cgma
TDOctreeRefFace Class Reference
#include <TDOctreeRefFace.hpp>
Inheritance diagram for TDOctreeRefFace:
ToolData
List of all members.
Public Member Functions
 TDOctreeRefFace ()
 ~TDOctreeRefFace ()
CubitBoolean get_visit (void) const
void set_visit (CubitBoolean type)
void set_create_2dmat (const CubitBoolean new_val)
CubitBoolean get_create_2dmat ()
void set_ref_face (RefFace *ptr_ref_face)
void append_list_item (int loop_id)
void set_last_curve_id (int id)
DLIList< CubitPoint * > * get_ptr_cubit_point_list ()
void set_ptr_cubit_point_list (DLIList< CubitPoint * > *ptr_cubit_point_list)
DLIList< CubitFacetEdge * > * get_ptr_cubit_facet_edge_list ()
void set_ptr_cubit_facet_edge_list (DLIList< CubitFacetEdge * > *ptr_cubit_facet_edge_list)
DLIList< CubitFacet * > * get_ptr_cubit_facet_list ()
void set_ptr_cubit_facet_list (DLIList< CubitFacet * > *ptr_cubit_facet_list)
CubitBoolean is_adj_curves (int id1, int id2)
CubitFacetsplit_facet_into_two_facets (CubitFacet *target_facet, CubitPoint *edge1_pt, CubitPoint *edge2_pt, CubitFacetEdge *boundary_edge, CubitPoint *new_pt, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &facet_edge_list, DLIList< CubitPoint * > &point_list)
CubitBoolean split_facet_locally_along_edge (CubitFacet *target_facet, CubitPoint *edge1_pt, CubitPoint *edge2_pt, CubitFacetEdge *boundary_edge, int num_of_segments, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &facet_edge_list, DLIList< CubitPoint * > &point_list)
CubitBoolean split_facet_type_00 (CubitFacet *target_facet, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &facet_edge_list, DLIList< CubitPoint * > &point_list)
CubitBoolean split_facet_type_01 (CubitFacet *target_facet, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &facet_edge_list, DLIList< CubitPoint * > &point_list)
CubitBoolean split_facet_type_02 (CubitFacet *target_facet, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &facet_edge_list, DLIList< CubitPoint * > &point_list)
CubitBoolean split_facet_type_03 (CubitFacet *target_facet, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &facet_edge_list, DLIList< CubitPoint * > &point_list)
CubitBoolean split_facet_type_12 (CubitFacet *target_facet, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &facet_edge_list, DLIList< CubitPoint * > &point_list)
CubitBoolean split_facet_type_13 (CubitFacet *target_facet, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &facet_edge_list, DLIList< CubitPoint * > &point_list)
CubitBoolean split_facet_type_23 (CubitFacet *target_facet, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &facet_edge_list, DLIList< CubitPoint * > &point_list)
CubitBoolean split_facet_type_33 (CubitFacet *target_facet, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &facet_edge_list, DLIList< CubitPoint * > &point_list)
CubitBoolean check_valid_facets (CubitBoolean disable_if_bad)
Static Public Member Functions
static int is_td_octree_ref_face (const ToolData *td)
static CubitStatus add_td (RefFace *ref_face)
static TDOctreeRefFaceget_td (RefFace *ref_face)
Private Attributes
DLIList< CubitPoint * > * ptrCubitPointList
DLIList< CubitFacetEdge * > * ptrCubitFacetEdgeList
DLIList< CubitFacet * > * ptrCubitFacetList
RefFacerefFace
DLIList< int > loopIndex
int lastCurveID
CubitBoolean visit
CubitBoolean create_2dmat
Detailed Description
Definition at line 25 of file TDOctreeRefFace.hpp.
Member Function Documentation
CubitStatus TDOctreeRefFace::add_td ( RefFace ref_face) [static]
Definition at line 67 of file TDOctreeRefFace.cpp.
  ToolData *td;
  td = ref_face->get_TD(&TDOctreeRefFace::is_td_octree_ref_face);
  if ( td == NULL )
    TDOctreeRefFace *td_gm = new TDOctreeRefFace;
    ref_face->add_TD( td_gm);
    td_gm->set_ref_face( ref_face );
  else
    TDOctreeRefFace *td_gm = CAST_TO(td, TDOctreeRefFace);
  return CUBIT_SUCCESS;
void TDOctreeRefFace::append_list_item ( int  loop_id) [inline]
Definition at line 68 of file TDOctreeRefFace.hpp.
