cgma
#include <CollapseAngleTool.hpp>
Public Member Functions | |
CubitStatus | auto_collapse (double length, double angle, CubitBoolean preview, CubitBoolean if_comp_vertex, double max_angle) |
void | collapse_one_angle (RefVertex *vex_ptr, RefEdge *edge_to_remove, RefEdge *the_other_edge, double length1, double length2, CubitBoolean get_position, CubitVector &position, CubitBoolean preview, CubitBoolean if_comp_vertex, double angle) |
Static Public Member Functions | |
static CollapseAngleTool * | instance () |
Private Member Functions | |
CollapseAngleTool () | |
~CollapseAngleTool () | |
CubitStatus | partition_curve (RefEdge *&edge, RefVertex *root_vertex, CubitVector &position, RefVertex *&new_vertex) |
CubitBoolean | if_partition_surf (RefVertex *vex_ptr, RefEdge *edge_to_remove, RefFace *common_face) |
CubitStatus | partition_curve (RefEdge *&edge, RefVertex *root_vertex, double arc_length, RefVertex *&new_vertex) |
CubitStatus | partition_surface (RefFace *common_face, RefEdge *&edge, RefVertex *root, RefVertex *vertex1, RefVertex *veretx2, RefFace *&result_face) |
CubitStatus | collapse_angle (RefVertex *vex_ptr, RefEdge *edge_to_remove, RefEdge *the_other_edge, double length1, double length2, CubitBoolean get_position, CubitVector &position) |
CubitStatus | draw_preview (RefVertex *vex_ptr, RefEdge *edge_to_remove, RefEdge *the_other_edge, double length1, double length2, CubitBoolean get_position, CubitVector &position) |
void | exchange_edges (RefEdge *&edge, RefEdge *&the_other_edge) |
double | the_surface_angle (RefEdge *edge, RefVertex *root_vertex, double length) |
CubitStatus | position_from_length (RefEdge *edge, RefVertex *root_vertex, double arc_length, CubitVector &v_new) |
Private Attributes | |
DLIList< RefEdge * > | partly_drawn_curve |
Static Private Attributes | |
static CollapseAngleTool * | instance_ = NULL |
Definition at line 19 of file CollapseAngleTool.hpp.
CollapseAngleTool::CollapseAngleTool | ( | ) | [private] |
Definition at line 353 of file CollapseAngleTool.cpp.
CollapseAngleTool::~CollapseAngleTool | ( | ) | [private] |
Definition at line 357 of file CollapseAngleTool.cpp.
CubitStatus CollapseAngleTool::auto_collapse | ( | double | length, |
double | angle, | ||
CubitBoolean | preview, | ||
CubitBoolean | if_comp_vertex, | ||
double | max_angle | ||
Definition at line 133 of file CollapseAngleTool.cpp.
{ //clear out the partly_drawn_curve list partly_drawn_curve.clean_out(); //finding all angles less than 'angle' DLIList<RefEntity*> entity_list; DLIList<RefVolume*> volume_list; RefVolume * ref_volume; DLIList <RefEdge *> large_edge_angles_list; DLIList <RefEdge *> small_edge_angles_list; DLIList <double> large_angles_list; DLIList <double> small_angles_list; int total_interior; int total_fuzzy; CubitStatus result = CUBIT_SUCCESS; // get an instance of GeometryQueryTool GeometryQueryTool *gqt = GeometryQueryTool::instance(); volume_list.clean_out(); result = gqt->ref_entity_list("volume", entity_list); if (result == CUBIT_FAILURE || entity_list.size() < 1) { PRINT_ERROR("This command is prepared for volume mesh only.\n" "The angles must reside on volumes.