cgma
GeometryModifyTool.hpp
00001
00015 #ifndef GEOMETRYMODIFYTOOL_HPP
00016 #define GEOMETRYMODIFYTOOL_HPP
00017
00018 #include <stdio.h>
00019 #include <map>
00020
00021 #include "CubitDefines.h"
00022 #include "GeometryDefines.h"
00023 #include "CubitBox.hpp"
00024 #include "CubitVector.hpp"
00025 #include "DLIList.hpp"
00026 #include "CGMGeomConfigure.h"
00027 #include "FacetShapeDefs.hpp"
00028 #include "CubitColor.hpp"
00029
00030 class CoEdgeSM;
00031 class LoopSM;
00032 class CubitPlane;
00033 class Surface;
00034 class Lump;
00035 class Curve;
00036 class Body;
00037 class RefVertex;
00038 class RefEdge;
00039 class RefFace;
00040 class RefVolume;
00041 class RefVertex;
00042 class RefFace;
00043 class RefVolume;
00044 template <class X> class DLIList;
00045 class Loop;
00046 class LoopSM;
00047 class RefEntity;
00048 class CoEdgeSM;
00049 class Surface;
00050 class ShellSM;
00051 class Lump;
00052 class TopologyEntity;
00053 class TopologyBridge;
00054 class ShellSM;
00055 class GeometryModifyEngine;
00056 class TopologyBridge;
00057 class TopologyEntity;
00058 class BodySM;
00059 class Surface;
00060 class Curve;
00061 class TBPoint;
00062 class GeometryEntity;
00063
00064
00066 class CUBIT_GEOM_EXPORT GeometryModifyTool
00067 {
00068
00069   friend class MergeTool;
00070 public :
00071
00086   static GeometryModifyTool* instance( GeometryModifyEngine* GMEPtr = NULL);
00087
00088   static void delete_instance();
00089
00091   ~GeometryModifyTool();
00092
00097
00098   Body* sphere( double radius,
00099                 int x_shift = 0,
00100                 int y_shift = 0,
00101                 int z_shift = 0,
00102                 double inner_radius = 0,
00103                 bool delete_side = false );
00104
00109
00110   Body* brick( double wid, double dep, double hi );
00111
00118
00119   Body* brick( const CubitVector &center,
00120                const CubitVector axes[3],
00121                const CubitVector &extension );
00122
00128
00129   Body* prism( double height, int sides, double major, double minor );
00130
00137
00138   Body* pyramid( double height, int sides, double major, double minor,
00139                  double top=0.0 );
00140
00148
00149   Body* cylinder( double hi, double r1, double r2, double r3 );
00150
00156
00157   Body* torus( double r1, double r2 );
00158
00165
00166   Body* planar_sheet( const CubitVector& p1,
00167                       const CubitVector& p2,
00168                       const CubitVector& p3,
00169                       const CubitVector& p4 );
00170
00176
00177   Body* planar_sheet( const CubitVector &center,
00178                       const CubitVector axes[2],
00179                       double width, double height );
00180
00189
00190   Body* planar_sheet( const CubitPlane& plane,
00191                       const CubitBox& bounding_box,
00192                       int extension_type = 0,
00193                       double extension = 0.0 );
00194
00202
00203   Body* create_body( VolumeFacets& volume, std::map<FacetShapes*, RefEntity*>& entity_map,
00204                      const FacetPointSet& points, int interp_order);
00205
00207   CubitStatus scale ( Body *&entity,
00208                       const CubitVector& point,
00209                       const CubitVector& factors,
00210                       bool check_to_transform = true,
00211                       bool preview = false,
00212                       bool reset_preview=true);
00213
00226
00227   Body* copy_body( Body* body_ptr,
00228       std::map< RefEntity*, RefEntity* > *old_to_new_map = NULL );
00229
00233
00234   RefEntity* copy_refentity( RefEntity *old_entity );
00235
00237   CubitStatus reverse( DLIList<Body*> &body_list );
00238
00240   CubitStatus reverse( DLIList<RefFace*> &ref_face_list );
00241
00245
00246
00247   CubitStatus align_entities( RefFace *my_face,
00248                           RefFace *target_face,
00249                           DLIList<RefEntity*> &entities_to_move,
00250                           bool reverse,
00251                           CubitVector &my_center,
00252                           CubitVector &axis_of_rot,
00253                           CubitVector &target_center,
00254                           double &angle,
00255                           bool preview);
00275
00276   CubitStatus align_entities(DLIList<RefEntity*> &entities_to_move,
00277                              CubitVector &position_to_align,
00278                              CubitVector &position_to_align_to,
00279                              CubitVector &axis_origin,
00280                              CubitVector &axis_of_rot,
00281                              double &angle_of_rotation,
00282                              bool preview);
00283
00301
00302   CubitStatus align_entities( DLIList<RefEntity*>& reference_entities,
00303                               DLIList<RefEntity*> &entities_to_move,
00304                               CubitVector align_to_vec,
00305                               CubitVector &my_center,
00306                               CubitVector &axis_of_rot,
00307                               double &angle,
00308                               bool preview );
00336
00337   CubitStatus chop( DLIList<Body*> &bodies,
00338                     DLIList<Body*> &intersectBodies,
00339                     DLIList<Body*> &outsideBodies,
00340                     Body*& leftoversBody,
00341                     bool keep_old = false,
00342                     bool nonreg = false );
00343
00344   CubitStatus hollow( DLIList<Body*>& bodies,
00345                       DLIList<RefFace*> faces_to_remove,
00346                       DLIList<Body*>& new_bodies,
00347                       double depth);
00348
00350   CubitStatus thicken( DLIList<Body*>& bodies,
00351                        DLIList<Body*>& new_bodies,
00352                        double depth,
00353                        bool both = false );
00355   CubitStatus unite( DLIList<Body*> &bodies,
00356                      DLIList<Body*> &newBodies,
00357                      bool keep_old = false );
00358
00360   CubitStatus unite( DLIList<BodySM*> &body_sm_list,
00361                      DLIList<BodySM*> &new_body_sm_list,
00362                      bool keep_old = false);
00363
00365   CubitStatus subtract( DLIList<Body*> &tool_body_list,
00366                         DLIList<Body*> &from_bodies,
00367                         DLIList<Body*> &new_bodies,
00368                         bool imprint = false,
00369                         bool keep_old = false );
00370
00372   CubitStatus subtract( Body* tool_body,
00373                         DLIList<Body*> &from_bodies,
00374                         DLIList<Body*> &new_bodies,
00375                         bool imprint = false,
00376                         bool keep_old = false );
00377
00382
00383   CubitStatus validate_normals( DLIList<Body*>& bodies,
00384                                 RefFace *surf_ref,
00385                                 bool reverse );
00386
00388   CubitStatus intersect( Body *tool_body_ptr,
00389                          DLIList<Body*> &from_bodies,
00390                          DLIList<Body*> &new_bodies,
00391                          bool keep_old = false,
00392                          bool preview = false );
00393
00395   CubitStatus intersect( DLIList<Body*> &from_bodies,
00396                          DLIList<Body*> &new_bodies,
00397                          bool keep_old = false,
00398                          bool preview = false);
00399
00404
00405   CubitStatus section( DLIList<Body*> &section_body_list,
00406                        const CubitVector &point_1,
00407                        const CubitVector &point_2,
00408                        const CubitVector &point_3,
00409                        DLIList<Body*> &new_body_list,
00410                        CubitBoolean keep_normal_side,
00411                        CubitBoolean keep_old = CUBIT_FALSE );
00412
00414   CubitStatus split_periodic( Body *body_ptr,
00415                               Body *&new_body_ptr );
00416
00418   CubitStatus stitch( DLIList<Body*> &bodies_to_stitch,
00419                       DLIList<Body*> &result_list,
00420                       bool tighten_gaps,
00421                       double tolerance = -1.0 );
00422
00424   CubitStatus discover_topology(RefFace *ref_face_ptr,
00425                                 CubitVector &pos,
00426                                 double &step_size,
00427                                 int num_subdivisions);
00428
00429   CubitStatus imprint_and_merge_curves(RefEdge *curve1,
00430                                        RefEdge *curve2,
00431                                        DLIList<RefVertex*> &vert_list,
00432                                        double divergence_angle,
00433                                        DLIList<DLIList<RefEdge*>*> &curves_to_merge1,
00434                                        DLIList<DLIList<RefEdge*>*> &curves_to_merge2,
00435                                        DLIList<DLIList<RefEdge*>*> &prev_curve_merge_lists,
00436                                        DLIList<DLIList<RefFace*>*> &prev_surf_merge_lists);
00437
00438 #ifdef KCM_MESH_TO_GEOM
00439
00440   CubitStatus mesh2brep(std::vector<double> &xvals,
00441                         std::vector<double> &yvals,
00442                         std::vector<double> &zvals,
00443                         std::vector<unsigned int> &tri_connectivity,
00444                         DLIList<BodySM*> &new_body_sms);
00445 #endif
00446
00448   void march_path_to_discover_horizontal(CubitVector &start_pos,
00449                   CubitVector &sweep_dir,
00450                   RefFace *start_face,
00451                   CubitVector &march_dir,
00452                   double &step_size,
00453                   DLIList<CubitVector> &final_points,
00454                   DLIList<RefFace*> &ending_faces);
00455   void march_path_to_discover_vertical(CubitVector &start_pos,
00456                  CubitVector &sweep_dir,
00457                  RefFace *start_face,
00458                  CubitVector &march_dir,  // should be normalized
