cgma
RefEdge.hpp
00001 //-------------------------------------------------------------------------
00002 //
00003 // Filename      : RefEdge.hpp
00004 //
00005 // Purpose       : This file contains the declarations of the class
00006 //                 RefEdge.
00007 //
00008 // Special Notes :
00009 //
00010 // Creator       : Xuechen Liu
00011 //
00012 // Creation Date : 07/11/96
00013 //
00014 // Owner         : Malcolm J. Panthaki
00015 //-------------------------------------------------------------------------
00016
00017 #ifndef REF_EDGE_HPP
00018 #define REF_EDGE_HPP
00019
00020 #include "BasicTopologyEntity.hpp"
00021 #include "CastTo.hpp"
00022
00023 const double maxSegmentLengthError = 0.005;
00024
00025 class CoEdge;
00026
00027 class CubitVector;
00028 class FacetEvalTool;
00029 class Curve;
00030
00031 class GMem;
00032
00033 // ********** END FORWARD DECLARATIONS     **********
00034
00035 class CUBIT_GEOM_EXPORT RefEdge : public BasicTopologyEntity
00036 {
00037 public :
00038
00039   typedef RefVertex ChildType;
00040   typedef RefFace ParentType;
00041
00042 // ********** BEGIN STATIC FUNCTION DECLARATIONS     **********
00043 // ********** END STATIC FUNCTION DECLARATIONS     **********
00044
00045   friend class RefEntityFactory;
00046     //- the factory is allowed to call the (private) constructors
00047
00048   virtual ~RefEdge() ;
00049     //- The destructor
00050
00051   static const char* get_class_name()
00052      {
00053        return "Curve";
00054      }
00055
00056   virtual const char* class_name() const
00057      {
00058        return get_class_name();
00059      }
00060
00061   DagType dag_type() const { return DagType::ref_edge_type(); }
00062   const std::type_info& entity_type_info() const { return typeid(RefEdge); }
00063
00064   void get_parent_ref_entities(DLIList<RefEntity*>& entity_list);
00065
00066   virtual CubitStatus get_point_direction( CubitVector& origin,
00067                                            CubitVector& direction );
00068     //- Only valid for straight lines
00069     //- Finds the underlying line's origin and direction unit vector
00070     //- Returns CUBIT_FAILURE if curve is not a line
00071
00072   virtual CubitStatus get_center_radius( CubitVector& center, double& radius );
00073     //- Only valid for arcs
00074     //- Finds the underlying arc's center point and radius
00075     //- Returns CUBIT_FAILURE if curve is not an arc
00076
00077   // ********* TOPOLOGY ********************
00078
00079   RefVertex* start_vertex();
00080   RefVertex* end_vertex();
00081     //R RefVertex*
00082     //R- Returned RefVertex pointer
00083     //- These functions get the start and end RefVertex'es of this
00084     //- RefEdge.
00085     //-
00086     //- MJP Notes:
00087     //- The start and end RefVertices are cached in the RefEdge (see
00088     //- private member data, start/end_RefVertex). These need to be
00089     //- updated if the end RefVertices could have changed during a
00090     //- geometric operation.  See the routine, RefEdge::update to
00091     //- see how this is done.
00092
00093   virtual void reverse_topology();
00094
00095   Chain* get_chain_ptr();
00096     //R Chain*
00097     //R- Pointer to the first Chain
00098     //- This function returns a pointer to the first Chain that this
00099     //- RefEdge points to.
00100
00101   CubitStatus get_co_edges( DLIList<CoEdge*> &co_edges_found_list,
00102                 RefFace *input_ref_face_ptr = NULL );
00103     //R CubitStatus
00104     //R-CubitSucces/CubitFailure
00105     //O co_edges_found_list and optional input_ref_face_ptr
00106     //O- Gets the coedges that
00107     //- correspond to "this" RefEdge, they are populated into the
00108     //- co_edges_found_list. If an input_ref_face_ptr is sent it
00109     //- gets the co_edges that are just associated with that ref_face.
00110     //- Remember that usually there will be only one but for hard lines
00111     //- and sipes there may be two co-edges/ref-edge/ref-face.
00112     //- Note: This function will just blindly append the co-edges it
00113     //- finds into the co_edges_found_list.  A merge-unique might be
00114     //- more expensive than we want.
