver
00136       //                         subphase of the geometry building phase. The sharp
00137       //                         edge solver attempts to heal all edges and vertices
00138       //                         that are shared by surfaces that intersect sharply.
00139       //                         This includes nontangential surface junctions.
00140       //             genericspline - performs all of the stages of the generic spline
00141       //                             solver subphase of the geometry building phase.
00142       //                             The generic spline solver attempts to heal
00143       //                             generic tangential spline junctions, (e.g., the
00144       //                             intersection curve is not an isoparametric curve
00145       //                             of both splines in the intersection).
00146       //             wrapup - handles remaining pcurves, wraps up
00147       //                      geometry buiilding phase (user shouldn't suppress)
00148       //    5) postprocess - correction of neg-area faces, duplicate vertices, edge groups;
00149       //                     last step - always done (user shouldn't suppress)
00150
00151       virtual void list_incremental() = 0;
00152       // Lists the current settings for incremental healing
00153
00154       virtual void list_tolerances( DLIList<Body*> &body_list ) = 0;
00155       // Lists out the tolerances of each body, separately
00156
00157       virtual double get_default_simplify_tol() = 0;
00158       virtual void set_default_simplify_tol( double tol ) = 0;
00159       virtual double get_default_stitch_min_tol() = 0;
00160       virtual void set_default_stitch_min_tol( double tol ) = 0;
00161       virtual double get_default_stitch_max_tol() = 0;
00162       virtual void set_default_stitch_max_tol( double tol ) = 0;
00163       virtual double get_default_geombuild_tol() = 0;
00164       virtual void set_default_geombuild_tol( double tol ) = 0;
00165       virtual double get_default_analytic_tol() = 0;
00166       virtual void set_default_analytic_tol( double tol ) = 0;
00167       virtual double get_default_isospline_tol() = 0;
00168       virtual void set_default_isospline_tol( double tol ) = 0;
00169       virtual double get_default_reblend_classify_tol() = 0;
00170       virtual void set_default_reblend_classify_tol( double tol ) = 0;
00171       virtual double get_default_reblend_tol() = 0;
00172       virtual void set_default_reblend_tol( double tol ) = 0;
00173       virtual void reset_default_tolerances() = 0;
00174       virtual void list_default_tolerances() = 0;
00175       // Functions to set the default tolerances used.  The healer calculates
00176       // the default tolerance per body.  These functions allow the user to override
00177       // these defaults for all bodies healed.  In incremental healing, the user can
00178       // override these defaults by sending-in tolerances.  For autoheal, these
00179       // defaults are used if they are set, otherwise the healer calculates
00180       // intelligent defaults.
00181
00182       virtual void clean_attributes( DLIList<Body*>& body_list ) = 0;
00183       // Cleans healer attributes from the bodies.  These can be left if the
00184       // CleanAtt setting was used when doing analysis or healing.
00185
00186       virtual CubitBoolean get_cleanatt_flg() = 0;
00187       virtual void set_cleanatt_flg( CubitBoolean flg ) = 0;
00188       // Get/set flags which determine whether to clean attributes after
00189       // analysis and healing.
00190
00191       virtual int get_show_method() = 0; // 0-none, 1-highlight, 2-draw
00192       virtual void set_show_method( int method ) = 0;
00193       // Method determines how bad geometry is displayed
00194
00195       virtual CubitBoolean get_show_summary_flg() = 0;
00196       virtual void set_show_summary_flg( CubitBoolean flg ) = 0;
00197       // Flag to determine whether to list a summary when showing bad geometry
00198
00199       virtual CubitBoolean get_show_details_flg() = 0;
00200       virtual void set_show_details_flg( CubitBoolean flg ) = 0;
00201       // Flag to determine whether to list details when showing bad geometry
00202
00203       virtual CubitBoolean get_show_on_heal_flg() = 0;
00204       virtual void set_show_on_heal_flg( CubitBoolean flg ) = 0;
00205       // Flag to determine whether to show bad geometry after healing
00206
00207       virtual CubitBoolean get_check_vol_on_heal_flg() = 0;
00208       virtual void set_check_vol_on_heal_flg( CubitBoolean flg ) = 0;
00209       virtual double get_vol_on_heal_limit() = 0;
00210       virtual void set_vol_on_heal_limit( double limit ) = 0;
00211       // Allow for checking of short curves after healing
00212
00213       virtual CubitBoolean get_check_surf_on_heal_flg() = 0;
00214       virtual void set_check_surf_on_heal_flg( CubitBoolean flg ) = 0;
00215       virtual double get_surf_on_heal_limit() = 0;
00216       virtual void set_surf_on_heal_limit( double limit ) = 0;
