cgma
GeometryQueryEngine.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : GeoemtricQueryEngine.hpp
00003 //
00004 // Purpose       : Define the interface for all solid model query
00005 //                 engines.
00006 //
00007 // Special Notes : This is an abstract base class.
00008 //
00009 // Creator       : Tim Tautges
00010 //
00011 // Creation Date : 2/01
00012 //
00013 // Owner         : Tim Tautges
00014 //-------------------------------------------------------------------------
00015
00016 #ifndef GEOMETRIC_QUERY_ENGINE_HPP
00017 #define GEOMETRIC_QUERY_ENGINE_HPP
00018
00019 #include "CubitObserver.hpp"
00020 #include "CubitDefines.h"
00021 #include "GeometryDefines.h"
00022 #include "CubitMessage.hpp"
00023 #include "CGMGeomConfigure.h"
00024 #include "CubitCompat.h"
00025
00026 class CubitString;
00027 class CubitVector;
00028 template <class X> class DLIList;
00029 class Body;
00030 class GMem;
00031
00032 class TopologyBridge;
00033 class TopologyEntity;
00034 class GeometryEntity;
00035 class BodySM;
00036 class Lump;
00037 class Surface;
00038 class Curve;
00039 class TBPoint;
00040 class Loop;
00041 class RefFace;
00042
00043 enum Model_File_Type {
00044   MFT_NOT_DEFINED = 0,
00045   IGES_TYPE,
00046   CATIA_TYPE,
00047   STEP_TYPE,
00048   PROE_TYPE,
00049   GRANITE_TYPE,
00050   GRANITE_G_TYPE,
00051   GRANITE_SAT_TYPE,
00052   GRANITE_PROE_PART_TYPE,
00053   GRANITE_PROE_ASM_TYPE,
00054   GRANITE_NEUTRAL_TYPE,
00055   NCGM_TYPE,
00056   CATIA_NCGM_TYPE,
00057   CATPART_TYPE,
00058   CATPRODUCT_TYPE,
00059   FACET_TYPE,
00060   SOLIDWORKS_TYPE,
00061   OCC_TYPE,
00062   KCM_TYPE
00063 };
00064
00065
00066 extern const char*
00067 get_MFT_string(Model_File_Type);
00068
00069 inline const char*
00070 get_MFT_string(Model_File_Type type)
00071 {
00072   switch (type)
00073   {
00074     case MFT_NOT_DEFINED :
00075       return "Model File Type NOT DEFINED";
00076     case IGES_TYPE :
00077       return "IGES";
00078     case CATIA_TYPE :
00079       return "CATIA";
00080     case STEP_TYPE :
00081       return "STEP";
00082     case PROE_TYPE :
00083       return "PROE";
00084     case GRANITE_TYPE :
00085       return "GRANITE";
00086     case GRANITE_G_TYPE :
00087       return "GRANITE_G";
00088     case GRANITE_SAT_TYPE :
00089       return "GRANITE_SAT";
00090     case GRANITE_PROE_PART_TYPE :
00091       return "GRANITE_PROE_PART";
00092     case GRANITE_PROE_ASM_TYPE :
00093       return "GRANITE_PROE_ASM";
00094     case GRANITE_NEUTRAL_TYPE :
00095       return "GRANITE_NEUTRAL";
00096     case NCGM_TYPE :
00097       return "NCGM";
00098     case CATIA_NCGM_TYPE :
00099       return "CATIA_NCGM";
00100     case CATPART_TYPE :
00101       return "CATPART";
00102     case CATPRODUCT_TYPE :
00103       return "CATPRODUCT";
00104     case FACET_TYPE :
00105       return "FACET";
00106     case SOLIDWORKS_TYPE :
00107       return "SOLIDWORKS";
00108     case OCC_TYPE:
00109       return "OCC";
00110     case KCM_TYPE:
00111       return "KCM";
00112     default :
00113       PRINT_ERROR("Model_File_Type index %i is not handled properly in get_MFT_string()\n", type);
00114   }
00115
00116   return "";
00117 }  //  get_MFT_string()
00118
00119
00120 static const char* const GRANITE_G = ".g";
00121 static const char* const GRANITE_PROE_PART = ".prt";
00122 static const char* const GRANITE_PROE_ASM = ".asm";
00123 static const char* const GRANITE_PROE_NEUTRAL = ".neu";
00124 static const char* const STEP_IMPORT_DEFAULT_LOG  = "step_import.log";
00125 static const char* const IGES_IMPORT_DEFAULT_LOG = "iges_import.log";
00126 static const char* const CATIA_IMPORT_DEFAULT_LOG = "catia_import.log";
00127 static const char* const GRANITE_EXPORT_DEFAULT_LOG = "granite_export.log";
00128 static const char* const STEP_EXPORT_DEFAULT_LOG = "step_export.log";
00129 static const char* const IGES_EXPORT_DEFAULT_LOG = "iges_export.log";
00130 static const char* const OCC_EXPORT_DEFAULT_LOG = "occ_export.log";
00131 static const char* const KCM_EXPORT_DEFAULT_LOG = "kcm_export.log";
00132 static const char* const STEP_IGES_TRANSLATOR = "step_iges_translator";
