cgma
GraphicsData.cpp
00001
00010 #undef NDEBUG
00011 #include <cassert>
00012
00013 #include "stdio.h"
00014
00015 #include "GMem.hpp"
00016 #include "GeometryQueryTool.hpp"
00017 #include "GeometryModifyTool.hpp"
00018 #include "RefEdge.hpp"
00019 #include "RefFace.hpp"
00020 #include "CubitDefines.h"
00021 #include "CubitBox.hpp"
00022 #include "InitCGMA.hpp"
00023 #include "TestUtilities.hpp"
00024
00025 #ifndef SRCDIR
00026 # define SRCDIR .
00027 #endif
00028
00029 #if defined (TEST_OCC)
00030 #  define ENGINE "OCC"
00031 #else
00032 #  error "Which engine to test?"
00033 #endif
00034
00035 #define STRINGIFY_(X) #X
00036 #define STRINGIFY(X) STRINGIFY_(X)
00037 #define SRCPATH STRINGIFY(SRCDIR) "/"
00038
00039 // forward declare some functions used and defined later
00040 int GraphicsData();
00041
00042 // macro for printing a separator line
00043 #define PRINT_SEPARATOR   PRINT_INFO("=======================================\n");
00044
00045
00046 // main program - initialize, then send to proper function
00047 int main (int argc, char **argv)
00048 {
00049   CubitStatus s = InitCGMA::initialize_cgma( ENGINE );
00050   if (CUBIT_SUCCESS != s) return 1;
00051
00052   //Do tests.
00053   int rsl = GraphicsData();
00054   if (rsl == 1)
00055      PRINT_INFO("Operation Failed");
00056
00057   int ret_val = ( CubitMessage::instance()->error_count() );
00058   if ( ret_val != 0 )
00059   {
00060     PRINT_ERROR("Errors found during Mergechk session.\n");
00061   }
00062   else
00063     ret_val = 0;
00064
00065   return ret_val;
00066
00067 }
00068
00069 int GraphicsData()
00070 {
00071   GeometryModifyTool::instance()->brick(10,10,10);
00072
00073   GeometryQueryEngine* engine = GeometryQueryTool::instance()->get_gqe();
00074
00075   if(!engine)
00076   {
00077     printf("no engine\n");
00078     return 1;
00079   }
00080
00081   CubitBox uninit_box;
00082
00083   CubitBox model_bbox(
00084       CubitVector(-5, -5, -5),
00085       CubitVector(5, 5, 5)
00086       );
00087
00088
00089   DLIList<RefEdge*> edges;
00090   GeometryQueryTool::instance()->ref_edges(edges);
00091
00092   // expect 24 edges
00093   if(edges.size() != 12)
00094   {
00095     printf("wrong edge count\n");
00096     return 1;
00097   }
00098
00099   // get graphics data for the curves
00100
00101   CubitBox g_curves = uninit_box;
00102   GMem gmem;
00103   for(int i=0; i<edges.size(); i++)
00104   {
00105     RefEdge* edge = edges.get_and_step();
00106     if(engine->get_graphics(edge->get_curve_ptr(), &gmem) != CUBIT_SUCCESS ||
00107         gmem.pointListCount == 0)
00108     {
00109       printf("got no edge facet data for edge %i\n", edge->id());
00110     }
00111     else
00112     {
00113       for(int j=0; j<gmem.pointListCount; j++)
00114       {
00115         const GPoint& pt = gmem.point_list()[j];
00116         g_curves |= CubitVector(pt.x, pt.y, pt.z);
00117       }
00118     }
00119   }
00120
00121   printf("curve bbox range = %f %f %f\n",
00122       g_curves.x_range(), g_curves.y_range(), g_curves.z_range());
00123
00124   if(!cubit_box_identical(g_curves, model_bbox, GEOMETRY_RESABS))
00125   {
00126     printf("didn't get accurate facet data for curves\n");
00127     return 1;
00128   }
00129
00130
00131   CubitBox g_surfaces = uninit_box;
00132   DLIList<RefFace*> faces;
00133   GeometryQueryTool::instance()->ref_faces(faces);
00134
00135   // expect 6 edges
00136   if(faces.size() != 6)
00137   {
00138     printf("wrong face count\n");
00139     return 1;
00140   }
00141
00142   // get graphics data for the surfaces
00143   for(int i=0; i<faces.size(); i++)
00144   {
00145     RefFace* face = faces.get_and_step();
00146     if(engine->get_graphics(face->get_surface_ptr(), &gmem) != CUBIT_SUCCESS ||
00147         gmem.pointListCount == 0 || gmem.fListCount == 0)
00148     {
00149       printf("got no face facet data for face %i\n", face->id());
00150     }
00151     else
00152     {
00153       const GPoint* pts = gmem.point_list();
00154       const int* facets = gmem.facet_list();
00155       int facet_size = gmem.fListCount;
00156       for(int j=0; j<facet_size;)
00157       {
00158         int num = facets[j++];
00159         for(int k=0; k<num; k++)
00160         {
00161           const GPoint& pt = pts[facets[j++]];
00162           g_surfaces |= CubitVector(pt.x, pt.y, pt.z);
00163         }
00164       }
00165     }
00166   }
00167
00168   printf("surface bbox range = %f %f %f\n",
00169       g_surfaces.x_range(), g_surfaces.y_range(), g_surfaces.z_range());
00170
00171   if(!cubit_box_identical(g_surfaces, model_bbox, GEOMETRY_RESABS))
00172   {
00173     printf("didn't get accurate facet data for surfaces\n");
00174     return 1;
00175   }
00176
00177
00178   return 0;
00179 }
00180