00459                  double &step_size,
00460                  DLIList<CubitVector> &final_points,
00461                  DLIList<RefFace*> &ending_faces);
00462   void march_using_planes(CubitVector &point_on_surf,
00463                           RefFace *surf,
00464                           CubitVector &march_dir,
00465                           double step_size,
00466                           DLIList<CubitVector> &horizontal_points,
00467                           DLIList<CubitVector> &vertical_points);
00468   void trace_out_curves(Body *plane_body,
00469                         CubitVector &start_point,
00470                         CubitVector &march_dir,
00471                         double step_size,
00472                         DLIList<CubitVector> &horizontal_points,
00473                         DLIList<CubitVector> &vertical_points);
00474
00476   void subdivide_pie(CubitVector &dir1, CubitVector &dir2, int num_subdivisions,
00477                                        DLIList<CubitVector> &all_directions);
00478
00490
00491   CubitStatus split_surface( RefFace *ref_face_ptr,
00492                              DLIList<CubitVector*> &locations,
00493                              DLIList<DLIList<CubitVector*>*> &vec_lists,
00494                              CubitBoolean preview_flg = CUBIT_FALSE,
00495                              CubitBoolean create_ref_edges_flg = CUBIT_FALSE,
00496                              CubitBoolean clear_previous_previews = CUBIT_TRUE );
00497
00498
00502
00503   CubitStatus split_surface( DLIList<RefFace*> &ref_face_list,
00504                              DLIList<CubitVector*> &locations,
00505                              DLIList<DLIList<DLIList<CubitVector*>*>*> &list_of_vec_lists,
00506                              CubitBoolean preview_flg = CUBIT_FALSE,
00507                              CubitBoolean create_ref_edges_flg = CUBIT_FALSE,
00508                              CubitBoolean clear_previous_previews = CUBIT_TRUE );
00509
00541
00542   CubitStatus split_surfaces_extend( DLIList<RefFace*> &ref_face_list,
00543                                      DLIList<RefVertex*> &ref_vertex_list,
00544                                      CubitBoolean preview_flg = CUBIT_FALSE,
00545                                      CubitBoolean create_ref_edges_flg = CUBIT_FALSE );
00546
00602
00603   CubitStatus split_surfaces( DLIList<RefFace*> &ref_face_list,
00604                               int num_segs,
00605                               double fraction,
00606                               double distance,
00607                               RefEdge *from_curve_ptr,
00608                               DLIList<RefVertex*> &corner_vertex_list,
00609                               DLIList<RefVertex*> &through_vertex_list,
00610                               RefEdge *curve_dir_ptr = NULL,
00611                               CubitBoolean preview_flg = CUBIT_FALSE,
00612                               CubitBoolean create_ref_edges_flg = CUBIT_FALSE );
00613
00630
00631   CubitStatus split_surfaces_offset(
00632       DLIList<RefFace*> &ref_face_list,
00633       DLIList<RefEdge*> &edge_list,
00634       int num_segs,
00635       double distance,
00636       CubitBoolean partition_flg = CUBIT_FALSE,
00637       CubitBoolean blunt_flg = CUBIT_FALSE,
00638       CubitBoolean preview_flg = CUBIT_FALSE,
00639       CubitBoolean create_ref_edges_flg = CUBIT_FALSE);
00640
00648
00649   CubitStatus auto_mid_surface(
00650       DLIList<Body*> &body_list_in,
00651       DLIList<Body*> &body_list_out,
00652       DLIList<Body*> &old_bodies_midsurfaced,
00653       DLIList<double> &thickness_list,
00654       double lower_tol,
00655       double upper_tol,
00656       CubitBoolean delete_midsurfaced,
00657       CubitBoolean preview);
00672
00673   CubitStatus webcut_with_cylinder( DLIList<Body*>& webcut_body_list,
00674                                     double radius,
00675                                     const CubitVector &axis,
00676                                     const CubitVector& center,
00677                                     DLIList<Body*> &results_list,
00678                                     DLIList<Body*> &neighboring_bodies,
00679                                     ImprintType imprint_type = NO_IMPRINT,
00680                                     CubitBoolean merge = CUBIT_FALSE ,
00681                                     CubitBoolean preview = CUBIT_FALSE);
00682
00688
00689   CubitStatus webcut_with_Cone( DLIList<Body*>& webcut_body_list,
00690                                 DLIList<BodySM*> &webcut_bodySM_list,
00691                                 double outer_radius,
00692                                 double top_radius,
00693                                 CubitVector &Axispt1,
00694                                 CubitVector& Axispt2,
00695                                 DLIList<Body*> &results_list,
00696                                 DLIList<Body*> &neighboring_bodies,
00697                                 ImprintType imprint_type = NO_IMPRINT,
00698                                 CubitBoolean merge = CUBIT_FALSE ,
00699                                 CubitBoolean preview = CUBIT_FALSE);
00700
00701 #ifdef CAT
00702   CubitStatus webcut_across_translate( DLIList<Body*>& body_list,
00703                                        RefFace* plane_surf1,
00704                                        RefFace* plane_surf2,
00705                                        DLIList<Body*>& results_list,
00706                                        ImprintType imprint_type = NO_IMPRINT,
00707                                        CubitBoolean merge = CUBIT_FALSE,
00708                                        CubitBoolean preview = CUBIT_FALSE);
00712 #endif
00713
00722
00723   CubitStatus webcut_with_brick( DLIList<Body*>& webcut_body_list,
00724                                  const CubitVector &center,
00725                                  const CubitVector axes[3],
00726                                  const CubitVector &extension,
00727                                  DLIList<Body*> &results_list,
00728                                  DLIList<Body*> &neighbor_list,
00729                                  ImprintType imprint_type = NO_IMPRINT,
00730                                  CubitBoolean merge = CUBIT_FALSE,
00731                                  CubitBoolean preview = CUBIT_FALSE);
00732
00733
00739
00740   CubitStatus webcut_with_planar_sheet( DLIList<Body*>& webcut_body_list,
00741                                         const CubitVector &center,
00742                                         const CubitVector axes[2],
00743                                         double width,
00744                                         double height,
00745                                         DLIList<Body*> &results_list,
00746                                         DLIList<Body*> &neighbor_list,
00747                                         ImprintType imprint_type = NO_IMPRINT,
00748                                         CubitBoolean merge = CUBIT_FALSE,
00749                                         CubitBoolean preview = CUBIT_FALSE);
00750
00751
00769
00770   CubitStatus webcut_with_plane( DLIList<Body*>& webcut_body_list,
00771                                  const CubitVector &vector1,
00772                                  const CubitVector &vector2,
00773                                  const CubitVector &vector3,
00774                                  DLIList<Body*> &results_list,
00775                                  DLIList<Body*> &neighbor_list,
00776                                  ImprintType imprint_type = NO_IMPRINT,
00777                                  CubitBoolean merge = CUBIT_FALSE,
00778                                  CubitBoolean preview = CUBIT_FALSE) ;
00779
00799
00800   CubitStatus webcut_with_surface( DLIList<Body*>& webcut_body_list,
00801                                    RefFace* refFace,
00802                                    DLIList<Body*>& results_list,
00803                                    DLIList<Body*> &neighbor_list,
00804                                    ImprintType imprint_type = NO_IMPRINT,
00805                                    CubitBoolean merge = CUBIT_FALSE,
00806                                    CubitBoolean preview = CUBIT_FALSE);
00807
00827
00828   CubitStatus webcut_with_curve_loop( DLIList<Body*>& webcut_body_list,
00829                               DLIList<RefEdge*>& refedge_list,
00830                               DLIList<Body*>& results_list,
00831                               DLIList<Body*> &neighbor_list,
00832                               ImprintType imprint_type = NO_IMPRINT,
00833                               CubitBoolean merge = CUBIT_FALSE,
00834                               CubitBoolean preview = CUBIT_FALSE);
00835
00841
00842   CubitStatus webcut_with_sheet( DLIList<Body*>& webcut_body_list,
00843                                  Body *sheet_body,
00844                                  DLIList<Body*> &new_bodies,
00845                                  DLIList<Body*> &neighbor_list,
00846                                  ImprintType imprint_type = NO_IMPRINT,
00847                                  CubitBoolean merge = CUBIT_FALSE,
00848                                  CubitBoolean preview = CUBIT_FALSE);
00849
00867
00868   CubitStatus webcut_with_body( DLIList<Body*>& webcut_body_list,
00869                         Body* body,
00870                         DLIList<Body*>& results_list,
00871                                 DLIList<Body*> &neighbor_list,
00872                                 ImprintType imprint_type = NO_IMPRINT,
00873                         CubitBoolean merge = CUBIT_FALSE,
00874                                 CubitBoolean preview = CUBIT_FALSE);
00875
00879
00880   CubitStatus webcut_with_extended_sheet( DLIList<Body*> &webcut_body_list,
00881                                           DLIList<RefFace*> &ref_face_list,
00882                                           DLIList<Body*> &new_bodies,
00883                                           DLIList<Body*> &neighbor_list,
