cgma
CubitOctreeConstants.hpp File Reference
#include "CubitDefines.h"
Enumerations
enum  CubitOctreeType { CUBIT_OCTREE_VOLUME, CUBIT_OCTREE_FACE, CUBIT_OCTREE_EDGE }
enum  OctreePosition {
  O_UNSET = -1, O_LEFT, O_RIGHT, O_BOTTOM,
  O_TOP, O_BACK, O_FRONT
enum  OctreeNodeConstant {
  NODE_SIZE, NODE_FACE_NUM, NODE_DISTANCE, NODE_NORMAL,
  NODE_TENSOR, NODE_ELEM_TENSOR
enum  OctreeSourceEntityType { OCTREE_SIZE_DEFAULT = 0 }
enum  InterpolationMode {
  INVERSE_SIZE, INVERSE_DISTANCE, INVERSE_SIZE_DISTANCE, MIN_DISTANCE,
  MIN_SIZE, AVERAGE
enum  InterpolationType { INVERSE_LINEAR, INVERSE_QUADRATIC, INVERSE_CUBIC }
enum  InterpolationModeInsideCell {
  TRILINEAR_INTERPOLATION_INSIDE_CELL, INVERSE_DISTANCE_INTERPOLATION_INSIDE_CELL, MIN_DISTANCE_INTERPOLATION_INSIDE_CELL, MIN_SIZE_INTERPOLATION_INSIDE_CELL,
  INVERSE_SQUARE_DISTANCE_INTERPOLATION_INSIDE_CELL
enum  SizeType { MESH_SIZE, SCALED_SIZE }
enum  DistanceMetric { PROJECTED_DIST, CAPSULE_DIST, MANHATTAN_DIST }
enum  IntersectionMethod { GRID_EDGE_INT, SAT_INTERSECT }
Variables
const int OCTREE_X = 0
const int OCTREE_Y = 1
const int OCTREE_Z = 2
const int MAX_NUM_ZERO_SIZE_NODES = 2
const int CUTOFF_OCTREE_DEPTH = 3
const int CUTOFF_BBOX_RANGE_RATIO = 17
const int CUTOFF_NUM_NODES = 250
const int MIN_DEPTH_OCTREE [4] = { 0, 2, 5, 5}
const int MAX_DEPTH_OCTREE [4] = { 0, 7, 7, 7}
const int INCR_DEPTH_OCTREE_FOR_SKELETON = 0
const int OCTREE_MIN_DEPTH_OCTREE [4] = { 0, MIN_DEPTH_OCTREE[1] + INCR_DEPTH_OCTREE_FOR_SKELETON,MIN_DEPTH_OCTREE[2] + INCR_DEPTH_OCTREE_FOR_SKELETON, MIN_DEPTH_OCTREE[3] + INCR_DEPTH_OCTREE_FOR_SKELETON}
const int OCTREE_MAX_DEPTH_OCTREE [4] = { 0, MAX_DEPTH_OCTREE[1] + INCR_DEPTH_OCTREE_FOR_SKELETON,MAX_DEPTH_OCTREE[2] + INCR_DEPTH_OCTREE_FOR_SKELETON, MAX_DEPTH_OCTREE[3] + INCR_DEPTH_OCTREE_FOR_SKELETON}
const double OCTREE_TOLERANCE_FOR_CURVE_DECIMATION_FACTOR = 0.5
const int OCTREE_TIME_ACCURACY_LEVEL = 2
const double FACET_SPLITTING_INTERNAL_ANGLE = 10.0 * CUBIT_PI / 180.0
const double OCTREE_EPSILON = 0.000001
const CubitBoolean OCTREE_POSITIVE = CUBIT_TRUE
const CubitBoolean OCTREE_NEGATIVE = CUBIT_FALSE
const InterpolationType DEFAULT_INVERSE_DISTANCE_SCHEME_INSIDE_CELL = INVERSE_LINEAR
const InterpolationModeInsideCell DEFAULT_INTERPOLATION_INSIDE_CELL = INVERSE_SQUARE_DISTANCE_INTERPOLATION_INSIDE_CELL
const IntersectionMethod OCTREE_DEFAULT_INTERSECTION_METHOD [4] = { (IntersectionMethod)0, SAT_INTERSECT, SAT_INTERSECT, SAT_INTERSECT}
const DistanceMetric defaultDistanceMetric = CAPSULE_DIST
const double N_CLOSEST_FACETS_FACTOR_FOR_FRONT_NORMALS = 1.00
const double ANGLE_BETWEEN_FACETS_NORMAL_FOR_OCTREE_BASED_ON_SURF_CURVATURE_FACTOR = 0.5
const double SLENDER_FACET_INTERNAL_ANGLE = 10.0 * CUBIT_PI / 180.0
const double ANG_FACET_EXTRACT [4] = { 15.0, 15.0, 10.0, 5.0 }
Enumeration Type Documentation
Enumerator:
CUBIT_OCTREE_VOLUME
CUBIT_OCTREE_FACE
CUBIT_OCTREE_EDGE
Definition at line 34 of file CubitOctreeConstants.hpp.