00115
00116   double angle_between( RefEdge *other_edge_ptr, RefFace *face_ptr );
00117     //- Returns the "inside" angle between this edge and
00118     // other_edge_ptr.  Figures out which edge comes first.  Only
00119     // requirement is that both edges must be on face_ptr and on
00120     // the same loop.  Angle is in radians.
00121
00122   CubitSense sense( RefFace *face );
00123     //- Sense of this edge wrt the given face.
00124     //- Return CUBIT_FORWARD or CUBIT_REVERSED.
00125     //- Returns CUBIT_UNKNOWN if there is more than one coedge, and
00126     //- senses don't agree, or if there are no coedges.
00127
00128   virtual int dimension() const;
00129     //- returns dimension of the actual entity.
00130
00131   int num_of_common_ref_face( RefEdge *other_edge );
00132     // get the number of common refFace for two refEdges.
00133
00134   RefFace *  common_ref_face (RefEdge* otherRefEdgePtr);
00135     //  - Find one common RefFace
00136
00137   int common_ref_faces ( RefEdge* otherRefEdgePtr, DLIList<RefFace*> &common_face_list );
00138     //- Returns all common RefFaces that this edge shares with the input edge
00139
00140   RefVertex* common_ref_vertex( RefEdge* otherRefEdgePtr );
00141     //- Find common RefVertex
00142
00143   RefVertex* common_ref_vertex( RefEdge* next_ref_edge,
00144                                 RefFace* ref_face_ptr );
00145     //- Finds the common vertex between the next_ref_edge and
00146     //- this edge, assuming that this edge comes before next_ref_edge
00147     //- in a the loop around the surface. This is needed because
00148     //- two edges may share two vertices...
00149
00150   CubitBoolean common_vertices( RefEdge* otherRefEdgePtr,
00151                                 DLIList<RefVertex*> &common_verts);
00152     //-Populates the common_verts with the vertices that are common
00153     //-between the two curves.
00154     //-Returns CUBIT_TRUE if there are common vertices/ false otherwise.
00155
00156   RefEdge* get_other_curve(RefVertex* common_vertex,
00157                            RefFace* ref_face_ptr);
00158     //- Finds the other curve on the ref_face_ptr that shares
00159     //- the common vertex
00160
00161   CubitStatus get_two_co_edges( RefEdge *next_ref_edge,
00162                                 RefFace *ref_face_ptr,
00163                                 CoEdge *&co_edge_this,
00164                                 CoEdge *&co_edge_next );
00165     //R CubitStatus
00166     //R- CUBIT_SUCCESS/CUBIT_FAILURE
00167     //O next_ref_edge, ref_face_ptr, co_edge_this, co_edge_next
00168     //O-Returns the co_edge that corrisponds to 'this' ref_edge
00169     //- and the one that corrisponds to next_ref_edge, with
00170     //- respect to the ref_face_ptr.
00171     //- Special Note : next_ref_edge must follow 'this' ref_edge in a Loop
00172     //- on the ref_face_ptr, this is assumed so the function
00173     //- will assert if this is not done...
00174
00175   RefFace *other_face(RefFace *not_face, RefVolume *ref_volume = NULL);
00176     //- return the (an) other face sharing this edge, which also borders
00177     //- ref_volume if non-NULL
00178
00179   RefVertex* other_vertex( RefVertex* refVertexPtr );
00180     //- Returns the vertex at the other end of the edge.
00181
00182   RefVertex* closest_vertex(const CubitVector &point3);
00183
00184   // ********* GEOMETRY ********************
00185
00186   Curve* get_curve_ptr() ;
00187   Curve const* get_curve_ptr() const ;
00188     //R Curve*
00189     //R- A pointer to the Curve to which this RefEdge points.
00190     //- This function returns a pointer to the Curve
00191     //- to which the current RefEdge points.
00192
00193   CubitVector start_coordinates();
00194   CubitVector end_coordinates();
00195     //R CubitVector
00196     //R- Returned location.
00197     //- These functions return the start and end global coordinate
00198     //- locations of the RefEdge.
00199     //-
00200     //- NOTE:
00201     //- These coordinates remain consistent throughout the life of the
00202     //- RefEdge, regardless of the fact that the actual start and
00203     //- end RefVerex'es may change (e.g., after a merge operation).