00884                                           int &num_cut,
00885                                           ImprintType imprint_type = NO_IMPRINT,
00886                                           CubitBoolean merge = CUBIT_FALSE,
00887                                           CubitBoolean preview = CUBIT_FALSE);
00888
00890   CubitStatus webcut_with_sweep_surfaces_rotated(
00891                             DLIList<Body*> &webcut_body_list,
00892                             DLIList<RefFace*> &tool_faces,
00893                             CubitVector &point,
00894                             CubitVector &sweep_axis,
00895                             double angle,
00896                             RefFace* stop_surf,
00897                             bool up_to_next,
00898                             DLIList<Body*> &new_bodies,
00899                             DLIList<Body*> &neighbor_list,
00900                             ImprintType imprint_type = NO_IMPRINT,
00901                             CubitBoolean merge = false,
00902                             CubitBoolean preview = false);
00903
00905   CubitStatus webcut_with_sweep_curves_rotated(
00906                             DLIList<Body*> &webcut_body_list,
00907                             DLIList<RefEdge*> &tool_curves,
00908                             CubitVector &point,
00909                             CubitVector &sweep_axis,
00910                             double angle,
00911                             RefFace* stop_surf,
00912                             DLIList<Body*> &new_bodies,
00913                             DLIList<Body*> &neighbor_list,
00914                             ImprintType imprint_type = NO_IMPRINT,
00915                             CubitBoolean merge = false,
00916                             CubitBoolean preview = false);
00917
00919   CubitStatus webcut_with_sweep_surfaces(
00920                             DLIList<Body*> &webcut_body_list,
00921                             DLIList<RefFace*> &tool_faces,
00922                             const CubitVector sweep_vector,
00923                             bool sweep_perp,
00924                             bool through_all,
00925                             bool outward,
00926                             bool up_to_next,
00927                             RefFace *stop_surf,
00928                             RefEdge* edge_to_sweep_along,
00929                             DLIList<Body*> &new_bodies,
00930                             DLIList<Body*> &neighbor_list,
00931                             ImprintType imprint_type = NO_IMPRINT,
00932                             CubitBoolean merge = false,
00933                             CubitBoolean preview = false);
00934
00936   CubitStatus webcut_with_sweep_curves(
00937                             DLIList<Body*> &webcut_body_list,
00938                             DLIList<RefEdge*> &tool_curves,
00939                             const CubitVector sweep_vector,
00940                             bool through_all,
00941                             RefFace *stop_surf,
00942                             RefEdge* edge_to_sweep_along,
00943                             DLIList<Body*> &new_bodies,
00944                             DLIList<Body*> &neighbor_list,
00945                             ImprintType imprint_type = NO_IMPRINT,
00946                             CubitBoolean merge = false,
00947                             CubitBoolean preview = false);
00948
00950   CubitStatus remove_topology( DLIList<RefEdge*> &ref_edge_list,
00951         DLIList<RefFace*> &ref_face_list, double backoff_distance,
00952         double small_curve_size, DLIList<Body*> &new_body_list,
00953         CubitBoolean propagate,
00954         CubitBoolean preview);
00955
00961
00962   CubitStatus offset_curves( DLIList<RefEdge*>& ref_edge_list,
00963                              DLIList<RefEdge*>& output_edge_list,
00964                              double offset_distance,
00965                              const CubitVector& offset_direction,
00966                              int gap_type = 1 );
00967
00973
00974   CubitStatus trim_curve( RefEdge* trim_curve,
00975                           const CubitVector& trim_vector,
00976                           const CubitVector& keep_vector );
00977
00979   CubitStatus imprint( DLIList<Body*> &from_body_list,
00980                        DLIList<Body*> &new_body_list,
00981                        CubitBoolean keep_old = CUBIT_FALSE );
00982
00988
00989   CubitStatus imprint( DLIList<Body*> &body_list,
00990                        DLIList<RefEdge*> &ref_edge_list,
00991                        DLIList<Body*>& new_body_list,
00992                        CubitBoolean keep_old_body = CUBIT_FALSE,
00993                        CubitBoolean show_messages = CUBIT_TRUE );
00994
01003
01004   CubitStatus imprint( DLIList<RefFace*> &ref_face_list,
01005                        DLIList<RefEdge*> &ref_edge_list,
01006                        DLIList<Body*>& new_body_list,
01007                        CubitBoolean keep_old_body = CUBIT_FALSE );
01008
01016
01017   CubitStatus imprint( DLIList<Surface*> &surface_list,
01018                        DLIList<DLIList<Curve*>*> &curve_lists_list,
01019                        Body*& new_body,
01020                        CubitBoolean keep_old_body = CUBIT_FALSE,
01021                        CubitBoolean expand = CUBIT_TRUE);
01022
01027
01028   CubitStatus imprint(DLIList<Body*> &body_list,
01029                        DLIList<CubitVector> &vector_list,
01030                        DLIList<Body*>& new_body_list,
01031                        CubitBoolean keep_old_body = CUBIT_FALSE,
01032                        CubitBoolean merge = CUBIT_FALSE );
01033
01034   //HEADER- Sweep-related functions. All of these are implemented
01035   //HEADER- only for RefEntities whose underlying geometry is
01036   //HEADER- represented by a solid model such as . The interface
01037   //HEADER- itself is free of .
01038
01039
01041    CubitStatus imprint_projected_edges( DLIList<RefFace*> &ref_face_list,
01042                                         DLIList<RefEdge*> &ref_edge_list,
01043                                         DLIList<Body*>& new_body_list,
01044                                         CubitBoolean keep_old_body,
01045                                         CubitBoolean keep_free_edges );
01046
01049    CubitStatus imprint_projected_edges( DLIList<RefFace*> &ref_face_list,
01050                                         DLIList<Body*> &body_list,
01051                                         DLIList<RefEdge*> &ref_edge_list,
01052                                         DLIList<Body*>& new_body_list,
01053                                         CubitBoolean keep_old_body,
01054                                         CubitBoolean keep_free_edges );
01055
01058   CubitStatus tolerant_imprint( DLIList<RefFace*> &ref_faces,
01059                                 DLIList<RefEdge*> &ref_edge_list,
01060                                 DLIList<Body*> &new_bodies,
01061                                 bool merge = false );
01062
01065   CubitStatus tolerant_imprint( RefFace *ref_face,
01066                                 DLIList<RefEdge*> &ref_edge_list,
01067                                 Body *&new_body, bool merge = false );
01068
01071   CubitStatus tolerant_imprint( DLIList<Body*> &bodies, DLIList<Body*> &new_bodies,
01072                                 double overlap_tol,
01073                                 double imprint_tol,
01074                                 bool merge = false );
01075
01077   CubitStatus project_edges( DLIList<RefFace*> &ref_face_list,
01078                               DLIList<RefEdge*> &ref_edge_list_in,
01079                              DLIList<RefEdge*> &ref_edge_list_new,
01080                              CubitBoolean trim_projected = CUBIT_FALSE);
01081
01083   CubitStatus regularize_body( Body *body_ptr, Body *&new_body );
01084
01087   CubitStatus regularize_refentity( RefEntity *old_entity_ptr,
01088                                     Body *&new_body_ptr);
01089
01092   CubitStatus test_regularize_refentity( RefEntity *old_entity_ptr);
01093
01094   CubitStatus split_free_curve( RefEdge *ref_edge,
01095                                 DLIList<CubitVector> &split_locations,
01096                                 DLIList<RefEdge*> &new_ref_edges );
01097
01099   CubitStatus split_body( Body *body_ptr,
01100                           DLIList<Body*> &new_bodies ) const;
01101
01105
01106   CubitStatus separate_surfaces( DLIList<RefFace*> &ref_face_list,
01107                                  DLIList<Body*> &new_bodies );
01108
01109
01111
01113   static void set_group_imprint(CubitBoolean flag) {groupImprint = flag;}
01115   static CubitBoolean get_group_imprint() {return groupImprint;}
01116
01118   static void set_all_edges_imprint( CubitBoolean flag );
01120   static CubitBoolean get_all_edges_imprint();
01121
01123   static void boolean_regularize( CubitBoolean flag );
01125   static CubitBoolean boolean_regularize();
01126
01128   static CubitBoolean unite_mixed_models();
01130   static void unite_mixed_models( CubitBoolean flag );
01131
01133   static CubitBoolean get_new_ids() {return newIds;}
01135   static void set_new_ids(CubitBoolean flag) {newIds = flag;}
01136
01138   static CubitBoolean get_old_names() { return oldNames; }
01140   static void set_old_names(CubitBoolean flag) { oldNames = flag; }
01141
01143   static void initialize_settings();
01144
01145
01146   #ifdef PROE
01147   CubitStatus prepare_for_topology_update( BodySM* old_bodysm );
01148
01149   CubitStatus finish_topology_update( BodySM* new_bodysm,
01150                                       Body* old_body );
01151   #endif
01152
01154   static RefEntity* get_copy_entity() { return copyingEntity; }
01155
01157   static void set_copy_entity( RefEntity *ent) { copyingEntity = ent; }
01158
01159   double get_resultant_angle_score(RefFace *narrow_face,
01160                                    RefFace *other_face,
01161                                    RefEdge *common_edge);
01162
01163   double get_neighbor_type_score(RefEdge *common_edge,