00133 static const char* const TRANSLATOR_DIR =  "/translator/";
00134
00135 class CUBIT_GEOM_EXPORT GeometryQueryEngine
00136 {
00137
00138 public:
00139
00141   virtual ~GeometryQueryEngine() {}
00142
00165       virtual CubitStatus export_solid_model(
00166                                    DLIList<TopologyBridge*>& bridge_list,
00167                                    const char* file_name,
00168                                    Model_File_Type file_type,
00169                                    const CubitString &cubit_version,
00170                                    ModelExportOptions &export_options ) = 0;
00171
00172       virtual CubitStatus export_solid_model(
00173                                    DLIList<TopologyBridge*>& bridge_list,
00174                                    char*& p_buffer,
00175                                    int& n_buffer_size,
00176                                    bool b_export_buffer) = 0;
00177
00180      virtual CubitStatus save_temp_geom_file(
00181                                  DLIList<TopologyBridge*> &ref_entity_list,
00182                                  const char *filename,
00183                                  const CubitString &cubit_version,
00184                                  CubitString &created_file,
00185                                  CubitString &created_file_type ) = 0;
00186
00211      virtual CubitStatus import_solid_model(
00212                                 const char* file_name,
00213                                 Model_File_Type file_type,
00214                                 DLIList<TopologyBridge*>& imported_entities,
00215                                 ModelImportOptions &import_options ) = 0;
00216
00217      virtual CubitStatus import_solid_model(DLIList<TopologyBridge*> &imported_entities,
00218                                             const char* pBuffer,
00219                                             const int n_buffer_size) = 0;
00220
00221      //O imported_entities
00222      //O- List of top-level entities read from file
00223      //I print_results
00224      //I- If false, fail silently (don't write error messages to stdout or stderr)
00225
00226       virtual CubitStatus get_underlying_curves(Curve * curve_ptr,
00227                                  DLIList<TopologyBridge*>& curve_list)  ;
00228       // -currently used only by VirtualGeometryEngine to get the underlying
00229       // - curves from virtual curves.
00230       virtual CubitStatus get_underlying_surfaces(Surface * surf_ptr,
00231                                  DLIList<TopologyBridge*>& surf_list)  ;
00232       virtual CubitStatus get_underlying_bridges(TopologyBridge* bridge_ptr,
00233                                  DLIList<TopologyBridge*>& bridge_list);
00234
00235       virtual CubitStatus get_intersections(
00236                                     Curve* ref_edge1, CubitVector& point1,
00237                                     CubitVector& point2,
00238                                     DLIList<CubitVector>& intersection_list,
00239                                     bool bounded = false,
00240                                     bool closest = false ) = 0;
00241
00242       virtual CubitStatus get_intersections(
00243                                     Curve* ref_edge1, Curve* ref_edge2,
00244                                     DLIList<CubitVector>& intersection_list,
00245                                     bool bounded = false,
00246                                     bool closest = false ) = 0;
00247       //- Finds the intersections of the two curves.  If the bounded flag is
00248       //- true, it finds only those intersections within the parameter range
00249       //- of both curves; otherwise it uses the extensions of the curves.  The
00250       //- closest option is currently valid only if both curves are straight,
00251       //- in which case it will return the 2 closest intersection locations,
00252       //- if the straight lines don't actually intersect. The function allocates
00253       //- the CubitVectors in the returned list, so be sure to free them.
