cgma
SurfParamTool.cpp
00001 //- Class: SurfParamTool
00002 //-------------------------------------------------------------------------
00003 // Filename      : SurfParamTool.cpp
00004 //
00005 // Purpose       : This is the generic version of ParamTool when the
00006 //                 geometry engine has a sufficient parameterization.
00007 //                 It uses the tool's existing functions to get transform
00008 //                 between uv and xyz spaces.
00009 //
00010 // Creator       : Christopher Hynes
00011 //
00012 // Creation Date : 7/10/2002
00013 //
00014 // Owner         : Christopher Hynes
00015 //-------------------------------------------------------------------------
00016
00017 #include "SurfParamTool.hpp"
00018 #include "CastTo.hpp"
00019 #include "Surface.hpp"
00020 #include "DLIList.hpp"
00021
00022 //-------------------------------------------------------------------------
00023 // Function:    SurfParamTool
00024 // Description: constructor
00025 // Author:      chynes
00026 // Date:        7/10/2002
00027 //-------------------------------------------------------------------------
00028 SurfParamTool::SurfParamTool(Surface *surf)
00029 {
00030
00031     //- update private variables
00032     refSurf = surf;
00033
00034 }
00035
00036 //-------------------------------------------------------------------------
00037 // Function:    SurfParamTool
00038 // Description: deconstructor
00039 // Author:      chynes
00040 // Date:        7/10/2002
00041 //-------------------------------------------------------------------------
00042 SurfParamTool::~SurfParamTool() {}
00043
00044 //===================================================================================
00045 // Function: set_up_space (Public)
00046 // Description: sets up space of flattening
00047 // Author: chynes
00048 // Date: 7/10/02
00049 //===================================================================================
00050 CubitStatus SurfParamTool::set_up_space(void) {
00051
00052     CubitStatus rv = CUBIT_SUCCESS;
00053
00054
00055     return rv;
00056 }
00057
00058 //===================================================================================
00059 // Function: transform_to_uv (Public)
00060 // Description: same as title, the local sizing will be returned in the z coord
00061 // Author: chynes
00062 // Date: 7/10/02
00063 //===================================================================================
00064 CubitStatus SurfParamTool::transform_to_uv(const CubitVector &xyz_location, CubitVector &uv_location)
00065 {
00066     double u,v;
00067
00068     CubitStatus rv = refSurf->u_v_from_position(xyz_location, u, v);
00069     uv_location.set(u,v,1.0);
00070
00071     CubitVector du, dv;
00072     uv_derivitives(u,v,du,dv);
00073
00074     return rv;
00075 }
00076
00077 //===================================================================================
00078 // Function: transform_to_xyz (Public)
00079 // Description: same as title
00080 // Author: chynes
00081 // Date: 7/10/02
00082 //===================================================================================
00083 CubitStatus SurfParamTool::transform_to_xyz(CubitVector &xyz_location, const CubitVector &uv_location)
00084 {
00085     xyz_location = refSurf->position_from_u_v(uv_location.x(), uv_location.y());
00086
00087     return CUBIT_SUCCESS;
00088 }
00089
00090 CubitStatus SurfParamTool::uv_derivitives( double u_param, double v_param, CubitVector &du, CubitVector &dv )
00091 {
00092     return refSurf->uv_derivitives (u_param, v_param, du, dv);
00093 }
00094
00095 //void intersect2DLines(double x0, double y0, double x1, double y1,
00096 //                    double x2, double y2, double x3, double y3,
00097 //                    double &xc, double &yc)
00101 //{
00102 //  double u = ( (x3-x2)*(y0-y2) - (y3-y2)*(x0-x2) ) / ( (y3-y2)*(x1-x0) - (x3-x2)*(y1-y0) );
00103 //
00104 //  xc = x0 + u * (x1-x0);
00105 //  yc = y0 + u * (y1-y0);
00106 //}
00107 //
00108 //
00109 //
00110 //CubitStatus SurfParamTool::circumcenter(double u0, double v0,
00111 //                       double u1, double v1,
00112 //                       double u2, double v2,
00113 //                       CubitVector &center)
00118 //{
00119 //
00120 //  // first, lets calculate the circumcenter without the gradients to make sure the system works
00121 //
00122 //  // our method for finding a circumcenter utilizes the fact that the perpendicalar bisectors of each side
00123 //  // of the triangle intersect at the circumcenter
00124 //
00125 //  // find the three bisectors of the sides
00126 //
00127 //  double u3 = u0 + (u1 - u0) * 0.5;   // midpoint of side 0-1
00128 //  double v3 = v0 + (v1 - v0) * 0.5;
00129 //
00130 //  double u4 = u3 + v0 - v1;   // point on the perp bisector of side 0-1
00131 //  double v4 = v3 + u1 - u0;
00132 //
00133 //  double u5 = u1 + (u2 - u1) * 0.5;   // midpoint of side 1-2
00134 //  double v5 = v1 + (v2 - v1) * 0.5;
00135 //
00136 //  double u6 = u5 + v1 - v2;   // point on the perp bisector of side 1-2
00137 //  double v6 = v5 + u2 - u1;
00138 //
00139 //  double u7 = u0 + (u2 - u0) * 0.5;   // midpoint of side 0-2
00140 //  double v7 = v0 + (v2 - v0) * 0.5;
00141 //
00142 //  double u8 = u7 + v0 - v2;