01164                                  RefFace *other_face,
01165                                  double small_curve_size,
01166                                  int &neighbor_is_narrow_or_small);
01167
01168   double get_dihedral_angle_score(RefFace *f1, RefFace *f2,
01169                                   RefEdge *common_edge);
01170
01171   double get_edge_type_score(RefEdge *common_edge, double small_curve_size);
01172   double get_diff_from_multiple_of_90(double angle);
01173   void split_surface_with_narrow_region(RefFace *face,
01174                                         DLIList<CubitVector> &split_pos1_list,
01175                                         DLIList<CubitVector> &split_pos2_list);
01176
01178
01192
01193   RefVertex* make_RefVertex(CubitVector const& point, int color = CUBIT_DEFAULT_COLOR_INDEX) const;
01194   RefVertex* make_RefVertex( RefVertex *vertex ) const;
01195
01197   Body *make_Body(Surface *surface) const;
01198
01218
01219   RefEdge* make_RefEdge( GeometryType ref_edge_type,
01220                          RefVertex *ref_vertex_1,
01221                          RefVertex *ref_vertex_2,
01222                          DLIList<CubitVector*>& vector_list,
01223                          RefFace* reffaca_ptr = NULL ) const ;
01224
01239
01240   RefEdge* make_RefEdge(  RefVertex *ref_vertex_1,
01241                           RefVertex *ref_vertex_2,
01242                           RefFace* ref_face_ptr,
01243                           RefVertex const* ref_vertex_3 = NULL ) const ;
01244
01253
01254   RefEdge* make_RefEdge(RefEdge *ref_edge,
01255                         bool copy_attribs = true,
01256                         std::map< RefEntity*, RefEntity* > *old_to_new_map = NULL ) const;
01257
01303
01304   RefEdge* make_RefEdge(GeometryType ref_edge_type,
01305                         RefVertex *ref_vertex_1,
01306                         RefVertex *ref_vertex_2,
01307                         CubitVector const* intermediate_point = NULL ) const;
01308
01309   RefEdge* make_elliptical_RefEdge( RefVertex *vert1,
01310                                     RefVertex *vert2,
01311                                     CubitVector center_point,
01312                                     double start_angle,
01313                                     double end_angle,
01314                                     CubitSense sense) const;
01315
01316
01318   RefFace* make_RefFace(RefFace *from_ref_face,
01319                         std::map< RefEntity*, RefEntity* > *old_to_new_map = NULL) const;
01320
01334
01335   Body* make_extended_sheet( DLIList<RefFace*> &ref_face_list,
01336                              CubitBox *clip_box_ptr = NULL,
01337                              bool preview = false) const;
01338
01362
01363   RefFace* make_RefFace(GeometryType ref_face_type,
01364                         DLIList<RefEdge*>& ref_edge_list,
01365                         bool is_free_face,
01366                         RefFace *ref_face_ptr = NULL,
01367                         bool check_edges = true ) const ;
01368
01382
01383   Body* make_Body(DLIList<RefVolume*>& ref_volume_list) const ;
01384
01390
01391   Body* make_Body(RefFace *from_ref_face,
01392                   std::map< RefEntity*, RefEntity* > *old_to_new_map = NULL ) const;
01393
01415
01416   Body* make_Body(GeometryType ref_face_type,
01417                   DLIList<RefEdge*>& ref_edge_list,
01418                   RefFace *ref_face_ptr = NULL) const ;
01419
01421   CubitStatus sweep_translational(DLIList<RefEntity*>& ref_ent_list,
01422                                   const CubitVector& sweep_vector,
01423                                   double draft_angle,
01424                                   int draft_type,
01425                                   CubitBoolean switchside,
01426                                   CubitBoolean rigid,
01427                                   CubitBoolean anchor_entity,
01428                                   CubitBoolean keep_old,
01429                                   DLIList<Body*>& output_body_list);
01430
01431   CubitStatus sweep_helical( DLIList<RefEntity*>& ref_ent_list,
01432                              CubitVector &location,
01433                              CubitVector &direction,
01434                              double &thread_distance,
01435                              double &angle,
01436                              bool right_handed,
01437                              CubitBoolean anchor_entity,
01438                              CubitBoolean keep_old,
01439                              DLIList<Body*>& output_body_list);
01440
01441    CubitStatus sweep_curve_target(CubitPlane ref_plane,
01442                          DLIList<RefEntity*>& ref_ent_list);
01443
01444    CubitStatus sweep_curve_target(DLIList<RefEdge*>& curve_list,
01445                             Body *target_body,
01446                             DLIList<Body*> &out_bodies,
01447                             CubitVector direction,
01448                             CubitPlane stop_plane,
01449                             bool unite);
01450
01451    CubitStatus sweep_surface_target(RefFace *face,
01452                                     Body *target_body,
01453                                     CubitVector distance,
01454                                     CubitPlane stop_plane,
01455                                     double magnitude = 0.0 );
01456
01457    CubitStatus sweep_surface_target(CubitPlane ref_plane,
01458                         DLIList<RefEntity*>& ref_ent_list);
01459
01460   CubitStatus sweep_perpendicular(DLIList<RefEntity*>& ref_ent_list,
01461                                   double distance,
01462                                   double draft_angle,
01463                                   int draft_type,
01464                                   CubitBoolean switchside,
01465                                   CubitBoolean rigid,
01466                                   CubitBoolean anchor_entity,
01467                                   CubitBoolean keep_old,
01468                                   DLIList<Body*>& output_body_list);
01469
01471   CubitStatus sweep_rotational(DLIList<RefEntity*>& ref_ent_list,
01472                                const CubitVector& point,
01473                                const CubitVector& direction,
01474                                double angle,
01475                                DLIList<Body*>& output_body_list,
01476                                CubitBoolean anchor_entity,
01477                                CubitBoolean keep_old,
01478                                int steps = 0,
01479                                double draft_angle = 0.0,
01480                                int draft_type = 0,
01481                                CubitBoolean switchside = CUBIT_FALSE,
01482                                CubitBoolean make_solid = CUBIT_FALSE,
01483                                CubitBoolean rigid = CUBIT_FALSE );
01484
01486   CubitStatus sweep_along_curve(DLIList<RefEntity*>& ref_ent_list,
01487                                 DLIList<RefEdge*>& ref_edge_list,
01488                                 DLIList<Body*>& output_body_list,
01489                                 CubitBoolean anchor_entity,
01490                                 CubitBoolean keep_old,
01491                                 double draft_angle = 0.0,
01492                                 int draft_type = 0,
01493                                 CubitBoolean rigid = CUBIT_FALSE);
01494
01496   CubitStatus tweak_bend(DLIList<Body*> &bend_bodies,
01497                     DLIList<Body*> &new_body_list,
01498                     CubitVector& neutral_root,
01499                     CubitVector& bend_axis,
01500                     CubitVector& bend_direction,
01501                     double radius,
01502                     double angle,
01503                       DLIList<CubitVector> &bend_regions,
01504                       double width = -1,
01505                       CubitBoolean center_bend = CUBIT_FALSE,
01506                       int num_points = 0,
01507                       CubitBoolean keep_old_body = CUBIT_FALSE,
01508                       CubitBoolean preview = CUBIT_FALSE );
01509
01515
01516   CubitStatus tweak_chamfer( DLIList<RefEdge*> &ref_edge_list,
01517                              double left_offset,
01518                              DLIList<Body*> &new_body_list,
01519                              double right_offset = -1.0,
01520                              CubitBoolean keep_old_body = CUBIT_FALSE,
01521                              CubitBoolean preview = CUBIT_FALSE );
01522
01528
01529   CubitStatus tweak_chamfer( DLIList<RefVertex*> &ref_vertex_list,
01530                              double offset1,
01531                              DLIList<Body*> &new_body_list,
01532                              RefEdge *edge1 = NULL,
01533                              double offset2 = -1.0,
01534                              RefEdge *edge2 = NULL,
01535                              double offset3 = -1.0,
01536                              RefEdge *edge3 = NULL,
01537                              CubitBoolean keep_old_body = CUBIT_FALSE,
01538                              CubitBoolean preview = CUBIT_FALSE );
01539
01542   CubitStatus tweak_fillet( DLIList<RefEdge*> &ref_edge_list,
01543                             double radius,
01544                             DLIList<Body*> &new_body_list,
01545                             CubitBoolean keep_old_body = CUBIT_FALSE,
01546                             CubitBoolean preview = CUBIT_FALSE );
01547
01552
01553   CubitStatus tweak_fillet( RefEdge *ref_edge_ptr,
01554                             double start_radius,
01555                             double end_radius,
01556                             Body *&new_body_ptr,
01557                             CubitBoolean keep_old_body = CUBIT_FALSE,
01558                             CubitBoolean preview = CUBIT_FALSE );
01559
01561   CubitStatus tweak_fillet( DLIList<RefVertex*> &ref_vertex_list,
01562                             double radius,
01563                             DLIList<Body*> &new_body_list,
