cgma
SettingHolder.hpp
00001 //- Class: SettingHolder
00002 //- Description: SettingHolder class - used for save and restore settings
00003 //- Owner: Wesley Gill
00004 //- Checked By:
00005 //- Version
00006
00007 #ifndef SETTINGHOLDER_HPP
00008 #define SETTINGHOLDER_HPP
00009
00010 #include "CubitString.hpp"
00011 #include "CubitDefines.h"
00012 #include "CGMUtilConfigure.h"
00013
00014 typedef enum SETTING_TYPE
00015 {
00016   SETTING_UNKNOWN_VALUE_TYPE = -1,
00017   SETTING_INT_VALUE_TYPE = 0,
00018   SETTING_DOUBLE_VALUE_TYPE = 1,
00019   SETTING_CUBITBOOLEAN_VALUE_TYPE = 2,
00020   SETTING_CUBITSTRING_VALUE_TYPE = 3
00021                         // int = 0, double = 1, CubitBoolean = 2, CubitString = 3, debug = 4
00022 } SettingType;
00023
00024
00025 class CUBIT_UTIL_EXPORT SettingHolder
00026 {
00027   friend class SettingHandler;
00028 public:
00029   SettingHolder();
00030   ~SettingHolder();
00031
00032   //- constructor for int settings
00033   SettingHolder(CubitString, void (*)(int), int (*)(), int);
00034
00035   //- constructor for double settings
00036   SettingHolder(CubitString, void (*)(double), double (*)(), double);
00037
00038   //- constructor for CubitBoolean settings
00039   SettingHolder(CubitString, void (*setFn)(CubitBoolean),
00040                 CubitBoolean (*getFn)(), CubitBoolean);
00041
00042   //- constructor for CubitString settings
00043   SettingHolder(CubitString n, void (*setFn) (CubitString),
00044                 CubitString (*getFn)(), char* value);
00045
00046   //- constructor for int settings
00047   SettingHolder(CubitString, void (*)(int), int (*)());
00048
00049   //- constructor for double settings
00050   SettingHolder(CubitString, void (*)(double), double (*)());
00051
00052   //- constructor for CubitBoolean settings
00053   SettingHolder(CubitString, void (*)(CubitBoolean), CubitBoolean (*)());
00054
00055   //- constructor for CubitString settings
00056   SettingHolder(CubitString n, void (*setFn) (CubitString),
00057                  CubitString (*getFn)());
00058
00059
00060 private:
00061
00062   //Use an enum for setting_type??
00063
00064   SettingType setting_type;     // Defines the type of setting
00065                         // int = 0, double = 1, CubitBoolean = 2, CubitString = 3, debug = 4
00066
00067   CubitString name;               // Name of the setting
00068   CubitString description;        // Description of the setting
00069   int int_value;
00070   double double_value;
00071   CubitString string_value;
00072
00073   int (*get_int_function) ();            // Pointer to get int function
00074   double (*get_double_function) ();      // Pointer to get double function
00075   CubitBoolean (*get_bool_function) ();  // Pointer to get boolean function
00076   CubitString (*get_string_function) (); // Pointer to get string function
00077
00078   void (*set_int_function) (int);            // Pointer to set int function
00079   void (*set_double_function) (double);      // Pointer to set double function
00080   void (*set_bool_function) (CubitBoolean);  // Pointer to set bool function
00081   void (*set_string_function) (CubitString); // Pointer to set string function
00082
00083 };
00084
00085 #endif
00086
00087
00088
00089
00090
