cgma
TDFacetBoundaryEdge.hpp
00001 //- Class:       TDFacetBoundaryEdge
00002 //- Description: Tool data for storing additional information at
00003 //-              the boundary of a facet set
00004 //- Owner:       Steve Owen
00005 //- Checked by:
00006 //- Version:
00007
00008 #ifndef TD_FACET_BOUNDARY_EDGE_HPP
00009
00010
00011 #define TD_FACET_BOUNDARY_EDGE_HPP
00012
00013 #include "CubitDefines.h"
00014 #include "ToolData.hpp"
00015 #include "DLIList.hpp"
00016 #include "CubitVector.hpp"
00017 #include "MemoryManager.hpp"
00018 #include "CastTo.hpp"
00019 class CubitFacetEdge;
00020 class CubitFacet;
00021 class CubitPoint;
00022
00023 typedef struct BoundaryEdgeData
00024 {
00025   CubitVector bezierCtrlPts[3];
00026   CubitFacet *adjFacet;
00027   int surfID;
00028   int computed;
00029 } BoundaryEdgeData;
00030
00031 class TDFacetBoundaryEdge : public ToolData
00032 {
00033 private:
00034
00035   static MemoryManager memoryManager;
00036     //- memory management object
00037
00038   CubitFacetEdge *edgePtr;
00039     //Because non-manifold geometry complicates things a little, if
00040     // we are using a represenation that is of a higher order than
00041     // linear.  We figure out which edges edgePtr should be C1 with
00042     // along a curve... The two edges (if exist) are store in nextEdgePtr
00043     // (if it is the edge across node(1)) or prevEdgePtr (if it is the
00044     // edge across node(0)).
00045   CubitFacetEdge *nextEdgePtr;
00046   CubitFacetEdge *prevEdgePtr;
00047   DLIList <BoundaryEdgeData *> edgeDataList;
00048
00049 public:
00050
00051   TDFacetBoundaryEdge();
00052     //- constructor
00053
00054   ~TDFacetBoundaryEdge();
00055
00056   static int is_facet_boundary_edge(const ToolData* td)
00057      {return (CAST_TO(const_cast<ToolData*>(td), TDFacetBoundaryEdge) != NULL);}
00058
00059   void add_surf(int new_id);
00060
00061   CubitFacetEdge *get_edge()
00062     { return edgePtr; }
00063
00064   void set_edge( CubitFacetEdge *edge_ptr )
00065     { edgePtr = edge_ptr; }
00066
00067   CubitFacetEdge *get_next_edge()
00068     { return nextEdgePtr; }
00069
00070   void set_next_edge( CubitFacetEdge *edge_ptr )
00071     { nextEdgePtr = edge_ptr; }
00072
00073   CubitFacetEdge *get_prev_edge()
00074     { return prevEdgePtr; }
00075
00076   void set_prev_edge( CubitFacetEdge *edge_ptr )
00077     { prevEdgePtr = edge_ptr; }
00078
00079
00080   SetDynamicMemoryAllocation(memoryManager)
00081     //- class specific new and delete operators
00082
00083   static void set_memory_allocation_increment(int increment = 0)
00084     {memoryManager.set_memory_allocation_increment(increment);}
00085     //- set block memory size increment
00086
00087   static void destroy_memory()
00088     {memoryManager.destroy_memory();}
00089     //- destroy all memory allocted to this object
00090
00091   static CubitStatus add_facet_boundary_edge(CubitFacetEdge *edge_ptr);
00092   static TDFacetBoundaryEdge* get_facet_boundary_edge(CubitFacetEdge *edge_ptr);
00093
00094   int control_points( CubitVector *ctrl_pts, int surf_id );
00095     //- get the control points (return the order)
00096   void control_points( CubitVector *ctrl_pts, int order, int surf_id );
00097     //- set the bezier control points on the edge.
00098     //- end points are assumed to be the first and last
00099     //- ctrl pt so they are not passed in.  Pass in order-1
00100     //- control points (max order = 4)
00101   CubitStatus control_points( CubitFacet *facet, CubitVector *ctrl_pts );
00102     // return the control pons on the edge of a facet based
00103     // on its edge use direction
00104   void get_control_points( CubitPoint *point_ptr, CubitVector ctrl_pts[3],
00105                            int surf_id );
00106   void set_control_points( CubitPoint *point_ptr, CubitVector ctrl_pts[3],
00107                            int surf_id );
00108     // get and set control points oriented with respect to the
00109     // point_ptr (ie.  point_ptr is the first control point on the edge)
00110     // Note: only gets and sets the middle three control points.  The
00111     // other 2 are the edge vertices.
00112
00113   void add_surf_facet( DLIList<CubitFacet *> &facet_list );
00114     // add facet representing a new surface adjacent this edge
00115
00116   void set_surf_id( CubitFacet *facet_ptr, int surf_id );
00117     // set id of surface defined by facet_ptr
00118
00119   CubitBoolean is_internal_edge();
00120     // return whether this edge is internal to a surface
00121
00122   CubitStatus init_control_points( double min_dot );
00123     // initialize control points on boundary edge
00124
00125   CubitStatus merge_control_points();
00126     // find aerage of control points and set on edge
00127
00128   CubitStatus compute_curve_tangent( int surf_id,
00129                                      CubitFacetEdge *edge,
00130                                      double min_dot,
00131                                      CubitVector &T0,
00132                                      CubitVector &T3 );
00133     // compute the tangents to the endpoints of a feature edge.
00134
00135   CubitFacetEdge *next_feature_edge( int surf_id,
00136                                      CubitFacetEdge *this_edge,
00137                                      CubitPoint *p0 );
00138     // given a facet boundary edge and one of its nodes, find the
00139     // next edge on the same surface
00140
00141   CubitBoolean is_at_surf( int surf_id );
00142     // return whether the given edge has one of its adjacent
00143     // faces on the given surface
00144 };
00145
00146
00147 #endif // TD_FACET_BOUNDARY_EDGE_HPP
00148
00149