\n"); return result; } CAST_LIST(entity_list, volume_list, RefVolume); int i; small_edge_angles_list.clean_out(); for (i=0; i < volume_list.size(); i++) { ref_volume = volume_list.get_and_step(); assert (ref_volume != NULL); GeomMeasureTool::find_interior_curve_angles(ref_volume, 360, angle, large_edge_angles_list, small_edge_angles_list, large_angles_list, small_angles_list, total_interior, total_fuzzy); } //collapse small angles, use perpendicular to the second curve. int size = small_edge_angles_list.size(); int init_size = size+1; int index = 0; RefVertex *vex_ptr = NULL; RefEdge *edge_to_remove = NULL; RefEdge *the_other_edge = NULL; double length1 = -1.0, length2 = -1.0; CubitVector position; CubitBoolean if_step_over = CUBIT_FALSE; while (size != 0) { if (init_size <= size) break; init_size = size; small_edge_angles_list.reset(); assert (size%2 == 0); double angle1, angle2; if (CUBIT_TRUE == preview || CUBIT_TRUE == if_step_over) { if_step_over = CUBIT_FALSE; for (i=0; i<index; i++) small_edge_angles_list.step(); } //find the vertex for each edge pair. edge_to_remove = small_edge_angles_list.get_and_step(); the_other_edge = small_edge_angles_list.get_and_step(); index += 2; assert (edge_to_remove != NULL && the_other_edge != NULL); vex_ptr = edge_to_remove->common_ref_vertex(the_other_edge); if (vex_ptr == NULL) { size -= 2; if_step_over = CUBIT_TRUE; continue; } //check to make sure there's one common refface between the edges. if(edge_to_remove->num_of_common_ref_face(the_other_edge) != 1) { PRINT_INFO("Curves %d and %d are not candidates for collapsing because\n", edge_to_remove->id(), the_other_edge->id()); PRINT_INFO("the two curves need to have exactly one common face.\n"); size -= 2; if_step_over = CUBIT_TRUE; continue; } //find the true to_be_removed edge angle1 = the_surface_angle(edge_to_remove, vex_ptr, length); angle2 = the_surface_angle(the_other_edge, vex_ptr, length); if (angle1 != -1.0 && angle2 != -1.0 && (fabs(angle1 - CUBIT_PI) > fabs(angle2 - CUBIT_PI))) exchange_edges(edge_to_remove, the_other_edge); else if (angle1 == -1.0 || angle2 == -1.0 || (fabs(angle1 - CUBIT_PI) == fabs(angle2 - CUBIT_PI))) { //curved curve has higher priority than straight curve. if ((edge_to_remove->geometry_type() == STRAIGHT_CURVE_TYPE) &&(the_other_edge->geometry_type() != STRAIGHT_CURVE_TYPE)) exchange_edges(edge_to_remove, the_other_edge); //shorter curve has higher priority than longer curve. else if (((edge_to_remove->geometry_type() != STRAIGHT_CURVE_TYPE) &&(the_other_edge->geometry_type() != STRAIGHT_CURVE_TYPE)) || ((edge_to_remove->geometry_type() == STRAIGHT_CURVE_TYPE) &&(the_other_edge->geometry_type() == STRAIGHT_CURVE_TYPE))) { if (edge_to_remove->get_arc_length() > the_other_edge->get_arc_length()) exchange_edges(edge_to_remove, the_other_edge); } }//else if // determine the length1 if (length >= (edge_to_remove->get_arc_length() - GEOMETRY_RESABS)) length1 = -1.0; else length1 = length; //determine the position on curve2 RefVertex * tmp_vertex = edge_to_remove->other_vertex(vex_ptr); CubitVector tmp_vec = tmp_vertex->coordinates(); if (length1 != -1.0) { result = position_from_length(edge_to_remove, vex_ptr, length1, tmp_vec); } the_other_edge->closest_point(tmp_vec, position); //check if position is within the_other_edge CubitBox position_box(position); CubitBox edge_box = the_other_edge->bounding_box(); // check if it's a preview command. if (CUBIT_TRUE == preview) { if (!position_box.overlap(0, edge_box)) draw_preview(vex_ptr, edge_to_remove, the_other_edge, length1, -1.0, CUBIT_FALSE, position); else draw_preview(vex_ptr, edge_to_remove, the_other_edge, length1, -1.0, CUBIT_TRUE, position); size -= 2; continue; } //collapse angle else if (!position_box.overlap(0, edge_box)) result = collapse_angle( vex_ptr, edge_to_remove, the_other_edge, length1, -1.0, CUBIT_FALSE, position); else result = collapse_angle( vex_ptr, edge_to_remove, the_other_edge, length1, length2, CUBIT_TRUE, position); if (result != CUBIT_SUCCESS) { result = CUBIT_SUCCESS; continue ; } if (if_comp_vertex) { DLIList<RefEdge*> edge_list; vex_ptr->ref_edges(edge_list); int id = vex_ptr->id(); if (edge_list.size() == 2) { DLIList<RefEdge*> composite_edges; max_angle *= (CUBIT_PI / 180); CompositeTool::instance()->composite(edge_list, composite_edges, NULL, max_angle); if (composite_edges.size() > 0) { DLIList<int> id_list; id_list.append(id); CubitUtil::list_entity_ids("Composite out of vertex ", id_list); } } } small_edge_angles_list.clean_out(); for (i=0; i < volume_list.size(); i++) { ref_volume = volume_list.get_and_step(); assert (ref_volume != NULL); GeomMeasureTool::find_interior_curve_angles(ref_volume, 360, angle, large_edge_angles_list, small_edge_angles_list, large_angles_list, small_angles_list, total_interior, total_fuzzy); } size = small_edge_angles_list.size(); }//while return result; }
CubitStatus CollapseAngleTool::collapse_angle | ( | RefVertex * | vex_ptr, |
RefEdge * | edge_to_remove, | ||
RefEdge * | the_other_edge, | ||
double | length1, | ||
double | length2, | ||
CubitBoolean | get_position, | ||
CubitVector & | position | ||
) | [private] |
Definition at line 681 of file CollapseAngleTool.cpp.
{ CubitStatus result = CUBIT_SUCCESS; RefVertex *new_vertex1 = edge_to_remove->other_vertex(vex_ptr); RefVertex *new_vertex2 = the_other_edge->other_vertex(vex_ptr); DLIList<RefFace*> ref_faces; edge_to_remove-> ref_faces(ref_faces); RefFace *common_face = NULL; DLIList<RefFace*> common_face_list; int nfaces = edge_to_remove->num_of_common_ref_face(the_other_edge); if (nfaces == 1) common_face = edge_to_remove->common_ref_face(the_other_edge); else { assert (nfaces == 2); edge_to_remove->common_ref_faces(the_other_edge, common_face_list); } if (length1 != -1.0) { result = partition_curve(edge_to_remove, vex_ptr, length1, new_vertex1); if (result != CUBIT_SUCCESS) { PRINT_ERROR("Operation failed at vertex %d, curve %d and curve %d.\n", vex_ptr->id(), edge_to_remove->id(), the_other_edge->id()); return result; } } if (get_position) { result = partition_curve(the_other_edge, NULL, position, new_vertex2); if (result != CUBIT_SUCCESS) { PRINT_ERROR("Operation failed at vertex %d, curve %d and curve %d.\n", vex_ptr->id(), edge_to_remove->id(), the_other_edge->id()); return result; } } else if (!get_position && length2 != -1.0) { result = partition_curve(the_other_edge, vex_ptr, length2, new_vertex2); if (result != CUBIT_SUCCESS) { PRINT_ERROR("Operation failed at vertex %d, curve %d and curve %d.\n", vex_ptr->id(), edge_to_remove->id(), the_other_edge->id()); return result; } } if (nfaces > 1) //determine the common face. { CubitBox edge_box(new_vertex1->coordinates()); edge_box |= new_vertex2->bounding_box(); CubitBox face_box1, face_box2; RefFace *face1, *face2; face1 = common_face_list.get_and_step(); face2 = common_face_list.get(); face_box1 = face1->bounding_box(); face_box2 = face2->bounding_box(); if(edge_box.overlap(0, face_box1)) { // Face 1 overlaps with the partition points. if(edge_box.overlap(0, face_box2)) { // Both face 1 and face 2 overlap with the parition points. // We must do a further check to try to choose the best one. // Take the mid point between the two vertices and calculate // the distance from both faces. Choose