01564                             CubitBoolean keep_old_body = CUBIT_FALSE,
01565                             CubitBoolean preview = CUBIT_FALSE );
01566
01568   CubitStatus tweak_move( DLIList<RefFace*> &ref_face_list,
01569                           const CubitVector &delta,
01570                           DLIList<Body*> &new_body_list,
01571                           CubitBoolean keep_old_body = CUBIT_FALSE,
01572                           CubitBoolean preview = CUBIT_FALSE );
01573
01575   CubitStatus tweak_move( DLIList<RefEdge*> &ref_edge_list,
01576                           const CubitVector &delta,
01577                           DLIList<Body*> &new_body_list,
01578                           CubitBoolean keep_old_body = CUBIT_FALSE,
01579                           CubitBoolean preview = CUBIT_FALSE );
01580
01585
01586   CubitStatus tweak_offset( DLIList<RefFace*> &ref_face_list,
01587                             double offset_distance,
01588                             DLIList<RefFace*> *add_ref_face_list_ptr,
01589                             DLIList<double> *add_offset_list_ptr,
01590                             DLIList<Body*> &new_body_list,
01591                             CubitBoolean keep_old_body = CUBIT_FALSE,
01592                             CubitBoolean preview = CUBIT_FALSE );
01593
01598
01599   CubitStatus tweak_offset( DLIList<RefEdge*> &ref_edge_list,
01600                             double offset_distance,
01601                             DLIList<RefEdge*> *add_ref_face_list_ptr,
01602                             DLIList<double> *add_offset_list_ptr,
01603                             DLIList<Body*> &new_body_list,
01604                             CubitBoolean keep_old_body = CUBIT_FALSE,
01605                             CubitBoolean preview = CUBIT_FALSE );
01606
01608   CubitStatus tweak_remove_individually( DLIList<RefFace*> &ref_face_list,
01609                                          DLIList<Body*> &new_body_list,
01610                                          CubitBoolean keep_surface = CUBIT_FALSE,
01611                                          CubitBoolean keep_old_body = CUBIT_FALSE,
01612                                          CubitBoolean preview = CUBIT_FALSE );
01613
01615   CubitStatus tweak_remove_together( DLIList<RefFace*> &ref_face_list,
01616                                      DLIList<Body*> &new_body_list,
01617                                      CubitBoolean extend_adjoining = CUBIT_TRUE,
01618                                      CubitBoolean keep_surface = CUBIT_FALSE,
01619                                      CubitBoolean keep_old_body = CUBIT_FALSE,
01620                                      CubitBoolean preview = CUBIT_FALSE);
01621
01626
01627   CubitStatus tweak_remove( DLIList<RefEdge*> &ref_edge_list,
01628                             DLIList<Body*> &new_body_list,
01629                             CubitBoolean keep_old_body = CUBIT_FALSE,
01630                             CubitBoolean preview = CUBIT_FALSE );
01631
01642
01643   CubitStatus tweak_target( DLIList<RefFace*> &ref_face_list,
01644                             DLIList<RefFace*> &target_face_list,
01645                             DLIList<Body*> &new_body_list,
01646                             CubitBoolean extend_flg = CUBIT_TRUE,
01647                             CubitPlane *limit_plane = NULL,
01648                             CubitBoolean reverse_flg = CUBIT_FALSE,
01649                             CubitBoolean keep_old_body = CUBIT_FALSE,
01650                             CubitBoolean preview = CUBIT_FALSE );
01651
01663
01664   CubitStatus tweak_target( DLIList<RefFace*> &ref_face_list,
01665                             CubitPlane &plane,
01666                             DLIList<Body*> &new_body_list,
01667                             CubitBoolean reverse_flg = CUBIT_FALSE,
01668                             CubitBoolean keep_old_body = CUBIT_FALSE,
01669                             CubitBoolean preview = CUBIT_FALSE );
01670
01683
01684   CubitStatus tweak_target( DLIList<RefEdge*> &ref_edge_list,
01685                             DLIList<RefFace*> &target_face_list,
01686                             DLIList<Body*> &new_body_list,
01687                             CubitBoolean extend_flg = CUBIT_TRUE,
01688                             CubitPlane *limit_plane = NULL,
01689                             CubitBoolean reverse_flg = CUBIT_FALSE,
01690                             CubitBoolean keep_old_body = CUBIT_FALSE,
01691                             CubitBoolean preview = CUBIT_FALSE,
01692                             double max_area_increase = 0 );
01693   CubitStatus tweak_target( DLIList<RefEdge*> &ref_edge_list,
01694                             CubitPlane &plane,
01695                             DLIList<Body*> &new_body_list,
01696                             CubitBoolean reverse_flg = CUBIT_FALSE,
01697                             CubitBoolean keep_old_body = CUBIT_FALSE,
01698                             CubitBoolean preview = CUBIT_FALSE );
01699
01712
01713   CubitStatus tweak_target( DLIList<RefEdge*> &ref_edge_list,
01714                             DLIList<RefEdge*> &target_edge_list,
01715                             DLIList<Body*> &new_body_list,
01716                             CubitBoolean extend_flg = CUBIT_TRUE,
01717                             CubitPlane *limit_plane = NULL,
01718                             CubitBoolean reverse_flg = CUBIT_FALSE,
01719                             CubitBoolean keep_old_body = CUBIT_FALSE,
01720                             CubitBoolean preview = CUBIT_FALSE,
01721                             double max_area_increase = 0 );
01734
01735   CubitStatus tweak_target( RefVertex *ref_vertex_ptr,
01736                             DLIList<RefFace*> &modify_ref_face_list,
01737                             CubitVector &target_loc,
01738                             Body *&new_Body_ptr,
01739                             CubitBoolean keep_old_body = CUBIT_FALSE,
01740                             CubitBoolean preview = CUBIT_FALSE );
01741
01744   CubitStatus remove_curve_slivers( DLIList<Body*> &bodies, double lengthlimit );
01745
01747   CubitStatus create_net_surface( DLIList<Surface*>& ref_face_list, BodySM *& new_body,
01748                                   DLIList<DLIList<CubitVector*>*> &vec_lists_u,
01749                                   DLIList<DLIList<CubitVector*>*> &vec_lists_v,
01750                                   double net_tol = 1e-3,
01751                                   CubitBoolean heal = CUBIT_TRUE );
01752
01754   CubitStatus create_net_surface( DLIList<RefEdge*>& u_curves,
01755                                   DLIList<RefEdge*>& v_curves,
01756                                   double net_tol = 1e-3,
01757                                   CubitBoolean heal = CUBIT_TRUE );
01758
01760   CubitStatus create_offset_surface( RefFace* ref_face_ptr,
01761                                      double offset_distance );
01762
01770
01771   CubitStatus create_offset_sheet( DLIList<RefFace*> &ref_face_list,
01772                                    double offset_distance,
01773                                    DLIList<RefFace*> *add_ref_face_list_ptr,
01774                                    DLIList<double> *add_offset_list_ptr,
01775                                    DLIList<Body*> &new_body_list,
01776                                    CubitBoolean preview = CUBIT_FALSE );
01777
01779   CubitStatus create_offset_body( Body *body_ptr, Body *&new_body,
01780                                   double offset_distance );
01781
01783   CubitStatus create_skin_surface( DLIList<RefEdge*>& ref_edges,
01784                                    Body*& new_body,
01785                                    DLIList<RefEdge*>& guides);
01786
01788   CubitStatus loft_surfaces_to_body(DLIList<RefFace*> &surfaces,
01789                                     DLIList<double> &takeoff_factor_list,
01790                                     DLIList<RefFace*> &takeoff_vector_surface_list,
01791                                     DLIList<CubitVector> &surface_takeoff_vector_list,
01792                                     DLIList<RefEdge*> &takeoff_vector_curve_list,
01793                                     DLIList<CubitVector> &curve_takeoff_vector_list,
01794                                     DLIList<RefEdge*> &guides,
01795                                     DLIList<RefVertex*> &match_vertices_list,
01796                                     Body*& new_body,
01797                                     CubitBoolean global_guides,
01798                                     CubitBoolean closed,
01799                                     CubitBoolean show_matching_curves,
01800                                     CubitBoolean preview
01801                                     );
01802
01803
01804
01805
01806
01807   CubitStatus create_surface_curve(DLIList<RefEntity*> curve_entity,
01808                                    DLIList<RefEntity*> target_entity,
01809                    CubitVector sweep_direction = CubitVector (0,0,0),
01810                    CubitBoolean distance_flag = CUBIT_FALSE);
01811
01812   Body* create_rectangle_surface( double width, double height, CubitVector plane );
01813
01814   Body* create_parallelogram_surface( RefVertex *v1,
01815                                             RefVertex *v2,
01816                                             RefVertex *v3 );
01817
01818   Body* create_circle_surface( double radius, CubitVector plane );
01819
01820   Body* create_circle_surface( RefVertex *v1,
01821                                      RefVertex *v2,
01822                                      RefVertex *v3 );
01823
01824   Body* create_circle_surface( RefVertex *v1,
01825                                      RefVertex *v2,
01826                                      CubitVector center_point );
01827
01828   Body* create_ellipse_surface( RefVertex *v1,
01829                                       RefVertex *v2,
01830                                       CubitVector center_point );
01831
01832   Body* create_ellipse_surface( double major_radius,
