cgma
CollapseAngleTool Member List
This is the complete list of members for CollapseAngleTool, including all inherited members.
auto_collapse(double length, double angle, CubitBoolean preview, CubitBoolean if_comp_vertex, double max_angle)CollapseAngleTool
collapse_angle(RefVertex *vex_ptr, RefEdge *edge_to_remove, RefEdge *the_other_edge, double length1, double length2, CubitBoolean get_position, CubitVector &position)CollapseAngleTool [private]
collapse_one_angle(RefVertex *vex_ptr, RefEdge *edge_to_remove, RefEdge *the_other_edge, double length1, double length2, CubitBoolean get_position, CubitVector &position, CubitBoolean preview, CubitBoolean if_comp_vertex, double angle)CollapseAngleTool
CollapseAngleTool()CollapseAngleTool [private]
draw_preview(RefVertex *vex_ptr, RefEdge *edge_to_remove, RefEdge *the_other_edge, double length1, double length2, CubitBoolean get_position, CubitVector &position)CollapseAngleTool [private]
exchange_edges(RefEdge *&edge, RefEdge *&the_other_edge)CollapseAngleTool [private]
if_partition_surf(RefVertex *vex_ptr, RefEdge *edge_to_remove, RefFace *common_face)CollapseAngleTool [private]
instance()CollapseAngleTool [static]
instance_CollapseAngleTool [private, static]
partition_curve(RefEdge *&edge, RefVertex *root_vertex, CubitVector &position, RefVertex *&new_vertex)CollapseAngleTool [private]
partition_curve(RefEdge *&edge, RefVertex *root_vertex, double arc_length, RefVertex *&new_vertex)CollapseAngleTool [private]
partition_surface(RefFace *common_face, RefEdge *&edge, RefVertex *root, RefVertex *vertex1, RefVertex *veretx2, RefFace *&result_face)CollapseAngleTool [private]
partly_drawn_curveCollapseAngleTool [private]
position_from_length(RefEdge *edge, RefVertex *root_vertex, double arc_length, CubitVector &v_new)CollapseAngleTool [private]
the_surface_angle(RefEdge *edge, RefVertex *root_vertex, double length)CollapseAngleTool [private]
~CollapseAngleTool()CollapseAngleTool [private]