the one with the // smaller distance. This approach was chosen because there // was a case where one of the potential common faces was // actually a composite that had a 90 degree turn in it // so that the end points of the edge that would be used // to partition it fell on the composite surface but the // rest of the interior of the edge didn't lie on the surface. // However, the edge completely lied on the other potential // surface and so it was the better candidate. CubitVector mid_pos = (new_vertex1->coordinates() + new_vertex2->coordinates())/2; Surface *surf1 = face1->get_surface_ptr(); Surface *surf2 = face2->get_surface_ptr(); if(surf1 && surf2) { CubitVector pos1, pos2; surf1->closest_point(mid_pos, &pos1); surf2->closest_point(mid_pos, &pos2); if((mid_pos - pos1).length_squared() < (mid_pos - pos2).length_squared()) { common_face = face1; } else { common_face = face2; } } else { PRINT_ERROR("Operation failed because one of the potential common faces doesn't have a surface.\n"); return CUBIT_FAILURE; } } else { // Only face 1 overlaps so use it as the common face. common_face = face1; } } else if(edge_box.overlap(0, face_box2)) { // Only face 2 overlaps so use it as the common face. common_face = face2; } else { // Neither face overlaps so throw an error. PRINT_ERROR("Operation failed to find a valid common face for partitioning.\n"); return CUBIT_FAILURE; } } CubitBoolean partition_surface_ = CUBIT_FALSE; // check if edge_to_remove is the only one that shares the two surfaces. if (length1 == -1.0) partition_surface_ = if_partition_surf(vex_ptr, edge_to_remove, common_face); RefFace * face_to_remove = common_face; if (length1 != -1.0 || get_position || length2 != -1.0 || partition_surface_) { RefFace *result_face; result = partition_surface(common_face, edge_to_remove, vex_ptr, new_vertex1, new_vertex2, result_face); if (result != CUBIT_SUCCESS) { PRINT_ERROR("Split of surface %d failed.\n", common_face->id()); PRINT_ERROR("Operation failed at vertex %d, curve %d and curve %d.\n", vex_ptr->id(), edge_to_remove->id(), the_other_edge->id()); return result; } DLIList<RefEdge*> ref_edges; result_face->ref_edges(ref_edges); int i; for (i = 0; i <ref_edges.size(); i++) if (ref_edges.get_and_step() == edge_to_remove) { face_to_remove = result_face; break; } } if (face_to_remove != common_face) { ref_faces.remove(common_face); ref_faces.append(face_to_remove); } DLIList<RefFace*> result_faces; CompositeTool::instance()->composite(ref_faces, result_faces); if( result_faces.size() > 0 ) { DLIList<int> id_list; int e; for( e = 0; e < result_faces.size(); e++) { id_list.append( result_faces.get_and_step()->id() ); CubitUtil::list_entity_ids("Created composite surfaces ", id_list ); } } else { PRINT_ERROR("Operation failed at vertex %d, curve %d and curve %d.\n", vex_ptr->id(), edge_to_remove->id(), the_other_edge->id()); result = CUBIT_FAILURE; } //composite out new_vertex1 DLIList<RefEdge*> edge_list; RefEdge* composite_edge = NULL; int id = new_vertex1->id(); new_vertex1->ref_edges(edge_list); if (edge_list.size() == 2) composite_edge = CompositeTool::instance()->composite(edge_list); if (composite_edge) { DLIList<int> id_list; id_list.append(id); CubitUtil::list_entity_ids("Composite out of vertex ", id_list); } return result; }
void CollapseAngleTool::collapse_one_angle | ( | RefVertex * | vex_ptr, |
CubitVector & | position, | ||
double | angle | ||
Definition at line 47 of file CollapseAngleTool.cpp.