01833                                       double minor_radius,
01834                                       CubitVector plane );
01835
01836   CubitStatus idealize_hole_slot_geometry(DLIList<RefEntity*> idealize_entity,
01837                                      DLIList<RefEntity*> exclude_entity,
01838                                      double arc_radius,
01839                                      double slot_arc_radius,
01840                                      double slot_length,
01841                                      CubitBoolean preview = CUBIT_FALSE);
01842
01843   CubitStatus idealize_fillet_geometry(DLIList<RefEntity*> idealize_entity,
01844                                        DLIList<RefEntity*> exclude_entity,
01845                                        double fillet_rad,
01846                                        CubitBoolean internal_flg,
01847                                        CubitBoolean external_flg,
01848                                        CubitBoolean preview = CUBIT_FALSE);
01849
01850   CubitStatus create_surface_doubler(DLIList<RefEntity*> doubler_entity,
01851                                     DLIList<RefEntity*> target_entity,
01852                                     DLIList<Body*> &body_list_out,
01853                                     CubitBoolean internal_flg = CUBIT_FALSE,
01854                                     CubitBoolean extend_flg = CUBIT_TRUE,
01855                                     CubitPlane *limit_plane = NULL,
01856                                     CubitVector sweep_direction = CubitVector(0,0,0),
01857                                     CubitBoolean preview = CUBIT_FALSE);
01858
01864
01865   CubitStatus create_surface( DLIList<CubitVector*>& vec_list,
01866                               Body *&new_body,
01867                               RefFace *ref_face_ptr,
01868                   CubitBoolean project_points );
01869
01870   CubitStatus create_surface( DLIList<RefVertex*> &vert_list,
01871                               Body *&new_body,
01872                               RefFace *on_surface = NULL);
01873
01874
01876   CubitStatus create_weld_surface( CubitVector &root,
01877                                    RefFace *ref_face1,
01878                                    double leg1,
01879                                    RefFace *ref_face2,
01880                                    double leg2,
01881                                    Body *&new_body );
01882
01888
01889   CubitStatus create_solid_bodies_from_surfs( DLIList<RefFace*> &ref_face_list,
01890                                       DLIList<Body*> &new_bodies,
01891                                       CubitBoolean keep_old = CUBIT_FALSE,
01892                                       CubitBoolean heal = CUBIT_TRUE,
01893                                       CubitBoolean sheet = CUBIT_FALSE ) const;
01894
01896   CubitStatus surface_intersection( RefFace *ref_face1,
01897                                     RefFace *ref_face2,
01898                                     DLIList<RefEdge*> &ref_edge_list );
01899
01900   RefEdge* create_arc(const CubitVector& position,
01901                                double radius,
01902                                double start_angle,
01903                                double end_angle,
01904                                CubitVector plane,
01905                                CubitBoolean preview = CUBIT_FALSE);
01906
01907   RefEdge* create_arc_radius( RefVertex* ref_vertex1,
01908                                    RefVertex* ref_vertex2,
01909                                    const CubitVector &normal,
01910                                    double radius,
01911                                    CubitBoolean other_arc = CUBIT_FALSE ,
01912                                    CubitBoolean full = CUBIT_FALSE,
01913                                    CubitBoolean preview = CUBIT_FALSE);
01915   RefEdge* create_arc_three( RefVertex* ref_vertex1,
01916                              RefVertex* ref_vertex2,
01917                              RefVertex* ref_vertex3,
01918                              CubitBoolean full = CUBIT_FALSE,
01919                              CubitBoolean preview = CUBIT_FALSE );
01920
01922   RefEdge* create_arc_three( RefEdge* ref_edge1,
01923                              RefEdge* ref_edge2,
01924                              RefEdge* ref_edge3,
01925                              CubitBoolean full = CUBIT_FALSE,
01926                              CubitBoolean preview = CUBIT_FALSE );
01927
01930
01931   RefEdge* create_arc_center_edge( RefVertex* ref_vertex1,
01932                                    RefVertex* ref_vertex2,
01933                                    RefVertex* ref_vertex3,
01934                                    const CubitVector &normal,
01935                                    double radius = CUBIT_DBL_MAX,
01936                                    CubitBoolean full = CUBIT_FALSE,
01937                                    CubitBoolean preview = CUBIT_FALSE );
01938
01940   CubitStatus create_curve_combine( DLIList<RefEdge*>& ref_edge_list,
01941                                     RefEdge *&new_ref_edge_ptr );
01942
01943
01944   CubitStatus create_curve_helix( CubitVector &location,
01945                                   CubitVector &direction,
01946                                   CubitVector &start_point,
01947                                   double &thread_distance,
01948                                   double &angle,
01949                                   bool right_handed,
01950                                   RefEdge *&new_ref_edge_ptr);
01951
01952
01954   static void set_sep_after_webcut_setting(CubitBoolean val) {sepAfterWebcut = val;}
01955
01957   static CubitBoolean get_sep_after_webcut_setting() {return sepAfterWebcut;}
01958
01961
01962   CubitBoolean same_modify_engine(DLIList<TopologyEntity*> &topo_list) const;
01963
01968
01969
01970   CubitBoolean same_modify_engine(DLIList<RefEntity*> &ref_entity_list,
01971                   CubitBoolean check_children = CUBIT_FALSE) const;
01972
01973
01976   GeometryModifyEngine* common_modify_engine( DLIList<RefFace*>& faces,
01977                                               DLIList<RefEdge*>& edges,
01978                                               DLIList<Surface*>& surfaces,
01979                                               DLIList<Curve*>& curves,
01980                                               CubitBoolean allow_composites = CUBIT_FALSE) const;
01981
01982
01983
01984   CubitStatus unmerge_and_return_merge_partners(RefVertex *input_vertex,
01985                                                 DLIList<DLIList<RefVertex*>*> &vert_merge_lists,
01986                                                 DLIList<DLIList<RefEdge*>*> &curve_merge_lists,
01987                                                 DLIList<DLIList<RefFace*>*> &surf_merge_lists);
01988
01990   void add_gme(GeometryModifyEngine *gme_ptr);
01991
01994   CubitStatus remove_gme(GeometryModifyEngine *gme_ptr);
01995
01997   void get_gme_list(DLIList<GeometryModifyEngine*> &gme_list);
01998
02000   GeometryModifyEngine *get_gme() const;
02001
02002
02004   GeometryModifyEngine *get_engine(TopologyBridge *tb_ptr) const;
02005
02007   GeometryModifyEngine *get_engine(TopologyEntity *te_ptr,
02008                                    TopologyBridge** bridge = 0) const;
02009
02020
02021   CubitStatus get_offset_intersections(RefEdge* ref_edge1, RefEdge* ref_edge2,
02022                                         DLIList<CubitVector> &intersection_list,
02023                                         double offset, CubitBoolean ext_first = CUBIT_TRUE );
02024
02031
02032   CubitStatus get_offset_intersections( RefEdge* ref_edge_ptr, RefFace* ref_face_ptr,
02033                                         DLIList<CubitVector> &intersection_list,
02034                                         double offset = 0.0,
02035                                         CubitBoolean ext_surf = CUBIT_TRUE );
02036
02038   CubitStatus get_mid_plane( RefFace *ref_face_1,
02039                              RefFace *ref_face_2,
02040                              Body *body_to_trim_to,
02041                              DLIList<RefFace*> &mid_plane_surfs ) const;
02042
02045   CubitStatus get_mid_surface( RefFace *ref_face_1,
02046                              RefFace *ref_face_2,
02047                              Body *body_to_trim_to,
02048                              DLIList<RefFace*> &mid_plane_surfs ) const;
02049
02051   CubitStatus set_default_gme(GeometryModifyEngine* GMEPtr);
02052
02060   GeometryModifyEngine* group_bodies_by_engine( DLIList<Body*>& remaining_bodies,
02061                                                 DLIList<Body*>& engine_bodies,
02062                                                 DLIList<BodySM*>& engine_body_sms ) const;
02063
02064   static CubitStatus prepare_for_copy( RefEntity *ref_ents,
02065                                        TopologyBridge *&top_bridge );
02066
02067   static CubitStatus finish_copy( TopologyBridge *&new_bridge,
02068                                   TopologyBridge *old_bridge );
02069
02070   static CubitStatus clean_up_from_copy_failure( TopologyBridge *old_bridge );
02071
02072   bool contains_composites(DLIList<TopologyBridge*>& bridge_list ) const;
02073   bool contains_partitions(DLIList<TopologyBridge*>& bridge_list ) const;
02074   bool contains_partitions( DLIList<Body*>& list ) const;
02075   bool contains_composites( DLIList<Body*>& list ) const;
02076
02077 protected :
02078
02079   GeometryModifyTool(GeometryModifyEngine* GMEPtr);
02083   GeometryModifyEngine* make_RefEdge_common ( RefVertex* start_vertex,
02084                                               RefVertex* end_vertex,
02085                                               TBPoint*& start_point,
02086                                               TBPoint*& end_point,
02087                                               RefFace* ref_face = 0,
02088                                               Surface** surface = 0) const;
02089     //- Common code for misc. make_RefEdge functions.
