cgma
SettingHandler.hpp
00001 //- Class: SettingHandler
00002 //- Description: SettingHandler class - used for save and restore settings
00003 //- Owner: Wesley Gill
00004 //- Checked By:
00005 //- Version
00006
00007 #ifndef SETTINGHANDLER_HPP
00008 #define SETTINGHANDLER_HPP
00009
00010 #include "CubitString.hpp"
00011 #include "CubitDefines.h"
00012 #include "SettingHolder.hpp"
00013 #include <map>
00014 #include <vector>
00015 #include "CGMUtilConfigure.h"
00016
00017
00018 class CUBIT_UTIL_EXPORT SettingHandler
00019 {
00020   friend class SettingHolder;
00021 public:
00022   ~SettingHandler();
00023   static SettingHandler* instance(); // make an instance of SettingHandler
00024
00025   static void delete_instance(); //deletes instance if it exists
00026
00027   void add_setting(const char* name, void (*setFn) (int), int (*getFn)());
00028   void add_setting(const char* name, void (*setFn) (double), double (*getFn)());
00029   void add_setting(const char* name, void (*setFn) (CubitBoolean), CubitBoolean (*getFn)());
00030   void add_setting(const char* name, void (*setFn) (CubitString), CubitString (*getFn)());
00031
00032   void get_settings_list( std::vector< std::pair<CubitString, SettingHolder*> > &list);
00033
00034   void print_settings(); // Output all settings using PRINT_INFO
00035   void save_settings(const char *filename); //Save settings into a file specified by the user
00036   void save_settings(); //Save settings into a default file
00037   void restore_settings(const char *filename); // Restore settings stored in a file
00038
00039     SettingHolder* get_setting_holder(CubitString name);
00040     inline SettingType get_setting_type(SettingHolder *setting);
00041
00042     inline int get_setting_int(SettingHolder *setting);
00043     inline double get_setting_double(SettingHolder *setting);
00044     inline CubitBoolean get_setting_bool(SettingHolder *setting);
00045     inline CubitString get_setting_string(SettingHolder *setting);
00046     inline int get_setting_debug_value(SettingHolder *setting);
00047
00048     inline void set_setting_int(SettingHolder *setting, int int_value);
00049     inline void set_setting_double(SettingHolder *setting, double double_value);
00050     inline void set_setting_bool(SettingHolder *setting, CubitBoolean bool_value);
00051     inline void set_setting_string(SettingHolder *setting, CubitString string_value);
00052     inline void set_setting_debug_value(SettingHolder *setting, int debug_value);
00053
00054 private:
00055
00056   void (*debug_set_function)(const int index, const int value);  //Pointer to the debug set function
00057   int  (*debug_get_function)(const int index);  //Pointer to the debug set function
00058
00059   //Private constructor for singleton pattern
00060   SettingHandler();
00061
00062   static SettingHandler* instance_;
00063
00064   //The debug flags are added to the map in the constuctor of the MessageFlag class.  Although
00065   //the MessageFlag constructor should only be called once(Singleton) it is called multiple times.
00066   //This causes an error because you cannot add the same setting to the map more than once.  This boolean
00067   //prevents this problem from occuring.
00068   CubitBoolean debug_flags_added;
00069
00070   std::map<CubitString, SettingHolder*> mSettingsList;
00071
00072
00073 };
00074
00075 inline SettingType SettingHandler::get_setting_type(SettingHolder *setting)
00076 { return setting->setting_type; }
00077
00078 inline int SettingHandler::get_setting_int(SettingHolder *setting)
00079 { return (setting->get_int_function)(); }
00080
00081 inline double SettingHandler::get_setting_double(SettingHolder *setting)
00082 { return (setting->get_double_function)(); }
00083
00084 inline CubitBoolean SettingHandler::get_setting_bool(SettingHolder *setting)
00085 { return (setting->get_bool_function)(); }
00086
00087 inline CubitString SettingHandler::get_setting_string(SettingHolder *setting)
00088 { return (setting->get_string_function)(); }
00089
00090 //inline int SettingHandler::get_setting_debug_value(SettingHolder *setting)
00091 //{ return debug_get_function(setting->index); }
00092
00093 inline void SettingHandler::set_setting_int(SettingHolder *setting, int int_value)
00094 { (setting->set_int_function)(int_value); }
00095
00096 inline void SettingHandler::set_setting_double(SettingHolder *setting, double double_value)
00097 { (setting->set_double_function)(double_value); }
00098
00099 inline void SettingHandler::set_setting_bool(SettingHolder *setting, CubitBoolean bool_value)
00100 { (setting->set_bool_function)(bool_value); }
00101
00102 inline void SettingHandler::set_setting_string(SettingHolder *setting, CubitString string_value)
00103 { (setting->set_string_function)(string_value); }
00104
00105 //inline void SettingHandler::set_setting_debug_value(SettingHolder *setting, int debug_value)
00106 //{ (*debug_set_function)(setting->index, debug_value); }
00107
00108 #endif
00109
00110
00111
00112
00113
00114
00115