00204
00205   virtual void move_to_curve ( CubitVector& vector );
00206     //- Moves the given location (CubitVector or CubitNode) to the closest
00207     //- point on the Curve
00208
00209   CubitStatus get_interior_extrema(DLIList<CubitVector*>& interior_points,
00210                                    CubitSense& return_sense) const;
00211
00212   CubitStatus closest_point_trimmed( CubitVector const& location,
00213                                      CubitVector& closest_location);
00214     //R void
00215     //I location
00216     //I- The point to which the closest point on the Curve is desired.
00217     //O closest_location
00218     //O- The point on the Curve, closest to the input location which
00219     //O- will be on the Curve.  This is input as a reference
00220     //O- so that the function can modify its contents.
00221
00222
00223   CubitStatus closest_point( CubitVector const& location,
00224                              CubitVector& closest_location,
00225                              CubitVector* tangent_ptr = NULL,
00226                              CubitVector* curvature_ptr = NULL);
00227     //R void
00228     //I location
00229     //I- The point to which the closest point on the Curve is desired.
00230     //O closest_location
00231     //O- The point on the Curve, closest to the input location which
00232     //O- might not be on the Curve.  This is input as a reference
00233     //O- so that the function can modify its contents.
00234     //O tangent_ptr
00235     //O- The tangent to the Curve (output as a unit vector) at the
00236     //O- closest_location.
00237     //O curvature_ptr
00238     //O- The curvature of the Curve at the closest_location.
00239     //- This function computes the point on the Curve closest to the input
00240     //- location.
00241     //-
00242     //- If the tangent and/or curvature is required, then the calling code
00243     //- is responsible for allocating space for the CubitVector(s) and
00244     //- sending in the relevant non-NULL pointers.  If either of these
00245     //- pointers is NULL, the related quantity is not computed.
00246     //-
00247     //- Notes:
00248     //- The tangent direction is always in the positive direction of the
00249     //- *owning RefEdge*, regardless of the positive direction of the
00250     //- underlying solid model entities, if any.
00251
00252   CubitPointContainment point_containment( const CubitVector &point );
00253     //R CubitPointContainment - is the point on bounds of the curve?
00254     //R- CUBIT_PNT_OFF, CUBIT_PNT_ON, CUBIT_PNT_UNKNOWN
00255     //I CubitVector
00256     //I- position to check, known to be on the Curve
00257     // NOTE: POINT MUST LIE ON THE CURVE FOR THIS FUNCTION TO WORK PROPERLY.
00258
00259   void tangent ( const CubitVector &point, CubitVector& tangent_vec );
00260     //- Return the tangent for the point on this RefEdge that is closest
00261     //- to the input "point".  The tangent direction is always in the
00262     //- positive direction of the RefEdge.  The positive direction of
00263     //- the RefEdge is an invariant through its lifecycle.
00264
00265
00266   CubitStatus tangent( const CubitVector &point,
00267                        CubitVector& tangent_vec,
00268                        RefFace *ref_face_ptr );
00269     //R CubitStatus
00270     //R- CUBIT_SUCCESS/CUBIT_FAILURE
00271     //O point, tangent_vec, ref_face_ptr
00272     //O- Get the correct tangent with respect to
00273     //- the ref_face_ptr.
00274     //- This tangent function is not the safest method for getting
00275     //- the tangent on a surface.  In face if there could be
00276     //- another direction, this function could fail...(assert).
00277     //- This function assumes that there is only 1 co-edge per
00278     //- this ref_face for this REfEdge.
00279
00280   CubitStatus tangent( const CubitVector &point, CubitVector& tangent_vec,
00281                        RefEdge *next_ref_edge, RefFace *ref_face_ptr );
00282     //- Retruns the tangent for the point on this RefEdge that is closest
00283     //- to the input "point".  Also, because the next_ref_edge and
00284     //- the ref_face_ptr are given, the tangent is oriented correctly.
00285     //- NOTE: It is assumed that 'this' RefEdge and next_ref_edge are
00286     //- in order in a "Loop" sense on the given ref_face_ptr.  The next
00287     //- ref_edge obviously must follow 'this' edge in this loop.
00288
00289   virtual double measure();
00290     //- A generic geometric extent function.
00291     //- Returns volume for RefVolumes, area for RefFaces, length for RefEdge,
00292     //- and 1.0 for RefVertices
00293     //- A RefGroup calculates the maximum dimension of its contained
00294     //- entities and returns the sum of the measures() of all entities
00295     //- of that dimension.
