cgma
SplitCompositeSurfaceTool.cpp
00001 #include "SplitCompositeSurfaceTool.hpp"
00002 #include "GeometryModifyTool.hpp"
00003 #include "RefFace.hpp"
00004 #include "CompositeSurface.hpp"
00005 #include "CompositeCurve.hpp"
00006 #include "Curve.hpp"
00007 #include "Point.hpp"
00008 #include "GeometryModifyEngine.hpp"
00009 #include "GeometryQueryTool.hpp"
00010
00011 SplitCompositeSurfaceTool *SplitCompositeSurfaceTool::instance_ = NULL;
00012
00013 SplitCompositeSurfaceTool *SplitCompositeSurfaceTool::instance()
00014 {
00015   if (instance_ == NULL)
00016     instance_ = new SplitCompositeSurfaceTool();
00017
00018   return instance_;
00019 }
00020
00021 CubitStatus SplitCompositeSurfaceTool::split_surface(RefFace *ref_face_ptr,
00022                                                      DLIList<CubitVector*> &locations,
00023                                                      DLIList<DLIList<CubitVector*>*> &vec_lists,
00024                                                      CubitBoolean preview_flg,
00025                                                      CubitBoolean create_ref_edges_flg,
00026                                                      CubitBoolean clear_previous_previews)
00027 {
00028    get_additional_split_points(ref_face_ptr->get_surface_ptr(), vec_lists);
00029
00030    return GeometryModifyTool::instance()->split_surface(ref_face_ptr,
00031       locations, vec_lists, preview_flg, create_ref_edges_flg, clear_previous_previews);
00032 }
00033
00034 CubitStatus SplitCompositeSurfaceTool::split_surface(DLIList<RefFace*> &ref_face_list,
00035                                                      DLIList<CubitVector*> &locations,
00036                                                      DLIList<DLIList<DLIList<CubitVector*>*>*> &list_of_vec_lists,
00037                                                      CubitBoolean preview_flg,
00038                                                      CubitBoolean create_ref_edges_flg,
00039                                                      CubitBoolean clear_previous_previews)
00040 {
00041    for( int jj = ref_face_list.size() ; jj > 0 ; jj--)
00042    {
00043       DLIList<DLIList<CubitVector*>*> vec_lists = *( list_of_vec_lists.get_and_step() );
00044
00045       get_additional_split_points(ref_face_list.get_and_step()->get_surface_ptr(), vec_lists );
00046    }
00047
00048    return GeometryModifyTool::instance()->split_surface(ref_face_list,
00049       locations, list_of_vec_lists, preview_flg, create_ref_edges_flg, clear_previous_previews);
00050 }
00051
00052 void SplitCompositeSurfaceTool::find_faces_for_pos(CubitVector &pos, DLIList<Surface*> surf_list,
00053                         CubitPointContainment &containment,
00054                         DLIList<Surface*> &out_list)
00055 {
00056   int j;
00057
00058   for(j=surf_list.size(); j>0; j--)
00059   {
00060     Surface *surf_ptr = surf_list.get_and_step();
00061     containment = surf_ptr->point_containment(pos);
00062     if(containment == CUBIT_PNT_INSIDE || containment == CUBIT_PNT_BOUNDARY)
00063       out_list.append_unique(surf_ptr);
00064   }
00065 }
00066
00067 void SplitCompositeSurfaceTool::get_additional_split_points(Surface *surf,
00068                             DLIList<DLIList<CubitVector*>*> &vec_lists)
00069 {
00070   int i, j, k, num_surfs;
00071   DLIList<Surface*> surf_list;
00072
00073   CompositeSurface *cs = dynamic_cast<CompositeSurface*>(surf);
00074   if(cs && (num_surfs = cs->num_surfs()) > 1)
00075   {
00076     for(i=0; i<num_surfs; i++)
00077     {
00078       Surface *surf = cs->get_surface(i);
00079       if(surf)
00080         surf_list.append(surf);
00081     }
00082
00083     DLIList<Curve*> hidden_curves;
00084     cs->get_hidden_curves(hidden_curves);
00085
00086     for(i=vec_lists.size(); i--;)
00087     {
00088       // Remove any hidden curves that already have points on them.
00089       DLIList<Curve*> hidden_curves_without_pts = hidden_curves;
00090       DLIList<CubitVector*> *vec_list = vec_lists.get_and_step();
00091       for(j=vec_list->size(); j--;)
00092       {
00093         CubitVector *cur_vec = vec_list->get_and_step();
00094         DLIList<Curve*> crvs_to_remove;
00095         for(k=hidden_curves_without_pts.size(); k>0; k--)
00096         {
00097           Curve *crv = hidden_curves_without_pts.get_and_step();
00098           CubitVector foot;
00099           crv->closest_point_trimmed(*cur_vec, foot);
00100           if(foot.about_equal(*cur_vec))
00101             crvs_to_remove.append_unique(crv);
00102         }
00103         hidden_curves_without_pts -= crvs_to_remove;
00104       }
00105
00106       // Now we should only have hidden curves with no points on them.