02090     //- Input  : start and end vertices and an optional RefFace pointer.
02091     //- Returns: The modify engine to use to create the curve.
02092     //- Output : points in the returned modify engine and if a refface
02093     //-          was given, a surface in the modify engine.
02094     //- Determines which engine to use to create the curve and returns
02095     //- TopologyBridges owned by that surface.  New Points are created
02096     //- if either the RefVertex already has a parent RefEdge or because
02097     //- a common modify engine could not be found for all the input
02098     //- entities.
02099
02100   CubitStatus okay_to_modify( DLIList<Body*>& bodies, const char* op ) const;
02101
02102   GeometryModifyEngine* common_modify_engine( DLIList<Body*>& bodies,
02103                                               DLIList<BodySM*>& bodysms ) const;
02104
02105   GeometryModifyEngine* common_modify_engine( DLIList<RefFace*>& faces,
02106                                               DLIList<Surface*>& surfaces,
02107                                               CubitBoolean allow_composites = CUBIT_FALSE ) const;
02108   GeometryModifyEngine* common_modify_engine( DLIList<RefEdge*>& edges,
02109                                               DLIList<Curve*>& curves,
02110                                               CubitBoolean allow_composites = CUBIT_FALSE ) const;
02111   GeometryModifyEngine* common_modify_engine( DLIList<RefVertex*>& vertices,
02112                                               DLIList<TBPoint*>& points,
02113                                               CubitBoolean allow_composites = CUBIT_FALSE ) const;
02114
02115   GeometryModifyEngine* common_modify_engine( DLIList<TopologyEntity*>& topology_list,
02116                                               DLIList<TopologyBridge*>& engine_bridges,
02117                                               CubitBoolean allow_composites
02118                                               = CUBIT_FALSE ) const;
02143 public:
02144
02146   CubitStatus finish_sm_op( DLIList<Body*>& input_bodies,
02147                             DLIList<BodySM*>& new_bodies,
02148                             DLIList<Body*>& result_bodies,
02149                             bool print_info = true ) const;
02150     //- Common code for completion of solid model engine operations
02151     //- on a set of bodies.
02152     //I input_bodies
02153     //I- A list of potentially modified or deleted bodies that were
02154     //I- were passed as input to the solid modeling operation.
02155     //I new_bodies
02156     //I- New bodies created during the solid modeling operation.
02157     //I result_bodies
02158     //I- New Bodys created for the BodySMs in new_bodies.
02159     //I update_input_bodies
02160     //I- Update DAG for non-deleted input_bodies
02161     //I delete_old_first
02162     //I- Clean out all deactivated geometry from input_bodies
02163     //I- before generating any new entities.  This has effect
02164     //I- on the resulting topology or IDs, but does affect the
02165     //I- names on new entities.
02166
02167 protected:
02168
02169   GeometryModifyEngine* tweak_setup( DLIList<RefFace*>& input_faces,
02170                                      const char* tweak_function_name,
02171                                      DLIList<Body*>& old_bodies_out,
02172                                      DLIList<Surface*>& surfaces_out,
02173                                      CubitBoolean allow_composites = CUBIT_FALSE);
02174
02175   GeometryModifyEngine* tweak_setup( DLIList<RefEdge*>& input_edges,
02176                                      const char* tweak_function_name,
02177                                      DLIList<Body*>& old_bodies_out,
02178                                      DLIList<Curve*>& curves_out,
02179                                      CubitBoolean allow_composites = CUBIT_FALSE );
02180
02181   GeometryModifyEngine* tweak_setup( DLIList<RefVertex*> &input_vertices,
02182                                      const char* name,
02183                                      DLIList<Body*> &output_bodies,
02184                                      DLIList<TBPoint*> &output_points,
02185                                      CubitBoolean allow_composites = CUBIT_FALSE );
02186
02187   CubitStatus sweep_setup ( const char* sweep_function_name,
02188                             DLIList<RefEntity*>& entity_list,
02189                             DLIList<Body*>& body_list,
02190                             GeometryModifyEngine*& engine,
02191                             CubitBoolean& changed_new_ids,
02192                             DLIList<GeometryEntity*>& geom_list,
02193                             bool keep_old,
02194                             DLIList<RefEdge*>* edge_list = 0,
02195                             DLIList<Curve*>* curve_list = 0 );
02196     //- Common setup code for sweep functions
02197     //I sweep_function_name
02198     //I- Name to use in error messages.
02199     //I entity_list
02200     //I- Input entity list to be swept
02201     //O body_list
02202     //O- Existing bodies that could potentially be modified.
02203     //O engine
02204     //O- Engine to call sweep_* on.
02205     //O change_new_ids
02206     //O- Save this value and pass into sweep_finish to make sure
02207     //O- state of 'new ids' is restored.
02208     //O geom_list
02209     //O- TopologyBridges to pass to the sweep fuction of the ModifyEngine.
02210     //I edge_list
02211     //I- RefEdges describing sweep path
02212     //O curve_list
02213     //O- Curves corresponding to edges in edge_list.
02214
02215   CubitStatus imprint_singly( DLIList<Body*>& body_list,
02216                               DLIList<Body*>& new_bodies,
02217                               CubitBoolean keep_old );
02218     //- Implementation of imprint(..) when group_imprint is false.
02219
02220   void remove_dead_entity_names( RefEntity* entity ) const;
02221     //- If the passed entity or any child entities are dead
02222     //- (have no TopologyBridges), remove entity names.
02223
02224   Body* update_body( Body* body ) const;
02225     //- Destroy or update modified body, as appropriate.
02226
02227 private :
02228
02230   static GeometryModifyTool* instance_;
02231
02233   static CubitBoolean groupImprint;
02234
02236   static CubitBoolean meshAutodelete;
02237
02240   static CubitBoolean meshAutodeleteRemesh;
02241
02243   static CubitBoolean newIds;
02244
02247   static CubitBoolean oldNames;
02248
02251   static CubitBoolean sepAfterWebcut;
02252
02258   static CubitBoolean allEdgesImprint;
02259
02261   static CubitBoolean booleanRegularize;
02262
02264   static CubitBoolean uniteMixedModels;
02265
02269
02270   static RefEntity *copyingEntity;
02271
02273   DLIList<GeometryModifyEngine*> gmeList;
02274
02275   void get_merged_curve_and_surface_ids( DLIList<Body*> &bodies,
02276                                          DLIList<int> &merged_surface_ids,
02277                                          DLIList<int> &merged_curve_ids ) const;
02278
02279   CubitStatus match_v1_to_c1(RefVertex *&v1,
02280                                              RefVertex *&v2,
02281                                              RefVertex *c1_v1,
02282                                              RefVertex *c1_v2,
02283                                              RefVertex *c2_v1,
02284                                              RefVertex *c2_v2);
02285
02286   CubitStatus find_best_curves_to_merge(DLIList<RefEdge*> *&curves_from_curve1,
02287                                         DLIList<RefEdge*> *&curves_from_curve2,
02288                                         RefEdge *&curve1,
02289                                         RefEdge *&curve2);
02290
02291   CubitStatus unmerge_and_return_merge_partners(RefEdge *input_curve,
02292                                                 DLIList<DLIList<RefEdge*>*> &curve_merge_lists,
02293                                                 DLIList<DLIList<RefFace*>*> &surf_merge_lists);
02294
02295   CubitStatus unmerge_input(RefEdge *curve1,
02296                           RefEdge *curve2,
02297                           DLIList<DLIList<RefEdge*>*> &curve_merge_lists,
02298                           DLIList<DLIList<RefFace*>*> &surf_merge_lists);
02299
02300   CubitStatus calculate_split_points_for_merge(RefEdge* c1,
02301                                                RefEdge* c2,
02302                                                DLIList<RefVertex*> &verts_to_merge,
02303                                                double *merge_tolerance,
02304                                                DLIList<CubitVector> &merge_end_points_on_curve1,
02305                                                DLIList<CubitVector> &merge_end_points_on_curve2,
02306                                                DLIList<CubitBoolean> &split_flags_for_curve1,
02307                                                DLIList<CubitBoolean> &split_flags_for_curve2,
02308                                                double divergence_angle);
02309   CubitStatus find_overlap_region(RefEdge *c1,
02310                                             RefEdge *c2,
02311                                             RefVertex *v1,
02312                                             RefVertex *v2,
02313                                             bool forward_c1,
02314                                             bool forward_c2,