Enumerator:
PROJECTED_DIST
CAPSULE_DIST
MANHATTAN_DIST
Definition at line 81 of file CubitOctreeConstants.hpp.
Enumerator:
INVERSE_SIZE
INVERSE_DISTANCE
MIN_DISTANCE
MIN_SIZE
AVERAGE
Definition at line 66 of file CubitOctreeConstants.hpp.
Enumerator:
Definition at line 73 of file CubitOctreeConstants.hpp.
Enumerator:
INVERSE_LINEAR
INVERSE_QUADRATIC
INVERSE_CUBIC
Definition at line 69 of file CubitOctreeConstants.hpp.
Enumerator:
GRID_EDGE_INT
SAT_INTERSECT
Definition at line 84 of file CubitOctreeConstants.hpp.
Enumerator:
NODE_SIZE
NODE_FACE_NUM
NODE_DISTANCE
NODE_NORMAL
NODE_TENSOR
NODE_ELEM_TENSOR
Definition at line 45 of file CubitOctreeConstants.hpp.
Enumerator:
O_UNSET
O_LEFT
O_RIGHT
O_BOTTOM
O_TOP
O_BACK
O_FRONT
Definition at line 42 of file CubitOctreeConstants.hpp.
Enumerator:
OCTREE_SIZE_DEFAULT
Definition at line 60 of file CubitOctreeConstants.hpp.
enum SizeType
Enumerator:
MESH_SIZE
SCALED_SIZE
Definition at line 78 of file CubitOctreeConstants.hpp.
Variable Documentation
const double ANG_FACET_EXTRACT[4] = { 15.0, 15.0, 10.0, 5.0 }
Definition at line 97 of file CubitOctreeConstants.hpp.
Definition at line 31 of file CubitOctreeConstants.hpp.
Definition at line 32 of file CubitOctreeConstants.hpp.
Definition at line 30 of file CubitOctreeConstants.hpp.
Definition at line 53 of file CubitOctreeConstants.hpp.
Definition at line 38 of file CubitOctreeConstants.hpp.
const int MAX_DEPTH_OCTREE[4] = { 0, 7, 7, 7}
Definition at line 37 of file CubitOctreeConstants.hpp.
Definition at line 28 of file CubitOctreeConstants.hpp.
const int MIN_DEPTH_OCTREE[4] = { 0, 2, 5, 5}
Definition at line 36 of file CubitOctreeConstants.hpp.
Definition at line 90 of file CubitOctreeConstants.hpp.
Definition at line 62 of file CubitOctreeConstants.hpp.
Definition at line 63 of file CubitOctreeConstants.hpp.
Definition at line 51 of file CubitOctreeConstants.hpp.
Definition at line 48 of file CubitOctreeConstants.hpp.
Definition at line 20 of file CubitOctreeConstants.hpp.
Definition at line 21 of file CubitOctreeConstants.hpp.
Definition at line 22 of file CubitOctreeConstants.hpp.
Definition at line 95 of file CubitOctreeConstants.hpp.