00143 //  double v8 = v7 + u2 - u0;
00144 //
00145 //  // intersect two bisectors to give a cirumcenter
00146 //
00147 //  double xc, yc;
00148 //  intersect2DLines(u3,v3,u4,v4,u5,v5,u6,v6,xc,yc);
00149 //  double xc2, yc2;
00150 //  intersect2DLines(u3,v3,u4,v4,u7,v7,u8,v8,xc2,yc2);
00151 //  double xc3, yc3;
00152 //  intersect2DLines(u5,v5,u6,v6,u7,v7,u8,v8,xc3,yc3);
00153 //
00154 //
00155 //
00156 //
00157 //  //// get derivitives of each point
00158 //
00159 //  //CubitVector du0, du1, du2, dv0, dv1, dv2, du, dv;
00160 //  //uv_derivitives (u0, v0, du0, dv0);
00161 //  //uv_derivitives (u1, v1, du1, dv1);
00162 //  //uv_derivitives (u2, v2, du2, dv2);
00163 //
00164 //  //// for now, average derivities first
00165 //
00166 //  //du = (du0 + du1 + du2) / 3.0; n
00167 //  //dv = (dv0 + dv1 + dv2) / 3.0;
00168 //
00169 //  //// Calculate the rotation angle to the principal axis
00170 //
00171 //  //double alpha = atan2( 2.0 * ( du.x()*dv.x() + du.y()*dv.y() ), (du.length_squared() - dv.length_squared())) * 0.5;
00172 //
00173 //  //// Calculate principal derivitives
00174 //
00175 //  //double cosa = acos(alpha);
00176 //  //double sina = asin(alpha);
00177 //  //CubitVector dup = cosa * du + sina * dv;
00178 //  //CubitVector dvp = -sina * du + cosa * dv;
00179 //
00180 //  ////
00181 //
00182 //
00183 //  return CUBIT_SUCCESS;
00184 //}
00185
00186
00187
00188
00189 //EOF
00190
00191 //- Class: TestParamTool
00192 //-------------------------------------------------------------------------
00193 // Filename      : TestParamTool.cpp
00194 //
00195 // Purpose       : This is the generic version of ParamTool when the
00196 //                 geometry engine has a sufficient parameterization.
00197 //                 It uses the tool's existing functions to get transform
00198 //                 between uv and xyz spaces.
00199 //
00200 // Creator       : Christopher Hynes
00201 //
00202 // Creation Date : 7/10/2002
00203 //
00204 // Owner         : Christopher Hynes
00205 //-------------------------------------------------------------------------
00206
00207 #include "CastTo.hpp"
00208 #include "Surface.hpp"
00209 #include "DLIList.hpp"
00210
00211 //-------------------------------------------------------------------------
00212 // Function:    TestParamTool
00213 // Description: constructor
00214 // Author:      chynes
00215 // Date:        7/10/2002
00216 //-------------------------------------------------------------------------
00217 TestParamTool::TestParamTool()
00218 {
00219
00220     //- update private variables
00221 //  refSurf = surf;
00222
00223   uRange = 1.0;
00224   vRange = 4.0;
00225
00226   xMin = -0.5;
00227   yMin = -0.5;
00228
00229   xMax = 0.5;
00230   yMax = 0.5;
00231
00232
00233   zDepth = 0.5;  // constant z coordinate of test surface
00234
00235 }
00236
00237 //-------------------------------------------------------------------------
00238 // Function:    TestParamTool
00239 // Description: deconstructor
00240 // Author:      chynes
00241 // Date:        7/10/2002
00242 //-------------------------------------------------------------------------
00243 TestParamTool::~TestParamTool() {}
00244
00245 //===================================================================================
00246 // Function: set_up_space (Public)
00247 // Description: sets up space of flattening
00248 // Author: chynes
00249 // Date: 7/10/02
00250 //===================================================================================
00251 CubitStatus TestParamTool::set_up_space(void)
00252 {
00253
00254     CubitStatus rv = CUBIT_SUCCESS;
00255
00256
00257     return rv;
00258 }
00259
00260 //===================================================================================
00261 // Function: transform_to_uv (Public)
00262 // Description: same as title, the local sizing will be returned in the z coord
00263 // Author: chynes
00264 // Date: 7/10/02
00265 //===================================================================================
00266 CubitStatus TestParamTool::transform_to_uv(const CubitVector &xyz_location, CubitVector &uv_location)
00267 {
00268   // calculate the u,v from the x,y
00269
00270   double u = (xyz_location.x()-xMin)/(xMax-xMin) * uRange;
00271   double v = (xyz_location.y()-yMin)/(yMax-yMin) * vRange;
00272     uv_location.set(u,v,1.0);
00273
00274     return CUBIT_SUCCESS;
00275 }
00276
00277 //===================================================================================
00278 // Function: transform_to_xyz (Public)
00279 // Description: same as title
00280 // Author: chynes
00281 // Date: 7/10/02
00282 //===================================================================================
00283 CubitStatus TestParamTool::transform_to_xyz(CubitVector &xyz_location, const CubitVector &uv_location)
00284 {
00285   // get x,y from u,v
00286
00287   double x = uv_location.x()/uRange + xMin;
00288   double y = uv_location.y()/vRange + yMin;
00289
00290   xyz_location.set(x,y,zDepth);
00291
00292     return CUBIT_SUCCESS;
00293 }
00294
00295 CubitStatus TestParamTool::uv_derivitives( double u_param, double v_param, CubitVector &du, CubitVector &dv )
00296 {
00297   du.set(1.0/uRange,0,0);
00298   dv.set(0,1.0/vRange,0);
00299   return CUBIT_SUCCESS;
00300 }
