cgma
SurfParamTool.hpp
00001 //- Class: SurfParamTool
00002 //-------------------------------------------------------------------------
00003 // Filename      : SurfParamTool.hpp
00004 //
00005 // Purpose       : This is the generic version of ParamTool when the
00006 //                 geometry engine has a sufficient parameterization.
00007 //                 It uses the tool's existing functions to get transform
00008 //                 between uv and xyz spaces.
00009 //
00010 // Creator       : Christopher Hynes
00011 //
00012 // Creation Date : 7/10/2002
00013 //
00014 // Owner         : Christopher Hynes
00015 //-------------------------------------------------------------------------
00016
00017 #ifndef SURF_PARAM_TOOL_HPP
00018 #define SURF_PARAM_TOOL_HPP
00019
00020 #include "ParamTool.hpp"
00021 #include "CGMGeomConfigure.h"
00022
00023 class Surface;
00024 class CubitVector;
00025 template <class X> class DLIList;
00026
00028 class CUBIT_GEOM_EXPORT SurfParamTool : public ParamTool
00029 {
00030 public:
00031
00032     //- constructor
00033     SurfParamTool(Surface *surf);
00034
00035     //- deconstructor
00036     ~SurfParamTool();
00037
00038     CubitStatus set_up_space(void);
00039
00040     CubitStatus transform_to_uv(const CubitVector &xyz_location, CubitVector &uv_location);
00041
00042     CubitStatus transform_to_xyz(CubitVector &xyz_location, const CubitVector &uv_location);
00043
00044     CubitStatus uv_derivitives( double u_param, double v_param,
00045                                     CubitVector &du, CubitVector &dv );
00046
00047     static CubitStatus circumcenter(double u0, double v0,
00048                                         double u1, double v1,
00049                                         double u2, double v2,
00050                                         CubitVector &center);  // temp function to be moved elsewhere
00051
00052 private:
00053
00054     Surface *refSurf;
00055     //- reference surface
00056 };
00057
00058 class Surface;
00059 class CubitVector;
00060 template <class X> class DLIList;
00061
00063 class CUBIT_GEOM_EXPORT TestParamTool : public ParamTool
00064 {
00065 public:
00066
00067     //- constructor
00068     TestParamTool();
00069
00070     //- deconstructor
00071     ~TestParamTool();
00072
00073     CubitStatus set_up_space(void);
00074
00075     CubitStatus transform_to_uv(const CubitVector &xyz_location, CubitVector &uv_location);
00076
00077     CubitStatus transform_to_xyz(CubitVector &xyz_location, const CubitVector &uv_location);
00078
00079     CubitStatus uv_derivitives( double u_param, double v_param,
00080                                     CubitVector &du, CubitVector &dv );
00081
00082     static CubitStatus circumcenter(double u0, double v0,
00083                                         double u1, double v1,
00084                                         double u2, double v2,
00085                                         CubitVector &center);  // temp function to be moved elsewhere
00086
00087 private:
00088
00089 //  Surface *refSurf;
00090     //- reference surface
00091
00092   double uRange, vRange;
00093   double zDepth;
00094
00095   double xMin, yMin, xMax, yMax;
00096
00097 };
00098
00099 #endif //
00100