00217       // Allow for checking of small surfaces after healing
00218
00219       virtual CubitBoolean get_check_curve_on_heal_flg() = 0;
00220       virtual void set_check_curve_on_heal_flg( CubitBoolean flg ) = 0;
00221       virtual double get_curve_on_heal_limit() = 0;
00222       virtual void set_curve_on_heal_limit( double limit ) = 0;
00223       // Allow for checking of short curves after healing
00224
00225       virtual CubitBoolean get_show_bad_vertices_flg() = 0;
00226       virtual void set_show_bad_vertices_flg( CubitBoolean flg ) = 0;
00227       virtual CubitBoolean get_show_bad_curves_flg() = 0;
00228       virtual void set_show_bad_curves_flg( CubitBoolean flg ) = 0;
00229       virtual CubitBoolean get_show_bad_coedges_flg() = 0;
00230       virtual void set_show_bad_coedges_flg( CubitBoolean flg ) = 0;
00231       virtual CubitBoolean get_show_bad_loops_flg() = 0;
00232       virtual void set_show_bad_loops_flg( CubitBoolean flg ) = 0;
00233       virtual CubitBoolean get_show_bad_surfaces_flg() = 0;
00234       virtual void set_show_bad_surfaces_flg( CubitBoolean flg ) = 0;
00235       virtual CubitBoolean get_show_bad_shells_flg() = 0;
00236       virtual void set_show_bad_shells_flg( CubitBoolean flg ) = 0;
00237       virtual CubitBoolean get_show_bad_volumes_flg() = 0;
00238       virtual void set_show_bad_volumes_flg( CubitBoolean flg ) = 0;
00239       virtual CubitBoolean get_show_bad_bodies_flg() = 0;
00240       virtual void set_show_bad_bodies_flg( CubitBoolean flg ) = 0;
00241       // Get/set for flags for what to show during analysis/show
00242
00243       virtual void list_onshow_flgs() = 0;
00244       // Function to list to user what the current onshow flags are
00245
00246       virtual CubitBoolean get_inc_preprocess_flg() = 0;
00247       virtual void set_inc_preprocess_flg( CubitBoolean flg ) = 0;
00248       virtual CubitBoolean get_inc_simplify_flg() = 0;
00249       virtual void set_inc_simplify_flg( CubitBoolean flg ) = 0;
00250       virtual CubitBoolean get_inc_stitch_flg() = 0;
00251       virtual void set_inc_stitch_flg( CubitBoolean flg ) = 0;
00252       virtual CubitBoolean get_inc_geombuild_flg() = 0;
00253       virtual void set_inc_geombuild_flg( CubitBoolean flg ) = 0;
00254       virtual CubitBoolean get_inc_analytic_flg() = 0;
00255       virtual void set_inc_analytic_flg( CubitBoolean flg ) = 0;
00256       virtual CubitBoolean get_inc_isospline_flg() = 0;
00257       virtual void set_inc_isospline_flg( CubitBoolean flg ) = 0;
00258       virtual CubitBoolean get_inc_reblend_flg() = 0;
00259       virtual void set_inc_reblend_flg( CubitBoolean flg ) = 0;
00260       virtual CubitBoolean get_inc_sharpedge_flg() = 0;
00261       virtual void set_inc_sharpedge_flg( CubitBoolean flg ) = 0;
00262       virtual CubitBoolean get_inc_genericspline_flg() = 0;
00263       virtual void set_inc_genericspline_flg( CubitBoolean flg ) = 0;
00264       virtual CubitBoolean get_inc_wrapup_flg() = 0;
00265       virtual void set_inc_wrapup_flg( CubitBoolean flg ) = 0;
00266       virtual CubitBoolean get_inc_postprocess_flg() = 0;
00267       virtual void set_inc_postprocess_flg( CubitBoolean flg ) = 0;
00268       // Functions for controlling incremental healing
00269
00270       virtual void measure_filter( DLIList<RefEntity*> &ref_entities,
00271                                    double measure_value,
00272                                    double tolerance ) = 0;
00273
00274       virtual CubitStatus force_simplify_to_plane( DLIList<RefFace*> &ref_face_list,
00275                                                    DLIList<Body*>& new_body_list,
00276                                                    CubitBoolean keep = CUBIT_FALSE ) = 0;
00277       virtual CubitStatus force_simplify_to_cylinder( DLIList<RefFace*> &ref_face_list,
00278                                                       DLIList<Body*>& new_body_list,
00279                                                       CubitBoolean keep = CUBIT_FALSE ) = 0;
00280       virtual CubitStatus force_simplify_to_cone( DLIList<RefFace*> &ref_face_list,
00281                                                   DLIList<Body*>& new_body_list,
00282                                                   CubitBoolean keep = CUBIT_FALSE ) = 0;
00283       virtual CubitStatus force_simplify_to_sphere( DLIList<RefFace*> &ref_face_list,
00284                                                     DLIList<Body*>& new_body_list,
00285                                                     CubitBoolean keep = CUBIT_FALSE ) = 0;
00286       virtual CubitStatus force_simplify_to_torus( DLIList<RefFace*> &ref_face_list,
00287                                                    DLIList<Body*>& new_body_list,
00288                                                    CubitBoolean keep = CUBIT_FALSE ) = 0;
00289       // Forces a spline surface to be an analytical of the type specified.
00290
00291    protected:
00292
00293    private:
00294
00295 };
00296
00297 #endif
00298