{ loopIndex.append(loop_id); }
Definition at line 479 of file TDOctreeRefFace.cpp.
  int i;
  CubitBoolean good_facets = CUBIT_TRUE;
  CubitFacetEdge *facet_edge;
  for (i=0; i < ptrCubitFacetEdgeList->size(); ++i)
    facet_edge = ptrCubitFacetEdgeList->get_and_step();
    if (facet_edge->num_adj_facets() > 2)
      good_facets = CUBIT_FALSE;
      break;
  if (disable_if_bad && !good_facets) {set_create_2dmat(CUBIT_FALSE);}
  return good_facets;
Definition at line 64 of file TDOctreeRefFace.hpp.
{return create_2dmat;}
Definition at line 82 of file TDOctreeRefFace.hpp.
{ return ptrCubitFacetList; }
Definition at line 76 of file TDOctreeRefFace.hpp.
{ return ptrCubitPointList; }
TDOctreeRefFace * TDOctreeRefFace::get_td ( RefFace ref_face) [static]
Definition at line 95 of file TDOctreeRefFace.cpp.
  ToolData *td;
  if ( td != NULL )
    return td_gm;
  return (TDOctreeRefFace*) NULL;
CubitBoolean TDOctreeRefFace::get_visit ( void  ) const [inline]
Definition at line 60 of file TDOctreeRefFace.hpp.
{ return visit; }
CubitBoolean TDOctreeRefFace::is_adj_curves ( int  id1,
int  id2
Definition at line 106 of file TDOctreeRefFace.cpp.
  int loop_index1, loop_index2;
  int i;
  int first_curve_id, last_curve_id, start_curve_id;
  loopIndex.reset();
  loop_index1 = CUBIT_INT_MAX;
    // i indicates loop index
  for( i = 0; i < loopIndex.size(); i++ ){
    start_curve_id = loopIndex.get_and_step();
    if( id1 < start_curve_id ){
      loop_index1 = i - 1;
      break;
  if( loop_index1 == CUBIT_INT_MAX ){
  loopIndex.reset();
  loop_index2 = CUBIT_INT_MAX;
    if( id2 < start_curve_id ){
      loop_index2 = i - 1;
      break;
  if( loop_index2 == CUBIT_INT_MAX ){
  if( loop_index1 != loop_index2 ){
      // curves are not in same loop
    return CUBIT_FALSE;
  else{
    if( abs(id1 - id2) == 1 ){
        // adj curves of same loop
      return CUBIT_TRUE;
    loopIndex.reset();
    loopIndex.step( loop_index1 );
    first_curve_id = loopIndex.get_and_step();
    last_curve_id = loopIndex.get() - 1;
    if( last_curve_id < first_curve_id ){
//      PRINT_DEBUG_157(" id1 = %d and id2 = %d", id1, id2 );
//      PRINT_DEBUG_157(" Note: Last curve id ( %d ) is less than first curve id ( %d ) \n", last_curve_id, first_curve_id );
      last_curve_id = lastCurveID;
//      PRINT_DEBUG_157(" last_curve_id is reset to %d \n", lastCurveID );
    if( abs(id1 - id2) == (last_curve_id - first_curve_id ) ){
        // firs and last curve of same loop
      return CUBIT_TRUE;
      // part of same curve
    if( abs(id1 - id2) == 0 ){
      return CUBIT_TRUE;
      // same loop but non-adj curves
    return CUBIT_FALSE;
static int TDOctreeRefFace::is_td_octree_ref_face ( const ToolData td) [inline, static]
Definition at line 70 of file TDOctreeRefFace.hpp.
      {return (CAST_TO(const_cast<ToolData*>(td), TDOctreeRefFace) != NULL);}
void TDOctreeRefFace::set_create_2dmat ( const CubitBoolean  new_val) [inline]
Definition at line 63 of file TDOctreeRefFace.hpp.
{create_2dmat = new_val;}
void TDOctreeRefFace::set_last_curve_id ( int  id) [inline]
Definition at line 73 of file TDOctreeRefFace.hpp.
{ lastCurveID = id; }
void TDOctreeRefFace::set_ptr_cubit_facet_edge_list ( DLIList< CubitFacetEdge * > *  ptr_cubit_facet_edge_list) [inline]
Definition at line 80 of file TDOctreeRefFace.hpp.