00296     //- Default return value is 0.0 for all other RefEntities.
00297
00298   virtual CubitString measure_label();
00299     //- Returns the type of measure: (volume, area, length, or N/A)
00300
00301   double get_arc_length();
00302   double get_arc_length ( const CubitVector &point1,
00303                           const CubitVector &point2 );
00304   double get_arc_length ( const CubitVector &point1, int whichEnd );
00305     //- Various arc length calculations, some are redundant
00306     //- the length returned is always positive.
00307
00308   double get_chord_length();
00309     //- Calculates and returns the straight-line distance
00310     //- between the startRefVertex and the endRefVertex
00311
00312   CubitVector curve_center();
00313   //- return a guess at the "centroid" of the curve, not the midpoint.
00314   //- For a non-periodic curves, returns the average of vertices
00315   //- For periodic curves, returns the average of the midpoint and the vertex.
00316
00317   virtual CubitVector center_point();
00318     //- Returns location at the "actual" center of this RefEdge (along the
00319     //- arc of the RefEdge)
00320
00321   CubitStatus mid_point ( const CubitVector &point1, const CubitVector &point2,
00322                           CubitVector& midPoint );
00323     //- Calculate midpoint between the 2 points on this RefEdge
00324
00325   CubitStatus mid_point ( CubitVector &mid_point);
00326     //- Calculate midpoint on this RefEdge
00327
00328   CubitStatus position_from_fraction( double fraction_along_curve,
00329                                       CubitVector &ouput_position );
00330     //R CubitStatus
00331     //I fraction in parameter space along refedge. (1/3,2/3,4/5...)
00332     //O- position where percent in parameter space lies.
00333     //-This function takes the given fraction, finds the parameter value,
00334     //-and calculates this position. This is based off the vgi curve.
00335
00336   double start_param();
00337     //R double
00338     //- this function returns the starting parameter of the underlying curve
00339
00340   double end_param();
00341     //R double
00342     //- this function returns the ending parameter of the underlying curve
00343
00344   CubitBoolean get_param_range( double& start_param,
00345                                 double& end_param );
00346     //R CubitBoolean
00347     //R- CUBIT_TRUE/FALSE
00348     //O start_param, end_param
00349     //O- The "lower" and "upper" parameter values of the RefEdge.
00350     //- This function returns the parameter bounds for the RefEdge.
00351     //- The start_param represents the parameter value of the
00352     //- start location of the RefEdge and the end_param that of the
00353     //- end location.
00354     //-
00355     //- CUBIT_TRUE is returned if the RefEdge is defined parametrically
00356     //- and CUBIT_FALSE if it is not.  In the latter case, the
00357     //- output values of start_ and end_param are undetermined.
00358     //-
00359     //- MJP Note:
00360     //- The numercial value of the start_param could be higher
00361     //- than that of the end_param.
00362
00363   double u_from_position (const CubitVector& input_position);
00364     //R double
00365     //R- The returned "u" parameter value in local parametric space
00366     //I input_position
00367     //I- The input position for which "u" is to be computed.
00368     //- This function returns the coordinate of a point in the local
00369     //- parametric (u) space that corresponds to the input position in
00370     //- global (world) space.  The input point is first moved to the
00371     //- closest point on the Curve and the parameter value of that
00372     //- point is determined.
00373
00374   CubitStatus position_from_u (double u_value,
00375                                CubitVector& output_position);
00376     //R CubitStatus
00377     //R- CUBIT_SUCCESS/FAILURE
00378     //I u_value
00379     //I- The input u parameter value
00380     //O output_position
00381     //O- The output position
00382     //- This function returns the coordinates of a point in the global
00383     //- (world) space that corresponds to the input parametric position
00384     //- in the local space.
00385     //-
00386     //- If the input parameter value is not defined for the Curve, then
00387     //- the input CubitVector is not modified and CUBIT_FAILURE is
00388     //- returned. Otherwise, position is appropriately modified and
00389     //- CUBIT_SUCCESS is returned.
00390     //-
00391     //- If the curve is periodic, the input u_value is first "normalized"
00392     //- to the fundamental period of the Curve before its position
00393     //- in global space is determined.
