cgma
MergeToolAssistant.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : MergeToolAssistant.hpp
00003 //
00004 // Purpose       : Abstract class defining methods for doing other
00005 //                 other operations as a part of merging, for example
00006 //                 handling mesh.
00007 //
00008 // Special Notes : Creating an instance of this class automagically
00009 //                 registers it with MergeTool.  Similarly destroying
00010 //                 the instance will unregister it, and destroying
00011 //                 the MergeTool instance will destroy all registered
00012 //                 MergeToolAssistants.
00013 //
00014 // Creator       : Jason Kraftcheck
00015 //
00016 // Creation Date : 04/26/01
00017 //-------------------------------------------------------------------------
00018
00019 #ifndef MERGE_TOOL_ASSISTANT_HPP
00020 #define MERGE_TOOL_ASSISTANT_HPP
00021
00022 #include "CubitDefines.h"
00023 #include "CubitString.hpp"
00024 #include "CGMGeomConfigure.h"
00025
00026 class RefEntity;
00027 class RefFace;
00028 class RefEdge;
00029 class RefVertex;
00030
00031 class CUBIT_GEOM_EXPORT MergeToolAssistant
00032 {
00033
00034   public:
00035
00036     MergeToolAssistant();
00037     //- Constructor
00038     //- Registers this assistant with MergeTool.
00039
00040
00041     virtual ~MergeToolAssistant();
00042     //- Destructor
00043     //- Unregister this assistant with MergeTool.
00044
00045
00046     virtual CubitString class_identifier() = 0;
00047     //- Return a CubitString for MergeTool to use in error messages.
00048
00049     virtual CubitBoolean
00050     can_merge( RefFace* keep_face_ptr, RefFace* dead_face_ptr ) = 0;
00051     //- Allow MergeToolAssistant to abort the merge.  The
00052     //- implementation of MergeToolAssistant is expected
00053     //- to check the mergeability of all child RefEdges and
00054     //- RefVertices as well.  The merge partner for each
00055     //- child entity can be determined by calling
00056     //- RefEntity::get_compare_partner().  If get_compare_partner()
00057     //- returns NULL, this should indicate that the child entities
00058     //- are already merged.
00059
00060     virtual CubitBoolean
00061     can_merge( RefEdge* keep_edge_ptr, RefEdge* dead_edge_ptr ) = 0;
00062     //- Allow MergeToolAssistant to abort the merge.  The
00063     //- implementation of MergeToolAssistant is expected
00064     //- to check the mergeability of all child RefVertices.
00065     //- The merge partner for each child entity can be determined
00066     //- by calling RefEntity::get_compare_partner().  If
00067     //- get_compare_partner() returns NULL, this should indicate
00068     //- that the child entities are already merged.
00069
00070     virtual CubitBoolean
00071     can_merge( RefVertex* keep_vtx_ptr, RefVertex* dead_vtx_ptr ) = 0;
00072     //- Allow MergeToolAssistant to abort the merge.
00073
00074     virtual void
00075     merging( RefEntity* keep_entity_ptr,
00076              RefEntity* dead_entity_ptr,
00077              CubitBoolean opposite_sense ) = 0;
00078     //- This method is called to notify an assistant of a merge in
00079     //- progress.  This method is called for each RefEntity merged.
00080     //- For example when merging two RefEdges, this method will
00081     //- first be called for each RefVertex as it is merged, and
00082     //- then for the RefEdge.  This method is called after all
00083     //- child entities have been merged, but just prior to merging
00084     //- the passed entites.  For example if two RefFaces are being
00085     //- merged, when this method is called for those RefFaces, all
00086     //- child RefEdges, CoEdges and Loops have already been merged.
00087     //- The RefFaces will SHARE A COMMON SET OF LOOPS.
00088
00089     virtual void
00090     unmerged( RefEntity* old_entity_ptr,
00091               RefEntity* new_entity_ptr,
00092               CubitBoolean reversed ) = 0;
00093     //I old_entity_ptr
00094     //I- A pointer to the RefEntity that existed prior to the unmerge.
00095     //I new_entity_ptr
00096     //I- A pointer to the new RefEntity created as a
00097     //I- GeometryEntity was split off of old_entity_ptr.
00098     //I old_sense_switched
00099     //I- True of the geometric sense of the old entity was changed
00100     //I- as a part of the unmerge.
00101     //I new_sense_switched
00102     //I- True if the geometric sense of the old entity was not changed
00103     //I- and the new entity has the opposite sense of the old.
00104     //- Notifies MergeToolAssistant that an unmerge has occured.
00105     //- This method will be called for all unmerged RefEntities.  For
00106     //- example, when a RefEdge is unmerged, the method will first be
00107     //- called for the RefEdge while the child vertices are still
00108     //- merged.  It will then be called for the child RefVertices
00109     //- if/when they are unmerged.
00110
00111     virtual void finish_merge()   = 0;
00112     //- Let assisitant know that merge operation is completed
00113     //- in case any temporary data neds to be cleaned up.
00114
00115     virtual void finish_unmerge() = 0;
00116     //- Final call to clean up any data.  Called just before
00117     //- MergeTool returns control to its caller.
00118
00119 };
00120
00121 #endif
00122
