cgma
ToolDataUser.hpp
00001 //- Class: ToolDataUser
00002 //- Owner: Scott Mitchell
00003 //- Description: This is the tool data interface that every class that uses a
00004 //-              tool data needs to specify. E.g. CubitNode and CubitFace
00005 //-              are derived from this class.
00006 //- Checked By:
00007 //- Version: $Id:
00008
00009 #ifndef TOOL_DATA_USER_HPP
00010 #define TOOL_DATA_USER_HPP
00011
00012 #include "CubitDefines.h"
00013 #include "CGMUtilConfigure.h"
00014
00015 class ToolData;
00016
00017 typedef int (*IdentityFn)(const ToolData* td);
00018 template <class X> class DLIList;
00019
00020 class CUBIT_UTIL_EXPORT ToolDataUser
00021 {
00022
00023 private:
00024     ToolDataUser( const ToolDataUser& );
00025     void operator=( const ToolDataUser&);
00026
00027   ToolData *toolData;
00028   //- generic pointer to extra data needed by a particular VolSmoothTool.
00029   //- see the _TD functions below for how to access this
00030
00031   void      tool_data(ToolData *set_data) {toolData = set_data;}
00032   ToolData* tool_data()    const          {return toolData;}
00033   //- all external access/setting should be done with the _TD functions.
00034
00035 public:
00036
00037   ToolDataUser () { toolData = NULL; }
00038
00039   virtual ~ToolDataUser();
00040   //- automatically deletes all the chained ToolDatas
00041
00042   virtual CubitBoolean delete_TD(IdentityFn specified_type);
00043   //- delete the specific type of tool data from the chain.
00044   //- return true if something was actually found and deleted.
00045
00046   virtual CubitBoolean delete_TD(ToolData *td);
00047   //- delete the specific tool data from the chain.
00048   //- return true if something was actually found and deleted.
00049
00050   virtual ToolData *remove_TD(IdentityFn specified_type);
00051   //- remove the specific type of tool data from the chain, and
00052   //- return it.
00053
00054   virtual ToolData *remove_TD(ToolData *td);
00055   //- remove the specific tool data from the chain, and
00056   //- return it.
00057
00058   virtual void add_TD(ToolData *new_td);
00059   //- add the new_td to the beginning of the tool_data chain
00060
00061   virtual ToolData *get_TD(IdentityFn specified_type);
00062   virtual ToolData const *get_TD(IdentityFn specified_type) const;
00063   virtual void get_all_TDs(IdentityFn specified_type,
00064                            DLIList <ToolData *> *all_tds) const;
00065
00066   virtual void get_all_TDs(DLIList <ToolData *> *all_tds) const;
00067   //- get the specific type of ToolData in the chain.
00068   //- returns null if not found.
00069
00070 };
00071
00072
00073 #endif // TOOL_DATA_USER_HPP
00074
00075
00076
00077
00078