{ ptrCubitFacetEdgeList = ptr_cubit_facet_edge_list; }
void TDOctreeRefFace::set_ptr_cubit_facet_list ( DLIList< CubitFacet * > *  ptr_cubit_facet_list) [inline]
Definition at line 83 of file TDOctreeRefFace.hpp.
{ ptrCubitFacetList = ptr_cubit_facet_list; }
void TDOctreeRefFace::set_ptr_cubit_point_list ( DLIList< CubitPoint * > *  ptr_cubit_point_list) [inline]
Definition at line 77 of file TDOctreeRefFace.hpp.
{ ptrCubitPointList = ptr_cubit_point_list; }
void TDOctreeRefFace::set_ref_face ( RefFace ptr_ref_face) [inline]
Definition at line 66 of file TDOctreeRefFace.hpp.
{ refFace = ptr_ref_face; }
void TDOctreeRefFace::set_visit ( CubitBoolean  type) [inline]
Definition at line 61 of file TDOctreeRefFace.hpp.
{ visit = type; }
CubitFacet * TDOctreeRefFace::split_facet_into_two_facets ( CubitFacet target_facet,
CubitPoint edge1_pt,
CubitPoint edge2_pt,
CubitFacetEdge boundary_edge,
CubitPoint new_pt,
DLIList< CubitFacet * > &  facet_list,
DLIList< CubitFacetEdge * > &  facet_edge_list,
DLIList< CubitPoint * > &  point_list
Definition at line 304 of file TDOctreeRefFace.cpp.
    //add new_pt to point_list
  point_list.append( new_pt );
  new_pt->marked( abs( edge->marked() ));
    // split triangle
  CubitFacetData* facet_d = dynamic_cast<CubitFacetData*>(target_facet);
  assert(!!facet_d);
    // fix up existing facet
  int pt2_index = target_facet->point_index( edge2_pt );
  bool edge_reversed = ( edge1_pt == target_facet->point( (pt2_index+1) % 3 ) );
  int edge_index = (pt2_index + 1 + edge_reversed) % 3;
  edge2_pt->remove_facet( target_facet );
  facet_d->set_point( new_pt, pt2_index );
  new_pt->add_facet( target_facet );
  target_facet->update_plane();
    // make new facet and update facet list
  CubitPoint* other_pt = target_facet->point( edge_index );
  CubitFacetData* new_facet;
  if( edge_reversed )
    new_facet = new CubitFacetData( other_pt, edge2_pt, new_pt );
  else
    new_facet = new CubitFacetData( other_pt, new_pt, edge2_pt );
    // facet constructor takes care of this
    // update the facets in points
    // this takes care of adj facets of new edges and
    // conversely edges of two facets
    //edge2_pt->add_facet( new_facet );
    //new_pt->add_facet( new_facet );
    //other_pt->add_facet( new_facet );
    // Facets list in the points should be updated before creating new edge
    // the edge constructor generates adjacet facets.
    // split edge, if there is one
    //CubitFacetEdge* edge = edge1_pt->shared_edge( edge2_pt );
  CubitFacetEdgeData* new_edge = 0;
  if( edge ){
    CubitFacetEdgeData* edge_d = dynamic_cast<CubitFacetEdgeData*>(edge);
    assert(!!edge_d);
      // make sure new edge has same orientation as old edge
    new_edge = dynamic_cast<CubitFacetEdgeData*>(new_pt->shared_edge(edge2_pt));
    if( edge->point(0) == edge1_pt ){
      edge_d->set_point(new_pt, 1);
      if ( !new_edge )
        new_edge = new CubitFacetEdgeData( new_pt, edge2_pt );
      else if( new_edge->point(0) != new_pt )
        new_edge->flip();
    else {
      edge_d->set_point(new_pt, 0);
      if ( !new_edge )
        new_edge = new CubitFacetEdgeData( edge2_pt, new_pt );
      else if( new_edge->point(1) != new_pt )
        new_edge->flip();
    new_edge->marked( abs( edge->marked() ) );
    facet_edge_list.append( new_edge );
  else{
    PRINT_INFO("ERROR:Edge is doesn't exist. Splitting is not possible");
  int sense;
      // constructor takes care of this
      if ( new_edge ) {
      assert(!new_facet->edge(0));
      new_facet->edge( new_edge, 0 );
      new_edge->add_facet( new_facet );
      sense = new_facet->point( 1 ) == new_edge->point(0) ? 1 : -1;
      new_facet->edge_use( sense, 0 );
    // facet_list appended
  facet_list.append( new_facet );
    // move other edge, if there is one
  int pt1_index = ( pt2_index + 2 - edge_reversed ) % 3;