{ if (CUBIT_TRUE == preview) draw_preview(vex_ptr, edge_to_remove, the_other_edge, length1, length2, get_position, position); else { CubitStatus result = CUBIT_SUCCESS; DLIList<RefFace*> ref_faces; edge_to_remove->ref_faces(ref_faces); RefFace *common_face = NULL; DLIList<RefFace*> common_face_list; int nfaces = edge_to_remove->num_of_common_ref_face(the_other_edge); if( nfaces == 0 ) return; if (nfaces == 1) common_face = edge_to_remove->common_ref_face(the_other_edge); else edge_to_remove->common_ref_faces(the_other_edge, common_face_list); if(common_face) common_face_list.append_unique( common_face ); bool undo_on = false; DLIList<Body*> bodies_to_note; if( CubitUndo::get_undo_enabled() ) { for( int k=0; k<common_face_list.size(); k++ ) bodies_to_note.append_unique( common_face_list[k]->body() ); CubitUndo::save_state_with_cubit_file( bodies_to_note ); undo_on = true; CubitUndo::set_undo_enabled( false ); } CubitStatus status = collapse_angle( vex_ptr, edge_to_remove, the_other_edge, length1, length2, get_position, position); if( CUBIT_FAILURE == status && undo_on ) { CubitUndo::set_undo_enabled( true ); CubitUndo::remove_last_undo(); return; } if (if_comp_vertex) { DLIList<RefEdge*> edge_list; vex_ptr->ref_edges(edge_list); if (edge_list.size() == 2) { DLIList<RefEdge*> composite_edges; angle *= (CUBIT_PI / 180); int id = vex_ptr->id(); CompositeTool::instance()->composite(edge_list, composite_edges, NULL, angle); if (composite_edges.size() > 0) { DLIList<int> id_list; id_list.append(id); CubitUtil::list_entity_ids("Composite out of vertex ", id_list); } } } if( undo_on ) CubitUndo::set_undo_enabled( true ); if( CubitUndo::get_undo_enabled() && CUBIT_SUCCESS == result ) CubitUndo::note_result_bodies( bodies_to_note ); else if( CubitUndo::get_undo_enabled() && CUBIT_FAILURE == result ) CubitUndo::remove_last_undo(); } }
CubitStatus CollapseAngleTool::draw_preview | ( | RefVertex * | vex_ptr, |
) | [private] |
Definition at line 519 of file CollapseAngleTool.cpp.
{ CubitStatus result = CUBIT_SUCCESS; //flush out previous drawing GfxDebug::display_all(); //wireframe display of future composite surface per design review. DLIList<RefFace*> ref_faces; edge_to_remove-> ref_faces(ref_faces); RefFace *common_face = edge_to_remove->common_ref_face(the_other_edge); assert(ref_faces.size() == 2); RefFace *highlight_surf = ref_faces.get_and_step(); if (highlight_surf == common_face) highlight_surf = ref_faces.get(); DLIList<RefEdge*> ref_edges; highlight_surf->ref_edges(ref_edges); ref_edges.remove(edge_to_remove); int i; for (i = 0; i < partly_drawn_curve.size(); i++) ref_edges.remove(partly_drawn_curve.get_and_step()); for(i = 0; i < ref_edges.size(); i++) GfxDebug::draw_ref_entity(ref_edges.get_and_step(), CUBIT_BLUE_INDEX); //check if there will be a cutting edge CubitBoolean if_partition = if_partition_surf(vex_ptr, edge_to_remove, common_face); if (length1 == -1.0 && !get_position && length2 == -1.0 && !if_partition) { ref_edges.clean_out(); common_face->ref_edges(ref_edges); ref_edges.remove(edge_to_remove); for (i = 0; i < partly_drawn_curve.size(); i++) ref_edges.remove(partly_drawn_curve.get_and_step()); for(i = 0; i < ref_edges.size(); i++) GfxDebug::draw_ref_entity(ref_edges.get_and_step(), CUBIT_BLUE_INDEX); return result; } CubitVector location, location2, location3; if (length1 == -1.0) location = edge_to_remove->other_vertex(vex_ptr)->coordinates(); if (length1 != -1.0) result = position_from_length(edge_to_remove, vex_ptr, length1, location); if ( !get_position && length2 == -1.0 && (length1 != -1.0 || (length1 == -1.0 && if_partition))) location2=the_other_edge->other_vertex(vex_ptr)->coordinates(); else if(get_position) location2 = position; else if (length2 != -1.0) result = position_from_length(the_other_edge, vex_ptr, length2, location2); GfxDebug::draw_line(location, location2, CUBIT_BLUE_INDEX); //Draw part of curves double length; CubitVector temp_vex; GPoint pts[5]; location3 = vex_ptr->coordinates(); partly_drawn_curve.append(the_other_edge); partly_drawn_curve.append(edge_to_remove); if (the_other_edge->geometry_type() == STRAIGHT_CURVE_TYPE) GfxDebug::draw_line(location3, location2, CUBIT_BLUE_INDEX); else { length = the_other_edge->get_arc_length(location2, location3); pts[0].x = location3.x(); pts[0].y = location3.y(); pts[0].z = location3.z(); pts[4].x = location2.x(); pts[4].y = location2.y(); pts[4].z = location2.z(); position_from_length(the_other_edge, vex_ptr, length/4, temp_vex); pts[1].x = temp_vex.x(); pts[1].y = temp_vex.y(); pts[1].z = temp_vex.z(); position_from_length(the_other_edge, vex_ptr, length/2, temp_vex); pts[2].x = temp_vex.x(); pts[2].y = temp_vex.y(); pts[2].z = temp_vex.z(); position_from_length(the_other_edge, vex_ptr, length*0.75, temp_vex); pts[3].x = temp_vex.x(); pts[3].y = temp_vex.y(); pts[3].z = temp_vex.z(); GfxDebug::draw_polyline(pts, 5, CUBIT_BLUE_INDEX); } RefVertex *vertex = edge_to_remove->other_vertex(vex_ptr); location3 = vertex->coordinates(); if (edge_to_remove->geometry_type() == STRAIGHT_CURVE_TYPE) GfxDebug::draw_line(location3, location, CUBIT_BLUE_INDEX); else { length = edge_to_remove->get_arc_length(location, location3); pts[0].x = location3.x(); pts[0].y = location3.y(); pts[0].z = location3.z(); pts[4].x = location.x(); pts[4].y = location.y(); pts[4].z = location.z(); position_from_length(edge_to_remove, vertex, length/4, temp_vex); pts[1].x = temp_vex.x(); pts[1].y = temp_vex.y(); pts[1].z = temp_vex.z(); position_from_length(edge_to_remove, vertex, length/2, temp_vex); pts[2].x = temp_vex.x(); pts[2].y = temp_vex.y(); pts[2].z = temp_vex.z(); position_from_length(edge_to_remove, vertex, length*0.75, temp_vex); pts[3].x = temp_vex.x(); pts[3].y = temp_vex.y(); pts[3].z = temp_vex.z(); GfxDebug::draw_polyline(pts, 5, CUBIT_BLUE_INDEX); } GfxDebug::flush(); return result; }
void CollapseAngleTool::exchange_edges | ( | RefEdge *& | edge, |
RefEdge *& | the_other_edge | ||
) | [private] |
Definition at line 361 of file CollapseAngleTool.cpp.
{ RefEdge* temp_edge; temp_edge = edge; edge = the_other_edge; the_other_edge = temp_edge; }
CubitBoolean CollapseAngleTool::if_partition_surf | ( | RefVertex * | vex_ptr, |
RefFace * | common_face | ||
) | [private] |
Definition at line 661 of file CollapseAngleTool.cpp.
{ CubitBoolean partition_surface_ =CUBIT_FALSE; RefVertex *temp_vtx = NULL; RefEdge * temp_edge = NULL; if (edge_to_remove->start_vertex() == vex_ptr) temp_vtx = edge_to_remove->end_vertex(); else temp_vtx = edge_to_remove->start_vertex(); temp_edge = edge_to_remove->get_other_curve(temp_vtx, common_face); if (temp_edge->num_of_common_ref_face(edge_to_remove) > 1) partition_surface_ = CUBIT_TRUE; return partition_surface_; }
CollapseAngleTool * CollapseAngleTool::instance | ( | void | ) | [static] |
Definition at line 40 of file CollapseAngleTool.cpp.
{ if (instance_ == NULL) instance_ = new CollapseAngleTool(); return instance_; }
CubitStatus CollapseAngleTool::partition_curve | ( | RefEdge *& | edge, |
RefVertex * | root_vertex, | ||
RefVertex *& | new_vertex | ||
) | [private] |
Definition at line 423 of file CollapseAngleTool.cpp.