00254
00255       virtual CubitStatus get_intersections(
00256                                    Curve* curve,
00257                                    Surface* surface,
00258                                    DLIList<CubitVector>& intersection_list,
00259                                    bool bounded = false ) = 0;
00260       //- Finds the intersections of the curve and surface.  The curve is extended
00261       //- if the bounded flag is not false.  The function allocates the CubitVectors
00262       //- in the returned list, so be sure to free them.
00263
00264       virtual CubitStatus entity_extrema(
00265                                 DLIList<GeometryEntity*> &ref_entity_list,
00266                                 const CubitVector *dir1,
00267                                 const CubitVector *dir2,
00268                                 const CubitVector *dir3,
00269                                 CubitVector &extrema,
00270                                 GeometryEntity *&extrema_entity_ptr ) = 0;
00271       //- Gets the extrema position along the first given direction. If there
00272       //- is more than one extrema position, the other directions will be used
00273       //- to determine a unique position.  Directions 2 and 3 can be NULL.
00274       //- Entities supported include bodies, volumes, surfaces, curves and
00275       //- vertices.  The entity the extrema is found on is also returned.
00276
00277       virtual CubitStatus entity_entity_distance(
00278                                          GeometryEntity *ref_entity_ptr1,
00279                                          GeometryEntity *ref_entity_ptr2,
00280                                          CubitVector &pos1,
00281                                          CubitVector &pos2,
00282                                          double &distance ) = 0;
00283       //- Gets the minimum distance between two entities and the closest positions
00284       //- on those entities. Supports vertices, curves, surfaces, volumes and bodies.
00285
00286       virtual void validate_geometry_database() const {};
00287
00288       virtual void delete_solid_model_entities(DLIList<BodySM*>& body_list) const = 0;
00289       virtual CubitStatus delete_solid_model_entities(GeometryEntity* ref_entity_ptr) const;
00290       virtual CubitStatus delete_solid_model_entities( BodySM* body_ptr ) const = 0;
00291       virtual CubitStatus delete_solid_model_entities(Surface* surf_ptr ) const = 0;
00292       virtual CubitStatus delete_solid_model_entities( Curve* curve_ptr ) const = 0;
00293       virtual CubitStatus delete_solid_model_entities( TBPoint* point_ptr ) const = 0;
00294       virtual CubitStatus delete_topology_bridge (TopologyBridge* bridge) const;
00295       //- Deletes the solid model entities associcated with the input
00296       //- free-floating RefEntity. If the input RefEntity is not free-floating,
00297       //- then its underlying  ENTITYs are not deleted and CUBIT_FAILURE
00298       //- is returned.
00299       //- Returns CUBIT_SUCCESS if all went well, otherwise, CUBIT_FAILURE.
00300
00301   virtual CubitStatus fire_ray( CubitVector &origin,
00302                                 CubitVector &direction,
00303                                 DLIList<TopologyBridge*> &at_entity_list,
00304                                 DLIList<double> &ray_params,
00305                                 int max_hits = 0,
00306                                 double ray_radius = 0.0,
00307                                 DLIList<TopologyBridge*> *hit_entity_list=0 ) const = 0;
00308     //- Fire a ray at specified entities, returning the parameters (distances)
00309     //- along the ray and optionally the entities hit.  Returned lists are
00310     //- appended to.  Input entities can be any of bodies, volumes, faces,
00311     //- edges or vertices.  Optionally you can specify the maximum number of
00312     //- hits to return (default = 0 = unlimited), and the ray radius to use for
00313     //- intersecting the entities (default = 0.0 = use modeller default).