  CubitFacetEdge* other_edge = target_facet->edge( pt1_index );
  int e_index;
  if( other_edge ){
    other_edge->remove_facet(target_facet);
      //target_facet->edge( 0, pt1_index );
    e_index = 1 + edge_reversed;
    assert(!new_facet->edge(e_index));
    new_facet->edge( other_edge, e_index );
    other_edge->add_facet( new_facet );
    sense = new_facet->point( ( e_index + 1 ) % 3 ) == other_edge->point(0) ? 1 : -1;
    new_facet->edge_use( sense, e_index );
    // Add new mid edge in two facets
  CubitFacetEdgeData *new_mid_edge_data;
  CubitFacetEdge *new_mid_edge;
  if( edge_reversed )
    new_mid_edge_data = new CubitFacetEdgeData( other_pt, new_pt );
  else
    new_mid_edge_data = new CubitFacetEdgeData( new_pt, other_pt );
  new_mid_edge = CAST_TO( new_mid_edge_data, CubitFacetEdge );
  new_mid_edge->marked(2);
    // new_mid_edge is appended
  facet_edge_list.append( new_mid_edge );
    /* ////edge constructor takes care of this
       target_facet->edge( new_mid_edge, pt1_index );
       if( !edge_reversed ){  // new_mid_edge index 2
       new_facet->edge( new_mid_edge, ( e_index + 1 ) % 3 );
       sense = new_facet->point( ( e_index + 2 ) % 3 ) == new_mid_edge->point(0) ? 1 : -1;
       new_facet->edge_use( sense, (e_index + 1 ) % 3);
       else{ // edge index 1
       new_facet->edge( new_mid_edge, ( e_index - 1 ) % 3 );
       sense = new_facet->point( ( e_index  ) % 3 ) == new_mid_edge->point(0) ? 1 : -1;
       new_facet->edge_use( sense, (e_index - 1 ) % 3);
#ifndef NDEBUG
    /* ---------------------- TESTING ----------------------- */
    // Testing the oerientation of faces w.r.t. the common edge
  int index0, index1;
  if( new_mid_edge->num_adj_facets() != 2 ){
    PRINT_INFO("ERROR:number of adjacent faces of new mid edge is not equal to 2 \n");
    assert(0);
  CubitFacet *ptr_facet0 = new_mid_edge->adj_facet(0);
  CubitFacet *ptr_facet1 = new_mid_edge->adj_facet(1);
  for( index0 = 0; index0 < 3; index0++ ){
    if( ptr_facet0->edge(index0) == new_mid_edge )
      break;
  for( index1 = 0; index1 < 3; index1++ ){
    if( ptr_facet1->edge(index1) == new_mid_edge )
      break;
  if( index0 == 3 || index1 == 3 ){
    PRINT_INFO("ERROR: new edge doesn't exist at the adjacent facets \n");
    assert(0);
  if( ptr_facet0->edge_use(index0) == ptr_facet1->edge_use(index1) ){
    PRINT_INFO("ERROR: The orientation of edges is adjacent facet is not proper \n");
    assert(0);
#endif
    //PRINT_DEBUG_157("Passes\n");
  return CAST_TO( new_facet, CubitFacet );
CubitBoolean TDOctreeRefFace::split_facet_locally_along_edge ( CubitFacet target_facet,
Definition at line 280 of file TDOctreeRefFace.cpp.
  int i;
  CubitFacet *new_facet;
  CubitVector position, delta_length;
  delta_length = (edge2_pt->coordinates() - edge1_pt->coordinates()) / num_of_segments;
  for( i = num_of_segments - 1; i >= 1; i-- ){
    position = edge1_pt->coordinates() + ( delta_length * i );
    CubitPointData* new_pt_data = new CubitPointData( position );
      // update TD and append the list
    CubitPoint *new_pt = CAST_TO(new_pt_data, CubitPoint);
    new_facet = split_facet_into_two_facets( target_facet, edge1_pt, edge2_pt, ptr_edge, new_pt, facet_list, facet_edge_list, point_list );
      // mark the newly created facets so that they are not checked for
      // further splitting.  "this" facet is marked in Octree.cpp.
    new_facet->marked( -1 );
    edge2_pt = new_pt;
  return CUBIT_TRUE;
CubitBoolean TDOctreeRefFace::split_facet_type_00 ( CubitFacet target_facet,
CubitBoolean TDOctreeRefFace::split_facet_type_01 ( CubitFacet target_facet,
CubitBoolean TDOctreeRefFace::split_facet_type_02 ( CubitFacet target_facet,
CubitBoolean TDOctreeRefFace::split_facet_type_03 ( CubitFacet target_facet,
Definition at line 177 of file TDOctreeRefFace.cpp.