{ CubitStatus result = CUBIT_SUCCESS; DLIList<CubitVector*> vect_list; vect_list.append( new CubitVector( position ) ); DLIList<RefVertex*> vertex_list; RefVertex* the_vertex = NULL; edge->ref_vertices(vertex_list); if (vertex_list.size() == 1) the_vertex = vertex_list.get(); DLIList<RefEdge*> tmp_list; result = PartitionTool::instance()-> partition( edge, vect_list, tmp_list ); delete vect_list.pop(); if (!result) { PRINT_ERROR("Split of curve %d failed.\n", edge->id()); return result; } //Only change new_vertex when the partition succeeds. RefEdge *temp_edge = tmp_list.get_and_step(); if (NULL != the_vertex) { new_vertex = temp_edge->other_vertex(the_vertex); double len1 = temp_edge->get_arc_length(); double len2 = tmp_list.get()->get_arc_length(); if (len1 > len2) edge = tmp_list.get(); else edge = temp_edge; } else if (temp_edge != edge) { new_vertex = edge->common_ref_vertex(temp_edge); if (root_vertex && edge->start_vertex() != root_vertex && edge->end_vertex() != root_vertex) edge = temp_edge; } else { new_vertex = edge->common_ref_vertex(tmp_list.get()); if (root_vertex && edge->start_vertex() != root_vertex && edge->end_vertex() != root_vertex) edge = tmp_list.get(); } return result; }
double | arc_length, | ||
) | [private] |
Definition at line 408 of file CollapseAngleTool.cpp.
{ CubitStatus result = CUBIT_SUCCESS; CubitVector v_new; result = position_from_length(edge, root_vertex, arc_length, v_new); if (result == CUBIT_SUCCESS) result = partition_curve(edge, root_vertex, v_new, new_vertex); return result; }
CubitStatus CollapseAngleTool::partition_surface | ( | RefFace * | common_face, |
RefEdge *& | edge, | ||
RefVertex * | root, | ||
RefVertex * | vertex1, | ||
RefVertex * | veretx2, | ||
RefFace *& | result_face | ||
) | [private] |
Definition at line 476 of file CollapseAngleTool.cpp.
{ CubitStatus result = CUBIT_SUCCESS; DLIList<CubitVector*> positions; positions.append(new CubitVector(vertex1->get_point_ptr()->coordinates())); positions.append(new CubitVector(vertex2->get_point_ptr()->coordinates())); DLIList<RefEdge*> new_edges; result_face = PartitionTool::instance()-> insert_edge( common_face, positions, CUBIT_FALSE, new_edges ); // make sure that we actually get something out of insert_edge if (new_edges.size() == 0) { if (positions[0]) delete positions[0]; if (positions[1]) delete positions[1]; return CUBIT_FAILURE; } RefEdge *new_edge = new_edges.get(); if(new_edge) { RefVertex * start = new_edge->start_vertex(); RefVertex * end = new_edge->end_vertex(); if (start != vertex1 && end != vertex1) edge_to_remove = root->common_ref_edge(start == vertex2 ? end : start); } delete positions.get_and_step(); delete positions.get(); if( result_face == NULL ) result = CUBIT_FAILURE; return result; }
CubitStatus CollapseAngleTool::position_from_length | ( | RefEdge * | edge, |
CubitVector & | v_new | ||
) | [private] |
Definition at line 393 of file CollapseAngleTool.cpp.
{ CubitStatus result; double sense = 1.0; if (root_vertex != edge->start_vertex()) sense = -1.0; CubitVector v_root = root_vertex->get_point_ptr()->coordinates(); result = edge->point_from_arc_length(v_root, arc_length*sense, v_new); return result; }
double CollapseAngleTool::the_surface_angle | ( | RefEdge * | edge, |
double | length | ||
) | [private] |
Definition at line 370 of file CollapseAngleTool.cpp.
{ DLIList <RefFace *> ref_faces; double arc_length = length/2; double fraction; if (length > edge->get_arc_length()) arc_length = edge->get_arc_length()/2; fraction = edge->fraction_from_arc_length(root_vertex, arc_length); edge->ref_faces(ref_faces); if (ref_faces.size() != 2) return -1.0; double angle = GeometryQueryTool::instance()-> surface_angle(ref_faces.get_and_step(),ref_faces.get(), edge, NULL, fraction); return angle; }
CollapseAngleTool * CollapseAngleTool::instance_ = NULL [static, private] |
Definition at line 49 of file CollapseAngleTool.hpp.
DLIList<RefEdge *> CollapseAngleTool::partly_drawn_curve [private] |
Definition at line 52 of file CollapseAngleTool.hpp.