00394
00395   double u_from_arc_length ( double root_param,
00396                              double arc_length );
00397     //R double
00398     //R- Returned parameter value
00399     //I root_param
00400     //I- The parameter value of the "root point"
00401     //I arc_length
00402     //I- A distance along the Curve
00403     //- This function returns the parameter value of the point that is
00404     //- "arc_length" away from the root point in the
00405     //- positive sense direction of the owning RefEdge.
00406     //-
00407     //- A negative value for distance would force the search to go in the
00408     //- negative (sense) direction of the RefEdge.
00409     //-
00410     //- NOTE:
00411     //- The important assumption that is made in this routine is that
00412     //- the end points of the RefEdge that owns this Curve are the same
00413     //- as the end points of the first solid model entity in the list of
00414     //- solid model entities associated with this Curve.
00415
00416   double fraction_from_arc_length(RefVertex *root_vertex,
00417                                   double     length);
00418
00419   CubitStatus point_from_arc_length ( double root_param,
00420                                       double arc_length,
00421                                       CubitVector& new_point );
00422     //- See below. This allows you to directly specify the starting parameter,
00423     //- instead of it being determined from the root_point.
00424
00425   CubitStatus point_from_arc_length ( const CubitVector& root_point,
00426                                       double arc_length,
00427                                       CubitVector& new_point );
00428     //- Return a point arc_length distance from root_point
00429     //- on this RefEdge.
00430     //-
00431     //- If arc_length is negative, the new point
00432     //- is in the negative sense direction (along the RefEdge) from
00433     //- the root point.
00434     //-
00435     //- If the curve is not periodic and the point arc_length away
00436     //- from root_point in the appropriate direction goes beyond
00437     //- the end point of the RefEdge, that end point is returned
00438     //- as new_point.
00439     //-
00440     //- If the curve is periodic and the point arc_length away
00441     //- from root_point in the appropriate direction goes beyond
00442     //- the end point of the RefEdge, wrap around is done.
00443     //-
00444     //- NOTE: I have had problems with this function if the root point
00445     //- is the start vertex, for some reason by a factor of 1e-7 the
00446     //- parameter value is different between the start_param and the
00447     //- parameter found from the start_vertex location.  So I will switch
00448     //- EdgeMeshTool to go off the start parameter instead of this function.
00449
00450
00451   double length_from_u( double parameter1,
00452                         double parameter2 );
00453     //R double arc length
00454     //I double parameter1, parameter value of one end of arc
00455     //I double parameter2, parameter value of the other end of arc
00456     //
00457     // Calculates, the distance along the curve between parameters
00458     // parameter1 and parameter2.
00459     //
00460     // The order of the paramters does affect the result.
00461     // That is, if parameter1 is closer to the start parameter,
00462     // the result is positive.  If parameter1 is closer to
00463     // the end parameter, the result is negative.
00464     //
00465     // For periodic curves, the length is calculated along
00466     // the curve in the diretion of increasing parameter value.
00467     // Therefore, if the caller wants the length calculation
00468     // to be in a direction that crosses the periodic break,
00469     // the interval [parameter1, parameter2] should span a
00470     // break point in the period.
00471
00472
00473   CubitBoolean is_periodic();
00474     //R CubitBoolean
00475     //R- CUBIT_TRUE/CUBIT_FALSE
00476     //- This function determines whether the underlying geometry of the
00477     //- Curve is periodic or not.  Returns CUBIT_TRUE if it is and
00478     //- CUBIT_FALSE if it is not.
00479
00480   CubitBoolean is_periodic( double& period);
00481     //R CubitBoolean
00482     //R- CUBIT_TRUE/CUBIT_FALSE
00483     //O period
00484     //O- Returned period value
00485     //- This function determines whether the underlying geometry of the
00486     //- Curve is periodic or not.  Returns CUBIT_TRUE if it is and
00487     //- CUBIT_FALSE if it is not.
00488     //-
00489     //- If it is periodic, then it returns the period in the input
00490     //- reference variable, "period". This value is set to 0.0 if
00491     //- the Curve is not periodic.
00492
00493   int get_mark();
00494   void set_mark( int set_value );
00495     //- get/set generic 2-bit mark.
00496
00497   CubitStatus relative_sense( RefEdge *ref_edge_ptr_2,
00498                               double tolerance_factor,
00499                               CubitSense *sense,
00500                               CubitBoolean &spatially_equal,
00501                               CubitBoolean force_merge = CUBIT_FALSE);
00502     //- calculates the relative sense of two refedges and tries to
00503     //- see if there are two points that are close on each edge (1/3 and 2/3
00504     //- param value).