00314
00315   virtual void get_ordered_loops(RefFace* /*face*/, DLIList<Loop*> &/*loop_list*/) const {};
00316
00317   virtual CubitStatus get_isoparametric_points(Surface* ref_face_ptr,
00318                                                int &nu, int &nv,
00319                                                GMem *&gMem) const = 0;
00320
00321   virtual CubitStatus get_u_isoparametric_points(Surface* ref_face_ptr,
00322                                                  double v, int &n,
00323                                                  GMem *&gMem) const = 0;
00324
00325   virtual CubitStatus get_v_isoparametric_points(Surface* ref_face_ptr,
00326                                                  double u, int &n,
00327                                                  GMem *&gMem) const = 0;
00328
00329   virtual CubitStatus transform_vec_position(
00330     CubitVector const& position_vector,
00331     BodySM *OSME_ptr,
00332     CubitVector &transform_vector ) const = 0;
00333     //R CubitStatus
00334     //R- CUBIT_SUCCESS/CUBIT_FAILURE
00335     //I position_vector on body, body that was transformed
00336     //O vector showning transform.
00337     //O-Computes the transform from the transformed body.
00338
00339   virtual int curve_is_on_ignored_surface(Curve * /*curve*/,
00340                     Surface * /*surf*/) { return 0; }
00341
00342   virtual const char* modeler_type() = 0;
00343   virtual int get_major_version() = 0;
00344   virtual int get_minor_version() = 0;
00345   virtual int get_subminor_version() = 0;
00346   virtual int get_allint_version();
00347   virtual CubitString get_engine_version_string() = 0;
00348
00349   virtual bool is_intermediate_engine() {return FALSE;}
00350
00351     //- pass a string back identifying this query engine
00352   virtual CubitStatus set_export_version(const int major,
00353                                          const int minor);
00354   virtual CubitStatus set_export_allint_version(const int version);
00355   virtual CubitStatus list_engine_versions(CubitString &versions);
00356     //- gets, sets, and lists choices for solid modeling engine version(s)
00357
00358   virtual double get_sme_resabs_tolerance() const = 0; // Gets solid modeler's resolution absolute tolerance
00359   virtual double set_sme_resabs_tolerance( double new_resabs ) = 0;
00360
00361   virtual CubitStatus set_int_option( const char* opt_name, int val ) = 0;
00362   virtual CubitStatus set_dbl_option( const char* opt_name, double val ) = 0;
00363   virtual CubitStatus set_str_option( const char* opt_name, const char* val ) = 0;
00364    //- Set solid modeler options
00365
00366   virtual CubitStatus get_graphics( BodySM *bodysm, GMem* g_mem,
00367                                     std::vector<Surface*> &surface_to_facets_vector,
00368                                     std::vector<TopologyBridge*> &vertex_edge_to_point_vector,
00369                                     std::vector<std::pair<TopologyBridge*, std::pair<int,int> > > &facet_edges_on_curves,
00370                                     unsigned short normal_tolerance,
00371                                     double distance_tolerance, double max_edge_length ) const;
00372   //I bodysm -- body you want to facet
00373   //O g_mem -- structure containing all the points and facet connectivity
00374   //O surfaces_to_facets_vector -- the ith facet in g_mem is on the ith Surface in this vector
00375   //O vertex_edge_to_point_vector -- the ith point in the g_mem in on the ith surface/edge/vertex in this vector
00376   //O facet_edges_on_curves -- the TopologyBri dges are the Curves in bodysm and the pair is the indices to the
00377   //                           facet points in the g_mem's point array that make a single facet edge on the Curve.
00378   //I various input tolerances.