    // Do Nothing
    // During CAT centroid will give the approximate branch point
  return CUBIT_TRUE;
CubitBoolean TDOctreeRefFace::split_facet_type_12 ( CubitFacet target_facet,
CubitBoolean TDOctreeRefFace::split_facet_type_13 ( CubitFacet target_facet,
Definition at line 184 of file TDOctreeRefFace.cpp.
  int i;
  CubitFacetEdge *boundary_edge = NULL, *ptr_edge;
  CubitPoint *boundary_edge_pnt0, *boundary_edge_pnt1, *other_boundary_point;
  double internal_angle;
  int num_of_segments;
  for( i = 0; i < 3; i++ ){
    ptr_edge = target_facet->edge(i);
    if( abs( ptr_edge->marked() ) == 1 ){
      boundary_edge = ptr_edge;
      break;
  boundary_edge_pnt0 = boundary_edge->point(0);
  boundary_edge_pnt1 = boundary_edge->point(1);
    other_boundary_point = target_facet->point(i);
    if( other_boundary_point->id() != boundary_edge_pnt0->id() &&  other_boundary_point->id() != boundary_edge_pnt1->id() ){
      break;
  internal_angle = target_facet->angle( other_boundary_point );
  num_of_segments = (int)(floor( (internal_angle / (FACET_SPLITTING_INTERNAL_ANGLE )) + 0.5));
  if( num_of_segments > 1 )
    split_facet_locally_along_edge( target_facet, boundary_edge_pnt0, boundary_edge_pnt1, boundary_edge, num_of_segments, facet_list, facet_edge_list, point_list );
  return CUBIT_TRUE;
CubitBoolean TDOctreeRefFace::split_facet_type_23 ( CubitFacet target_facet,
Definition at line 219 of file TDOctreeRefFace.cpp.
  int i;
  CubitFacetEdge *ptr_edge, *boundary_edge1, *boundary_edge2 = NULL,
      *boundary_split_edge;
  CubitPoint *other_boundary_point;
  boundary_edge1 = NULL;
      if( boundary_edge1 == NULL ){
        boundary_edge1 = ptr_edge;
      else{
        boundary_edge2 = ptr_edge;
        break;
  CubitFacetEdgeData *boundary_edge1_data = dynamic_cast<CubitFacetEdgeData*>( boundary_edge1 );
  CubitFacetEdgeData *boundary_edge2_data = dynamic_cast<CubitFacetEdgeData*>( boundary_edge2 );
  if( boundary_edge1_data->length() > boundary_edge2_data->length() ){
    boundary_split_edge = boundary_edge1;
  else{
    boundary_split_edge = boundary_edge2;
    if( other_boundary_point->id() != boundary_split_edge->point(0)->id() &&  other_boundary_point->id() != boundary_split_edge->point(1)->id() ){
      break;
    split_facet_locally_along_edge( target_facet, boundary_split_edge->point(0), boundary_split_edge->point(1), boundary_split_edge, num_of_segments, facet_list, facet_edge_list, point_list );
  return CUBIT_TRUE;
CubitBoolean TDOctreeRefFace::split_facet_type_33 ( CubitFacet target_facet,
Definition at line 270 of file TDOctreeRefFace.cpp.
    // Do Nothing
    // WARNING: Degenerate Case
    // A triangualar surface patch is a facet.
    // Skeleton should be calculated by taking circum/in center and radius.
  return CUBIT_TRUE;
Member Data Documentation
Definition at line 50 of file TDOctreeRefFace.hpp.
Definition at line 42 of file TDOctreeRefFace.hpp.
Definition at line 40 of file TDOctreeRefFace.hpp.
Definition at line 36 of file TDOctreeRefFace.hpp.
Definition at line 32 of file TDOctreeRefFace.hpp.
Definition at line 38 of file TDOctreeRefFace.hpp.
Definition at line 44 of file TDOctreeRefFace.hpp.