00505
00506
00507   CubitBoolean about_spatially_equal( RefEdge* ref_edge_ptr_2,
00508                                       double tolerance_factor = 1.0,
00509                                       CubitSense* sensePtr = NULL,
00510                                       CubitBoolean notify_refEntity =
00511                                       CUBIT_FALSE );
00512
00513     //R CubitBoolean
00514     //R-CUBIT_TRUE/CUBIT_FALSE
00515     //I RefEdge, double, CubitSense*, CubitBoolean
00516     //I- Second RefEdge to compare, Tolerance factor to for GEOMETRY_RESABS,
00517     //I- and flag for notifying compared RefEntities.
00518     //O CubitSense*, and returned CubitBoolean.
00519     //O- if the two refEdges are spatially equal within the GEOMETRY_RESABS*
00520     //- the tolerance_factor, then CUBIT_TRUE will be returned.  Otherwise
00521     //- CUBIT_FALSE is returned.  If there is a non-null sesnePtr sent in,
00522     //- the sense pointer value will be assinged the relative sense of the
00523     //- RefEdges, ie, CUBIT_FORWARD/CUBIT_REVERSED.
00524     //- To do the comparison, the end points, 1/3 and 2/3 world
00525     //- points are spatially compared.
00526
00527   virtual int validate();
00528     //- Check that entity is valid. Returns number of problems detected.
00529
00530   CubitStatus evaluate_exterior_angle(double *exterior_angle);
00531     //- Calculate the exterior angle between this curve and the
00532     //- attached surfaces.  This function assumes that the curve is
00533     //- only attached to two (2) surfaces, otherwise it returns CUBIT_FAILURE;
00534
00535
00536 //=========  Add Code by SRS of Cat,  3/3/99 2:28:31 PM  =========
00537   CubitBoolean is_tolerant();
00538     //- Returns CUBIT_TRUE if refedge is a tolerant edge.  Tolerant
00539     //- edges can be created in the  healer if it is unable to
00540     //- heal the edge.
00541 //=========  Code End by SRS of Cat,  3/3/99 2:28:31 PM  =========
00542
00543   CubitStatus get_graphics( GMem& polyline, double angle_tolerance=0,
00544                                             double distance_tolerance=0,
00545                                             double max_edge_length=0 );
00546
00547   void reverse_tangent();
00548
00549   static void suppress_edge_length_warning(bool flag);
00550
00551
00552 protected:
00553
00554   RefEdge(Curve* curvePtr) ;
00555     //- The constructor with a pointer to a Curve.
00556
00557 private:
00558   void initialize();
00559     //- Initializes all member data
00560
00561   double get_lower_param_bound();
00562   double get_upper_param_bound();
00563     //- Get the parameter values at the start and end locations of
00564     //- the RefEdge.  If it is periodic, this is taken into account
00565     //- and the lower and upper bounds of the period are returned.
00566
00567   int refEdgeClone;
00568
00569   cBit markedFlag : 2; //- generic flag, one or two bits?
00570
00571   RefEdge( const RefEdge& );
00572   void operator=( const RefEdge& );
00573   static bool mSuppressEdgeLengthWarning;
00574 };
00575
00576 // ********** BEGIN HELPER CLASSES         **********
00577 // ********** END   HELPER CLASSES         **********
00578
00579 // ********** BEGIN INLINE FUNCTIONS       **********
00580
00581 inline int
00582 RefEdge::get_mark()
00583 { return markedFlag; }
00584
00585 inline void
00586 RefEdge::set_mark( int set_value )
00587 { markedFlag = set_value; }
00588
00589 template <> struct DLIListSorter<RefEdge*>
00590 {
00591   bool operator()(RefEdge* a, RefEdge* b) { return a->id() < b->id(); }
00592 };
00593
00594
00595 // ********** END INLINE FUNCTIONS         **********
00596
00597 // ********** BEGIN FRIEND FUNCTIONS       **********
00598 // ********** END FRIEND FUNCTIONS         **********
00599
00600 // ********** BEGIN EXTERN FUNCTIONS       **********
00601 // ********** END EXTERN FUNCTIONS         **********
00602
00603 #endif
00604