00379
00380
00381   virtual CubitStatus get_graphics( Surface* surface_ptr,
00382                                     GMem* gMem,
00383                                     unsigned short normal_tolerance=15,
00384                                     double distance_tolerance=0,
00385                                     double longest_edge = 0 ) const = 0;
00386
00387   virtual CubitStatus get_graphics( Surface* surface_ptr,
00388                             GMem *gmem,
00389                             std::vector<TopologyBridge*> &vertex_edge_to_point_vector,
00390                             std::vector<std::pair<TopologyBridge*, std::pair<int,int> > > &facet_edges_on_curves,
00391                             unsigned short normal_tolerance = 15,
00392                             double distance_tolerance = 0.0,
00393                             double max_edge_length = 0.0 ) const;
00394
00395     //R CubitStatus
00396     //R- CUBIT_SUCCESS/CUBIT_FAILURE
00397     //I ref_face_ptr
00398     //I- The RefFAce for which hoops facetting information will be
00399     //I- gathered.
00400     //O gMem
00401     //O- The sturage place for facets (and points).
00402     //= This function gathers and outputs  facet (and point)
00403     //- information for hoops involved in facetting an RefFace.  If
00404     //- all goes well, CUBIT_Success is retuned.
00405
00406   virtual CubitStatus get_graphics( Curve* curve_ptr,
00407                                     GMem* gMem,
00408                                     double angle_tolerance=0,
00409                                     double distance_tolerance=0,
00410                                     double max_edge_length=0 ) const = 0;
00411     //R CubitStatus
00412     //R- CUBIT_SUCCESS/CUBIT_FAILURE
00413     //I ref_edge_ptr
00414     //I- The RefEdge for which hoops facetting information will be
00415     //I- gathered/
00416     //O numSteps
00417     //O- The number of edges gathered.
00418     //O gMem
00419     //O- The sturage place for edges involved in facetting.
00420     //I tolerance
00421     //I- The tolerance deviation used when facetting the curve.
00422     //- This function tessellates the edge which is typically needed
00423     //- for graphically displaying the edge. If all goes well,
00424     //- CUBIT_SUCCESS is returned. Otherwise, CUBIT_FAILURE is returned.
00425
00426
00427   virtual CubitStatus translate( BodySM* body, const CubitVector& offset ) = 0;
00428   virtual CubitStatus rotate   ( BodySM* body, const CubitVector& axis, double angle ) = 0;
00429   virtual CubitStatus scale    ( BodySM* body, double factor ) = 0;
00430   virtual CubitStatus scale    ( BodySM* body, const CubitVector& factors ) = 0;
00431   virtual CubitStatus reflect  ( BodySM* body, const CubitVector& axis ) = 0;
00432   virtual CubitStatus restore_transform( BodySM* body ) = 0;
00433
00434   virtual CubitStatus translate( GeometryEntity* ent, const CubitVector& offset ) = 0;
00435   virtual CubitStatus rotate   ( GeometryEntity* ent, const CubitVector& axis, double degrees ) = 0;
00436   virtual CubitStatus scale    ( GeometryEntity* ent, double factor ) = 0;
00437   virtual CubitStatus scale    ( GeometryEntity* ent, const CubitVector& factors ) = 0;
00438   virtual CubitStatus reflect  ( GeometryEntity* ent, const CubitVector& axis ) = 0;
00439
00440   virtual CubitBoolean bodies_overlap (BodySM *body_ptr_1,
00441                                        BodySM *body_ptr_2 ) const = 0;
00442
00443   virtual CubitBoolean volumes_overlap (Lump *lump1, Lump *lump2 ) const = 0;
00444
00445   virtual TopologyBridge* get_visible_entity_at_point(TopologyBridge* /*hidden_tb*/, CubitVector* /*point*/){return NULL;};
00446
00447   virtual CubitStatus get_visible_entities( TopologyBridge *hidden_tb, DLIList<TopologyBridge*> &real_tbs );
00448
00449   virtual CubitStatus get_point_containment( DLIList<BodySM*> &body_list,
00450                                      DLIList<CubitVector> &point_list,
00451                                      double tolerance,
00452                                      bool allow_pts_in_multiple_bodies,
00453                                      std::vector< std::pair<BodySM*, std::vector<int> > > &bodysm_to_pt_indices );
00454
00455    protected:
00456
00457    private:
00458
00459 } ;
00460
00461 #endif