02315                                             bool &full_c1,
02316                                             bool &full_c2,
02317                                             double &c1_stop_param,
02318                                             double &c2_stop_param,
02319                                             double divergence_angle);
02320   CubitStatus separate_body_after_webcut (DLIList<Body*> &input_list,
02321                                           DLIList<Body*> &output_list) const;
02327   void fixup_merged_entities( DLIList<int> &merged_surface_ids,
02328                               DLIList<int> &merged_curve_ids ) const;
02329
02330   bool contains_intermediate_geom(DLIList<Body*>& list) const;
02331   bool contains_intermediate_geom(DLIList<TopologyBridge*>& list) const;
02332
02333   void do_attribute_setup(void);
02334   void do_attribute_cleanup(void);
02335   void push_attributes_before_modify(DLIList<BodySM*> &old_sms);
02336   CubitStatus restore_vg_after_modify(DLIList<BodySM*> &new_sms,
02337                                       DLIList<Body*> &old_bodies,
02338                                       GeometryModifyEngine *gme);
02339   void remove_pushed_attributes(DLIList<BodySM*> &new_sms,
02340                                       DLIList<Body*> &old_bodies);
02341   void push_imprint_attributes_before_modify(DLIList<BodySM*> &old_sms);
02342   void push_named_attributes_to_curves_and_points(DLIList<TopologyBridge*> &tb_list, const char *name_in);
02343   void remove_imprint_attributes_after_modify(DLIList<BodySM*> &body_sms,
02344                                               DLIList<BodySM*> &new_sms);
02345
02347   static void plane_preview(DLIList<Body*> &body_list,
02348                             const CubitVector &pt1,
02349                             const CubitVector &pt2,
02350                             const CubitVector &pt3);
02351
02352   void propagate_from_small_edge( RefEdge *edge,
02353                                   DLIList<RefEdge*> &small_edges,
02354                                   DLIList<RefFace*> &narrow_faces,
02355                                   DLIList<RefFace*> &processed_faces,
02356                                   double small_edge_length);
02357   void propagate_over_narrow_face( RefFace *narrow_face,
02358                                    RefEdge *edge,
02359                                    DLIList<RefFace*> &processed_faces,
02360                                    DLIList<RefEdge*> &small_edges,
02361                                    DLIList<RefFace*> &narrow_faces,
02362                                    double small_edge_length);
02363
02364   void propagate_merge_tolerance(DLIList<Body*> &body_list);
02365   void push_tolerance_attribute(DLIList<Body*> &body_list);
02366
02367   CubitStatus prepare_bc_for_webcut();
02368   CubitStatus finish_bc_webcut();
02369
02370   CubitStatus sweep_finish( const char* const sweep_function_name,
02371                             DLIList<Body*>& input_body_list,
02372                             DLIList<BodySM*>& new_body_list,
02373                             DLIList<Body*>& output_body_list,
02374                             CubitBoolean restore_newids );
02375     //- Common cleanup code for sweep functions
02376     //I sweep_function_name
02377     //I- Name to use in error messages.
02378     //I input_body_list
02379     //I- Bodies that may need to be updated.
02380     //I new_body_list
02381     //I- SMbodies returned by GeometryModifyEngine
02382     //I output_body_list
02383     //I- ref_bodies returned by GeometryModifyEngine
02384     //I restore_newids
02385     //I- Passed back from sweep_setup -- restore setting state.
02386
02387   CubitStatus finish_webcut( DLIList<Body*>& input_bodies,
02388                              DLIList<BodySM*>& webcut_results,
02389                              CubitBoolean merge,
02390                              CubitStatus webcut_status,
02391                              DLIList<Body*>& new_bodies,
02392                              DLIList<int> *merged_surface_ids = NULL,
02393                              DLIList<int> *merged_curve_ids = NULL,
02394                              CubitBoolean print_info = CUBIT_TRUE ) const;
02395     //- Helper function for all webcut functions.
02396     //- Finish up DAG update, merging, etc. after GME does webcut.
02397     //I input_bodies
02398     //I- The list of bodies that were webcut
02399     //I webcut_results
02400     //I- The new bodies returned by the GME webcut.
02401     //I merge
02402     //I- Merge after webcut
02403     //I webcut_status
02404     //I- The return value from the GME webcut function
02405     //O new_bodies
02406     //O- The new Bodies constructed from the passed BodySMs.
02407     //R CubitStatus
02408     //R- CUBIT_FAILURE on error, webcut_status on success.
02409     //- Does separate_body_after_webcut for all bodies if
02410     //- webcut_status == CUBIT_SUCCESS
02411     //- Merges bodies if webcut_status == CUBIT_SUCCESS AND merge == CUBIT_TRUE
02412
02413   CubitStatus tweak_remove( DLIList<RefFace*> &ref_face_list,
02414                             DLIList<Body*> &new_body_list,
02415                             CubitBoolean extend_adjoining = CUBIT_TRUE,
02416                             CubitBoolean keep_surface = CUBIT_FALSE,
02417                             CubitBoolean keep_old_body = CUBIT_FALSE,
02418                             CubitBoolean preview = CUBIT_FALSE);
02424   void get_neighboring_bodies( DLIList<Body*> &input_bodies,
02425                                DLIList<Body*> &neighboring_bodies );
02426
02427
02428   CubitStatus unite_separately( GeometryModifyEngine *gme_ptr,
02429                                 DLIList<Body*> &body_list,
02430                                 DLIList<Body*> &new_body_list,
02431                                 bool keep_old );
02432   CubitStatus unite_all( GeometryModifyEngine *gme_ptr,
02433                          DLIList<Body*> &body_list,
02434                          DLIList<Body*> &new_body_list,
02435                          bool keep_old );
02442   CubitStatus unite_private( GeometryModifyEngine *gme_ptr,
02443                              DLIList<Body*> &body_list,
02444                              DLIList<Body*> &new_body_list,
02445                              bool keep_old );
02449   GeometryModifyEngine * pull_common_surfs( DLIList<RefFace*> &ref_face_list,
02450                                             DLIList<RefFace*> &common_face_list,
02451                                             DLIList<Surface*> &common_surf_list );
02459   void remove_bodies_outside_bounding_box( DLIList<Body*> &body_list, CubitVector v1, CubitVector v2, CubitVector v3 );
02460   void remove_bodies_outside_bounding_box( DLIList<Body*> &body_list,   CubitBox &tool_bounding_box );
02461   CubitVector FindExtendedEndPt(  double outer_rad , double inner_rad , CubitVector inner_AxisPt ,
02462                                 CubitVector Axis , double Height );
02463
02464   CubitVector FindExtendedStartPt(  CubitBox box ,  double outer_rad , double inner_rad , CubitVector inner_AxisPt ,
02465                                 CubitVector Axis , double &Height , double dTanAngle , double &dExtendedadius );
02466
02467   void  FindExtendedPoints( CubitVector AxisPt1 , CubitVector AxisPt2 , double outer_radius , double inner_radius ,
02468                             CubitVector axis,double Height , CubitBox bounding_box , double dTanAngle , CubitVector& start ,
02469                             CubitVector& end , double& dExtended_OuterRadius, double& dExtended_InnerRadius  );
02470
02471   void preview_align( CubitVector translation_to_origin,
02472                       CubitVector origin_to_target,
02473                       double angle_of_rotation,
02474                       CubitVector axis_of_rotation,
02475                       DLIList<RefEntity*> &entities );
02476
02477   static CubitStatus create_old_to_new_ref_ent_map(
02478     TopologyBridge *old_top_level_bridge,
02479     TopologyBridge *new_top_level_bridge,
02480     std::map< RefEntity*, RefEntity* > &old_to_new_map,
02481     std::map< TopologyBridge*, TopologyBridge*> &old_tb_to_new_tb );
02482
02483 };
02484
02485 inline void GeometryModifyTool::set_all_edges_imprint( CubitBoolean flag )
02486 {allEdgesImprint = flag;}
02487 inline CubitBoolean GeometryModifyTool::get_all_edges_imprint()
02488 {return allEdgesImprint;}
02489
02490 inline CubitBoolean GeometryModifyTool::boolean_regularize()
02491 {return booleanRegularize;}
02492 inline void GeometryModifyTool::boolean_regularize(CubitBoolean flag)
02493 {booleanRegularize = flag;}
02494
02495 inline CubitBoolean GeometryModifyTool::unite_mixed_models()
02496 {return uniteMixedModels;}
02497 inline void GeometryModifyTool::unite_mixed_models(CubitBoolean flag)
02498 {uniteMixedModels = flag;}
02499
02500 inline void GeometryModifyTool::add_gme(GeometryModifyEngine *gme_ptr)
02501 {
02502   assert(gme_ptr != 0);
02503   if (!gmeList.move_to(gme_ptr)) gmeList.append(gme_ptr);
02504 }
02508 inline void GeometryModifyTool::get_gme_list(DLIList<GeometryModifyEngine*> &gme_list)
02509 {
02510   gme_list += gmeList;
02511 }
02515 inline GeometryModifyEngine *GeometryModifyTool::get_gme() const
02516 {
02517   GeometryModifyEngine *gme = NULL;
02518   if (gmeList.size()) {
02519     const_cast<GeometryModifyTool*>(this)->gmeList.reset();
02520     gme = gmeList.get();
02521   }
02522   return gme;
02523 }
02524
02525 #endif
02526