00107       if(hidden_curves_without_pts.size() > 0)
00108       {
00109         vec_list->reset();
00110         CubitVector *cur_vec = vec_list->get();
00111         CubitVector *last_vec = vec_list->prev();
00112         while(cur_vec != last_vec)
00113         {
00114           vec_list->move_to(cur_vec);
00115           CubitVector *next_vec = vec_list->next();
00116           DLIList<CubitVector*> tmp_list;
00117           DLIList<double> vals;
00118           tmp_list.append(cur_vec);
00119           tmp_list.append(next_vec);
00120           vals.append(0.0);
00121           vals.append(1.0);
00122           Curve *hidden_curve = hidden_curves_without_pts.get();
00123           CompositeCurve *cc = dynamic_cast<CompositeCurve*>(hidden_curve);
00124           if(cc)
00125             hidden_curve = cc->get_curve(0);
00126           GeometryModifyEngine *gme = GeometryModifyTool::instance()->
00127             get_engine(hidden_curve);
00128           TBPoint *pt1 = gme->make_Point(*cur_vec);
00129           TBPoint *pt2 = gme->make_Point(*last_vec);
00130           Curve *tmp_crv = gme->make_Curve(STRAIGHT_CURVE_TYPE, pt1, pt2, NULL);
00131           if(tmp_crv)
00132           {
00133             double arc_length = tmp_crv->get_arc_length();
00134             for(j=hidden_curves_without_pts.size(); j--;)
00135             {
00136               CubitVector pos1, pos2;
00137               double dist;
00138               Curve *crv = hidden_curves_without_pts.get_and_step();
00139               GeometryQueryTool::instance()->entity_entity_distance(crv, tmp_crv, pos1, pos2, dist);
00140               CubitVector v1 = *cur_vec - pos1;
00141               CubitVector v2 = *last_vec - pos1;
00142               v1.normalize();
00143               v2.normalize();
00144               if(v1 % v2 < .3)
00145               {
00146                 CubitVector *new_vec = new CubitVector(pos1);
00147                 v1 = (pt1->coordinates() - pos2);
00148                 double percent = v1.length()/arc_length;
00149                 if(percent > 1.0)
00150                   percent = 1.0;
00151                 if(percent < 0.0)
00152                   percent = 0.0;
00153                 tmp_list.reset();
00154                 vals.reset();
00155                 while(percent > vals.get())
00156                 {
00157                   vals.step();
00158                   tmp_list.step();
00159                 }
00160                 vals.back();
00161                 tmp_list.back();
00162                 vals.insert(percent);
00163                 tmp_list.insert(new_vec);
00164               }
00165             }
00166             delete tmp_crv;
00167           }
00168           delete pt1;
00169           delete pt2;
00170           if(tmp_list.size() > 2)
00171           {
00172             vec_list->move_to(cur_vec);
00173             tmp_list.reset();
00174             tmp_list.step();
00175             for(j=tmp_list.size(); j>2; j--)
00176             {
00177               vec_list->insert(tmp_list.get());
00178               tmp_list.step();
00179             }
00180           }
00181           cur_vec = next_vec;
00182         }
00183       }
00184     }
00185   }
00186 }
00187
00188 // Passed in direction should be normalized by calling function.
00189 void SplitCompositeSurfaceTool::find_face_with_non_zero_param_dir(DLIList<Surface*> &surf_list,
00190                                         CubitVector &dir,
00191                                         CubitVector &pos,
00192                                         Surface *&ret_surf,
00193                                         double &du, double &dv,
00194                                         double &step)
00195 {
00196   int i;
00197   ret_surf = NULL;
00198   for(i=surf_list.size(); i>0 && !ret_surf; i--)
00199   {
00200     Surface *surf = surf_list.get_and_step();
00201     CubitPointContainment cont = surf->point_containment(pos);
00202     if(cont == CUBIT_PNT_INSIDE)
00203     {
00204       double ulow, uhigh, vlow, vhigh;
00205       surf->param_dir(dir, pos, du, dv);
00206       surf->get_param_range_U(ulow, uhigh);
00207       surf->get_param_range_V(vlow, vhigh);
00208       double u_len = fabs(ulow-uhigh);
00209       double v_len = fabs(vlow-vhigh);
00210       double par_tol;
00211       if(u_len > v_len)
00212         par_tol = v_len/100.0;
00213       else
00214         par_tol = u_len/100.0;
00215       par_tol *= par_tol;
00216       double len = du*du + dv*dv;
00217       if(len > par_tol)
00218       {
00219         step = sqrt(u_len*u_len + v_len*v_len)/20.0;
00220         ret_surf = surf;
00221       }
00222     }
00223     else if(cont == CUBIT_PNT_BOUNDARY)
00224     {
00225       double ulow, uhigh, vlow, vhigh;
00226       surf->param_dir(dir, pos, du, dv);
00227       surf->get_param_range_U(ulow, uhigh);
00228       surf->get_param_range_V(vlow, vhigh);
00229       double u_len = fabs(ulow-uhigh);
00230       double v_len = fabs(vlow-vhigh);
00231       double par_tol;
00232       if(u_len > v_len)
00233         par_tol = v_len/100.0;
00234       else
00235         par_tol = u_len/100.0;
00236       par_tol *= par_tol;
00237       double len = du*du + dv*dv;
00238       if(len > par_tol)
00239       {
00240         double u, v;
00241         surf->u_v_from_position(pos, u, v);
00242         CubitVector new_pos = surf->position_from_u_v(u+du, v+dv);
00243         CubitPointContainment new_cont = surf->point_containment(new_pos);
00244         if(new_cont == CUBIT_PNT_INSIDE)
00245         {
00246           step = sqrt(u_len*u_len + v_len*v_len)/20.0;
00247           ret_surf = surf;
00248         }
00249       }
00250     }
00251   }
00252 }
