cgma
ImprintBoundaryTool.hpp File Reference
#include "GeometryDefines.h"
#include "AbstractTree.hpp"
#include "CubitDefines.h"
#include "DLIList.hpp"
Classes
class  ImprintBoundaryTool
Typedefs
typedef DLIList
< ImprintPointData * >
PointList
typedef DLIList< PointList * > PointLoopList
typedef DLIList
< ImprintLineSegment * >
SegList
typedef DLIList< SegList * > SegLoopList
Enumerations
enum  IntersectResult {
  UNSET_INTERSECT = -1, NO_INTERSECT = 0, CROSS_INTERSECT, T_INTERSECT_0,
  T_INTERSECT_1, T_INTERSECT_2, T_INTERSECT_3, L_INTERSECT_0_2,
  L_INTERSECT_0_3, L_INTERSECT_1_2, L_INTERSECT_1_3, OVERLAP_ALL_0_2_3_1,
  OVERLAP_ALL_2_0_1_3, OVERLAP_ALL_2_1_0_3, OVERLAP_ALL_0_3_2_1, OVERLAP_PART_0_3,
  OVERLAP_PART_0_2, OVERLAP_PART_1_2, OVERLAP_PART_1_3, OVERLAP_JOIN_02_1_3,
  OVERLAP_JOIN_02_3_1, OVERLAP_JOIN_03_1_2, OVERLAP_JOIN_03_2_1, OVERLAP_JOIN_13_0_2,
  OVERLAP_JOIN_13_2_0, OVERLAP_JOIN_12_0_3, OVERLAP_JOIN_12_3_0, SEGS_EQUAL_0_2,
  SEGS_EQUAL_0_3
enum  MatchType {
  NO_MATCH, MATCH_0_2, MATCH_0_3, MATCH_0_6,
  MATCH_0_7, MATCH_1_2, MATCH_1_3, MATCH_1_6,
  MATCH_1_7, MATCH_2_4, MATCH_2_5, MATCH_3_4,
  MATCH_3_5, ON_SEG_1, ON_SEG_2
enum  LoopEnum { RETURN_FAILURE, RETURN_SUCCESS, CONTINUE }
Typedef Documentation
Definition at line 26 of file ImprintBoundaryTool.hpp.
Definition at line 28 of file ImprintBoundaryTool.hpp.
Definition at line 29 of file ImprintBoundaryTool.hpp.
Definition at line 30 of file ImprintBoundaryTool.hpp.
Enumeration Type Documentation
Enumerator:
UNSET_INTERSECT
NO_INTERSECT
CROSS_INTERSECT
T_INTERSECT_0
T_INTERSECT_1
T_INTERSECT_2
T_INTERSECT_3
L_INTERSECT_0_2
L_INTERSECT_0_3
L_INTERSECT_1_2
L_INTERSECT_1_3
OVERLAP_ALL_0_2_3_1
OVERLAP_ALL_2_0_1_3
OVERLAP_ALL_2_1_0_3
OVERLAP_ALL_0_3_2_1
OVERLAP_PART_0_3
OVERLAP_PART_0_2
OVERLAP_PART_1_2
OVERLAP_PART_1_3
OVERLAP_JOIN_02_1_3
OVERLAP_JOIN_02_3_1
OVERLAP_JOIN_03_1_2
OVERLAP_JOIN_03_2_1
OVERLAP_JOIN_13_0_2
OVERLAP_JOIN_13_2_0
OVERLAP_JOIN_12_0_3
OVERLAP_JOIN_12_3_0
SEGS_EQUAL_0_2
SEGS_EQUAL_0_3
Definition at line 32 of file ImprintBoundaryTool.hpp.
                     { UNSET_INTERSECT = -1,
                       NO_INTERSECT = 0,
                       CROSS_INTERSECT,//Segments intersect like a cross or plus sign, not near end points.
                       T_INTERSECT_0, //tells which node intersects of segments {0,1} and {2,3}
                       T_INTERSECT_1,
                       T_INTERSECT_2,
                       T_INTERSECT_3,
                       L_INTERSECT_0_2, // Segments intersect like an L or just at one end.
                       L_INTERSECT_0_3,// Numbers denote which points of segments intersect of segments {0,1} and {2,3}
                       L_INTERSECT_1_2,
                       L_INTERSECT_1_3,
                       OVERLAP_ALL_0_2_3_1, //One line fits entirely inside the other line.  The number denotes
                       OVERLAP_ALL_2_0_1_3, //which line is the super segment of segments {0,1} or {2,3}
                       OVERLAP_PART_0_3, //Lines overlap, number denote which points are exterior of overlap.
                       OVERLAP_PART_0_2,
                       OVERLAP_PART_1_2,
                       OVERLAP_PART_1_3,
                       OVERLAP_JOIN_02_1_3,//Lines overlap, but are joined at one end.
                       OVERLAP_JOIN_02_3_1,//First two digits denote nodes that are joined (or ontop of each other)
                       OVERLAP_JOIN_03_1_2,//Next digit denotes node on segment.
                       OVERLAP_JOIN_03_2_1,//Last digit denotes node at end that is not on anything.
                       SEGS_EQUAL_0_2, //Linesegments are equal and match according to number.
                       SEGS_EQUAL_0_3};
enum LoopEnum
Enumerator:
RETURN_FAILURE
RETURN_SUCCESS
CONTINUE
Definition at line 92 of file ImprintBoundaryTool.hpp.
enum MatchType
Enumerator:
NO_MATCH
MATCH_0_2
MATCH_0_3
MATCH_0_6
MATCH_0_7
MATCH_1_2
MATCH_1_3
MATCH_1_6
MATCH_1_7
MATCH_2_4
MATCH_2_5
MATCH_3_4
MATCH_3_5
ON_SEG_1
ON_SEG_2
Definition at line 74 of file ImprintBoundaryTool.hpp.
