cgma
TDUniqueId.hpp
00001 //- Class: TDUniqueId
00002 //- Owner: Tim Tautges
00003 //- Description: This tool data generates unique ids using a random number
00004 //-    generator, and keeps an id in this object
00005 //- A NOTE ABOUT RANDOM NUMBER GENERATION USED IN THIS CLASS:
00006 //- A 3rd party random number generator is used in this class, to overcome limitations
00007 //- of the (16-bit) random number generator on windows systems.  This generator is in
00008 //- the TRandomMersenne class; see that class for documentation of the actual RNG source.
00009 //- In this class (TDUniqueId), the random number generator is seeded DURING THE FIRST CALL
00010 //- TO GET A UNIQUE ID with the output of time(NULL).  This "function-static" method is
00011 //- used to further randomize the seed to decrease the liklihood of getting duplicate uids.
00012 //-
00013 //- Checked By:
00014 //- Version:
00015
00016 #ifndef TD_UNIQUE_ID
00017 #define TD_UNIQUE_ID
00018
00019 #include "ToolData.hpp"
00020 #include "MemoryManager.hpp"
00021 #include "CubitDefines.h"
00022 #include "CGMGeomConfigure.h"
00023 #include <map>
00024
00025 template <class X> class DLIList;
00026 class ToolDataUser;
00027 class RefEntity;
00028 class TDUniqueId;
00029
00030 typedef std::multimap<long, TDUniqueId*> TDUIDList;
00031
00032 //This map is used when copying an entity. It maps the unique
00033 //id of the original to the unique id of the copy
00034 typedef std::map<long, long> COPYUIDMap;
00035
00036 class CUBIT_GEOM_EXPORT TDUniqueId : public ToolData
00037 {
00038 private:
00039
00040   int uniqueId;
00041     //- unique id of the owning entity
00042
00043   ToolDataUser *ownerEntity;
00044     //- back pointer to the owning entity (needed for sorted lists of
00045     //- TDUniqueId's)
00046
00047   static MemoryManager memoryManager;
00048     //- memory management object
00049
00050   static TDUIDList uniqueIdList;
00051     //- static list of all entities containing unique ids
00052
00053   static COPYUIDMap mapForCopying;
00054     //- maps original unique id to that on copy of entity
00055
00056   static int initialize();
00057     //- initialize the random number generator
00058
00059   static TDUIDList &unique_id_list();
00060     //- get a reference to the unique id map
00061
00062 public:
00063
00064   static int generate_unique_id();
00065
00066   TDUniqueId(ToolDataUser *owner, const int id = 0);
00067
00068   virtual ~TDUniqueId();
00069     //-constructor and destructor
00070
00071     //- clear copy map
00072   static void clear_copy_map();
00073
00074   static int is_unique_id(const ToolData* td);
00075
00076   static int get_unique_id(ToolDataUser *owner,
00077                            const CubitBoolean create_new = CUBIT_TRUE);
00078     //- get the unique id for owner, or create a new one
00079
00080   int unique_id(); /*{return uniqueId;};*/
00081   void unique_id(const int id) {uniqueId = id;};
00082     //- get/set functions for unique id
00083
00084   static int get_unique_id_for_copy( int original_id );
00085     //- when copying an entity that has unique id, gets another
00086     //unique id for the copy
00087
00088   ToolDataUser *owner_entity() {return ownerEntity;};
00089   void owner_entity(ToolDataUser *owner) {ownerEntity = owner;};
00090     //- get/set functions for ownerEntity
00091
00092   static ToolDataUser *find_td_unique_id(const int temp_id,
00093                                          const RefEntity *related_entity = NULL);
00094     //- find the tdu with id temp_id (sorts the list if not sorted)
00095
00096   static int find_td_unique_id(const int temp_id,
00097                                DLIList<ToolDataUser*> &td_list,
00098                                const RefEntity *related_entity = NULL);
00099     //- find all tdus with id temp_id (sorts the list if not sorted); returns num found
00100
00101   SetDynamicMemoryAllocation(memoryManager)
00102     //- class specific new and delete operators
00103
00104   static void set_memory_allocation_increment(int increment = 0)
00105       {memoryManager.set_memory_allocation_increment(increment);}
00106     //- set block memory size increment
00107
00108   static void destroy_memory()
00109       {memoryManager.destroy_memory();}
00110     //- destroy all memory allocted to this object
00111
00112 };
00113
00114 inline TDUIDList &TDUniqueId::unique_id_list()
00115 {
00116   return uniqueIdList;
00117 }
00118 #endif
00119
00120
